  4. [gelöst] Problem in der IOB DIAG
    6.7k
11 Beiträge 4 Kommentatoren 953 Aufrufe 3 Beobachtet
  • fuzzy1955F Offline
    fuzzy1955F Offline
    fuzzy1955
    schrieb am zuletzt editiert von fuzzy1955
    Hallo Leute,
    seit gestern erscheint bei meinem IOB-System in der DIAG folgende Meldung:
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    In der Langfassung von iob diag tauchen dann Fehler auf:
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.25+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     23:28:24 up 1 day,  1:33,  2 users,  load average: 0.80, 0.57, 0.50
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-06-26 23:28:24 CEST
               Universal time: Thu 2025-06-26 21:28:24 UTC
                     RTC time: Thu 2025-06-26 21:28:24
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    /home/iobroker/.diag.sh: line 461: [[: 20242 6083: syntax error in expression (error token is "6083")
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             17G        2.1G         11G        7.6M        3.8G         14G
    Swap:           536M          0B        536M
    Total:           17G        2.1G         11G
    Active iob-Instances:   14
            16219 M total memory
             1981 M used memory
             1754 M active memory
             3171 M inactive memory
            10743 M free memory
              179 M buffer memory
             3442 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 23:28:24 up 1 day,  1:33,  2 users,  load average: 0.80, 0.57, 0.50
    Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  16219.7 total,  10743.7 free,   1981.9 used,   3621.7 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.  14237.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.9G     0  7.9G   0% /dev
    tmpfs          tmpfs     1.6G  7.3M  1.6G   1% /run
    /dev/mmcblk0p2 ext4       15G   11G  2.6G  82% /
    tmpfs          tmpfs     8.0G     0  8.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Wed Jun 25 21:54:43 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:C6:D1:C2 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=46767ad0-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Jun 25 21:54:46 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Wed Jun 25 21:54:47 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.4G    /var/
    752M    /var/log
    751M    /var/log/journal/ce49b5c207f74de48fc362bf23ca73ba
    631M    /var/lib
    Archived and active journals take up 750.4M in the file system.
    /opt/iobroker/backups:
    102M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    594M    /opt/iobroker/iobroker-data/
    500M    /opt/iobroker/iobroker-data/files
    222M    /opt/iobroker/iobroker-data/files/vis-2
    89M     /opt/iobroker/iobroker-data/files/vis-2/static
    88M     /opt/iobroker/iobroker-data/files/vis-2/static/js
    44M     /opt/iobroker/iobroker-data/objects.jsonl
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.*
    Extended Pan ID:
    grep: /opt/iobroker/iobroker-data/zigbee_*/nvbackup.json: No such file or directory
    Pan ID:
    /home/iobroker/.diag.sh: line 713: printf: 0x: invalid hex number
    Channel:
    Network Key:
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.3
    /usr/bin/node           v20.19.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 20.19.3-1nodesource1
      Candidate: 20.19.3-1nodesource1
      Version table:
     *** 20.19.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 60500)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      system.adapter.emporia.0                : emporia               : raspberrypi                              - disabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
    + system.adapter.kecontact.0              : kecontact             : raspberrypi                              -  enabled
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.modbus.2                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.0.100
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi                              - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              - disabled
      system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: raspberrypi                              - disabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                              │ auto upgrade │
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ true         │
    Active repo(s): stable
    Upgrade policy: minor
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "backitup"     : 3.2.2    , installed 3.2.2
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "emporia"      : 0.0.12   , installed 0.1.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "kecontact"    : 3.1.0    , installed 3.1.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "shelly"       : 9.5.1    , installed 9.5.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-2-widgets-weather-and-heating": 0.10.4, installed 0.10.4
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        2026
    States:         1665
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      106        7246       762/mariadbd
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          7333       888/smbd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7215       703/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          7334       888/smbd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31189      6083/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31194      6083/iobroker.js-co
    tcp        0      0 192.168.0.100:1882      0.0.0.0:*               LISTEN      1001       49289      8662/io.shelly.0
    tcp6       0      0 :::445                  :::*                    LISTEN      0          7331       888/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7217       703/sshd: /usr/sbin
    tcp6       0      0 :::139                  :::*                    LISTEN      0          7332       888/smbd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       29611      6115/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       48458      8505/io.web.0
    udp        0      0 0.0.0.0:43875           0.0.0.0:*                           1001       48496      8569/io.kecontact.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        999        574/avahi-daemon: r
    udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       46073      8569/io.kecontact.0
    udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       46074      8569/io.kecontact.0
    udp        0      0 192.168.0.255:137       0.0.0.0:*                           0          6430       884/nmbd
    udp        0      0 192.168.0.100:137       0.0.0.0:*                           0          6429       884/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          6417       884/nmbd
    udp        0      0 192.168.0.255:138       0.0.0.0:*                           0          6432       884/nmbd
    udp        0      0 192.168.0.100:138       0.0.0.0:*                           0          6431       884/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          6418       884/nmbd
    udp        0      0 0.0.0.0:33484           0.0.0.0:*                           104        1001       574/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        1000       574/avahi-daemon: r
    udp6       0      0 :::57465                :::*                                104        1002       574/avahi-daemon: r
    udp6       0      0 fe80::7de6:a76b:229:546 :::*                                0          7358       651/NetworkManager
    2025-06-26 23:27:16.127  - error: host.raspberrypi No connection to databases possible, restart
    2025-06-26 23:27:16.131  - info: host.raspberrypi iobroker _restart
    2025-06-26 23:27:16.645  - info: host.raspberrypi iobroker Starting node restart.js
    2025-06-26 23:27:25.810  - info: host.raspberrypi iobroker.js-controller version 7.0.6 js-controller starting
    2025-06-26 23:27:25.812  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-06-26 23:27:25.812  - info: host.raspberrypi hostname: raspberrypi, node: v20.19.3
    2025-06-26 23:27:25.812  - info: host.raspberrypi ip addresses: 192.168.0.100 fdf3:7ab7:8f6:0:d7ac:9b82:4e10:8fea fe80::7de6:a76b:229d:d320
    2025-06-26 23:27:26.316  - info: host.raspberrypi-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
    2025-06-26 23:27:55.818  - error: host.raspberrypi No connection to databases possible, restart
    2025-06-26 23:27:55.823  - info: host.raspberrypi iobroker _restart
    2025-06-26 23:27:56.337  - info: host.raspberrypi iobroker Starting node restart.js
    2025-06-26 23:28:00.526  - info: host.raspberrypi iobroker.js-controller version 7.0.6 js-controller starting
    2025-06-26 23:28:00.528  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-06-26 23:28:00.529  - info: host.raspberrypi hostname: raspberrypi, node: v20.19.3
    2025-06-26 23:28:00.529  - info: host.raspberrypi ip addresses: 192.168.0.100 fdf3:7ab7:8f6:0:d7ac:9b82:4e10:8fea fe80::7de6:a76b:229d:d320
    2025-06-26 23:28:01.075  - info: host.raspberrypi-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
    2025-06-26 23:28:13.954  - info: shelly.0 (8662) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
    2025-06-26 23:28:30.539  - error: host.raspberrypi No connection to databases possible, restart
    2025-06-26 23:28:30.542  - info: host.raspberrypi iobroker _restart
    2025-06-26 23:28:31.041  - info: host.raspberrypi iobroker Starting node restart.js
    2025-06-26 23:28:35.346  - info: host.raspberrypi iobroker.js-controller version 7.0.6 js-controller starting
    2025-06-26 23:28:35.348  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-06-26 23:28:35.349  - info: host.raspberrypi hostname: raspberrypi, node: v20.19.3
    2025-06-26 23:28:35.349  - info: host.raspberrypi ip addresses: 192.168.0.100 fdf3:7ab7:8f6:0:d7ac:9b82:4e10:8fea fe80::7de6:a76b:229d:d320
    2025-06-26 23:28:35.937  - info: host.raspberrypi-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
    iob diag has finished.
    Das System ist am letzten Stand:
    IOB v7.6.17
    js-controller v7.0.6
    sudo apt update
    sudo apt full-upgrade
    iob update
    iob upgrade self
    iob upgrade
    Restore des IOB von 3 Tage zuvor.
    Der IOB fix zeigt folgendes:
    iob fix
    library: loaded
    Library version=2024-10-22
    ioBroker or some processes are still running:
    6083 iobroker.js-con
    6115 io.admin.0
    6183 io.backitup.0
    8505 io.web.0
    8520 io.vis-2.0
    8536 io.sql.0
    8558 io.javascript.1
    8569 io.kecontact.0
    8588 io.modbus.0
    8606 io.email.0
    8624 io.modbus.1
    8662 io.shelly.0
    18691 io.javascript.0
    18724 io.modbus.2
    Please stop them first and try again!
    Was ist die Ursache dafür und welche Schritte sind da notwendig? Vorweg danke für eure Unterstützung!
    Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
    Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
    Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
    Großes Danke an alle tatkräftigen Helfer im Forum!
    • fuzzy1955F fuzzy1955
      Hallo Leute,
      Script v.2025-03-08
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           536M          0B        536M
      Total:           17G        2.1G         11G
               1981 M used memory
              10743 M free memory
                179 M buffer memory
               3442 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      2.4G    /var/
      752M    /var/log
      631M    /var/lib
      USB-Devices by-id:
      zigbee.*
      Extended Pan ID:
      Pan ID:
      Channel:
      Network Key:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        2026
      States:         1665
      Pending Updates: 3
      IOB v7.6.17
      sudo apt update
      iob update
      iob upgrade self
      iob upgrade
      iob fix
      library: loaded
      6115 io.admin.0
      6183 io.backitup.0
      8505 io.web.0
      8520 io.vis-2.0
      8536 io.sql.0
      8569 io.kecontact.0
      8588 io.modbus.0
      8606 io.email.0
      8624 io.modbus.1
      8662 io.shelly.0
      18724 io.modbus.2
      @fuzzy1955 sagte in Problem in der IOB DIAG:
      iob stop
      iob fix
      sudo apt update
      sudo reboot
      Dann nochmal schauen was iob diag sagt.
      fuzzy1955F 1 Antwort Letzte Antwort
        iob stop
        iob fix
        sudo apt update
        sudo reboot
        fuzzy1955F Offline
        fuzzy1955F Offline
        fuzzy1955
        @thomas-braun sagte in Problem in der IOB DIAG:
        Dasselbe wie zuletzt:
        * Some output is masked. For full results please use 'iob diag --unmask' *
        Thomas BraunT ? 2 Antworten Letzte Antwort
          @fuzzy1955
          Äh? Das ist der 'Anleitungstext', der bei jedem Aufruf kommt.
            @fuzzy1955
            der Any Key ist nicht die Shift-Taste..
              @fuzzy1955
              fuzzy1955F Offline
              fuzzy1955F Offline
              fuzzy1955
              Pardon, ich war in Eile. Das ist der vollständige Inhalt:
              Script v.2025-03-08
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
               20:34:18 up 20:30,  2 users,  load average: 0.27, 0.20, 0.09
              CPU threads: 4
              Current issues:
                             Local time: Fri 2025-06-27 20:34:18 CEST
                         Universal time: Fri 2025-06-27 18:34:18 UTC
                               RTC time: Fri 2025-06-27 18:34:18
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:             17G        2.1G         13G        7.6M        1.3G         14G
              Swap:           536M          0B        536M
              Total:           17G        2.1G         14G
              Active iob-Instances:   16
                       2019 M used memory
                       1800 M active memory
                        937 M inactive memory
                      13108 M free memory
                        126 M buffer memory
                       1085 M swap cache
                        511 M total swap
                          0 M used swap
                        511 M free swap
              top - 20:34:18 up 20:30,  2 users,  load average: 0.27, 0.20, 0.09
              Tasks: 198 total,   1 running, 197 sleeping,   0 stopped,   0 zombie
              MiB Mem :  16219.7 total,  13108.8 free,   2019.0 used,   1211.2 buff/cache
              MiB Swap:    512.0 total,    512.0 free,      0.0 used.  14200.6 avail Mem
              *** FILESYSTEM ***
              /dev/mmcblk0p2 ext4       15G   11G  2.5G  82% /
              [Fri Jun 27 00:03:42 2025] Kernel command line: reboot=w coherent_pool=1M 8250.n        r_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=f        ake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:C6:D1:C2 vc_mem.mem_base        =0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 roo        t=PARTUUID=46767ad0-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Fri Jun 27 00:03:45 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8        -424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
              [Fri Jun 27 00:03:46 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87        a2-cd44114eb820 r/w. Quota mode: none.
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              2.4G    /var/
              752M    /var/log
              631M    /var/lib
              598M    /opt/iobroker/iobroker-data/
              47M     /opt/iobroker/iobroker-data/objects.jsonl
              26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41c        ee985.js.map
              USB-Devices by-id:
              USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 73821)
              admin:          7.6.17
              javascript:     8.9.2
              Adapter State
              + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
              + system.adapter.emporia.0                : emporia               : raspberrypi                              -  enabled
              + instance is alive
              Objects and States
              Objects:        1970
              States:         1645
              Pending Updates: 0
              tcp        0      0 192.168.0.100:1882      0.0.0.0:*               LISTEN      1001       142937     2605/io.shelly.0
              tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      106        2950       754/mariadbd
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8223       674/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8218       674/iobroker.js-con
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6281       881/smbd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5726       695/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6280       881/smbd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7314       1036/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8817       1378/io.web.0
              tcp6       0      0 :::139                  :::*                    LISTEN      0          6279       881/smbd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          5728       695/sshd: /usr/sbin
              tcp6       0      0 :::445                  :::*                    LISTEN      0          6278       881/smbd
              udp        0      0 0.0.0.0:50192           0.0.0.0:*                           104        2881       565/avahi-daemon: r
              udp        0      0 0.0.0.0:59433           0.0.0.0:*                           1001       9814       1259/io.kecontact.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2879       565/avahi-daemon: r
              udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       7566       1259/io.kecontact.0
              udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       7567       1259/io.kecontact.0
              udp        0      0 192.168.0.255:137       0.0.0.0:*                           0          3058       876/nmbd
              udp        0      0 192.168.0.100:137       0.0.0.0:*                           0          3057       876/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          3045       876/nmbd
              udp        0      0 192.168.0.255:138       0.0.0.0:*                           0          3060       876/nmbd
              udp        0      0 192.168.0.100:138       0.0.0.0:*                           0          3059       876/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          3046       876/nmbd
              udp6       0      0 :::5353                 :::*                                104        2880       565/avahi-daemon: r
              udp6       0      0 :::56308                :::*                                104        2882       565/avahi-daemon: r
              udp6       0      0 fe80::7de6:a76b:229:546 :::*                                0          5897       642/NetworkManager
              2025-06-27 09:34:31.903  - error: shelly.0 (2605) [MQTT] Unable to get mqttprefix of client with id "shellypro0110pm-8813bfd960b4"
              2025-06-27 09:34:43.376  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
              2025-06-27 09:35:43.512  - info: admin.0 (1036) <== Disconnect system.user.admin from ::ffff:192.168.0.20 admin
              2025-06-27 09:35:43.512  - info: web.0 (1378) <== Disconnect system.user.admin from ::ffff:192.168.0.20
              2025-06-27 09:43:25.974  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
              2025-06-27 10:55:25.983  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
              2025-06-27 12:07:25.988  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
              2025-06-27 13:19:25.986  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
              2025-06-27 14:30:46.126  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
              2025-06-27 14:30:58.146  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
              2025-06-27 14:31:25.979  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
              2025-06-27 14:39:32.186  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
              2025-06-27 14:40:04.204  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
              2025-06-27 14:40:10.223  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
              2025-06-27 14:40:11.106  - error: shelly.0 (2605) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'replace')
              2025-06-27 14:40:11.106  - error: shelly.0 (2605) [MQTT] Unable to get mqttprefix of client with id "shellypro0110pm-8813bfd960b4"
              2025-06-27 14:41:02.242  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
              2025-06-27 15:43:25.988  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
              2025-06-27 16:55:25.991  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
              2025-06-27 18:07:25.988  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
              2025-06-27 19:19:25.991  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                Script v.2025-03-08
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           536M          0B        536M
                Total:           17G        2.1G         14G
                         2019 M used memory
                        13108 M free memory
                          126 M buffer memory
                         1085 M swap cache
                          511 M total swap
                            0 M used swap
                          511 M free swap
                *** FILESYSTEM ***
                /var:
                2.4G    /var/
                752M    /var/log
                631M    /var/lib
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.6.17
                javascript:     8.9.2
                Adapter State
                + instance is alive
                Objects and States
                Objects:        1970
                States:         1645
                Pending Updates: 0
                @fuzzy1955
                Und um was geht es dir? Ist doch alles tutti.
                  @fuzzy1955
                  fuzzy1955F Offline
                  fuzzy1955F Offline
                  fuzzy1955
                  Anlass war, dass der IOB aus heiterem Himmel stoppte und auch nach mehreren Versuchen nicht mehr gestartet hat. Der Admin-Adapter lief immer auf einen Fehler. Leider habe ich davon keine Aufzeichnungen mehr. Ich spielte daraufhin ein Backup von 3 Tagen zuvor ein, das System lief wieder, aber diese Meldung irritierte mich:
                    @fuzzy1955
                    fuzzy1955F Offline
                    fuzzy1955F Offline
                    fuzzy1955
                    @neuschwansteini 😊
                      HomoranH Offline
                      HomoranH Offline
                      @fuzzy1955 sagte in [gelöst] Problem in der IOB DIAG:
                      die gibt es seit ewigen Zeiten und ist eine Anleitung, was man beachten soll, bevor man weitermacht, damit der Output auch für die Helferlein vernünftig lesbar wird.
                        fuzzy1955F Offline
                        fuzzy1955F Offline
                        fuzzy1955
                        @homoran sagte in [gelöst] Problem in der IOB DIAG:
                        Ups ... wieder was gelernt. Danke!
