  4. Nach Update des Container Managers (Syno) streikt Zigbee
    6.7k
48 Beiträge 7 Kommentatoren 5.6k Aufrufe 6 Beobachtet
    @airmaxchen
    2025-07-03 10:38:57.042 error Caught by controller[0]: Error: Cannot find module 'axios'
    Was liefert denn ein
    cd /opt/iobroker && npm ls axios
    Wundert mich eigentlich, der zigbee-Adapter verwendet axios nämlich gar nicht:
    echad@chet:/opt/iobroker $ npm ls axios
    iobroker.inst@3.0.0 /opt/iobroker
    ├─┬ iobroker.admin@7.7.1
    │ └─┬ @iobroker/socket-classes@2.2.18
    │   └── axios@1.10.0 deduped
    ├─┬ iobroker.ankersolix2@2.2.0
    │ └── axios@1.10.0
    ├─┬ iobroker.awtrix-light@2.0.0
    ├─┬ iobroker.backitup@3.3.4
    ├─┬ iobroker.cloud@5.0.1
    │ ├─┬ @iobroker/socket-classes@1.5.0
    │ │ └── axios@1.10.0 deduped
    ├─┬ iobroker.followthesun@0.5.2
    ├─┬ iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
    ├─┬ iobroker.ical@1.16.2
    │ ├── axios@1.10.0 deduped
    │ └─┬ node-ical@0.20.1
    ├─┬ iobroker.iceroad@1.2.1
    ├─┬ iobroker.iot@3.6.0
    ├─┬ iobroker.javascript@9.0.7
    ├─┬ iobroker.js-controller@7.0.7
    │ ├─┬ @iobroker/js-controller-adapter@7.0.7
    │ │ └─┬ @alcalzone/pak@0.8.1
    │ │   └── axios@0.26.1
    │ ├─┬ @iobroker/js-controller-cli@7.0.7
    │ ├─┬ @iobroker/js-controller-common-db@7.0.7
    ├─┬ iobroker.mihome-cloud@0.1.1
    ├─┬ iobroker.opendtu@3.1.0
    ├─┬ iobroker.openweathermap@1.3.0
    ├─┬ iobroker.parcel@0.2.10
    ├─┬ iobroker.playstation@0.0.3 (git+ssh://git@github.com/Lucky-ESA/ioBroker.playstation.git#398b19e821ea27f6ffe2fc39dbbb0349ce00cbf9)
    ├─┬ iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
    │ └── axios@0.21.4
    ├─┬ iobroker.tado@0.7.10
    ├─┬ iobroker.tankerkoenig@3.4.0
    ├─┬ iobroker.trashschedule@4.0.1
    ├─┬ iobroker.tuya@3.17.0
    └─┬ iobroker.weather-warnings@0.7.4
    Airmaxchen
    #41
    @thomas-braun sagte in Nach Update des Container Managers (Syno) streikt Zigbee:
    Das liefert:
    root@iobroker:/opt/iobroker# cd /opt/iobroker && npm ls axios
    sudo: unable to resolve host iobroker: Name or service not known
    iobroker.inst@2.0.3 /opt/iobroker
    ├─┬ iobroker.admin@7.6.17
    │ └─┬ @iobroker/socket-classes@2.2.19
    │   └── axios@1.10.0
    ├─┬ iobroker.backitup@3.2.2
    │ └── axios@1.10.0
    ├─┬ iobroker.fullybrowser@3.1.1
    │ └── axios@1.10.0
    ├─┬ iobroker.ical@1.16.1
    │ ├── axios@1.10.0
    │   └── axios@1.10.0
    ├─┬ iobroker.info@2.0.0
    │ └── axios@1.5.1
    ├─┬ iobroker.iot@3.3.0
    │ └── axios@1.10.0
    ├─┬ iobroker.javascript@8.9.2
    │ └── axios@1.10.0
    ├─┬ iobroker.js-controller@7.0.6
    │ ├─┬ @iobroker/js-controller-adapter@7.0.6
    │ ├─┬ @iobroker/js-controller-cli@7.0.6
    │ ├─┬ @iobroker/js-controller-common-db@7.0.6
    │ └── axios@1.10.0
    ├─┬ iobroker.lg-thinq@1.1.0
    │ └── axios@1.10.0
    ├─┬ iobroker.lovelace@4.1.15
    │ └── axios@1.10.0
    ├─┬ iobroker.octoprint@5.1.0
    │ └── axios@1.6.0
    ├─┬ iobroker.shelly@9.5.1
    │ └── axios@1.10.0
    ├─┬ iobroker.socketio@6.7.1
    │ └─┬ @iobroker/socket-classes@1.5.6
    │   └── axios@1.10.0
    ├─┬ iobroker.telegram@4.1.0
    │ └── axios@1.10.0
    ├─┬ iobroker.trashschedule@3.3.0
    │ └── axios@1.10.0
    ├─┬ iobroker.web@7.0.8
    │ └─┬ iobroker.socketio@7.0.8
    │     └── axios@1.10.0
    └─┬ iobroker.wled@0.7.2
      └── axios@0.27.2
    • A Airmaxchen
      Das liefert:
      │   └── axios@1.10.0
      │ └── axios@1.10.0
      │ └── axios@1.10.0
      │ ├── axios@1.10.0
      │   └── axios@1.10.0
      │ └── axios@1.5.1
      │ └── axios@1.10.0
      │ └── axios@1.10.0
      │ └── axios@1.10.0
      │ └── axios@1.10.0
      │ └── axios@1.10.0
      │ └── axios@1.6.0
      │ └── axios@1.10.0
      │   └── axios@1.10.0
      │ └── axios@1.10.0
      │ └── axios@1.10.0
      │     └── axios@1.10.0
        └── axios@0.27.2
      #42
      @airmaxchen
      Passt eigentlich.
      cd /opt/iobroker/node_modules/iobroker.zigbee && npm i --omit=dev --dry-run
      mal versuchen. Wenn das durchläuft dann nochmal ohne die --dry-run-Option.
      A 1 Antwort Letzte Antwort
        @airmaxchen
        Passt eigentlich.
        Airmaxchen
        #43
        @thomas-braun Wenn ich es mit "--dry-run" starte kommt eine sehr lange Liste die mir das Terminal innerhalb des Container Managers nicht vollständig anzeigen kann. Das Ende der Liste sieht so aus:
        added 967 packages in 35s
        130 packages are looking for funding
          run `npm fund` for details
        Ohne --dry-run kommt folgendes:
        root@iobroker:/opt/iobroker/node_modules/iobroker.zigbee# cd /opt/iobroker/node_modules/iobroker.zigbee && npm i --omit=dev
        added 61 packages in 12s
        22 packages are looking for funding
        • A Airmaxchen
          #44
          @airmaxchen sagte in Nach Update des Container Managers (Syno) streikt Zigbee:
          Ich würde auch ein gescheites Terminal verwenden und per SSH auf die Kiste gehen.
          Dann hau da jetzt noch den Fixer drüber. Muss aber soweit ich weiß bei Docker-Krams irgendwie anders ausgeführt werden.
            Airmaxchen
            #45
            @thomas-braun Ich habe jetzt auch den Fixer laufen lassen. Hat leider auch nicht geholfen.
            Ich komme erst wieder am Montag dazu weiterzumachen. Melde mich dann dann ggf. Danke!
            Z Ro75R 2 Antworten Letzte Antwort
            • A Airmaxchen
              Z Offline
              Z Offline
              zahnheinrich
              #46
              @airmaxchen
              Nur so als Einwurf von der Seite:
              Der Container läuft im privilegierten Modus?
              Sonst funktioniert (bei mir) das Durchreichen des USB anschlusses nicht.
              MfG Ulrich
              • A Airmaxchen
                Ro75R Offline
                Ro75R Offline
                Ro75
                #47
                Diese Info hilft so nicht. Alle angezeigten Informationen von ANFANG bis ENDE posten.
                Ro75.
                  Airmaxchen
                  #48
                  Jetzt habe ich ein schlechtes Gewissen, aber nach reichlicher Überlegung habe ich diese Probleme genutzt und meinen schon lange geplanten Umstieg auf Home Assistant jetzt schon gemacht.
                  Trotzdem vielen Dank für eure Bemühungen!
