  4. [gelöst] Worx baut keine Verbindung mehr auf.
    6.7k
5 Beiträge 3 Kommentatoren 524 Aufrufe 2 Beobachtet
  • Ben1983B Offline
    Ben1983B Offline
    Ben1983
    schrieb am zuletzt editiert von Ben1983
    Hallo, ich musste mein Worx passwort ändern und habe das auch nachträglich im Adapter eingetragen.
    Nun bekomme ich hier keine Verbindung mehr.
    Was kann das sein?
    worx.0
    2025-06-05 16:25:09.282	info	connectMqtt: Failed to connect: libaws-c-mqtt: AWS_ERROR_MQTT_UNEXPECTED_HANGUP, The connection was closed unexpectedly.
    worx.0
    2025-06-05 16:25:09.281	info	MQTT ERROR: Error: Failed to connect: libaws-c-mqtt: AWS_ERROR_MQTT_UNEXPECTED_HANGUP, The connection was closed unexpectedly.
    worx.0
    2025-06-05 16:25:09.085	info	Start check devices object!
    worx.0
    2025-06-05 16:25:08.928	info	Start MQTT connection
    worx.0
    2025-06-05 16:25:08.919	info	Autolock found! Create State : AutoLockTimer
    worx.0
    2025-06-05 16:25:08.918	info	Autolock found! Create State : AutoLock
    worx.0
    2025-06-05 16:25:08.915	info	OffLimits Module found! Create State : DF.OLMSwitch_FastHoming
    worx.0
    2025-06-05 16:25:08.915	info	OffLimits Module found! Create State : DF.OLMSwitch_Cutting
    worx.0
    2025-06-05 16:25:08.914	info	OffLimits Module found! Create State : DF
    worx.0
    2025-06-05 16:25:08.910	info	HL Module found! Create State : HL.on
    worx.0
    2025-06-05 16:25:08.909	info	HL Module found! Create State : HL.status
    worx.0
    2025-06-05 16:25:08.908	info	HL Module found! Create State : HL.enabled
    worx.0
    2025-06-05 16:25:08.907	info	HL Module found! Create State : HL
    worx.0
    2025-06-05 16:25:08.905	info	Torque control found, create states...
    worx.0
    2025-06-05 16:25:08.496	info	Create product folder and states for WR206E
    worx.0
    2025-06-05 16:25:07.689	info	Create folder activityLog and set states.
    worx.0
    2025-06-05 16:25:07.681	info	No new Firmware found, create dummy states...
    worx.0
    2025-06-05 16:25:07.678	info	No new Firmware found, check states...
    worx.0
    2025-06-05 16:25:07.676	info	Paused found, create states...
    worx.0
    2025-06-05 16:25:07.675	info	PartyModus found, create states...
    worx.0
    2025-06-05 16:25:07.673	info	OneTimeShedule found, create states...
    worx.0
    2025-06-05 16:25:07.205	info	Highest slots of mowing times 2 for device 20233029470500802296!
    worx.0
    2025-06-05 16:25:07.204	info	Found Vision - Create/Update calendar for 20233029470500802296!
    worx.0
    2025-06-05 16:25:07.196	info	Found device Vision M with id 20233029470500802296
    worx.0
    2025-06-05 16:25:07.196	info	Found 1 devices
    worx.0
    2025-06-05 16:25:07.017	info	Connected to worx server
    worx.0
    2025-06-05 16:25:06.435	info	Start login
    worx.0
    2025-06-05 16:25:06.434	info	Login to worx
    worx.0
    2025-06-05 16:25:06.433	info	Use new aws-iot-device-sdk-v2.
    worx.0
    2025-06-05 16:25:06.359	info	starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.worx, node: v22.16.0, js-controller: 7.0.6
    • Ben1983B Ben1983
      Was kann das sein?
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      @ben1983
      Was sein kann steht in der Doku drin:
      https://docs.aws.amazon.com/iot/latest/developerguide/device-advisor-troubleshooting.html
      Ist nur die Frage, ob du das im Code angehen kannst.
        @ben1983
        Ben1983B Offline
        Ben1983B Offline
        Ben1983
        @thomas-braun Heute morgen ging es wieder.
        Gestern musste ich das Passwort wechseln. Die MQTT Verbindung hatte wohl etwas gebraucht, oder der Worx Support hat das Token zurückgesetzt.
        Auf jeden Fall lief es heute morgen wieder ohne mein Zutun.
        Steffe.S.S 1 Antwort Letzte Antwort
        • Ben1983B Ben1983
          Steffe.S.S Offline
          Steffe.S.S Offline
          Steffe.S.
          schrieb am zuletzt editiert von Steffe.S.
          @ben1983
          Ich habe genau die selbe Meldung vom Adapter.
          worx.0
          worx.0
          Könntest Du vielleicht kurz erklären, was Du gemacht hast, damit diese Meldung verschwindet und der Adapter wieder funktioniert? Ich komm nicht zum Ziel.
          • Steffe.S.S Steffe.S.
            @ben1983
            worx.0
            worx.0
            Ben1983B Offline
            Ben1983B Offline
            Ben1983
            @steffe-s Ich hatte wie gesagt meine zugangsdaten neu erstellt. (Passwort)
            Das Rücksetzen des Tokens hat wohl etwas gedauert.
            Habe also nur gewartet.
            Blöderweise habe ich mich gestern Abend nochmal aus der App ausgewählt und wieder eingewählt und dann hatte ich wieder das gleiche.
            Es ging dann wieder und heute morgen war der Worx Adapter wieder mit der Meldung gelb.
            Nach 3-4 mal Neustarten des Adapter, wählte er sich wieder ein.... sehr seltsam
