  4. KNX Adapter funktioniert nicht mehr (Reboot Schleife)
    6.6k
6 Beiträge 2 Kommentatoren 262 Aufrufe 2 Beobachtet
    satric
    schrieb am zuletzt editiert von satric
    seid heute Nacht funktionierte mein KNX-Adapter (2.0.30) nicht mehr richtig. Vor allem waren Objekte betroffen die Werte (z.b. Temperatur) per Direct-Link vom IObroker zum KNX-Bus sendeten. Es kamen auch Fehlermeldungen (siehe Log-Auszug)
    2025-08-14 16:29:35.781  - info: host.raspberrypi instance system.adapter.knx.0 in version "2.0.30" started with pid 4699
    2025-08-14 16:29:39.470  - info: knx.0 (4699) starting. Version 2.0.30 in /opt/iobroker/node_modules/iobroker.knx, node: v22.18.0, js-controller: 7.0.6
    2025-08-14 16:29:43.259  - warn: knx.0 (4699) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
    2025-08-14 16:29:43.262  - info: knx.0 (4699) Connecting to knx GW: 192.168.XXX.XXX:3671 with phy. Adr: 1.1.0
    2025-08-14 16:29:43.393  - error: knx.0 (4699) uncaught exception: Cannot read properties of null (reading 'val')
    2025-08-14 16:29:43.393  - error: knx.0 (4699) TypeError: Cannot read properties of null (reading 'val')
        at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:421175)
        at processImmediate (node:internal/timers:487:21)
    2025-08-14 16:29:43.394  - error: knx.0 (4699) Cannot read properties of null (reading 'val')
    2025-08-14 16:29:43.466  - info: knx.0 (4699) terminating
    2025-08-14 16:29:43.468  - warn: knx.0 (4699) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-08-14 16:29:43.520  - error: knx.0 (4699) uncaught exception: Cannot read properties of null (reading 'val')
    2025-08-14 16:29:43.521  - error: knx.0 (4699) TypeError: Cannot read properties of null (reading 'val')
    2025-08-14 16:29:43.522  - error: knx.0 (4699) Cannot read properties of null (reading 'val')
    2025-08-14 16:29:43.955  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading 'val')
    2025-08-14 16:29:43.956  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:421175)
    2025-08-14 16:29:43.956  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:487:21)
    2025-08-14 16:29:43.956  - error: host.raspberrypi Caught by controller[1]: Unkown Inputvalue! Please also check Type of Datapoint.true
    2025-08-14 16:29:43.956  - error: host.raspberrypi Caught by controller[2]: Unkown Inputvalue! Please also check Type of Datapoint.false
    2025-08-14 16:29:43.956  - error: host.raspberrypi Caught by controller[3]: Unkown Inputvalue! Please also check Type of Datapoint.false
    2025-08-14 16:29:43.957  - error: host.raspberrypi Caught by controller[4]: TypeError: Cannot read properties of null (reading 'val')
    2025-08-14 16:29:43.957  - error: host.raspberrypi Caught by controller[4]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:421175)
    2025-08-14 16:29:43.957  - error: host.raspberrypi Caught by controller[4]:     at processImmediate (node:internal/timers:487:21)
    2025-08-14 16:29:43.958  - error: host.raspberrypi instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-08-14 16:29:43.958  - info: host.raspberrypi Restart adapter system.adapter.knx.0 because enabled
    Ich habe ca. 200 Gruppenadressen.
    Der Adapter startet ständig neu.
    Als ich nicht weiter kam habe ich die Instanz und den Adapter gelöscht und neuinstalliert. Danach läuft die KNX-Instanz und ich konnte die Gruppenadressen importieren. Aber im Gruppenadressen-Tool kann ich keine Direct-Links mehr einstellen, sobald ich einen Non-KNX IObroker State verknüpfen möchte, verschwindet das ganze Gruppenadressen-Tool.
    Mittlerweile habe ich auch Node.js 22 installiert und KNX-Adapter 2.0.31 , aber das verhalten blieb gleich.
    Vielleicht kann mir jemand helfen. Vielen Dank und viele Grüße
    • S satric
      @satric sagte in KNX Adapter funktioniert nicht mehr:
      (siehe Screenshot):
      Bitte KEINE Screenshots von Text. Das Log immer als Text in CodeTags eingebettet hier rein.
      Wenn es Text wäre könnte ich dir die passende Meldung auch zitieren. So nur:
      Dir fehlt die Lizenz für den Adapter.
      €dit: Ist nur ein Hinweis, das Limit ist wohl noch nicht erreicht.
        (siehe Screenshot):
        satric
        @thomas-braun Ich habe den Text als Code hinzugefügt. Vielen Dank
        • S satric
          @satric
          Geht doch...
          Und die Kirsche auf der Sahne wäre noch eine chronologisch richtige Abfolge. Kann man entweder dem Log direkt entnehmen
          iob logs
          oder wenn es schon aus der GUI sein muss stellt man die Leserichtung mit dem Pfeil ein.
            @satric
            Geht doch...
            iob logs
            satric
            @thomas-braun Schande über mein Haupt. Jetzt habe ich es hoffentlich.
              satric
              Ich habe es gefunden. Es war ein alter Direktlink, dessen Sensor nicht mehr aktiv ist. Diesen Link habe ich gelöscht, seitdem scheint es zu laufen. Keine Ahnung warum der Direktlink erst jetzt Probleme gemacht hat, denn den Sensor gibt es schon ein halbes Jahr nicht mehr.
