  4. Keine Anmeldung mehr möglich
    6.7k
26 Beiträge 4 Kommentatoren 1.6k Aufrufe 4 Beobachtet
  • U UweK
    ```bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: raspberrypi5
           Icon name: computer
              Kernel: Linux 6.12.25+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     20:02:13 up 1 day,  7:54,  3 users,  load average: 0.14, 0.11, 0.04
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-05-29 20:02:13 CEST
               Universal time: Thu 2025-05-29 18:02:13 UTC
                     RTC time: Thu 2025-05-29 18:02:13
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    Uwe
    HOME=/home/Uwe
    GROUPS=Uwe adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.5G        341M        7.5G        5.5M        670M        8.1G
    Swap:           209M          0B        209M
    Total:          8.7G        341M        7.7G
    Active iob-Instances:   0
             8063 M total memory
              325 M used memory
              221 M active memory
              433 M inactive memory
             7182 M free memory
              107 M buffer memory
              531 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 20:02:13 up 1 day,  7:54,  3 users,  load average: 0.14, 0.11, 0.04
    Tasks: 173 total,   1 running, 172 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.7 total,   7181.7 free,    326.2 used,    639.3 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   7737.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     807M  5.3M  802M   1% /run
    /dev/mmcblk0p2 ext4      117G  5.6G  106G   5% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
    [Wed May 28 12:07:56 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:32:63:A0 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=8e8d8989-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Wed May 28 12:07:59 2025] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
    [Wed May 28 12:08:00 2025] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,er
    /var:
    1.1G    /var/
    450M    /var/log/journal/7955a11edc2a4908be4e0376b1ccf614
    450M    /var/log
    207M    /var/cache
    Archived and active journals take up 449.5M in the file system.
    /opt/iobroker/backups:
    6.7M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    845M    /opt/iobroker/iobroker-data/
    746M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    43M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v21.7.3
    /usr/bin/node           v21.7.3
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 21.7.3-1nodesource1
      Candidate: 21.7.3-1nodesource1
      Version table:
     *** 21.7.3-1nodesource1 600
            500 https://deb.nodesource.com/node_21.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         21.7.2-1nodesource1 600
         21.7.1-1nodesource1 600
         21.7.0-1nodesource1 600
         21.6.2-1nodesource1 600
         21.6.1-1nodesource1 600
         21.6.0-1nodesource1 600
         21.5.0-1nodesource1 600
         21.4.0-1nodesource1 600
         21.3.0-1nodesource1 600
         21.2.0-1nodesource1 600
         21.1.0-1nodesource1 600
         21.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
     Unable to increase LUA script timeout: Error auth NOT SUPPORTED
     Cannot determine Set feature status: Connection is closed.
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/node_modules/iobroker.js-controller/admin/objects.jsonl"!
    Hosts:
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Adapters
    Objects and States
    Objects:        14
    States:         3
    W: Failed to fetch https://deb.nodesource.com/node_21.x/dists/nodistro/InRelease  Could not resolve 'proxy'
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Ign:1 https://deb.nodesource.com/node_21.x nodistro InRelease
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Err:1 https://deb.nodesource.com/node_21.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5579       793/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5581       793/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6402       677/avahi-daemon: r
    udp        0      0 0.0.0.0:56843           0.0.0.0:*                           104        6404       677/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        6403       677/avahi-daemon: r
    udp6       0      0 fe80::9f5b:17ea:875:546 :::*                                0          1683       754/NetworkManager
    udp6       0      0 :::33400                :::*                                104        6405       677/avahi-daemon: r
    2025-05-29 20:03:38.051  - warn: host.raspberrypi5-Server Objects 127.0.0.1:56276 Error from InMemDB: Error: auth NOT SUPPORTED
        at RedisHandler._handleCommand (file:///opt/iobroker/node_modules/@iobroker/db-base/build/esm/lib/redisHandler.js:141:40)
        at Resp.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-base/build/esm/lib/redisHandler.js:59:45)
        at Resp.emit (node:events:519:28)
        at Resp.write (/opt/iobroker/node_modules/respjs/index.js:129:12)
        at Socket.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-base/build/esm/lib/redisHandler.js:69:23)
        at Socket.emit (node:events:519:28)
        at addChunk (node:internal/streams/readable:559:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:510:3)
        at Readable.push (node:internal/streams/readable:390:5)
        at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
    2025-05-29 20:03:38.359  - warn: host.raspberrypi5-Server Objects 127.0.0.1:56286 Error from InMemDB: Error: auth NOT SUPPORTED
    2025-05-29 20:04:07.001  - error: host.raspberrypi5 No connection to databases possible, restart
    2025-05-29 20:04:07.004  - info: host.raspberrypi5 iobroker _restart
    2025-05-29 20:04:07.511  - info: host.raspberrypi5 iobroker Starting node restart.js
    iob diag has finished.
    Uwe@raspberrypi5:/home/iobroker $
    U Offline
    U Offline
    UweK
    @Thomas-Braun
    Leider sagt mir das alles nicht so viel.
    Zum Schluß sehe ich ein error. No connection to database.
    U 1 Antwort Letzte Antwort
    • U UweK
      @Thomas-Braun
      U Offline
      U Offline
      UweK
      @Thomas-Braun
      Schreiben sie gerne nochmal, wenn es ihre Zeit erlaubt.
      Ich melde mich nun erstmal ab und schaue morgen nochmal hier vorbei.
      • U UweK
        @Thomas-Braun
        @uwek
        Den fix zuvor auch ausgeführt?
        Kiste mal sauber neugestartet?
        • Thomas BraunT Online
          @uwek
          Ich würde behaupten, da hat es aus irgendwelchen Gründen die Datenbank zerlegt. Zück dein Backup und installier es nochmal neu.
            @uwek
            @thomas-braun sagte in Keine Anmeldung mehr möglich:
            @uwek
            @UweK
            ich fürchte das wird mit nodejs v21 zusammenhängen können.
            Also Basis komplett neu installieren, dann iobroker und zuletzt das Backup wiederherstellen
              @uwek
              @UweK
              U Offline
              U Offline
              UweK
              @Homoran
              @Thomas-Braun
              Danke für die Unterstützung und Zuarbeit.
              Ich werde alles von Grund auf neu installieren, und das Backup vom Dienstag einspielen.
              Dann denke ich, wird es wieder laufen.
