  4. [Gelöst] [Bug] ZWave stateChange number->string
    6.7k
6 Beiträge 3 Kommentatoren 1.2k Aufrufe
  • ? Offline
    Hallo all,
    ich habe bei mir Fehler im zwave Adapter.
    Ich habe als controler den USB Stick Aeotec AEOEZW090-C Aeon Labs im Einsatz.
    Bei mehreren meiner Fibaro Sensoren habe ich Fehler bei numerischen Werten.
    1.
    Device: FIBARO System FGWPE/F Wall Plug Gen5
    ! "common": {
    ! "name": "FIBARO System FGWPE/F Wall Plug Gen5",
    ! "role": "state"
    ! "native": {
    ! "manufacturer": "FIBARO System",
    ! "manufacturerid": "0x010f",
    ! "product": "FGWPE/F Wall Plug Gen5",
    ! "producttype": "0x0602",
    ! "productid": "0x1001",
    ! "type": "On/Off Power Switch",
    ! "name": "",
    ! "loc": "",
    ! "nodeID": 8
    ! "acl": {
    ! "object": 1636,
    ! "owner": "system.user.admin",
    ! "ownerGroup": "system.group.administrator"
    ! "_id": "zwave.0.NODE8",
    ! "type": "device"
    State: zwave.0.NODE8.SENSOR_MULTILEVEL.Power_1
    ! "common": {
    ! "name": "Power",
    ! "type": "number",
    ! "role": "sensor",
    ! "read": true,
    ! "write": false
    ! "native": {
    ! "value_id": "8-49-1-4",
    ! "node_id": 8,
    ! "class_id": 49,
    ! "type": "decimal",
    ! "genre": "user",
    ! "instance": 1,
    ! "index": 4,
    ! "label": "Power",
    ! "units": "W",
    ! "help": "",
    ! "read_only": true,
    ! "write_only": false,
    ! "min": 0,
    ! "max": 0,
    ! "is_polled": false
    ! "type": "state",
    ! "_id": "zwave.0.NODE8.SENSOR_MULTILEVEL.Power_1",
    ! "acl": {
    ! "object": 1636,
    ! "state": 1636
    Die numerischen Werte werden als string auf den state geschrieben.
    Auszug aus den Events:
    stateChange zwave.0.NODE8.SENSOR_MULTILEVEL.Power_1 "157.1" true zwave.0 2017-10-27 21:03:45.555 2017-10-27 21:03:45.555
    Device: FIBARO System FGK10x Door Opening Sensor
    ! "common": {
    ! "name": "FIBARO System FGK10x Door Opening Sensor",
    ! "role": "state"
    ! "native": {
    ! "nodeID": 14,
    ! "product": "FGK10x Door Opening Sensor",
    ! "producttype": "0x0701",
    ! "type": "Access Control Sensor",
    ! "name": "",
    ! "loc": ""
    ! "type": "device",
    ! "_id": "zwave.0.NODE14",
    ! "acl": {
    ! "object": 1636
    Styte: zwave.0.NODE14.SENSOR_MULTILEVEL.Temperature_1
    ! "common": {
    ! "name": "Temperature",
    ! "type": "number",
    ! "role": "value.temperature",
    ! "read": true,
    ! "write": false
    ! "native": {
    ! "value_id": "14-49-1-1",
    ! "node_id": 14,
    ! "class_id": 49,
    ! "genre": "user",
    ! "instance": 1,
    ! "index": 1,
    ! "label": "Temperature",
    ! "units": "C",
    ! "help": "",
    ! "min": 0,
    ! "max": 0,
    ! "type": "state",
    ! "_id": "zwave.0.NODE14.SENSOR_MULTILEVEL.Temperature_1",
    ! "acl": {
    ! "object": 1636,
    ! "state": 1636
    stateChange zwave.0.NODE14.SENSOR_MULTILEVEL.Temperature_1 "23.12" true zwave.0 2017-10-27 21:03:33.544 2017-10-27 21:03:33.544
    Ein kleiner Test mithilfe des ergab:
    log (typeof getState("zwave.0.NODE14.SENSOR_MULTILEVEL.Temperature_1").val);
    21:15:37.784	[info]	javascript.1 script.js.test.zwave: string
    21:15:37.784	[info]	javascript.1 script.js.test.zwave: registered 0 subscriptions and 0 schedules
    Ist der Bug schon bekannt?
    Hat jemand den Bug bei sich auch?
    Folgende Versionen habe ich laufen:
    ioBroker.zwave: 0.8.0
    ioBroker.js-controller: 1.1.3
    ioBroker.admin: 2.0.9
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Ist mir bei Aeotec-Multisensoren und Fibaro Relais noch nicht aufgefallen, aber schau ich mir morgen mal an.
      Das interessante dabei ist, dass die Werte und Typinformationen eigentlich 1:1 aus dem Treiber übernommen werden.
      Edit: Fibaro Relais (beides als number definiert):
      let x = getState("zwave.0.NODE2.SENSOR_MULTILEVEL.Power_1").val;
      log(typeof x); // => string
      x = getState("zwave.0.NODE2.SWITCH_MULTILEVEL.Level_1").val;
      log(typeof x); // => number
        Pman
        @AlCalzone:
        Das interessante dabei ist, dass die Werte und Typinformationen eigentlich 1:1 aus dem Treiber übernommen werden. `
        Ich konnte den Fehler bei mir jetzt auch feststellen, anscheinend kommen von OZW teilweise Strings statt Floats an, die dann auch im State landen. Ich habe einen Pull-Request erstellt, leider keine Zeit zum Testen :roll: .
        Gerne mal von hier installieren und testen:
        https://github.com/Pmant/ioBroker.zwave/tree/patch-1
          AlCalzoneA Offline
          AlCalzone
          Für existierende Objekte funktioniert der Fix (sie werden mit dem korrekten State aktualisiert). Neue Objekte werden noch falsch angelegt. Ich probiere mal, wie man das allgemeiner lösen kann.
            AlCalzoneA Offline
            AlCalzone
            Ursache gefunden:
            https://github.com/OpenZWave/node-openz … ils.cc#L90
            Für decimal-Werte gibt node-openzwave-shared strings zurück. Fixed in 0.9.0
            • ? Offline
              Fehler tritt mit Version 0.9.0 nicht mehr auf.
              -> Gelöst
