  4. ESPhome 0.5.0. Beta 8 Fehlermeldung
9 Beiträge 4 Kommentatoren 1.0k Aufrufe 4 Beobachtet
  • RaspiUserR Offline
    RaspiUserR Offline
    RaspiUser
    ... wegen "Nice to have" habe ich den ESPhome Adapter (Beta Repro) installiert und bekomme nach dem connecten eines ESP8266 mini im ESPhome Dashboard diese Fehlermeldung:
    INFO ESPHome 2024.8.3
    INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-6c16ca.yaml...
    Failed config
    esphome: None
      friendly_name: ESPHome Web 6c16ca
      Your ESPHome version is too old. Please update to at least 2024.11.0.
      min_version: 2024.11.0
      name_add_mac_suffix: False
      build_path: build/esphome-web-6c16ca
    Da ich nix durch try&error kaputt machen möchte (Su.fu. brachte mir keine konkreten ToDo's) frage ich hier lieber nach ...
    Hier noch die iob diag Abfrage, die wohl alle Fragen zum System beantworten sollte.
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: VM-ioBroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-29-amd64
        Architecture: x86-64
     Hardware Vendor: qemu
      Hardware Model: qemu
    Firmware Version: e0d6339-dirty-20220919_024111-d528eb931742
    OS is similar to:
    model name      : Westmere E56xx/L56xx/X56xx (Nehalem-C)
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:42:33 up 4 days,  1:54,  2 users,  load average: 0.52, 0.27, 0.15
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-01-28 11:42:33 CET
               Universal time: Tue 2025-01-28 10:42:33 UTC
                     RTC time: Tue 2025-01-28 10:42:33
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    raspiuser
    HOME=/home/raspiuser
    GROUPS=raspiuser adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev users netdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.3G        2.6G        4.3G        602K        1.8G        5.7G
    Swap:           1.0G          0B        1.0G
    Total:          9.3G        2.6G        5.3G
    Active iob-Instances:   29
             7940 M total memory
             2462 M used memory
              724 M active memory
             2862 M inactive memory
             4054 M free memory
              240 M buffer memory
             1462 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 11:42:33 up 4 days,  1:54,  2 users,  load average: 0.52, 0.27, 0.15
    Tasks: 142 total,   1 running, 141 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7940.7 total,   4054.2 free,   2462.0 used,   1702.7 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.   5478.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  588K  794M   1% /run
    /dev/sda1      ext4       48G  9.4G   37G  21% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     795M     0  795M   0% /run/user/1001
    [Fri Jan 24 09:48:24 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jan 24 09:48:25 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.7G    /var/
    1015M   /var/log
    1001M   /var/log/journal/27bb2095ba2b41ccb088ec3ad41fc1f5
    544M    /var/cache
    Archived and active journals take up 1000.0M in the file system.
    /opt/iobroker/backups:
    20M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    882M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c421aa81b69ded118718d3a5a7669f5d-if00-port0
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.2
    /usr/bin/node           v20.18.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.2-1nodesource1
      Candidate: 20.18.2-1nodesource1
      Version table:
     *** 20.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    VM-ioBroker         VM-ioBroker (version: 7.0.6, hostname: VM-ioBroker   , alive, uptime: 152917)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     1
    +-- iobroker.canbus@2.1.0 (git+ssh://git@github.com/crycode-de/ioBroker.canbus.git#27e0b1c58cf5ca0ff8668c10a5e34d5c6670f921)
    Adapter State
    + system.adapter.admin.0                  : admin                 : VM-ioBroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alpha-ess.0              : alpha-ess             : VM-ioBroker                              -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : VM-ioBroker                              -  enabled
      system.adapter.awtrix-light.1           : awtrix-light          : VM-ioBroker                              - disabled
    + system.adapter.backitup.0               : backitup              : VM-ioBroker                              -  enabled
    + system.adapter.canbus.0                 : canbus                : VM-ioBroker                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : VM-ioBroker                              -  enabled
    + system.adapter.discovery.0              : discovery             : VM-ioBroker                              -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: VM-ioBroker                              - disabled
    + system.adapter.esphome.0                : esphome               : VM-ioBroker                              -  enabled
      system.adapter.feiertage.0              : feiertage             : VM-ioBroker                              -  enabled
    + system.adapter.frontier_silicon.0       : frontier_silicon      : VM-ioBroker                              -  enabled
    + system.adapter.go-e.0                   : go-e                  : VM-ioBroker                              -  enabled
      system.adapter.history.0                : history               : VM-ioBroker                              - disabled
    + system.adapter.hm-rega.0                : hm-rega               : VM-ioBroker                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : VM-ioBroker                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : VM-ioBroker                              -  enabled, port: 0
      system.adapter.influxdb.0               : influxdb              : VM-ioBroker                              - disabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : VM-ioBroker                              -  enabled
    + system.adapter.javascript.0             : javascript            : VM-ioBroker                              -  enabled
    + system.adapter.klf200.0                 : klf200                : VM-ioBroker                              -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : VM-ioBroker                              -  enabled
      system.adapter.luftdaten.0              : luftdaten             : VM-ioBroker                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : VM-ioBroker                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.onkyo.0                  : onkyo                 : VM-ioBroker                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : VM-ioBroker                              - disabled
    + system.adapter.sainlogic.0              : sainlogic             : VM-ioBroker                              -  enabled, port: 1030, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : VM-ioBroker                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : VM-ioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : VM-ioBroker                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : VM-ioBroker                              -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : VM-ioBroker                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : VM-ioBroker                              -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : VM-ioBroker                              -  enabled
    + system.adapter.web.0                    : web                   : VM-ioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : VM-ioBroker                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c421aa81b69ded118718d3a5a7669f5d-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "alpha-ess"    : 3.0.1    , installed 3.0.1
    Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "canbus"       : 1.3.1    , installed 2.1.0
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
    Adapter    "go-e"         : 1.0.41   , installed 1.0.41
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "klf200"       : 1.3.5    , installed 1.3.5
    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
    Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "sainlogic"    : 0.11.6   , installed 0.11.6
    Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
    Objects and States
    Objects:        6862
    States:         5183
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.120:42010   0.0.0.0:*               LISTEN      1000       200357     17376/io.hm-rpc.1
    tcp        0      0 192.168.178.120:42001   0.0.0.0:*               LISTEN      1000       200352     17361/io.hm-rpc.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       198354     17150/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       198359     17150/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2723       531/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14540      1/init
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       323902     21243/python3
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       201729     17406/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       200428     17451/io.sonoff.0
    tcp        0      0 0.0.0.0:1030            0.0.0.0:*               LISTEN      1000       333928     22451/io.sainlogic.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       202877     17574/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       198439     17171/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       200958     17589/io.simple-api
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15422      531/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          2301       1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       323903     21190/io.esphome.0
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       323024     21243/python3
    udp        0      0 192.168.178.120:5353    0.0.0.0:*                           1000       323023     21243/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       323019     21243/python3
    udp        0      0 0.0.0.0:20000           0.0.0.0:*                           65534      17242      594/cannelloni
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15148      384/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1505       1/init
    udp6       0      0 :::111                  :::*                                0          14128      1/init
    2025-01-28 11:41:24.837  - info: host.VM-ioBroker iobroker NPM version: 10.8.2Installing iobroker.sainlogic@0.11.6... (System call)
    2025-01-28 11:41:29.312  - info: host.VM-ioBroker iobroker changed 1 package in 4s
    2025-01-28 11:41:29.313  - info: host.VM-ioBroker iobroker
    2025-01-28 11:41:29.319  - info: host.VM-ioBroker iobroker 168 packages are looking for funding  run `npm fund` for details
    2025-01-28 11:41:29.362  - info: host.VM-ioBroker iobroker Updating objects from io-package.json for adapter "sainlogic" with version "0.11.6"
    2025-01-28 11:41:29.426  - info: host.VM-ioBroker iobroker Update "system.adapter.sainlogic.0"
    2025-01-28 11:41:29.437  - info: host.VM-ioBroker stopInstance system.adapter.sainlogic.0 (force=false, process=true)
    2025-01-28 11:41:29.442  - info: sainlogic.0 (17542) Got terminate signal TERMINATE_YOURSELF
    2025-01-28 11:41:29.445  - info: sainlogic.0 (17542) Sainlogic Adapter gracefully shut down...
    2025-01-28 11:41:29.446  - info: sainlogic.0 (17542) terminating
    2025-01-28 11:41:29.447  - info: sainlogic.0 (17542) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-01-28 11:41:29.448  - info: sainlogic.0 (17542) Listener closed.
    2025-01-28 11:41:29.494  - info: host.VM-ioBroker stopInstance system.adapter.sainlogic.0 send kill signal
    2025-01-28 11:41:29.580  - info: host.VM-ioBroker iobroker upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
    2025-01-28 11:41:29.609  - info: host.VM-ioBroker iobroker upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
    2025-01-28 11:41:29.617  - info: host.VM-ioBroker iobroker upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
    2025-01-28 11:41:29.634  - info: host.VM-ioBroker iobroker upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
    2025-01-28 11:41:29.643  - info: host.VM-ioBroker iobroker upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
    2025-01-28 11:41:29.948  - info: sainlogic.0 (17542) terminating
    2025-01-28 11:41:30.008  - info: host.VM-ioBroker instance system.adapter.sainlogic.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-28 11:41:30.671  - info: host.VM-ioBroker iobroker exit 0
    2025-01-28 11:41:33.345  - info: host.VM-ioBroker instance system.adapter.sainlogic.0 in version "0.11.6" started with pid 22451
    2025-01-28 11:41:34.859  - info: sainlogic.0 (22451) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v20.18.2, js-controller: 7.0.6
    2025-01-28 11:41:34.880  - info: sainlogic.0 (22451) Starting Listener
    2025-01-28 11:42:20.366  - info: admin.0 (17171) <== Disconnect system.user.admin from ::ffff:192.168.178.95 admin
    Danke für die Hilfestellung ...
    • RaspiUserR RaspiUser
      Failed config
      esphome: None
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      raspiuser
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
               7940 M total memory
               2462 M used memory
                724 M active memory
               4054 M free memory
                240 M buffer memory
               1462 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      1.7G    /var/
      1015M   /var/log
      544M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6862
      States:         5183
      Pending Updates: 0
      @raspiuser sagte in ESPhome 0.5.0. Beta 8 Fehlermeldung:
      Du hast INFO ESPHome 2024.8.3 am Start.
      RaspiUserR 1 Antwort Letzte Antwort
        RaspiUserR Offline
        RaspiUserR Offline
        RaspiUser
        @thomas-braun sagte in ESPhome 0.5.0. Beta 8 Fehlermeldung:
        ... das hatte ich auch gelesen.
        Aber ich finde nix, wie man "Please update to at least 2024.11.0." macht ...
        Im Adapter finde ich nix, auf esphome.io bin ich "überfordert" ...
        Ist das irgend etwas auf LINUX Ebene ?
          Von ESPHome hab ich keine Ahnung.
          Was 'überfordert' dich denn konkret?
            RaspiUserR Offline
            RaspiUserR Offline
            RaspiUser
            ... da sind wir schon zwei ...
            Wenn ich auf esphome.io z.B. nach "2024.11.0" suchen lasse, kriege ich nix, was MIR weiterhilft (bzw. ich verstehe).
            Da derHinweis ja im Adapter auftaucht, hoffe ich auch hier in diesem Forum eine Antwort zu bekommen.
            Ich suche weiter ... es gibt ja auch ESPhome Foren ...
              Mit dem Unterschied, das ich es gar nicht verwende.
              €dit:
              Ist wohl ein pip-Paket und lässt sich entsprechend dann auch per
              pipx install esphome
              installieren/updaten.
                €dit:
                RaspiUserR Offline
                RaspiUserR Offline
                RaspiUser
                schrieb am zuletzt editiert von RaspiUser
                ... und ich es auch nur mal ausprobieren wollte ...
                Danke für den pip-Hinweis ... schau ich mir mal an.
                EDIT:
                • Ich habe mal die Version Beta 10 über Gihub installiert. In den Einstellungen der Instanz wäre es möglich gewesen, die ESPhome Version (also auch 2024.11.0) aus zu wählen oder "always the latest".
                • Bei dieser Version startete das Dasboard aber garnicht, also den Adapter gelöscht und zurück zu 8.
                • ... und zu "pip":
                raspiuser@VM-ioBroker:~$ python3 --version
                Python 3.11.2
                raspiuser@VM-ioBroker:~$ esphome version
                -bash: esphome: Kommando nicht gefunden.
                Also bevor ich jetzt etwas "kaputt" mache, mache ich lieber nix.
                Wenn hier niemand die Lösung hat, gerne her damit ... ansonsten war es das mit "ESPhome ausprobieren" bzw. "nice to have".
                A 1 Antwort Letzte Antwort
                  EDIT:
                  • ... und zu "pip":
                  Python 3.11.2
                  AndreasE112
                  Hi, ich habe den Adapter eben installiert. Er läuft aber das Webinterface geht nicht.
                  In den Adaptereinstellungen sehe ich mein "device".
                  Hat jemand ähnliche Erfahrungen gemacht und evtl. eine Lösung ?
                  Y 1 Antwort Letzte Antwort
                  • A AndreasE112
                    Y Offline
                    Y Offline
                    yettiz
                    @andrease112 said in ESPhome 0.5.0. Beta 8 Fehlermeldung:
                    Hab das selbe Problem allerdings mit ESPHome 2024.10.3
                    Webinterface funktioniert, aber beim Install von dieser kommt die Meldung mit der Version.
                    Finde aber nichts wie man auf ESPHome 2025.02.0. updatet
                    Die Sourcen liegen auf Github von Esphome, aber die Beta ist immer noch bei 8.
                    Würde ESPHome gerne testen/nutzen.
                    Hab sonst Shelly und Tasmota am laufen, Shelly wegen dem EM3 Pro, sonst alles auf Tasmota.
                    Und HA installieren für ESPHome muss nicht sein, HA hatte ich bereits und das taugt mir nicht.
