  4. Admin Adapter startet nicht mehr
    1.0k
    6.1k
5 Beiträge 4 Kommentatoren 480 Aufrufe 2 Beobachtet
    Smibser
    Ohne bewusst etwas verändert zu haben startet der admin Adapter nicht mehr.
    Hier der log vom startenden und gleich wieder terminierenden admin Adapter:
    admin.0 (21460) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.4, js-controller: 4.0.24
    admin.0 (21460) requesting all states
    admin.0 (21460) requesting all objects
    admin.0 (21460) received all objects
    admin.0 (21460) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
    admin.0 (21460) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    admin.0 (21460) get state error: Connection is closed.
    admin.0 (21460) get state error: DB closed
    admin.0 (21460) Cannot check node.js/npm version
    admin.0 (21460) terminating http server on port 8081
    • Adaptername: Admin
    • Link zu Adapterrepository: https://github.com/ioBroker/ioBroker.admin
    • Adapterversion: 6.3.5
    • js-controller Version: 4.0.24
    • Hardwaresystem: Raspberry Pi 4 Model B Rev 1.1
    • Arbeitsspeicher: 1.8GB
    • Festplattenart: SD-Karte
    • Betriebssystem: Raspbian GNU/Linux 10 (buster)
    • Nodejs-Version: v18.20.4
    • NPM-Version: 10.7.0
    Linux User bitte hier den Output von iob diag einfügen.
    			v.2025-02-23
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		32 bit
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    Display-Server: 	false
    Boot Target: 		multi-user.target
    Pending OS-Updates: 	1
    Pending iob updates: 	36
    Nodejs-Installation:
    /usr/bin/nodejs 	v18.20.4
    /usr/bin/node 		v18.20.4
    /usr/bin/npm 		10.7.0
    /usr/bin/npx 		10.7.0
    /usr/bin/corepack 	0.28.0
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:           1.9G        994M        206M         20M        670M        757M
    Swap:           99M         81M         18M
    Total:         2.0G        1.1G        225M
    Active iob-Instances: 	14
    Active repo(s): stable
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.3.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    Objects: 		9002
    States: 		6404
    Size of iob-Database:
    14M	/opt/iobroker/iobroker-data/objects.jsonl
    7.1M	/opt/iobroker/iobroker-data/objects.json.migrated
    7.1M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    0	/opt/iobroker/iobroker-data/objects.json.broken
    3.3M	/opt/iobroker/iobroker-data/states.jsonl
    996K	/opt/iobroker/iobroker-data/states.json.migrated
    992K	/opt/iobroker/iobroker-data/states.json.bak.migrated
    0	/opt/iobroker/iobroker-data/states.json.broken
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    Thomas BraunT HomoranH haselchenH 3 Antworten Letzte Antwort
    • S Smibser
      			v.2025-02-23
               Icon name: computer
            Architecture: arm
      Kernel: 		armv7l
      Userland: 		32 bit
      User-ID: 		1000
      /usr/bin/npm 		10.7.0
      /usr/bin/npx 		10.7.0
      MEMORY:
      Swap:           99M         81M         18M
      			admin 			6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects: 		9002
      States: 		6404
      @smibser
      Das hast du aber ganz lange 'nichts mehr verändert'.
      Alles hoffnungslos veraltet.
      • S Smibser
        			v.2025-02-23
                 Icon name: computer
              Architecture: arm
        Kernel: 		armv7l
        Userland: 		32 bit
        User-ID: 		1000
        /usr/bin/npm 		10.7.0
        /usr/bin/npx 		10.7.0
        MEMORY:
        Swap:           99M         81M         18M
        			admin 			6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects: 		9002
        States: 		6404
        @smibser sagte in Admin Adapter startet nicht mehr:
        bitte die Langfassung!
        lassen aber schon schlimmes vermuten.
        Diese harmlos aussehende Zahl ist aber darin begründet, dass
        schon lange nicht mehr supported wird
        • S Smibser
          			v.2025-02-23
                   Icon name: computer
                Architecture: arm
          Kernel: 		armv7l
          Userland: 		32 bit
          User-ID: 		1000
          /usr/bin/npm 		10.7.0
          /usr/bin/npx 		10.7.0
          MEMORY:
          Swap:           99M         81M         18M
          			admin 			6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects: 		9002
          States: 		6404
          haselchenH Offline
          haselchenH Offline
          haselchen
          @smibser
          Zudem , dass alles veraltet ist , hast Du sehr wohl was verändert.
          Du hast einen Admin hinzugefügt.
          admin.0 und admin.1 sind vorhanden .
          iobroker stop admin.1
          iobroker del admin.1
          iobroker start admin.0
          Und dann solltest Du wieder auf die GUI kommen .
          Dann Backup und dann Neuinstallation.
          • haselchenH haselchen
            @smibser
            @haselchen sagte in Admin Adapter startet nicht mehr:
            und beide auf port 8081.
            und beide nicht aktiv.
            @Smibser
            bitte die Langfassung von iob diag bevor du etwas änderst!
