  4. Unable to update node.js v20.19.1 to v20.19.2
    6.7k
2 Beiträge 2 Kommentatoren 356 Aufrufe 2 Beobachtet
  • G Offline
    ggansde
    Folgende Fehlermeldung erscheint:
    rm: cannot remove '/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
    Waiting for ioBroker to shut down - Give me a minute...
    Removing dfsg-nodejs
    *** These repos are active on your system:
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 https://apt.grafana.com stable InRelease
    Hit:5 https://repos.influxdata.com/debian bullseye InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Get:6 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
    Get:7 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [11.4 kB]
    Fetched 23.5 kB in 1s (16.4 kB/s)
    Installing nodejs now!
    Installing nodejs!
    COMPATIBILITY CHECK IN PROGRESS
    add fsevents 2.3.3
    added 1 package in 5s
    102 packages are looking for funding
      run `npm fund` for details
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    pi@iobroker:~ $ node -v
    v20.19.1
    • G ggansde
      Package: nodejs
      Pin-Priority: 1001
      Installing nodejs!
      add fsevents 2.3.3
      v20.19.1
      @ggansde
      Innerhalb einer Major-Version macht man das auch nicht über iob nodejs-update sondern über den Paketmanager deines Systems.
      sudo apt update
      sudo apt full-upgrade
      liefert?
      Edit: Ich sehe gerade, da war zuvor die Quelle von nodesource gar nicht angelegt. Vermutlich hattest/hast du da die dfsg-Version am Wickel (oder eine am Paketmanager vorbei gezirkelte Installation).
      Schau mal per
      iob diag
      nach der konkreten Situation.
