  4. Gelöst: Cannot resolve adapter class
12 Beiträge 3 Kommentatoren 1.0k Aufrufe 2 Beobachtet
    Smartin
    schrieb am zuletzt editiert von Smartin
    Moin,
    ich hatte heute morgen einen Stromausfall, seitdem kommt ioBroker nicht mehr auf die Füße
    host.iobroker1  2025-02-03 18:22:30.037	error	instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker1  2025-02-03 18:22:30.036	error	Caught by controller[0]: Node.js v20.18.2
    host.iobroker1  2025-02-03 18:22:30.034	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
    host.iobroker1  2025-02-03 18:22:30.036	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
    host.iobroker1  2025-02-03 18:22:30.035	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:36:21)
    host.iobroker1  2025-02-03 18:22:30.035	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.iobroker1  2025-02-03 18:22:30.034	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
    host.iobroker1  2025-02-03 18:22:30.033	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
    host.iobroker1  2025-02-03 18:22:30.032	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
    host.iobroker1  2025-02-03 18:22:30.031	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
    host.iobroker1  2025-02-03 18:22:30.031	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:101:17)
    host.iobroker1  2025-02-03 18:22:30.030	error	Caught by controller[0]: at resolveAdapterConstructor (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96:9)
    host.iobroker1  2025-02-03 18:22:30.030	error	Caught by controller[0]: Error: Cannot resolve adapter class
    host.iobroker1  2025-02-03 18:22:30.029	error	Caught by controller[0]: ^
    host.iobroker1  2025-02-03 18:22:30.028	error	Caught by controller[0]: throw new Error("Cannot resolve adapter class");
    host.iobroker1  2025-02-03 18:22:30.027	error	Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96
    Stand der Installation war alles aktuell (stable)
    node v20.18.2
    npm 10.8.2
    Probiert habe ich unter /opt/iobroker :
    • iob fix
    • iob upload all
    • npm cache clean --force
    • npm install iobroker --unsafe-perm
    Lief alles ohne Fehler durch, hat aber nichts am Fehler verändert. Waren eh nur hilflose Versuche mit fehlendem Fachwissen es selbst hinzubiegen 😊
    Irgendeine Datei vermutlich zerschossen. Weiß jemand wo ich da ansetzen kann?
    Gruß aus dem hohen Norden
    • AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @smartin ich fürchte du musst das Dateisystem überprüfen (lassen). Da wird beim Stromausfall was kaputt gegangen sein.
      A.
      • AsgothianA Asgothian
        A.
        Smartin
        @asgothian
        Danke für die schnelle Antwort,
        Wie überprüft man denn das Dateisystem?
        • S Smartin
          @asgothian
          @smartin das würde u.a. auch in iob diag enthalten sein.
            Smartin
            Sieht für mich erst einmal ohne Fehler aus, außer die Logzeilen am Ende mit der o.a. Fehlermeldung
            Script v.2025-02-02
            *** BASE SYSTEM ***
             Static hostname: iobroker1
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 12 (bookworm)
                      Kernel: Linux 6.6.74+rpt-rpi-v7
                Architecture: arm
            OS is similar to: debian
            Model           : Raspberry Pi 3 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : 32 bit
            Systemuptime and Load:
             19:52:59 up 19 min,  2 users,  load average: 0.23, 0.46, 0.34
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Mon 2025-02-03 19:53:00 CET
                       Universal time: Mon 2025-02-03 18:53:00 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            965M        258M        469M        5.7M        297M        707M
            Swap:           536M          0B        536M
            Total:          1.5G        258M        1.0G
            Active iob-Instances:   3
                      920 M total memory
                      246 M used memory
                      307 M active memory
                      107 M inactive memory
                      447 M free memory
                       40 M buffer memory
                      243 M swap cache
                      511 M total swap
                        0 M used swap
                      511 M free swap
            top - 19:53:00 up 19 min,  2 users,  load average: 0.23, 0.46, 0.34
            Tasks: 163 total,   1 running, 162 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  9.1 us, 18.2 sy,  0.0 ni, 63.6 id,  9.1 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :    920.9 total,    447.6 free,    246.2 used,    284.3 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.    674.7 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            Filesystem              Type      Size  Used Avail Use% Mounted on
            udev                    devtmpfs  329M     0  329M   0% /dev
            tmpfs                   tmpfs      93M  1.9M   91M   3% /run
            /dev/mmcblk0p2          ext4       15G  7.9G  5.6G  59% /
            tmpfs                   tmpfs     461M  1.3M  460M   1% /dev/shm
            tmpfs                   tmpfs     5.0M     0  5.0M   0% /run/lock
            /dev/mmcblk0p1          vfat      510M   79M  432M  16% /boot/firmware
            //192.168.1.1/fritz.nas cifs      458G  254G  204G  56% /media/fritz.nas
            tmpfs                   tmpfs      93M     0   93M   0% /run/user/1000
            [Mon Feb  3 19:33:25 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=0 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6199e680-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
            [Mon Feb  3 19:33:29 2025] EXT4-fs (mmcblk0p2): mounted filesystem bb15c8e6-d999-4838-be67-5ff200bffa46 ro with ordered data mode. Quota mode: none.
            [Mon Feb  3 19:33:33 2025] EXT4-fs (mmcblk0p2): re-mounted bb15c8e6-d999-4838-be67-5ff200bffa46 r/w. Quota mode: none.
            Show mounted filesystems:
            TARGET             SOURCE                  FSTYPE OPTIONS
            /                  /dev/mmcblk0p2          ext4   rw,noatime,commit=600
            |-/boot/firmware   /dev/mmcblk0p1          vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            `-/media/fritz.nas //192.168.1.1/fritz.nas cifs   rw,relatime,vers=3.1.1,cache=strict,username=raspi,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.1.1,file_mode=0755,dir_mode=0777,soft,nounix,mapposix,reparse=nfs,rsize=65536,wsize=65536,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
            /var:
            1.8G    /var/
            863M    /var/log
            824M    /var/log/journal/e80e6ab5978f473dbaef10c423ba5a67
            263M    /var/cache
            Journal file /var/log/journal/e80e6ab5978f473dbaef10c423ba5a67/user-1001@00062b82f9201301-c7d1c5c8c6b60dfe.journal~ is truncated, ignoring file.
            Archived and active journals take up 823.0M in the file system.
            /opt/iobroker/backups:
            70M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.1G    /opt/iobroker/iobroker-data/
            970M    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            29M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.2
            /usr/bin/node           v20.18.2
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.29.4
            nodejs:
              Installed: 20.18.2-1nodesource1
              Candidate: 20.18.2-1nodesource1
              Version table:
             *** 20.18.2-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                    100 /var/lib/dpkg/status
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2+rpi1 500
                    500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker1           iobroker1 (version: 7.0.6, hostname: iobroker1     , alive, uptime: 1159)
            iobroker2           iobroker2 (version: 4.0.24, hostname: iobroker2     , alive, uptime: 1151)
            iobroker3           iobroker3 (version: 7.0.3, hostname: iobroker3     , dead, uptime: 51222)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.4.10
            javascript:     8.8.3
            nodejs modules from github:     0
            Adapter State
              system.adapter.admin.0                  : admin                 : iobroker1                                -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.admin.2                  : admin                 : iobroker2                                -  enabled, compact enabled (group 1), port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.backitup.0               : backitup              : iobroker1                                - disabled, compact disabled
              system.adapter.backitup.1               : backitup              : iobroker3                                - disabled, compact disabled
              system.adapter.ble.0                    : ble                   : iobroker1                                - disabled
            + system.adapter.ble.1                    : ble                   : iobroker2                                -  enabled
              system.adapter.ble.2                    : ble                   : iobroker3                                - disabled
              system.adapter.devices.1                : devices               : iobroker1                                - disabled
              system.adapter.feiertage.0              : feiertage             : iobroker2                                -  enabled, compact enabled (group 5)
              system.adapter.flot.0                   : flot                  : iobroker1                                - disabled
              system.adapter.fritzdect.1              : fritzdect             : iobroker1                                - disabled, compact enabled (group 6)
              system.adapter.history.0                : history               : iobroker1                                - disabled, compact disabled
              system.adapter.iot.0                    : iot                   : iobroker1                                - disabled, compact disabled
              system.adapter.javascript.0             : javascript            : iobroker1                                - disabled, compact disabled
              system.adapter.logparser.0              : logparser             : iobroker1                                - disabled, compact enabled (group 3)
              system.adapter.luftdaten.0              : luftdaten             : iobroker1                                - disabled, compact enabled (group 3)
              system.adapter.luftdaten.1              : luftdaten             : iobroker1                                - disabled, compact enabled (group 3)
              system.adapter.parser.0                 : parser                : iobroker1                                - disabled, compact disabled
              system.adapter.ping.0                   : ping                  : iobroker1                                - disabled, compact enabled (group 3)
              system.adapter.simple-api.0             : simple-api            : iobroker1                                - disabled, compact enabled (group 0), port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.socketio.0               : socketio              : iobroker1                                - disabled, compact enabled (group 2), port: 8084, bind: 0.0.0.0, run as: admin
              system.adapter.sonoff.0                 : sonoff                : iobroker1                                - disabled, compact enabled (group 5), port: 1883, bind: 0.0.0.0
              system.adapter.telegram.0               : telegram              : iobroker1                                - disabled, compact enabled (group 3), port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0           : text2command          : iobroker1                                - disabled, compact enabled (group 0)
              system.adapter.tr-064.0                 : tr-064                : iobroker1                                - disabled, compact enabled (group 6)
              system.adapter.tuya.0                   : tuya                  : iobroker1                                - disabled, compact enabled (group 6)
              system.adapter.vis.0                    : vis                   : iobroker1                                - disabled, compact disabled
              system.adapter.web.0                    : web                   : iobroker1                                - disabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.yeelight-2.0             : yeelight-2            : iobroker1                                - disabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.4.10   , installed 7.4.10
            Adapter    "backitup"     : 3.0.31   , installed 3.0.31
            Adapter    "ble"          : 0.14.0   , installed 0.14.0
            Adapter    "devices"      : 1.1.5    , installed 1.1.5
            Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "logparser"    : 2.2.2    , installed 2.2.2
            Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
            Adapter    "parser"       : 2.2.4    , installed 2.2.2  [Updatable]
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
            Adapter    "telegram"     : 4.0.0    , installed 4.0.0
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
            Objects and States
            Objects:        6094
            States:         5461
            W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
            Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
            Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6163       658/smbd
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          5827       646/lighttpd
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2916       485/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        5752       582/pihole-FTL
            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6162       658/smbd
            tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        5758       582/pihole-FTL
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       868        477/iobroker.js-con
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       875        477/iobroker.js-con
            tcp6       0      0 :::139                  :::*                    LISTEN      0          6161       658/smbd
            tcp6       0      0 :::80                   :::*                    LISTEN      0          5826       646/lighttpd
            tcp6       0      0 ::1:4711                :::*                    LISTEN      999        5759       582/pihole-FTL
            tcp6       0      0 :::22                   :::*                    LISTEN      0          2918       485/sshd: /usr/sbin
            tcp6       0      0 :::53                   :::*                    LISTEN      999        5754       582/pihole-FTL
            tcp6       0      0 :::445                  :::*                    LISTEN      0          6160       658/smbd
            udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        5751       582/pihole-FTL
            udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          776        652/nmbd
            udp        0      0 192.168.1.30:137        0.0.0.0:*                           0          775        652/nmbd
            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          3026       652/nmbd
            udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          778        652/nmbd
            udp        0      0 192.168.1.30:138        0.0.0.0:*                           0          777        652/nmbd
            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          3027       652/nmbd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2866       399/avahi-daemon: r
            udp        0      0 0.0.0.0:49089           0.0.0.0:*                           104        2868       399/avahi-daemon: r
            udp6       0      0 fe80::fbb1:bcbf:a4a:546 :::*                                0          710        447/NetworkManager
            udp6       0      0 :::53                   :::*                                999        5753       582/pihole-FTL
            udp6       0      0 :::55370                :::*                                104        2869       399/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                104        2867       399/avahi-daemon: r
            2025-02-03 19:53:44.128  - error: host.iobroker1 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            2025-02-03 19:53:44.129  - error: host.iobroker1 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
            2025-02-03 19:53:44.129  - error: host.iobroker1 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
            2025-02-03 19:53:44.130  - error: host.iobroker1 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
            2025-02-03 19:53:44.130  - error: host.iobroker1 Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
            2025-02-03 19:53:44.130  - error: host.iobroker1 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:36:21)
            2025-02-03 19:53:44.131  - error: host.iobroker1 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
            2025-02-03 19:53:44.131  - error: host.iobroker1 Caught by controller[0]: Node.js v20.18.2
            2025-02-03 19:53:44.132  - error: host.iobroker1 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2025-02-03 19:54:18.870  - error: host.iobroker1 Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96
            2025-02-03 19:54:18.872  - error: host.iobroker1 Caught by controller[0]:   throw new Error("Cannot resolve adapter class");
            2025-02-03 19:54:18.873  - error: host.iobroker1 Caught by controller[0]:   ^
            2025-02-03 19:54:18.873  - error: host.iobroker1 Caught by controller[0]: Error: Cannot resolve adapter class
            2025-02-03 19:54:18.874  - error: host.iobroker1 Caught by controller[0]:     at resolveAdapterConstructor (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96:9)
            2025-02-03 19:54:18.874  - error: host.iobroker1 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:101:17)
            2025-02-03 19:54:18.882  - error: host.iobroker1 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
            2025-02-03 19:54:18.883  - error: host.iobroker1 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            2025-02-03 19:54:18.883  - error: host.iobroker1 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
            2025-02-03 19:54:18.884  - error: host.iobroker1 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
            2025-02-03 19:54:18.884  - error: host.iobroker1 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
            2025-02-03 19:54:18.884  - error: host.iobroker1 Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
            2025-02-03 19:54:18.885  - error: host.iobroker1 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:36:21)
            2025-02-03 19:54:18.885  - error: host.iobroker1 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
            2025-02-03 19:54:18.885  - error: host.iobroker1 Caught by controller[0]: Node.js v20.18.2
            2025-02-03 19:54:18.886  - error: host.iobroker1 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            Der RasPi selbst läuft auch, ist per SSH ansprechbar, Pi-Hole läuft auch ganz normal.
            • S Smartin
              Script v.2025-02-02
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
              Docker          : false
              Kernel          : armv7l
              Userland        : 32 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           536M          0B        536M
                        920 M total memory
                        246 M used memory
                        307 M active memory
                        447 M free memory
                         40 M buffer memory
                        243 M swap cache
                        511 M total swap
                          0 M used swap
                        511 M free swap
              *** FILESYSTEM ***
              /var:
              1.8G    /var/
              863M    /var/log
              263M    /var/cache
              USB-Devices by-id:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.4.10
              javascript:     8.8.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        6094
              States:         5461
              Pending Updates: 0
              @smartin sagte in Cannot resolve adapter class:
              ja, die befürchteten orphans sehe ich auch nicht.
              Wenn diese nicht Mittlerweile aus der logrotation verschwunden sind.
              Du kannst natürlich versuchen den Controller noch mal drüberzuinstallieren, leider fällt mir gerade der Befehl nicht ein.
                Smartin
                ich kenne dafür nur
                npm i iobroker.js-controller
                Damit eben probiert, keine Änderung 😞
                • S Smartin
                  ich kenne dafür nur
                  ich kenne dafür nur
                  nee, nicht mit npm rumhantieren!
                  war irgendwas wie iob upgrade js-controller@version und dann noch ein --Parameter
                    Smartin
                    @homoran sagte in Cannot resolve adapter class:
                    Ich finde da tatsächlich nur
                    npm install iobroker.js-controller@version --omit=dev
                    in einem Post von @Thomas-Braun vom 29.11.2024.
                    https://forum.iobroker.net/topic/46498/test-adapter-lg-thinq/706?lang=en-GB#
                    Mit iob upgrade js-controller* finde ich nix
                    • S Smartin
                      @smartin das jönnte es tatsächlich sein, aber npm Befehle müssen unbedingt im richtigen Verzeichnis ausgeführt werden.
                        Smartin
                        Super! Das war es! 👍
                        Habe mit
                        npm install iobroker.js-controller@7.0.5 --omit=dev
                        eine Version runter, dann mit
                        npm install iobroker.js-controller@7.0.6 --omit=dev
                        wieder auf den aktuellen Stand installiert. Nach Neustart des RasPi ist das Admin-GUI wieder ansprechbar, alle Scripte wieder am Start, keine Fehler mehr.
                        Vielen Dank! You made my day!
                        • S Smartin
                          Habe mit
                          Smartin
                          Halt, doch noch Fragen dazu ... nur um für ein nächstes Mal Stromausfall vlt. besser vorbereitet zu sein ...
                          Gibt es Empfehlungen für eine kleine USV für den Raspberry?
                          Und falls ja, gibt es dafür Workarounds, dass die USV kurz den Strom des Raspberry bei einem Ausfall übernimmt und durch irgendeinen Impuls ihn sauber herunterfährt? Dafür braucht es doch sicher keine riesigen Akkus dann.
