  4. Systemabsturz nach Raspi updating repository
    1.0k
    6.1k
4 Beiträge 3 Kommentatoren 449 Aufrufe 3 Beobachtet
  • retostoeckliR Offline
    retostoeckli
    Schon 2-3 mal beobachtet. Nach dem Updating des repository schiesst sich das System, respektive so wie ich vermute der Redis Server.
    Danach läuft mal 1-2 Minuten nichts, bis sich das System irgendwie wieder fängt.
    2024-12-28 14:50:24.175 - info: admin.0 (66276) Request actual repository...
    2024-12-28 14:50:24.797 - info: host.raspberrypi4 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2024-12-28 14:50:30.875 - info: admin.0 (66276) Repository received successfully.
    2024-12-28 15:13:57.576 - error: sourceanalytix.0 (66754) States database error: read ECONNRESET
    2024-12-28 15:13:57.648 - error: sprinklecontrol.0 (66773) States database error: write ECONNRESET
    2024-12-28 15:13:57.669 - error: swiss-weather-api.0 (66790) States database error: write ECONNRESET
    2024-12-28 15:13:57.723 - error: broadlink2.0 (66409) States database error: write ECONNRESET
    2024-12-28 15:13:57.732 - error: device-watcher.0 (66449) States database error: write ECONNRESET
    2024-12-28 15:13:57.732 - error: telegram.0 (264790) States database error: read ECONNRESET
    2024-12-28 15:13:57.747 - error: javascript.0 (66332) States database error: write ECONNRESET
    2024-12-28 15:13:57.746 - error: history.0 (66303) States database error: read ECONNRESET
    2024-12-28 15:13:57.735 - error: device-watcher.0 (66449) Objects database error: read ECONNRESET
    2024-12-28 15:13:57.624 - error: echarts.0 (66666) States database error: write ECONNRESET
    2024-12-28 15:13:57.873 - error: chromecast.0 (66428) Wohnzimmer - Error disconnecting - TypeError: Cannot read properties of null (reading 'socket')
    2024-12-28 15:13:57.572 - error: simple-api.0 (66728) States database error: read ECONNRESET
    2024-12-28 15:13:57.626 - error: notification-manager.0 (66494) States database error: write ECONNRESET
    2024-12-28 15:13:57.805 - error: backitup.0 (66394) States database error: write ECONNRESET
    2024-12-28 15:13:57.684 - error: lgtv.0 (67140) States database error: write ECONNRESET
    2024-12-28 15:13:57.722 - error: sainlogic.0 (66709) Objects database error: write EPIPE
    2024-12-28 15:13:58.032 - error: sainlogic.0 (66709) States database error: write ECONNRESET
    2024-12-28 15:13:57.426 - info: harmony.0 (66464) [CONNECT] lost Connection to Harmony Wohnzimmer Hub (192.168.0.43)
    2024-12-28 15:13:58.031 - error: harmony.0 (66464) States database error: write ECONNRESET
    2024-12-28 15:13:57.732 - error: text2command.0 (66835) States database error: write ECONNRESET
    2024-12-28 15:13:57.670 - error: web.0 (66868) States database error: read ECONNRESET
    2024-12-28 15:13:57.883 - error: ping.0 (67117) States database error: write ECONNRESET
    2024-12-28 15:13:57.682 - error: iot.0 (66682) States database error: read ECONNRESET
    2024-12-28 15:03:20.330 - info: mqtt.0 (66479) Client [SL3P_35736FF4] connection closed: timeout
    2024-12-28 15:13:58.197 - error: mqtt.0 (66479) States database error: write ECONNRESET
    2024-12-28 15:13:58.198 - info: mqtt.0 (66479) Client [] connection closed: timeout
    2024-12-28 15:13:58.236 - info: iot.0 (66682) Connection changed: disconnect
    2024-12-28 15:13:58.237 - info: iot.0 (66682) Connection lost
    2024-12-28 15:13:57.936 - error: rest-api.0 (66698) States database error: write ECONNRESET
    2024-12-28 15:13:57.878 - error: tuya.0 (66587) States database error: write EPIPE
    2024-12-28 15:13:58.244 - error: mqtt.0 (66479) Objects database error: read ECONNRESET
    2024-12-28 15:13:58.445 - error: zigbee.0 (284006) States database error: write ECONNRESET
    2024-12-28 15:13:58.424 - error: socketio.0 (66743) States database error: write ECONNRESET
    2024-12-28 15:13:58.582 - error: host.raspberrypi4 States database error: write ECONNRESET
    2024-12-28 15:13:58.638 - error: host.raspberrypi4 Objects database error: read ECONNRESET
    2024-12-28 15:13:58.678 - error: pushover.0 (66349) States database error: write ECONNRESET
    2024-12-28 15:13:58.964 - error: scenes.0 (66360) States database error: write ECONNRESET
    2024-12-28 15:13:58.991 - error: chromecast.0 (66428) States database error: write EPIPE
    2024-12-28 15:13:59.079 - error: dreame.0 (66651) States database error: write ECONNRESET
    2024-12-28 15:13:58.879 - error: rpi2.0 (66529) States database error: read ECONNRESET
    2024-12-28 15:13:59.406 - error: discovery.0 (66631) States database error: write ECONNRESET
    2024-12-28 15:13:59.443 - info: harmony.0 (66464) [CONNECT] Connected to Harmony Wohnzimmer Hub (192.168.0.43)
    2024-12-28 15:13:57.667 - error: shelly.0 (177635) Objects database error: write EPIPE
    2024-12-28 15:13:58.354 - error: shelly.0 (177635) States database error: write EPIPE
    2024-12-28 15:14:00.625 - info: shelly.0 (177635) [MQTT] Client Close: 192.168.0.121 (shellyplus1pm / shellyplus1pm-441793932584 / shellyplus1pm#441793932584#1) (false)
    2024-12-28 15:14:02.661 - info: sprinklecontrol.0 (66773) Objects database successfully reconnected
    2024-12-28 15:14:02.672 - info: sourceanalytix.0 (66754) Objects database successfully reconnected
    2024-12-28 15:14:02.705 - info: swiss-weather-api.0 (66790) Objects database successfully reconnected
    2024-12-28 15:14:02.750 - info: device-watcher.0 (66449) Objects database successfully reconnected
    2024-12-28 15:14:02.751 - info: device-watcher.0 (66449) Objects database successfully reconnected
    Der Redis Server melded jeweils zur gleichen Zeit:
    * redis-server.service - Advanced key-value store
         Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; preset: enabled)
         Active: active (running) since Sat 2024-12-28 15:14:16 CET; 1h 54min ago
           Docs: http://redis.io/documentation,
                 man:redis-server(1)
       Main PID: 287147 (redis-server)
         Status: "Ready to accept connections"
          Tasks: 6 (limit: 3916)
            CPU: 8min 42.178s
         CGroup: /system.slice/redis-server.service
                 `-287147 "/usr/bin/redis-server 127.0.0.1:6379"
    Dec 28 15:13:58 raspberrypi4 systemd[1]: redis-server.service: Main process exited, code=killed, status=9/KILL
    Dec 28 15:13:58 raspberrypi4 systemd[1]: redis-server.service: Failed with result 'signal'.
    Dec 28 15:13:58 raspberrypi4 systemd[1]: redis-server.service: Consumed 1h 42min 12.683s CPU time.
    Dec 28 15:13:59 raspberrypi4 systemd[1]: redis-server.service: Scheduled restart job, restart counter is at 4.
    Dec 28 15:13:59 raspberrypi4 systemd[1]: Stopped redis-server.service - Advanced key-value store.
    Dec 28 15:13:59 raspberrypi4 systemd[1]: redis-server.service: Consumed 1h 42min 12.683s CPU time.
    Dec 28 15:13:59 raspberrypi4 systemd[1]: Starting redis-server.service - Advanced key-value store...
    Dec 28 15:14:16 raspberrypi4 systemd[1]: Started redis-server.service - Advanced key-value store.
    An was kann das liegen?
    Bitte ausfüllen:
    • js-controller Version: 7.0.3
    • Admin Version: 7.1.5
    • Hardwaresystem: Pi4
    • Arbeitsspeicher: 4 GB
    • Festplattenart: SD-Karte,..
    • Betriebssystem: ...
    • Nodejs-Version: .20.18.1
    • NPM-Version: ...10.8.2
    • Installationsart: Skript
    • Image, Docker genutzt: Nein
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: raspberrypi4
           Icon name: computer
              Kernel: Linux 6.6.62+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     17:29:56 up 5 days,  8:18,  2 users,  load average: 0.74, 0.42, 0.43
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2024-12-28 17:29:56 CET
               Universal time: Sat 2024-12-28 16:29:56 UTC
                     RTC time: n/a
                    Time zone: Europe/Zurich (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        3.2G        587M        286K        280M        790M
    Swap:           209M         37M        172M
    Total:          4.2G        3.2G        760M
    Active iob-Instances:   33
             3791 M total memory
             3037 M used memory
             1763 M active memory
             1334 M inactive memory
              560 M free memory
               29 M buffer memory
              238 M swap cache
              199 M total swap
               35 M used swap
              164 M free swap
    top - 17:29:57 up 5 days,  8:18,  2 users,  load average: 0.74, 0.42, 0.43
    Tasks: 198 total,   1 running, 197 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 14.3 us,  0.0 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3791.9 total,    560.5 free,   3037.7 used,    268.1 buff/cache
    MiB Swap:    200.0 total,    164.5 free,     35.4 used.    754.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    1 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       29G  7.9G   20G  29% /
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Dec 23 09:11:12 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A2:09:83 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=e6a5e38d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Dec 23 09:11:15 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
    [Mon Dec 23 09:11:16 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.7G    /var/
    2.1G    /var/lib
    1.9G    /var/lib/redis
    226M    /var/log
    224M    /var/log/journal/1f3048c74be54e7dafe9fd893512ef3a
    Archived and active journals take up 223.7M in the file system.
    /opt/iobroker/backups:
    75M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    196M    /opt/iobroker/iobroker-data/
    129M    /opt/iobroker/iobroker-data/history
    62M     /opt/iobroker/iobroker-data/files
    31M     /opt/iobroker/iobroker-data/files/backitup.admin
    31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
    5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
    5.0M    /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816081001-if00
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: redis
    States  type: redis
    Hosts:
    raspberrypi4        raspberrypi4 (version: 7.0.3, hostname: raspberrypi4  , alive, uptime: 2481)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     3
    +-- iobroker.dreame@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.dreame.git#741b3bc2ab551669c0e4a47ae176967518cfca90)
    +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
    +-- iobroker.sprinklecontrol@0.2.13 (git+ssh://git@github.com/Dirk-Peter-md/ioBroker.sprinklecontrol.git#b9bbf48c1de1215c059d1c653ee5631d448d8cc7)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi4                             -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspberrypi4                             -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : raspberrypi4                             -  enabled
      system.adapter.devices.0                : devices               : raspberrypi4                             - disabled
    + system.adapter.discovery.0              : discovery             : raspberrypi4                             -  enabled
    + system.adapter.dreame.0                 : dreame                : raspberrypi4                             -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi4                             -  enabled
      system.adapter.habpanel.0               : habpanel              : raspberrypi4                             - disabled
    + system.adapter.harmony.0                : harmony               : raspberrypi4                             -  enabled
    + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4                             - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi4                             - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi4                             - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi4                             -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : raspberrypi4                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4                             -  enabled, port: 1883, bind: 192.168.0.54
    + system.adapter.notification-manager.0   : notification-manager  : raspberrypi4                             -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi4                             -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
    + system.adapter.rest-api.0               : rest-api              : raspberrypi4                             -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4                             -  enabled
    + system.adapter.sainlogic.0              : sainlogic             : raspberrypi4                             -  enabled, port: 8099, bind: 0.0.0.0
    + system.adapter.scenes.0                 : scenes                : raspberrypi4                             -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi4                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi4                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : raspberrypi4                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi4                             -  enabled
    + system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi4                             -  enabled
    + system.adapter.swiss-weather-api.0      : swiss-weather-api     : raspberrypi4                             -  enabled
      system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi4                             - disabled
    + system.adapter.telegram.0               : telegram              : raspberrypi4                             -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : raspberrypi4                             -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi4                             -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816081001-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
    Adapter    "lgtv"         : 2.3.1    , installed 2.3.1
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "notification-manager": 1.2.1, installed 1.2.1
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
    Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
    Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
    Adapter    "scenes"       : 3.2.3    , installed 3.0.4  [Updatable]
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "swiss-weather-api": 2.2.2, installed 2.2.2
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "telegram-menu": 2.1.3    , installed 2.1.3
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        12761
    States:         11090
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:6 https://packages.redis.io/deb bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        3555271    287147/redis-server
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       3601926    291083/io.shelly.0
    tcp        0      0 0.0.0.0:8099            0.0.0.0:*               LISTEN      1001       3602063    291221/io.sainlogic
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5657       672/sshd: /usr/sbin
    tcp        0      0 192.168.0.54:1883       0.0.0.0:*               LISTEN      1001       3603771    290989/io.mqtt.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      106        3555272    287147/redis-server
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       3602097    291255/io.socketio.
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       3604724    291240/io.simple-ap
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3600993    290779/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3602244    291376/io.web.0
    tcp6       0      0 :::8093                 :::*                    LISTEN      1001       3603971    291207/io.rest-api.
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5659       672/sshd: /usr/sbin
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       3601824    290974/io.harmony.0
    udp        0      0 0.0.0.0:51697           0.0.0.0:*                           1001       3623456    290925/io.broadlink
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       3604523    291098/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       3604524    291098/io.tuya.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       3601825    290974/io.harmony.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       3603660    290925/io.broadlink
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       3603695    290940/io.chromecas
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6414       540/avahi-daemon: r
    udp        0      0 0.0.0.0:42359           0.0.0.0:*                           1001       3603663    290925/io.broadlink
    udp        0      0 0.0.0.0:52846           0.0.0.0:*                           104        6416       540/avahi-daemon: r
    udp6       0      0 :::37106                :::*                                104        6417       540/avahi-daemon: r
    udp6       0      0 fe80::b666:a771:981:546 :::*                                0          6552       618/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        6415       540/avahi-daemon: r
    2024-12-28 17:11:27.217  - info: admin.0 (290779) ==> Connected system.user.admin from ::ffff:192.168.0.49
    2024-12-28 17:11:31.663  - info: admin.0 (290779) <== Disconnect system.user.admin from ::ffff:192.168.0.49 admin
    2024-12-28 17:13:41.709  - warn: admin.0 (290779) rpi2 has an invalid jsonConfig: [{"instancePath":"/items/_monitoring/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["accordion","alive","autocomplete","autocompleteSendTo","certificate","certificates","checkLicense","checkbox","chips","color","coordinates","cron","custom","datePicker","deviceManager","divider","file","fileSelector","func","header","icon","image","imageSendTo","instance","interface","ip","jsonEditor","language","number","objectId","panel","password","pattern","port","qrCode","room","select","selectSendTo","sendTo","setState","slider","state","staticImage","staticLink","staticText","table","text","textSendTo","timePicker","user","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
    2024-12-28 17:13:53.876  - info: host.raspberrypi4 stopInstance system.adapter.rpi2.0 (force=false, process=true)
    2024-12-28 17:13:53.888  - info: host.raspberrypi4 stopInstance system.adapter.rpi2.0 send kill signal
    2024-12-28 17:13:53.889  - info: rpi2.0 (291039) Got terminate signal TERMINATE_YOURSELF
    2024-12-28 17:13:53.893  - info: rpi2.0 (291039) terminating
    2024-12-28 17:13:53.894  - info: rpi2.0 (291039) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-28 17:13:54.392  - info: rpi2.0 (291039) terminating
    2024-12-28 17:13:54.449  - info: host.raspberrypi4 instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-12-28 17:13:57.932  - info: host.raspberrypi4 instance system.adapter.rpi2.0 in version "2.2.1" started with pid 292378
    2024-12-28 17:14:00.537  - info: rpi2.0 (292378) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
    2024-12-28 17:14:01.027  - info: rpi2.0 (292378) GPIO ports are not configured
    2024-12-28 17:14:45.852  - info: history.0 (290794) enabled logging of rpi2.0.memory.memory_free, Alias=false, WriteNulls=true
    2024-12-28 17:15:53.928  - info: history.0 (290794) enabled logging of rpi2.0.sdcard.sdcard_boot_used, Alias=false, WriteNulls=true
    2024-12-28 17:16:02.572  - warn: zigbee.0 (291437) DeviceAvailability:Failed to ping 0xa4c138b7fd6a2783 TS0505B
    2024-12-28 17:16:09.736  - info: history.0 (290794) enabled logging of rpi2.0.sdcard.sdcard_root_used, Alias=false, WriteNulls=true
    2024-12-28 17:16:21.591  - info: admin.0 (290779) ==> Connected system.user.admin from ::ffff:192.168.0.49
    2024-12-28 17:16:23.478  - info: admin.0 (290779) ==> Connected system.user.admin from ::ffff:192.168.0.49
    2024-12-28 17:17:38.907  - info: admin.0 (290779) <== Disconnect system.user.admin from ::ffff:192.168.0.49 echarts-show
    2024-12-28 17:17:38.914  - info: admin.0 (290779) <== Disconnect system.user.admin from ::ffff:192.168.0.49 echarts
    2024-12-28 17:19:14.992  - info: javascript.0 (290834) script.js.Light.Atrium.Atrium: Atrium On
    2024-12-28 17:26:03.346  - info: broadlink2.0 (290925) interface to be used: { netmaskBits: 24, address: '192.168.0.54/24', addrs: [ 192, 168, 0, 54 ], cidr: '192.168.0.54/24', bcaddr: '192.168.0.255'
    2024-12-28 17:26:03.348  - info: broadlink2.0 (290925) discover  [ '192.168.0.181' ] from 192.168.0.181:51697
    Ro75R Thomas BraunT 2 Antworten Letzte Antwort
    • retostoeckliR retostoeckli
                   man:redis-server(1)
              CPU: 8min 42.178s
      Bitte ausfüllen:
      Script v.2024-10-19
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           209M         37M        172M
               3791 M total memory
               3037 M used memory
                560 M free memory
                 29 M buffer memory
                238 M swap cache
                199 M total swap
                 35 M used swap
                164 M free swap
      *** FILESYSTEM ***
      /var:
      2.7G    /var/
      2.1G    /var/lib
      1.9G    /var/lib/redis
      226M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: redis
      States  type: redis
      Hosts:
      admin:          7.1.5
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        12761
      States:         11090
      Pending Updates: 0
      Ro75R Offline
      Ro75R Offline
      Ro75
      @retostoeckli Redis arbeitet komplett im RAM. Möglicherweise ist dieser dir bei 4GB ausgegangen. Erhöhe SWAP oder ein PI oder anderes Gerät mit mehr RAM oder verzichte auf Redis.
      Ro75.
                     man:redis-server(1)
                CPU: 8min 42.178s
        Bitte ausfüllen:
        Script v.2024-10-19
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           209M         37M        172M
                 3791 M total memory
                 3037 M used memory
                  560 M free memory
                   29 M buffer memory
                  238 M swap cache
                  199 M total swap
                   35 M used swap
                  164 M free swap
        *** FILESYSTEM ***
        /var:
        2.7G    /var/
        2.1G    /var/lib
        1.9G    /var/lib/redis
        226M    /var/log
        USB-Devices by-id:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: redis
        States  type: redis
        Hosts:
        admin:          7.1.5
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        12761
        States:         11090
        Pending Updates: 0
        @retostoeckli
        RAM zu knapp, Spannungsversorgung zweifelhaft, critical errors in dmesg, unnötiger Einsatz von redis.
          retostoeckli
          @thomas-braun @ro75 danke euch. Ich hab mal auf jsonl umgestellt und beobachte weiter. Sonst hilft nur das upgrade der HW
