  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Linux
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
256 Beiträge 29 Kommentatoren 119.7k Aufrufe
  • aurodionovA
    aurodionovA
    aurodionov
    Сыпет в лог (смотрю по ssh)
    ! 2014-12-03 08:55:25.505 - error: controller instance system.adapter.ping.0 terminated with code 6
    ! 2014-12-03 08:55:25.505 - info: Restart adapter system.adapter.ping.0 because enabled
    ! 2014-12-03 08:55:26.403 - info: controller instance system.adapter.admin.0 started with pid 16924
    ! 2014-12-03 08:55:28.567 - info: controller instance system.adapter.pushover.0 started with pid 16926
    ! 2014-12-03 08:55:28.925 - error: controller instance system.adapter.admin.0 terminated with code 7
    ! 2014-12-03 08:55:28.925 - info: Restart adapter system.adapter.admin.0 because enabled
    ! 2014-12-03 08:55:30.036 - error: controller instance system.adapter.pushover.0 terminated with code 7
    ! 2014-12-03 08:55:30.036 - info: Restart adapter system.adapter.pushover.0 because enabled
    ! 2014-12-03 08:55:30.998 - info: controller instance system.adapter.node-red.0 started with pid 16936
    ! 2014-12-03 08:55:32.289 - error: controller instance system.adapter.node-red.0 terminated with code 7
    ! 2014-12-03 08:55:32.289 - info: Restart adapter system.adapter.node-red.0 because enabled
    ! 2014-12-03 08:55:35.591 - info: controller instance system.adapter.javascript.0 started with pid 16942
    ! 2014-12-03 08:55:37.753 - info: controller instance system.adapter.email.0 started with pid 16944
    ! 2014-12-03 08:55:37.830 - error: controller instance system.adapter.javascript.0 terminated with code 7
    ! 2014-12-03 08:55:37.830 - info: Restart adapter system.adapter.javascript.0 because enabled
    ! 2014-12-03 08:55:39.077 - error: controller instance system.adapter.email.0 terminated with code 7
    ! 2014-12-03 08:55:39.077 - info: Restart adapter system.adapter.email.0 because enabled
    ! 2014-12-03 08:55:50.145 - info: controller instance system.adapter.legacy.0 started with pid 16954
    ! 2014-12-03 08:55:51.766 - error: controller instance system.adapter.legacy.0 terminated with code 7
    ! 2014-12-03 08:55:51.766 - info: Restart adapter system.adapter.legacy.0 because enabled
    ! 2014-12-03 08:55:55.517 - info: controller instance system.adapter.ping.0 started with pid 16960
    ! 2014-12-03 08:55:56.834 - info: ping.0 starting. Version 0.1.0
    ! 2014-12-03 08:55:56.982 - error: uncaught exception: Cannot call method 'replace' of undefined
    ! 2014-12-03 08:55:56.986 - error: TypeError: Cannot call method 'replace' of undefined
    ! at /opt/iobroker/adapter/ping/main.js:192:43
    ! at /opt/iobroker/lib/adapter.js:917:44
    ! at /opt/iobroker/lib/couch.js:158:13
    ! at Request._callback (/opt/iobroker/node_modules/nano/nano.js:303:11)
    ! at Request.self.callback (/opt/iobroker/node_modules/nano/node_modules/request/request.js:122:22)
    ! at Request.emit (events.js:98:17)
    ! at Request. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:888:14)
    ! at Request.emit (events.js:117:20)
    ! at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/nano/node_modules/request/request.js:839:12)
    ! at IncomingMessage.emit (events.js:117:20)</anonymous></anonymous>
    проблема с правами, или так и должно быть ?
    есть предположение, что так брокер проверяет падение драйверов.
    Пишу с пульта….
    • S
      S
      skifer
      Может не в тему, но пришла банана. Перепробовал 4 образа, но по hdmi чёрный экран и на плате горит постоянно красная лампочка. Пишут вроде, что это говорит о кривом образе. Что делать, месяц ждал, а тут такое.
      SD карта 4Gb (6 class).
      • BluefoxB
        @skifer:
        SD карта 4Gb (6 class). `
        У меня bananian завелась с первого раза. А не пробовал другую карточку?
        • E
          E
          electric69
          @skifer:
          Может просто предположение, но всё же…
          Проверь - к какому порту подключаешь питание...
          Надо к microUSB который DC-IN (он рядом с SATA), а не к USB-otg)))
          • S
            S
            skifer
            @electric69:
            @skifer:
            Надо к microUSB который DC-IN (он рядом с SATA), а не к USB-otg))) `
            Про питание я знаю, что они похожи частовстречающаяся проблема, но тыкаю туда куда_нада.))))))
            Остаётся проблема с флэшкой.
            • E
              E
              electric69
              @skifer:
              Остаётся проблема с флэшкой. `
              Откуда образ брал?
              Я пробовал как то раз образы линукс, не дебиан и не оф., были проблемы при самом первом старте если нет линка по LAN-порту.
              Воткнул патч-корд - заработал, не знаю почему.
              Сам юзаю образ Игоря - работает норм.
              • S
                S
                skifer
                Бананиан запустился. На старой флэшке. Андроиды и убунты не пошли. И странно, что андроид не запустился. Но сетевой не коннектил. Мот со шнуром и дроид станет. Остановлюсь на бананине.
                А сколько флэшка примерно протянет под системой?
                Что за разъём питания сата, откуда можно выдрать - который белый на два провода.
                Что можно придумать при отсутствии клавиш? Удалённо к примеру установить получится?
                • S
                  S
                  skifer
                  Электро, что за образ Игоря?
                  • E
                    E
                    electric69
                    @skifer:
                    Бананиан запустился. На старой флэшке. Андроиды и убунты не пошли. И странно, что андроид не запустился. Но сетевой не коннектил. Мот со шнуром и дроид станет. Остановлюсь на бананине. `
                    Мне бананиан не понравился. Не совсем качественная сборка - закос под Распбиан…
                    @skifer:
                    А сколько флэшка примерно протянет под системой? `
                    Смотря как часто пишется информация на флешку.
                    Основной поставщик операции записи - формирование логов, запись арзивных данных в файлы или БД.
                    У меня на малинке под MajorDoMo флешка умирала пару раз.
                    Первая была не новая - умерла через полгода.
                    Вторая снова с магазина (точнее с aliexpress) - не прожила и месяца.
                    Оффтоп - коллеги, никогда, слышите - НИКОГДА не покупайте НИКАКИЕ флешки/карты памяти на aliexpress.
                    Фирменные там стоят дороже чем в России, нонэйм дохнет быстро.
                    Сам обжегся раза 3 (из трех раз всего), причем одна из карт памяти вообще оказалась контрафактной - из 32Гб по факту могла вместить только 3,7Гб, остальное писалось по кругу поверх старых данных…
                    @skifer:
                    Что за разъём питания сата, откуда можно выдрать - который белый на два провода. `
                    Не понятен вопрос))
                    На кромке платы где HDMI:
                    1. разъем HDMI собственно,
                    2. разъем интерфейса SATA для подключения HDD,
                    3. разъем microUSB с надписью DC-IN - подключение питания 5В 2А,
                    4. разъем белого цвета с пинами GND, +5V - питание для HDD.
                    Для подключения HDD можно сделать самодельный кабель или купить - к примеру http://www.aliexpress.com/item/Free-Shipping-Banana-Pi-SATA-cable-Banana-Pi-HDD-Cable-Banana-Pi-hard-disk-cable-Connect/1987383181.html.
                    Я покупал банану-пи сразу с корпусом и кабелем для HDD, комплект брал http://www.aliexpress.com/item/Free-shipping-Banana-pi-sata-cable-case-fully-compatible-with-Raspberry-Pi-cubieboard-with-Gigabit-ethernet/2030355208.html.
                    @skifer:
                    Что можно придумать при отсутствии клавиш? Удалённо к примеру установить получится? `
                    Здесь тоже прошу поподробнее, из контекста не понятно о чем речь?
                    Какие клавиши нужны?
                    Что устанавливать удаленно?
                    @skifer:
                    Электро, что за образ Игоря? `
                    Ой-ёй, такого то не знать))
                    КМК каждый энтузиаст при работе с ARM-боардами должен был наткнуться на сайт http://www.igorpecovnik.com/, где автор выкладывает (и что самое главное - периодически обновляет) образы для различных ARM-плат, в том числе для популярных - cubietruck (на подходе кубик 4), банана-пи, олимекс и прочие…
                    Прошу обратить внимание на эти образы - для смарт-хоум идеальный вариант, ИМХО разумеется.
                    Все прелести образов описывать не буду - можно почитать в описании...
                    • S
                      S
                      skifer
                      Уже и андроид запустил - правда шаманских танцев не избежал.
                      Коннектор = о котором я говорил = это тот самый беленький на 2 выхода. Широкий можно найти, а что за белый, где он ещё юзается и где его можно выдрать - пока загадка.
                      Электро, что из линукса на банану ты ставил - интересует платформа для иоброкера?
                      Удалённо, я говорил про отсутствие клавиатуры. Удалённый терминал запустился сразу после старта бананиан.
                      • S
                        S
                        skifer
                        wget http://download.iobroker.org/ioBroker-0.1.1.deb
                        • S
                          S
                          skifer
                          Пошла установка.
                          Но вот такое:
                          • BluefoxB
                            @skifer:
                            Пошла установка.
                            Но вот такое: `
                            Уже есть http://download.iobroker.org/ioBroker-0.4.1.deb
                            Эти ошибки можно проигнорировать.
                            • S
                              S
                              skifer
                              После перезапуска банана на 8081 порту иоброкера не обнаружено. Не поднялся.
                              • E
                                E
                                electric69
                                @skifer:
                                Уже и андроид запустил - правда шаманских танцев не избежал. `
                                Если честно, вообще ни разу не устанавливал на свои железки андроид - в чем смысл?))
                                Ну разве что для опыта. Я наоборот, где по-умолчанию ведроид пытаюсь поставить линукс х86, пока не получается…
                                @skifer:
                                Коннектор = о котором я говорил = это тот самый беленький на 2 выхода. Широкий можно найти, а что за белый, где он ещё юзается и где его можно выдрать - пока загадка. `
                                Беленький коннектор единственный на плате))
                                Широкий для SATA конечно без проблем ищется - подойдет любой шлейф от компа.
                                Для питания HDD - попробуй порыться в старой технике, я в молодости работал серв.инженером оргтехники Canon - в принтерах/копирах струйных/лазерных (дешевых) таких коннекторов было много…
                                Телевизоры, магнитофоны, рессиверы старые тоже могут стать донором.
                                @skifer:
                                Электро, что из линукса на банану ты ставил - интересует платформа для иоброкера? `
                                Я выше писал, что юзаю образ http://www.igorpecovnik.com/2014/09/07/banana-pi-debian-sd-image/ для BananaPi. Бери образ с ядром версии 3.4.105 - на нем работают I2C, SPI, блютуз, даже IR-диод пашет, но сам пока не пробовал.
                                @skifer:
                                Удалённо, я говорил про отсутствие клавиатуры. Удалённый терминал запустился сразу после старта бананиан. `
                                Я обычно первую настройку делаю локально - подключаю клаву, сеть, HDMI к телеку старенькому и вперед:
                                1. меняю пароль для root,
                                2. настраиваю сеть - статику,
                                3. обновляю список пакетов и сами пакеты,
                                4. устанавливаю основной софт - mc, htop и прочее,
                                5. конфигурирую SSHD демон (порты, сертификаты).
                                Далее перезагружаюсь, проверяю и работаю по ssh.
                                Вопрос к BlueFox, на данный момент руководство по установке что на https://github.com/ioBroker/ioBroker/blob/master/doc/INSTALL.md актуально?
                                Где то читал, что теперь не нужен сервис CouchDB и Redis…
                                • BluefoxB
                                  @electric69:
                                  Где то читал, что теперь не нужен сервис CouchDB и Redis… `
                                  Нет не актуально. Redis и CouchDB не нужны. Но я пока не меняю описание, т.к. хочу сделать версии и с redis/CouchDB.
                                  В любом случае если их установить, то на работу это не повлияет.
                                  • E
                                    E
                                    electric69
                                    @Bluefox:
                                    @electric69:
                                    В любом случае если их установить, то на работу это не повлияет. `
                                    А https://github.com/ioBroker/ioBroker/blob/master/doc/INSTALL.md#download-and-install самого ioBroker правильная?
                                    305_betriebsstundenzaehler_080a.txt
                                    • E
                                      E
                                      electric69
                                      Установил так:
                                      1. Накатил на флешку систему http://www.igorpecovnik.com/2014/09/07/banana-pi-debian-sd-image/ версия 1.8 (Kernel 3.18.1), обновился, настроил ssh, установил htop и mc.
                                      Все действия от root.
                                      2. Установил Node.js с помощью https://github.com/joyent/node/wiki/Installing-Node.js-via-package-manager.
                                      3. Поставил redis-server и couchdb (на всякий случай) по https://github.com/ioBroker/ioBroker/blob/master/doc/INSTALL.md#install-redis.
                                      4. Установил ioBroker двумя командами:
                                      wget http://download.iobroker.org/ioBroker-0.4.1.deb
                                      dpkg -i ioBroker-0.4.1.deb
                                      Результат на скриншоте.
                                      Первый косяк - при попытке стартануть/остановить/перезапустить через /etc/init.d/iobroker.sh start/stop/restart - сыпет ошибки, что не знает юзера "pi" и у меня node.js запускается как /usr/bin/nodejs, подредактировал файл /etc/init.d/iobroker.sh
                                      #!/bin/bash
                                      BEGIN INIT INFO
                                      Provides: iobroker.sh
                                      Required-Start: $network $local_fs $remote_fs
                                      Required-Stop:: $network $local_fs $remote_fs
                                      Default-Start: 2 3 4 5
                                      Default-Stop: 0 1 6
                                      Short-Description: starts ioBroker
                                      END INIT INFO
                                      (( EUID )) && echo .You need to have root privileges.. && exit 1
                                      PIDF=/opt/iobroker/lib/iobroker.pid
                                      NODECMD=/usr/bin/nodejs
                                      IOBROKERCMD=/opt/iobroker/iobroker.js
                                      RETVAL=0
                                      IOBROKERUSER=root
                                      ! start() {
                                      echo -n "Starting ioBroker"
                                      sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD start
                                      RETVAL=$?
                                      ! stop() {
                                      echo -n "Stopping ioBroker"
                                      sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD stop
                                      RETVAL=$?
                                      case "$1" in
                                      start)
                                      start
                                      stop)
                                      stop
                                      restart)
                                      stop
                                      start
                                      echo "Usage: iobroker {start|stop|restart}"
                                      exit 1
                                      esac
                                      exit $RETVAL
                                      WEB-интерфейс по адресу бананы IP:8081 появился…
                                      Разбираюсь дальше.
                                      Эээ... Ачо делать дальше то?))
                                      • BluefoxB
                                        > Эээ… Ачо делать дальше то?))
                                        :D
                                        А какое оборудование у тебя есть?
                                        • Компьютеры? (Ping)
                                        • Arduino? (node-red)
                                        • Google Calendar? (не готово)
                                        • сообщение голосом о новых письмах IMAP (node-red), но нет голоса.
                                        • Нарисовать страницу дома/квартиры и подключить philipsHUE, Homematic, KNX, zWave? Да,… но ioBroker.vis именно сейчас находится в глубокой переработке.
                                        Поиграться со всем этим. Да..
                                        Ещё бы пару месяцев подождать и можно будет уже использовать.
                                        Спасибо, за баг с именем пользователя в init.d. Буду прописывать текущего пользователя при инсталляции.
                                        • E
                                          E
                                          electric69
                                          @Bluefox:
                                          • Нарисовать страницу дома/квартиры и подключить philipsHUE, Homematic, KNX, zWave? Да,… но ioBroker.vis именно сейчас находится в глубокой переработке. `
                                            Компы есть, ping попробую…
                                          Arduino есть, node-red попробую - где можно почитать как?))
                                          голоса нет - нет драйвера пока (типа sayit в CCU.IO) - ну подождем...
                                          DashUI не хватает, конечно - так привязался к нему.
                                          Еще один глюк заметил - при рестарте бананы, не стартует демон ioBroker.
                                          Приходится стартовать в ручную
                                          Так и задумано? Где можно покопаться?
