  4. shutter control Sonnenschutz
    6.6k
12 Beiträge 2 Kommentatoren 1.0k Aufrufe 1 Beobachtet
  • W WolfgangFB
    Was mache ich beim Sonnenschutz falsch? Ich möchte dass je nach Außentemperatur und Sonnenstand der Rolladen runter geht.
    Eingestellt habe ich folgendes:
    Lichtsensor habe ich leer gelassen, nur "Außentemperatur und Himmelsrichtung" gibt es nicht als Option.
    In den Logs sehe ich:
    shuttercontrol.0
    	2025-08-15 12:45:46.245	debug	outsidetemperature changed: alias.0.Raum.Garage.Temperatur.Aussen.Wert Value: 32
    shuttercontrol.0
    	2025-08-15 12:45:46.244	silly	States system redis pmessage esphome.0.E8DB84DD13D3.Sensor.2763839563.state/esphome.0.E8DB84DD13D3.Sensor.2763839563.state:{"val":32,"ack":true,"ts":1755254746241,"q":0,"from":"system.adapter.esphome.0","user":"system.user.admin","lc":1755254746241}
    shuttercontrol.0
    	2025-08-15 12:45:40.935	silly	States system redis pmessage tuya.0.bf43d94673b8cce5a0olfs.2/tuya.0.bf43d94673b8cce5a0olfs.2:{"val":100,"ack":true,"ts":1755254740681,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1755233595222}
    shuttercontrol.0
    	2025-08-15 12:45:29.507	silly	States system redis pmessage tuya.0.bfc1195760ea580081tysn.2/tuya.0.bfc1195760ea580081tysn.2:{"val":100,"ack":true,"ts":1755254729494,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1755233511732}
    shuttercontrol.0
    	2025-08-15 12:45:00.256	silly	States user redis pmessage shuttercontrol.0.info.Elevation/shuttercontrol.0.info.Elevation:{"val":53.2,"ack":true,"ts":1755254700115,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1755254700115}
    shuttercontrol.0
    	2025-08-15 12:45:00.040	silly	States user redis pmessage shuttercontrol.0.info.Azimut/shuttercontrol.0.info.Azimut:{"val":160.2,"ack":true,"ts":1755254700029,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc":1755254700029}
    shuttercontrol.0
    	2025-08-15 12:45:00.009	debug	Sun Elevation: 53.2°
    shuttercontrol.0
    	2025-08-15 12:45:00.009	debug	Sun Azimut: 160.2°
    shuttercontrol.0
    	2025-08-15 12:45:00.008	debug	calculate astrodata ...
    Meiner Meinung nach sind alle Voraussetzungen erfüllt (Temperatur über 25 Grad und Azimuth ist auch erfüllt. Aber der rollo bewegt sich nicht (morgens und abends geht er aber rauf und runter). Was habe ich falsch eingestellt? (In den Shuttercontrol Objekten ist der Rollebei "AutoSun" true falls das wichtig ist).
    @wolfgangfb welchen Zustand hat der Rollladen?
    zufällig Manu_Mode?
    W 1 Antwort Letzte Antwort
      zufällig Manu_Mode?
      W Offline
      W Offline
      WolfgangFB
      Wo sehe ich das bzw. wie ändere ich das?
      • W WolfgangFB
        @wolfgangfb sagte in shutter control Sonnenschutz:
        Wo sehe ich das
        am einfachsten im shuttercontrol sidebar Menü vom admin
        oder unter shuttercontrol.0.shutters.autoState
          Wo sehe ich das
          W Offline
          W Offline
          WolfgangFB
          Die stehen auf "Manu_mode", aber warum und wie ändere ich das (bzw. zu was)?
          • W WolfgangFB
            warum
            weil sie manuell bewegt wurden.
            Dann wird die Beschattungsautomatik bis zum nächsten morgen ausgesetzt.
            wie ändere ich das
            kommt auf deine Konfigurationen an
              warum
              wie ändere ich das
              W Offline
              W Offline
              WolfgangFB
              @homoran sagte in shutter control Sonnenschutz:
              warum
              Ich habe die Rolladen nicht manuell bewegt.
              wie ändere ich das
              Welcher Teil meiner Konfiguration? In der Sidebar ist unter "Rolladensteuerung" überall Azutomatisches Öffnen, automatisches Schließen und automatischer Sonnenschutz aktiviert.
              • W WolfgangFB
                warum
                wie ändere ich das
                oder per skript, alexa.....
                sonst fehlen dir wichtige Einstellungen bei Shuttercontrol
                z.B. blockieren bekannter Höhen
                lies dir mal die Super Doku zu dem Adapter durch.
                Dann muss ich das nicht alles machen.
                Da scheint noch Nachholbedarf an den Grundeinstellungen zu bestehen.
                • W Offline
                  W Offline
                  WolfgangFB
                  Ich verwende Shellys für die Rolladensteuerung und die werden nur über shutter control oder den physikalischen Schalter geschaltet, kein anderes Skript, keine Alexa. Welkche Einstellungen fehlen denn?
                  "Blockieren des Manu-Modus für bekannte Rollladenhöhen" ist bei mir nicht aktiviert. Auf- bzw. Abrunden" steht auf "aus"
                  Ich habe mir die Anleitung durchgelesen. Der Begriff "Manu_mode" kommt genau zwei mal vor. Wie man das zurücksetzt erschließt sich mir aber nicht.
                  Ich habe mich an die Anleitung gehalten, da steht z.B.:
                  autoAll
                  Button um alle Rollläden in den Auto Mode zu setzen
                  Wenn ich da drauf klicke ändert sich aber bei "Modus Rolladen" in der Sidebar nichts.
                  Unter Grundeinstellungen habe ich die Zeitverzögerung bei den Astro Einstellungen vorgenommen. Mehr möchte ich nicht. Ich habe keine Bereiche und das morgendliche und abendliche hoch und runterfahren funktioniert ja auch.
                  Ich habe trotz lesens der Anleitung nicht herausgefunden, an welcher grundlegenden Einstellung es bei mir scheitert, dass die Rolläden je nach Sonnenstand und Außentemperatur hoch und wieder runterfahren. Dafür gibt es Threads wie "Shutter Control Sonnenschutz (mal wieder)... ja ich weiss, gefühlt der 100. Thread zu dem Thema."
                  Ganz so trivial scheint es also nicht zu sein, sonst hätten wohl auch mehr User hier darauf geantwortet.
                  Könntest Du mir bitte sagen, welche grundlegende Einstellung ich ändern muss damit die Rolläden nicht in den "manu_mode" gehen und/oder der Manu_mode wieder aufgehoben wird und die Beschattung auch wieder aufgehoben wird?
                  • W WolfgangFB
                    autoAll
                    hast du verzögertes Feststelken der Behanghöhe konfiguriert?
                    indem du
                    da den Haken setzt und dann den Rollladen auf eine bekannte Höhe fährst
                    ...oder bis zum nächsten Morgen wartest
                      indem du
                      W Offline
                      W Offline
                      WolfgangFB
                      Ich habe auf einer zweiten Iobroker-Instanz shuttercontrol installiert und da hat es funktioniert (ohne dass immer wieder Manu_mode auftaucht), also shuttercontrol komplett deinstalliert und neu installiert und jetzt geht es.
                      • W WolfgangFB
                        und wahrscheinlich jetzt irgendwo eine scheinbare Kleinigkeit anders konfiguriert
