  4. IOB Proxmox CT No Space left on device.. aber wo?
deviceno space
6 Beiträge 2 Kommentatoren 554 Aufrufe 4 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    wendy2702
    heute abend ist mein IOB mit diesem Log Eintrag abgeschmiert:
    2025-02-04 20:27:53.864  - error: host.iobroker uncaught exception: ENOSPC: no space left on device, write
    2025-02-04 20:27:53.864  - error: host.iobroker Error: ENOSPC: no space left on device, write
    Allerdings komme ich gerade nicht dahinter wo denn das Device voll ist.
    mirko@iobroker:/opt/iobroker$ df -h
    Filesystem                        Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0   30G   15G   14G  52% /
    none                              492K  4.0K  488K   1% /dev
    udev                               16G     0   16G   0% /dev/tty
    tmpfs                              16G     0   16G   0% /dev/shm
    tmpfs                             6.3G  100K  6.3G   1% /run
    tmpfs                             5.0M     0  5.0M   0% /run/lock
    tmpfs                             3.2G     0  3.2G   0% /run/user/1001
    tmpfs                             3.2G     0  3.2G   0% /run/user/0
    NCDU (sorry für den Screenshot)
    Iob Diag:
    Script v.2025-02-02
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-8-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:45:37 up 3 days,  4:58,  2 users,  load average: 0.68, 1.93, 3.33
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-02-04 20:45:37 CET
               Universal time: Tue 2025-02-04 19:45:37 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    mirko
    HOME=/home/mirko
    GROUPS=mirko sudo iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             17G        341M         15G        114K        903M         16G
    Swap:             0B          0B          0B
    Total:           17G        341M         15G
    Active iob-Instances:   1
            16384 M total memory
              326 M used memory
              195 M active memory
              695 M inactive memory
            15196 M free memory
                0 M buffer memory
              861 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 20:45:37 up 3 days,  4:58,  2 users,  load average: 0.68, 1.93, 3.33
    Tasks:  33 total,   1 running,  32 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  16384.0 total,  15194.2 free,    327.8 used,    862.0 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.  16056.2 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
    * iobroker.service        loaded failed failed ioBroker Server
    3 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0 ext4       30G   15G   14G  52% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                            tmpfs     6.3G  108K  6.3G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1001
    tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/0
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
    /var:
    1.8G    /var/
    1.4G    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
    1.4G    /var/log
    247M    /var/lib
    Archived and active journals take up 176.4M in the file system.
    /opt/iobroker/backups:
    88M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.7G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/files
    456M    /opt/iobroker/iobroker-data/backup-objects
    194M    /opt/iobroker/iobroker-data/files/vis-2
    168M    /opt/iobroker/iobroker-data/files/vis
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    28M     /opt/iobroker/iobroker-data/states.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.2-1nodesource1
      Version table:
         20.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
     *** 20.18.1-1nodesource1 1001
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 685)
    pi-iobroker         pi-iobroker (version: 7.0.6, hostname: pi-iobroker   , dead, uptime: 332757)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.19
    javascript:     8.9.1
    nodejs modules from github:     1
    +-- iobroker.smartstate@0.0.4 (git+ssh://git@github.com/ChriD/ioBroker.smartstate.git#aa448478fd656fff055532b33decd1138d9222e3)
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : pi-iobroker                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
      system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
      system.adapter.enocean.0                : enocean               : pi-iobroker                              -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.frigate.0                : frigate               : iobroker                                 -  enabled
      system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
      system.adapter.habpanel.0               : habpanel              : iobroker                                 -  enabled
      system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
      system.adapter.history.0                : history               : iobroker                                 - disabled
      system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
      system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
      system.adapter.javascript.2             : javascript            : iobroker                                 -  enabled
      system.adapter.js2fs.0                  : js2fs                 : iobroker                                 - disabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
      system.adapter.matter.0                 : matter                : iobroker                                 - disabled
      system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled
      system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.4                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.5                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.6                 : modbus                : iobroker                                 - disabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
      system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobroker                                 - disabled
      system.adapter.nut.0                    : nut                   : iobroker                                 - disabled
      system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
      system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
      system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
      system.adapter.semp.0                   : semp                  : iobroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.18
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8091, bind: 192.168.178.18, run as: admin
      system.adapter.smartmeter.0             : smartmeter            : pi-iobroker                              -  enabled
      system.adapter.smartstate.0             : smartstate            : iobroker                                 - disabled
      system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 192.168.178.18, run as: admin
      system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
      system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 192.168.178.18
      system.adapter.tr-064.0                 : tr-064                : pi-iobroker                              - disabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
      system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
      system.adapter.web.3                    : web                   : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      system.adapter.yahka.1                  : yahka                 : iobroker                                 -  enabled
      system.adapter.yahka.2                  : yahka                 : iobroker                                 -  enabled
      system.adapter.yahka.3                  : yahka                 : iobroker                                 -  enabled
      system.adapter.yahka.4                  : yahka                 : iobroker                                 -  enabled
      system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'Test'             │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    Active repo(s): Beta (latest)
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "admin"        : 7.4.19   , installed 7.4.19
    Adapter    "alarm"        : 3.6.8    , installed 3.6.8
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
    Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "frigate"      : 1.3.1    , installed 1.3.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "hue"          : 3.14.1   , installed 3.14.1
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "javascript"   : 8.9.1    , installed 8.9.1
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "matter"       : 0.4.13   , installed 0.4.13
    Adapter    "mercedesme"   : 0.3.4    , installed 0.3.4
    Adapter    "modbus"       : 6.4.0    , installed 6.4.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "reolink"      : 1.1.2    , installed 1.1.2
    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "semp"         : 1.4.8    , installed 1.4.8
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "shuttercontrol": 1.8.8   , installed 1.8.8
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 4.0.0    , installed 4.0.0
    Adapter    "trashschedule": 4.0.0    , installed 4.0.0
    Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
    Adapter    "vis-2-widgets-collection": 1.1.13, installed 1.1.12 [Updatable]
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.3.1    , installed 6.3.1
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "yahka"        : 1.0.9    , installed 1.0.9
    Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        42329
    States:         37044
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 9
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10385      175/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          11276      323/master
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          11277      323/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          10387      175/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          9393       82/dhclient
    2025-02-04 20:40:00.933  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null ()
    2025-02-04 20:40:00.974  - warn: host.iobroker instance system.adapter.hass.0 terminated due to SIGKILL
    2025-02-04 20:40:00.974  - info: host.iobroker instance system.adapter.hass.0 terminated with code null ()
    2025-02-04 20:40:01.022  - warn: host.iobroker instance system.adapter.modbus.4 terminated due to SIGKILL
    2025-02-04 20:40:01.023  - info: host.iobroker instance system.adapter.modbus.4 terminated with code null ()
    2025-02-04 20:40:01.070  - warn: host.iobroker instance system.adapter.simple-api.0 terminated due to SIGKILL
    2025-02-04 20:40:01.070  - info: host.iobroker instance system.adapter.simple-api.0 terminated with code null ()
    2025-02-04 20:40:01.118  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
    2025-02-04 20:40:01.118  - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
    2025-02-04 20:40:01.162  - warn: host.iobroker instance system.adapter.linux-control.0 terminated due to SIGKILL
    2025-02-04 20:40:01.162  - info: host.iobroker instance system.adapter.linux-control.0 terminated with code null ()
    2025-02-04 20:40:01.206  - warn: host.iobroker instance system.adapter.web.1 terminated due to SIGKILL
    2025-02-04 20:40:01.206  - info: host.iobroker instance system.adapter.web.1 terminated with code null ()
    2025-02-04 20:40:01.247  - warn: host.iobroker instance system.adapter.web.2 terminated due to SIGKILL
    2025-02-04 20:40:01.247  - info: host.iobroker instance system.adapter.web.2 terminated with code null ()
    2025-02-04 20:40:01.294  - warn: host.iobroker instance system.adapter.web.3 terminated due to SIGKILL
    2025-02-04 20:40:01.294  - info: host.iobroker instance system.adapter.web.3 terminated with code null ()
    2025-02-04 20:40:01.337  - warn: host.iobroker instance system.adapter.vis-2.0 terminated due to SIGKILL
    2025-02-04 20:40:01.337  - info: host.iobroker instance system.adapter.vis-2.0 terminated with code null ()
    2025-02-04 20:40:01.380  - warn: host.iobroker instance system.adapter.pushover.0 terminated due to SIGKILL
    2025-02-04 20:40:01.380  - info: host.iobroker instance system.adapter.pushover.0 terminated with code null ()
    2025-02-04 20:40:01.427  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
    2025-02-04 20:40:01.471  - info: host.iobroker instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
    2025-02-04 20:40:01.471  - info: host.iobroker All instances are stopped.
    2025-02-04 20:40:01.495  - info: host.iobroker terminated
    Gucke ich falsch oder wo ist die Platte voll?
    Vielleicht saß ich auch heute schon zu lange im Auto und habe jetzt Tomaten auf den Augen.
    Bitte erleuchtet mich.
    EDIT: Warum sagt das Diag script das hier:
    Obwohl der fix vorher lief und ich auf dem Server noch nie was Graphisches hatte?
    EDIT2 : habe ja noch einen Slave dran hängen aber selbst auf dem ist aus meiner Sicht noch Platz:
    pi@pi-iobroker:~ $ df -h
    /dev/root       7.1G  5.8G  939M  87% /
    devtmpfs        324M     0  324M   0% /dev
    tmpfs           454M     0  454M   0% /dev/shm
    tmpfs           182M  1.1M  181M   1% /run
    tmpfs           5.0M   12K  5.0M   1% /run/lock
    /dev/mmcblk0p1  253M   44M  209M  18% /boot/firmware
    tmpfs            91M     0   91M   0% /run/user/1000
    pi@pi-iobroker:~ $
    • wendy2702W wendy2702
      Iob Diag:
      Script v.2025-02-02
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      mirko
      HOME=/home/mirko
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:             0B          0B          0B
      Total:           17G        341M         15G
                326 M used memory
                195 M active memory
              15196 M free memory
                  0 M buffer memory
                861 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      1.8G    /var/
      1.4G    /var/log
      247M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.4.19
      javascript:     8.9.1
      Adapter State
      + instance is alive
      Objects and States
      Objects:        42329
      States:         37044
      Pending Updates: 9
      pi@pi-iobroker:~ $
      @wendy2702 sagte in IOB Proxmox CT No Space left on device.. aber wo?:
      Der Fixer sollte dir anbieten, das Boottarget auf multi-user zu bringen.
        wendy2702W Online
        wendy2702W Online
        wendy2702
        @thomas-braun moin,
        Der fixer lief so durch.
        Keine Abfrage oder Ähnliches.
        Hast du eventuell noch ne Idee wegen dem Hauptproblem?
          @thomas-braun moin,
          Vielleicht auf dem LXC-Host?
            wendy2702W Online
            wendy2702W Online
            wendy2702
            @thomas-braun den hatte ich auch schon in Verdacht aber nix gesehen.
            df -h
            tmpfs                                                 3.2G  3.4M  3.1G   1% /run
            /dev/mapper/pve-root                                   94G   56G   34G  63% /
            tmpfs                                                  16G   37M   16G   1% /dev/shm
            efivarfs                                              128K   60K   64K  49% /sys/firmware/efi/efivars
            /dev/sda2                                             511M  336K  511M   1% /boot/efi
            Nextcloud                                             1.5T  128K  1.5T   1% /Nextcloud
            Nextcloud/subvol-111-disk-0                           1.8T  288G  1.5T  17% /Nextcloud/subvol-111-disk-0
            Motioneye                                             2.0T  128K  2.0T   1% /Motioneye
            Motioneye/subvol-110-disk-1                           2.0T  128K  2.0T   1% /Motioneye/subvol-110-disk-1
            Motioneye/subvol-110-disk-2                           3.6T  1.6T  2.0T  44% /Motioneye/subvol-110-disk-2
            Motioneye/subvol-110-disk-0                           2.0T  128K  2.0T   1% /Motioneye/subvol-110-disk-0
            Motioneye/subvol-109-disk-0                           8.0G  4.7G  3.4G  59% /Motioneye/subvol-109-disk-0
            /dev/fuse                                             128M   20K  128M   1% /etc/pve
            //192.168.2.1/FRITZ.NAS/ICY_DISK1/proxmox_backups_56  5.5T  1.9T  3.7T  33% /mnt/pve/NAS_1
              df -h
              @wendy2702
              Swap: 0B 0B 0B
              Richte mal ein SWAP ein.
