  4. Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten
    6.6k
28 Beiträge 5 Kommentatoren 2.6k Aufrufe 5 Beobachtet
  • K Krys
    So Leute, nach langem rumgefummel folgendes Ergebnis.
    was kurios war, mein iobroker hatte plötzlich zwei IP-Adressen, was offensichtlich auch zu zusätzlichen Problemen führte.
    Könnt ihr nochmal mit eurem geschulten Auge drüber schauen, ob euch noch was auffällt?
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-13-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     10:32:36 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-08-12 10:32:37 CEST
               Universal time: Tue 2025-08-12 08:32:37 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    krystian
    HOME=/home/krystian
    GROUPS=krystian dialout sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:             10G        2.6G        7.4G        114K        570M        8.0G
    Swap:           1.1G          0B        1.1G
    Total:           11G        2.6G        8.5G
    Active iob-Instances:   41
            10124 M total memory
             2478 M used memory
             2438 M active memory
              410 M inactive memory
             7101 M free memory
                0 M buffer memory
              544 M swap cache
             1024 M total swap
                0 M used swap
             1024 M free swap
    top - 10:32:37 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
    Tasks:  65 total,   1 running,  64 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 25.0 us,  0.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  10124.0 total,   7100.1 free,   2479.8 used,    544.3 buff/cache
    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7644.2 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  41% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  104K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
    /var:
    1.3G    /var/
    781M    /var/log
    774M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
    355M    /var/cache
    Archived and active journals take up 182.7M in the file system.
    /opt/iobroker/backups:
    251M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    660M    /opt/iobroker/iobroker-data/
    268M    /opt/iobroker/iobroker-data/files
    167M    /opt/iobroker/iobroker-data/history-data
    148M    /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/iot.admin
    45M     /opt/iobroker/iobroker-data/states.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/objects.jsonl
    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.4
    /usr/bin/node           v20.19.4
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 20.19.4-1nodesource1
      Candidate: 20.19.4-1nodesource1
      Version table:
     *** 20.19.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 428)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     4
    +-- iobroker.alexa2@3.27.3 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#1f026d3554d62693f1c785027d1e326cf6461998)
    +-- iobroker.cloudless-homeconnect@1.6.2 (git+ssh://git@github.com/eifel-tech/ioBroker.cloudless-homeconnect.git#2e5ef03576947db4490f99fe5b032ef5d0e216fe)
    +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
    `-- nodejieba@3.4.3 (git+ssh://git@github.com/yanyiwu/nodejieba.git#7b93462d7e8eff6f2939202a0abbfcbf64c9ec01)
    Adapter State
    + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
    + system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
      system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
    + system.adapter.geofency.0               : geofency              : ioBroker                                 -  enabled, port: 7999, bind: 0.0.0.0
    + system.adapter.google-sharedlocations.0 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.1 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.2 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.3 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
    + system.adapter.hmip.1                   : hmip                  : ioBroker                                 -  enabled
    + system.adapter.homeconnect.1            : homeconnect           : ioBroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
    + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
    + system.adapter.nuki.0                   : nuki                  : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      system.adapter.openweathermap.1         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ 1       │ 'latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "adguard"      : 1.0.1    , installed 1.0.1
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "ankersolix2"  : 2.2.0    , installed 2.2.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "hue"          : 3.16.1   , installed 3.16.1
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "notification-manager": 1.2.1, installed 1.2.1
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects:        29378
    States:         27132
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          343600     295/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          341984     1/init
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       344427     126/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       344422     126/iobroker.js-con
    tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       349074     700/io.nuki.0
    tcp        0      0 127.0.0.1:45729         0.0.0.0:*               LISTEN      1001       353213     813/io.yahka.0
    tcp        0      0 0.0.0.0:37503           0.0.0.0:*               LISTEN      1001       352501     813/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          344254     1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          341986     1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          343601     295/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       346474     306/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       356415     992/io.web.0
    udp        0      0 0.0.0.0:36423           0.0.0.0:*                           1001       345845     428/io.broadlink2.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       348828     681/io.mihome-vacuu
    udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       353940     874/io.mihome-vacuu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       352498     813/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       348185     443/io.chromecast.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       349155     760/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       353336     790/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       353337     790/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       346813     428/io.broadlink2.0
    udp        0      0 0.0.0.0:56183           0.0.0.0:*                           1001       355236     969/io.upnp.0
    udp        0      0 192.168.178.100:68      0.0.0.0:*                           103        345195     73/systemd-networkd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          341985     1/init
    udp        0      0 0.0.0.0:41265           0.0.0.0:*                           1001       347378     428/io.broadlink2.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       357628     969/io.upnp.0
    udp6       0      0 :::111                  :::*                                0          341987     1/init
    udp6       0      0 fe80::be24:11ff:fe5:546 :::*                                103        345342     73/systemd-networkd
    krystian@ioBroker:~$ systemctl status systemd-networkd-wait-online.service
    * systemd-networkd-wait-online.service - Wait for Network to be Configured
         Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; preset: disabled)
         Active: active (exited) since Tue 2025-08-12 10:25:35 CEST; 8min ago
           Docs: man:systemd-networkd-wait-online.service(8)
        Process: 108 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=0/SUCCESS)
       Main PID: 108 (code=exited, status=0/SUCCESS)
            CPU: 13ms
    @krys
    Ich sag ja, da klemmt beim Netzwerk was...
    Die üblichen Nicklichkeiten würde ich noch angehen.
    Bei Zigbee z. B. den Geräte Link 'by-id' verwenden usw.
    Ich würde auch jetzt auf nodejs@22 gehen:
    iob nodejs-update
    Und im Herbst würde ich das ganze Ding auf Debian 13 'Trixie' haben.
    • K Offline
      Krys
      nodejs 22 ist erledigt.
      beim Zigbee-Adapter, wenn ich vom Anschlussnamen
      eintrage, habe ich ne Bootschleife und der Adapter wird nicht grün.
      • K Krys
        @krys
        Dann stell es wieder um. Liegt vermutlich am LXC. Die Dinger ticken tw. etwas anders als ein 'richtiges' System.
        K 1 Antwort Letzte Antwort
          @krys
          Krys
          @thomas-braun Ja, da scheint irgendwas mit den Rechten nicht zu passen. Kriege es aber anders auch nicht durchgeschleift.
          • K Krys
            @krys
            Welche Rechte brauchst du denn an dem Gerät?
            ls -l /dev/ttyUSB0
              @krys
              ls -l /dev/ttyUSB0
              Krys
              @thomas-braun so wie ich das jetzt verstanden habe, sind die Rechte beim Host. Wie und was für Rechte ich brauche, das weiß ich nicht :/. Ich meine, es läuft ja grundsätzlich so wie es aktuell ist.
              • K Krys
                @krys
                Aber dann nicht wundern, wenn ggfls. genau das passiert:
                https://forum.iobroker.net/topic/81899/raspi-vermeidung-der-usb-port-wechsel?_=1755000455669
                • K Offline
                  Krys
                  Das ist tatsächlich in den letzten 4 Jahren nicht passiert.
