  4. Back IT UP
Back IT UP
12 Beiträge 2 Kommentatoren 1.2k Aufrufe 3 Beobachtet
    Smartuser_1
    ich bekomme einen Fehler beim Backup und kann diesen nicht zuordnen. Was könnte der Grund sein ?
    Danke für Eure Unterstützung. Vg
    12:40:35.458DEBUGgrafanaCreated dashboard directory
    12:40:35.501DEBUGgrafanaCreated dashboards_manually_restore directory
    12:40:35.525DEBUGgrafanaCreated datasource directory
    12:40:35.545DEBUGgrafanastart Grafana request ...
    12:40:35.589DEBUGgrafanaGrafana is available ... Status: 200
    12:40:35.844DEBUGgrafanastart Grafana backup compress ...
    12:40:35.854DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    12:40:35.993DEBUGgrafanaGrafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    **12:40:35.995ERRORgrafanacannot found Grafana Backup files**
    12:40:36.028DEBUGgrafanadone
    12:40:40.965DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2025_02_23-12_40_35_V_backupiobroker.tar.gz
    12:40:40.969DEBUGjavascriptsdone
    12:40:41.845DEBUGcifsCopy iobroker_2025_02_23-12_40_21_V_backupiobroker.tar.gz...
    12:40:41.868ERRORcifsError: EACCES: permission denied, open '/iobroker_2025_02_23-12_40_21_V_backupiobroker.tar.gz'
    12:40:41.870DEBUGcifsCopy influxDB_2025_02_23-12_40_31_V_backupiobroker.tar.gz...
    12:40:41.872ERRORcifsError: EACCES: permission denied, open '/influxDB_2025_02_23-12_40_31_V_backupiobroker.tar.gz'
    12:40:41.874DEBUGcifsCopy javascripts_2025_02_23-12_40_35_V_backupiobroker.tar.gz...
    12:40:41.879ERRORcifsError: EACCES: permission denied, open '/javascripts_2025_02_23-12_40_35_V_backupiobroker.tar.gz'
    12:40:41.912DEBUGcifsdone
    12:40:42.436ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
    12:40:42.474DEBUGcleandone
    12:40:42.590DEBUGhistoryHTMLnew history html values created
    12:40:42.626DEBUGhistoryHTMLdone
    • S Smartuser_1
      @smartuser_1 sagte in Back IT UP:
      Wie sehen die Rechte denn da aus? Liegt da ein gemountetes Dateisystem?
        Smartuser_1
        ja, da liegt ein gemountetes Dateisystem (Laufwerk auf einer WD-MyCloudmirror).
        Der Zugriff auf der WD ist lesend und schreibend für den User freigegeben. Die Files werden auch teilweise auf der WD geschrieben, allerdings fehlt "Grafana".
        Vg
        • S Smartuser_1
          Vg
          @smartuser_1
          CIFS/SMB? NFS? Was anderes?
          Wie sehen die Rechte konkret aus?
          ls -l /opt/iobroker/backups/
          sagt?
            @smartuser_1
            sagt?
            Smartuser_1
            @thomas-braun said in Back IT UP:
            -rw-rw-r--+ 1 iobroker iobroker 1790862 Feb  7 18:24 iobroker_2025_02_07-18_24_02_Pi5_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 1791381 Feb  8 02:48 iobroker_2025_02_08-02_48_20_Pi5_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker     135 Feb  7 18:24 javascripts_2025_02_07-18_24_06_Pi5_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker     136 Feb  8 02:48 javascripts_2025_02_08-02_48_24_Pi5_backupiobroker.tar.gz
            • S Smartuser_1
              @smartuser_1
              Da ist das NAS gemountet? Mit welchem Protokoll hängst du das ein?
                @smartuser_1
                Smartuser_1
                auf der NAS habe ich SMB 3 hinterlegt und im Adapter auch.
                • S Smartuser_1
                  @smartuser_1
                  Setz das mal auf 3.1.1
                    @smartuser_1
                    Smartuser_1
                    habe im Adapter jetzt 3.1.1 eingestellt, es kommen leider immer doch die Fehler:
                    17:19:07.728ERRORgrafanaError on Grafana Dashboard Request: AxiosError: Request failed with status code 500
                    17:19:13.820ERRORcifsError: EACCES: permission denied, open '/iobroker_2025_02_23-17_18_58_V_backupiobroker.tar.gz'
                    17:19:13.824DEBUGcifsCopy influxDB_2025_02_23-17_19_03_V_backupiobroker.tar.gz...
                    17:19:13.851ERRORcifsError: EACCES: permission denied, open '/influxDB_2025_02_23-17_19_03_V_backupiobroker.tar.gz'
                    17:19:13.852DEBUGcifsCopy javascripts_2025_02_23-17_19_07_V_backupiobroker.tar.gz...
                    17:19:13.855DEBUGcifsdone
                    17:19:14.415ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
                    • S Smartuser_1
                      mount
                      ls -la /opt/iobroker/backups/influxDB_2025_02_23-17_19_03_V_backupiobroker.tar.gz
                      sagt?
                        mount
                        sagt?
                        Smartuser_1
                        ... habe es gerade getestet:
                        ls: cannot access '/opt/iobroker/backups/influxDB_2025_02_23-17_19_03_V_backupiobroker.tar.gz': No such file or directory
                        und die Abfrage ls -l auf das gemountete Laufwerk (inkl. der alten Daten vom Raspberrypi4):
                        uld@raspberrypi5:~/Backup/share $ ls -l
                        total 4373328
                        -rwxr-xr-x 1 root root     3060 Dec 12  2022 '01 at.csv'
                        -rwxr-xr-x 1 root root    31046 Dec 14  2022  grafana_2022_12_14-20_05_16_backupiobroker.tar.gz
                        -rwxr-xr-x 1 root root    31047 Dec 15  2022  grafana_2022_12_15-02_41_33_V_backupiobroker.tar.gz
                        -rwxr-xr-x 1 root root    31092 Dec 22  2022  grafana_2022_12_22-02_41_35_V_backupiobroker.tar.gz
                        • S Smartuser_1
                          total 4373328
                          @smartuser_1
                          Die Dateien dürften aber eigentlich auch nicht dem root gehören.
