  4. [GELÖST]RingAdapter Error: Could not load the "sharp" module
    6.5k
10 Beiträge 2 Kommentatoren 751 Aufrufe 1 Beobachtet
    torstenhe
    schrieb am zuletzt editiert von torstenhe
    Moin,
    ich habe den Ring-Adapter installiert und bekomme nach dem Start des Adapters diese Meldung:
    code_text
    host.ioBroker(SmartHome1)
    2025-10-16 08:35:31.150	error	instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-10-16 08:35:31.150	error	Caught by controller[0]: Node.js v22.20.0
    2025-10-16 08:35:31.150	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sharp/lib/constructor.js:10:1)
    2025-10-16 08:35:31.150	error	Caught by controller[0]: at require (node:internal/modules/helpers:147:16)
    2025-10-16 08:35:31.150	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
    2025-10-16 08:35:31.150	error	Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2025-10-16 08:35:31.150	error	Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-10-16 08:35:31.150	error	Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
    2025-10-16 08:35:31.150	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
    2025-10-16 08:35:31.150	error	Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
    2025-10-16 08:35:31.149	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
    2025-10-16 08:35:31.149	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sharp/lib/sharp.js:121:9)
    2025-10-16 08:35:31.149	error	Caught by controller[0]: See https://sharp.pixelplumbing.com/install
    2025-10-16 08:35:31.149	error	Caught by controller[0]: - Consult the installation documentation:
    2025-10-16 08:35:31.149	error	Caught by controller[0]: npm install --os=linux --cpu=x64 sharp
    2025-10-16 08:35:31.149	error	Caught by controller[0]: - Add platform-specific dependencies:
    2025-10-16 08:35:31.149	error	Caught by controller[0]: See https://sharp.pixelplumbing.com/install#cross-platform
    2025-10-16 08:35:31.149	error	Caught by controller[0]: - Ensure your package manager supports multi-platform installation:
    2025-10-16 08:35:31.149	error	Caught by controller[0]: npm install --include=optional sharp
    2025-10-16 08:35:31.149	error	Caught by controller[0]: - Ensure optional dependencies can be installed:
    2025-10-16 08:35:31.149	error	Caught by controller[0]: Possible solutions:
    2025-10-16 08:35:31.148	error	Caught by controller[0]: Unsupported CPU: Prebuilt binaries for linux-x64 require v2 microarchitecture
    2025-10-16 08:35:31.148	error	Caught by controller[0]: Error: Could not load the "sharp" module using the linux-x64 runtime
    2025-10-16 08:35:31.148	error	Caught by controller[0]: ^
    2025-10-16 08:35:31.148	error	Caught by controller[0]: throw new Error(help.join('\n'));
    2025-10-16 08:35:31.148	error	Caught by controller[0]: /opt/iobroker/node_modules/sharp/lib/sharp.js:121
    code_text
    Kann mir da jemand helfen was ich machen kann?
    Vielen Dank im Voraus
    LG
    • T torstenhe
      Moin,
      code_text
      code_text
      LG
      haselchenH Offline
      haselchenH Offline
      haselchen
      @torstenhe sagte in Ring-Adapter: Error: Could not load the "sharp" module:
      Auf was fürn System mit Hardware bist Du unterwegs?
      Kompletten Auszug von
      iob diag
      bitte.
      • haselchenH haselchen
        iob diag
        bitte.
        torstenhe
        @haselchen
        Ich habe einen Proxmox laufen auf nem Lenovo Thinkcentre Tiny. iob info kommt noch. Bin @ Work und komm nicht ran wie ich ran will. ;-)
        PlatformBetriebssystem:linux
        Architektur:x64
        CPUs:4
        Modell:Common KVM processor
        RAM:11.6 GB
        Node.js:v22.20.0
        NPM:10.9.3
        _nodeCurrent:22.20.0
        _nodeNewest:22.20.0
        _nodeNewestNext:22.20.0
        _npmCurrent:10.9.3
        _npmNewest:10.9.3
        _npmNewestNext:10.9.3
        • T torstenhe
          @haselchen
          Architektur:x64
          CPUs:4
          RAM:11.6 GB
          Node.js:v22.20.0
          NPM:10.9.3
          _nodeNewest:22.20.0
          _npmCurrent:10.9.3
          _npmNewest:10.9.3
          haselchenH Offline
          haselchenH Offline
          haselchen
          @torstenhe
          Bei der Suche nach Deinem Error habe ich diese Antwort gefunden.
          I used pve to simulate the centos system, the cpu is Model: 15.6.1 "Common KVM processor", I just modified the hardware processor of the pve virtual machine and it worked
          Da ich da nicht in der Materie stecke und hoffe und denke, dass Du eine VM hast, musst Du wohl an den CPU Einstellungen etwas ändern.
            @torstenhe
            torstenhe
            @haselchen
            Hmm. Den Fehler hatte ich noch bei keinem anderen Adapter und das System läuft eigentlich sehr gut.
            Dann versuche ich mal in diese Richtung zu forschen.
            Dankeschön
              torstenhe
              @haselchen
              Du hast mich auf den richtigen Weg gebracht, vielen Dank. :-)
              Die Lösung war, den Prozessortyp der VM auf HOST umzustellen, jetzt läuft der Adapter.
              LG
              • T torstenhe
                @haselchen
                LG
                haselchenH Offline
                haselchenH Offline
                haselchen
                @torstenhe
                Siehste, kaum macht man es richtig 😬
                  @torstenhe
                  torstenhe
                  @haselchen
                  Man lernt nie aus. :-D
                  • T torstenhe
                    @haselchen
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @torstenhe
                    Setz noch bitte [GELÖST) vor Deinen Threadtitel.
                      @torstenhe
                      torstenhe
                      @haselchen
                      Aber klar doch. :-)
