  4. shutter control Sonnenschutz
    6.6k
12 Beiträge 2 Kommentatoren 1.0k Aufrufe 1 Beobachtet
  • W Offline
    W Offline
    WolfgangFB
    Was mache ich beim Sonnenschutz falsch? Ich möchte dass je nach Außentemperatur und Sonnenstand der Rolladen runter geht.
    Eingestellt habe ich folgendes:
    Lichtsensor habe ich leer gelassen, nur "Außentemperatur und Himmelsrichtung" gibt es nicht als Option.
    In den Logs sehe ich:
    shuttercontrol.0
    	2025-08-15 12:45:46.245	debug	outsidetemperature changed: alias.0.Raum.Garage.Temperatur.Aussen.Wert Value: 32
    shuttercontrol.0
    	2025-08-15 12:45:46.244	silly	States system redis pmessage esphome.0.E8DB84DD13D3.Sensor.2763839563.state/esphome.0.E8DB84DD13D3.Sensor.2763839563.state:{"val":32,"ack":true,"ts":1755254746241,"q":0,"from":"system.adapter.esphome.0","user":"system.user.admin","lc":1755254746241}
    shuttercontrol.0
    	2025-08-15 12:45:40.935	silly	States system redis pmessage tuya.0.bf43d94673b8cce5a0olfs.2/tuya.0.bf43d94673b8cce5a0olfs.2:{"val":100,"ack":true,"ts":1755254740681,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1755233595222}
    shuttercontrol.0
    	2025-08-15 12:45:29.507	silly	States system redis pmessage tuya.0.bfc1195760ea580081tysn.2/tuya.0.bfc1195760ea580081tysn.2:{"val":100,"ack":true,"ts":1755254729494,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1755233511732}
    shuttercontrol.0
    	2025-08-15 12:45:00.256	silly	States user redis pmessage shuttercontrol.0.info.Elevation/shuttercontrol.0.info.Elevation:{"val":53.2,"ack":true,"ts":1755254700115,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1755254700115}
    shuttercontrol.0
    	2025-08-15 12:45:00.040	silly	States user redis pmessage shuttercontrol.0.info.Azimut/shuttercontrol.0.info.Azimut:{"val":160.2,"ack":true,"ts":1755254700029,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1755254700029}
    shuttercontrol.0
    	2025-08-15 12:45:00.009	debug	Sun Elevation: 53.2°
    shuttercontrol.0
    	2025-08-15 12:45:00.009	debug	Sun Azimut: 160.2°
    shuttercontrol.0
    	2025-08-15 12:45:00.008	debug	calculate astrodata ...
    Meiner Meinung nach sind alle Voraussetzungen erfüllt (Temperatur über 25 Grad und Azimuth ist auch erfüllt. Aber der rollo bewegt sich nicht (morgens und abends geht er aber rauf und runter). Was habe ich falsch eingestellt? (In den Shuttercontrol Objekten ist der Rollebei "AutoSun" true falls das wichtig ist).
    • W WolfgangFB
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      @wolfgangfb welchen Zustand hat der Rollladen?
      zufällig Manu_Mode?
      W 1 Antwort Letzte Antwort
        zufällig Manu_Mode?
        W Offline
        W Offline
        WolfgangFB
        Wo sehe ich das bzw. wie ändere ich das?
        • W WolfgangFB
          @wolfgangfb sagte in shutter control Sonnenschutz:
          Wo sehe ich das
          am einfachsten im shuttercontrol sidebar Menü vom admin
          oder unter shuttercontrol.0.shutters.autoState
            Wo sehe ich das
            W Offline
            W Offline
            WolfgangFB
            Die stehen auf "Manu_mode", aber warum und wie ändere ich das (bzw. zu was)?
            • W WolfgangFB
              warum
              weil sie manuell bewegt wurden.
              Dann wird die Beschattungsautomatik bis zum nächsten morgen ausgesetzt.
              wie ändere ich das
              kommt auf deine Konfigurationen an
                warum
                wie ändere ich das
                W Offline
                W Offline
                WolfgangFB
                @homoran sagte in shutter control Sonnenschutz:
                warum
                Ich habe die Rolladen nicht manuell bewegt.
                wie ändere ich das
                Welcher Teil meiner Konfiguration? In der Sidebar ist unter "Rolladensteuerung" überall Azutomatisches Öffnen, automatisches Schließen und automatischer Sonnenschutz aktiviert.
                • W WolfgangFB
                  warum
                  wie ändere ich das
                  oder per skript, alexa.....
                  sonst fehlen dir wichtige Einstellungen bei Shuttercontrol
                  z.B. blockieren bekannter Höhen
                  lies dir mal die Super Doku zu dem Adapter durch.
                  Dann muss ich das nicht alles machen.
                  Da scheint noch Nachholbedarf an den Grundeinstellungen zu bestehen.
                  • W Offline
                    W Offline
                    WolfgangFB
                    Ich verwende Shellys für die Rolladensteuerung und die werden nur über shutter control oder den physikalischen Schalter geschaltet, kein anderes Skript, keine Alexa. Welkche Einstellungen fehlen denn?
                    "Blockieren des Manu-Modus für bekannte Rollladenhöhen" ist bei mir nicht aktiviert. Auf- bzw. Abrunden" steht auf "aus"
                    Ich habe mir die Anleitung durchgelesen. Der Begriff "Manu_mode" kommt genau zwei mal vor. Wie man das zurücksetzt erschließt sich mir aber nicht.
                    Ich habe mich an die Anleitung gehalten, da steht z.B.:
                    autoAll
                    Button um alle Rollläden in den Auto Mode zu setzen
                    Wenn ich da drauf klicke ändert sich aber bei "Modus Rolladen" in der Sidebar nichts.
                    Unter Grundeinstellungen habe ich die Zeitverzögerung bei den Astro Einstellungen vorgenommen. Mehr möchte ich nicht. Ich habe keine Bereiche und das morgendliche und abendliche hoch und runterfahren funktioniert ja auch.
                    Ich habe trotz lesens der Anleitung nicht herausgefunden, an welcher grundlegenden Einstellung es bei mir scheitert, dass die Rolläden je nach Sonnenstand und Außentemperatur hoch und wieder runterfahren. Dafür gibt es Threads wie "Shutter Control Sonnenschutz (mal wieder)... ja ich weiss, gefühlt der 100. Thread zu dem Thema."
                    Ganz so trivial scheint es also nicht zu sein, sonst hätten wohl auch mehr User hier darauf geantwortet.
                    Könntest Du mir bitte sagen, welche grundlegende Einstellung ich ändern muss damit die Rolläden nicht in den "manu_mode" gehen und/oder der Manu_mode wieder aufgehoben wird und die Beschattung auch wieder aufgehoben wird?
                    • W WolfgangFB
                      autoAll
                      hast du verzögertes Feststelken der Behanghöhe konfiguriert?
                      indem du
                      da den Haken setzt und dann den Rollladen auf eine bekannte Höhe fährst
                      ...oder bis zum nächsten Morgen wartest
                        indem du
                        W Offline
                        W Offline
                        WolfgangFB
                        Ich habe auf einer zweiten Iobroker-Instanz shuttercontrol installiert und da hat es funktioniert (ohne dass immer wieder Manu_mode auftaucht), also shuttercontrol komplett deinstalliert und neu installiert und jetzt geht es.
                        • W WolfgangFB
                          und wahrscheinlich jetzt irgendwo eine scheinbare Kleinigkeit anders konfiguriert
