  4. Fehler beim Backup von Grafana
7 Beiträge 2 Kommentatoren 695 Aufrufe 2 Beobachtet
    Snopy_16
    Bin von Raspi auf Mini-PC mit Proxmox umgestiegen. Mit Backitup habe ich alles wieder hergestellt.
    Daten (iobroker, History, InfluxDB, Grafana,..)liegen auf neuem System 👍
    Jetzt wollte ich nun das neue System gleich mal sichern, da kam beim grafana-backup folgende Fehlermeldung.
    backitup.0
    2024-12-11 10:30:32.950	error	[iobroker/grafana] cannot found Grafana Backup files
    backitup.0
    2024-12-11 10:30:32.936	error	[iobroker/grafana] Error on Grafana Dashboard Request: AxiosError: Request failed with status code 401
    Im Detail
    Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
    grafana: {"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n    at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\n    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\n    at IncomingMessage.emit (node:events:530:35)\n    at IncomingMessage.emit (node:domain:489:12)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at processTicksAndRejections (node:internal/process/task_queues:82:21)\n    at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n    at processTicksAndRejections (node:internal/process/task_queues:95:5)\n    at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer ****","User-Agent":"axios/1.7.9","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.23:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_REQUEST","status":401}
    Was hat das zu bedeuten? Wo kann ich ansetzen?
    Benutzername, PW und Servicetoken sind im Backitupadapter eingetragen.
    Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
    LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
    iobroker auf Proxmox VM
    Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
    FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
    • S Snopy_16
      backitup.0
      backitup.0
      Im Detail
      Snopy_16
      Wollte nun den LXD Container von grafana upgraden, da kam das
      root@grafana:~# apt upgrade
      Reading package lists... Done
      Building dependency tree... Done
      Calculating upgrade... Done
      The following packages will be upgraded:
        grafana
      1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      1 not fully installed or removed.
      Need to get 0 B/127 MB of archives.
      After this operation, 643 kB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Reading changelogs... Done
      (Reading database ... 32684 files and directories currently installed.)
      Preparing to unpack .../grafana_11.4.0_amd64.deb ...
      Unpacking grafana (11.4.0) over (11.3.1) ...
      dpkg: error processing archive /var/cache/apt/archives/grafana_11.4.0_amd64.deb (--unpack):
       cannot copy extracted data for './usr/share/grafana/public/app/plugins/datasource/azuremonitor/img/contoso_loans_grafana_dashboard.png' to '/usr/share/grafana/public/app/plugins/datasource/azuremonitor/img/contoso_loans_grafana_dashboard.png.dpkg-new': failed to write (No space left on device)
      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
      Errors were encountered while processing:
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      root@grafana:~#
      • S Snopy_16
          grafana
        root@grafana:~#
        @snopy_16 sagte in Fehler beim Backup von Grafana:
        Der Datenträger ist voll.
          Snopy_16
          Danke, das hab ich schon behoben.
          aber beim Backup kommt steht im log (Zeile 29) ein Fehler, obwohl eigentlich vorher keiner ausgegeben wird.
          11:57:14.913INFOguiBackup gestartet ...
          [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false}
          11:57:24.953DEBUGmountnfs-mount command: "sudo mount 192.168.178.10:/Sicherung/iobroker /opt/iobroker/backups"
          11:57:25.051DEBUGmountmount successfully completed
          11:57:25.094DEBUGmountdone
          [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149}
          11:57:28.279DEBUGiobrokerhost.iobroker 13795 objects saved
          11:57:29.278DEBUGiobrokerhost.iobroker 12355 states saved
          11:57:29.326DEBUGiobrokerhost.iobroker Validating backup ...
          11:57:29.332DEBUGiobrokerhost.iobroker "config.json" is valid
          11:57:29.343DEBUGiobrokerhost.iobroker "objects.jsonl" exists
          host.iobroker "states.jsonl" exists
          11:57:29.611DEBUGiobrokerhost.iobroker JSONL lines are valid
          11:57:29.689DEBUGiobrokerhost.iobroker The backup is valid!
          11:57:30.346DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz
          11:57:30.398DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
          11:57:31.359DEBUGiobrokerdone
          11:57:32.719DEBUGgrafanaStart Grafana Backup ...
          11:57:32.730DEBUGgrafanaCreated grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
          11:57:32.736DEBUGgrafanaCreated dashboard directory
          11:57:32.746DEBUGgrafanaCreated dashboards_manually_restore directory
          11:57:32.752DEBUGgrafanaCreated datasource directory
          11:57:32.764DEBUGgrafanastart Grafana request ...
          11:57:32.930DEBUGgrafanaGrafana is available ... Status: 200
          11:57:33.070DEBUGgrafanadone
          11:57:34.217DEBUGcifsused copy path: /Sicherung/iobroker
          11:57:34.261DEBUGcifsdone
          [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
          11:57:34.867ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
          11:57:34.878DEBUGcleandone
          11:57:34.974DEBUGhistoryHTMLnew history html values created
          11:57:35.064DEBUGhistoryHTMLdone
          [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz"],"errors":{"grafana":"{\"message\":\"Request failed with status code 401\",\"name\":\"AxiosError\",\"stack\":\"AxiosError: Request failed with status code 401\\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\\n at IncomingMessage.emit (node:events:530:35)\\n at IncomingMessage.emit (node:domain:489:12)\\n at endReadableNT (node:internal/streams/readable:1698:12)\\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\\n at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43\",\"config\":{\"transitional\":{\"silentJSONParsing\":true,\"forcedJSONParsing\":true,\"clarifyTimeoutError\":false},\"adapter\":[\"xhr\",\"http\",\"fetch\"],\"transformRequest\":[null],\"transformResponse\":[null],\"timeout\":0,\"xsrfCookieName\":\"XSRF-TOKEN\",\"xsrfHeaderName\":\"X-XSRF-TOKEN\",\"maxContentLength\":-1,\"maxBodyLength\":-1,\"env\":{},\"headers\":{\"Accept\":\"application/json, text/plain, */*\",\"Authorization\":\"Bearer 060fZi4mJKPmTHgPQRYmuaEKqL0lOUP-yvIVEPgyBB2ZZ1FBjhU-AMNOT7vQCNfRyx9_reM5l01bR27Mgop_9g==\",\"User-Agent\":\"axios/1.7.9\",\"Accept-Encoding\":\"gzip, compress, deflate, br\"},\"method\":\"get\",\"url\":\"http://192.168.178.23:3000/api/search\",\"responseType\":\"json\",\"httpsAgent\":{\"_events\":{},\"_eventsCount\":2,\"_maxListeners\":100,\"defaultPort\":443,\"protocol\":\"https:\",\"options\":{\"rejectUnauthorized\":true,\"noDelay\":true,\"path\":null},\"requests\":{},\"sockets\":{},\"freeSockets\":{},\"keepAliveMsecs\":1000,\"keepAlive\":false,\"maxSockets\":null,\"maxFreeSockets\":256,\"scheduling\":\"lifo\",\"maxTotalSockets\":null,\"totalSocketCount\":0,\"maxCachedSessions\":100,\"_sessionCache\":{\"map\":{},\"list\":[]}}},\"code\":\"ERR_BAD_REQUEST\",\"status\":401}"},"done":["mount","iobroker"],"types":["iobroker"]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"11. Dezember 2024 um 11:57 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
          11:57:35.222DEBUGhistoryJSONnew history json values created
          11:57:35.265DEBUGhistoryJSONdone
          11:57:35.377DEBUGumountmount active, umount is started ...
          [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz"],"errors":{"grafana":"{\"message\":\"Request failed with status code 401\",\"name\":\"AxiosError\",\"stack\":\"AxiosError: Request failed with status code 401\\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\\n at IncomingMessage.emit (node:events:530:35)\\n at IncomingMessage.emit (node:domain:489:12)\\n at endReadableNT (node:internal/streams/readable:1698:12)\\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\\n at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43\",\"config\":{\"transitional\":{\"silentJSONParsing\":true,\"forcedJSONParsing\":true,\"clarifyTimeoutError\":false},\"adapter\":[\"xhr\",\"http\",\"fetch\"],\"transformRequest\":[null],\"transformResponse\":[null],\"timeout\":0,\"xsrfCookieName\":\"XSRF-TOKEN\",\"xsrfHeaderName\":\"X-XSRF-TOKEN\",\"maxContentLength\":-1,\"maxBodyLength\":-1,\"env\":{},\"headers\":{\"Accept\":\"application/json, text/plain, */*\",\"Authorization\":\"Bearer 060fZi4mJKPmTHgPQRYmuaEKqL0lOUP-yvIVEPgyBB2ZZ1FBjhU-AMNOT7vQCNfRyx9_reM5l01bR27Mgop_9g==\",\"User-Agent\":\"axios/1.7.9\",\"Accept-Encoding\":\"gzip, compress, deflate, br\"},\"method\":\"get\",\"url\":\"http://192.168.178.23:3000/api/search\",\"responseType\":\"json\",\"httpsAgent\":{\"_events\":{},\"_eventsCount\":2,\"_maxListeners\":100,\"defaultPort\":443,\"protocol\":\"https:\",\"options\":{\"rejectUnauthorized\":true,\"noDelay\":true,\"path\":null},\"requests\":{},\"sockets\":{},\"freeSockets\":{},\"keepAliveMsecs\":1000,\"keepAlive\":false,\"maxSockets\":null,\"maxFreeSockets\":256,\"scheduling\":\"lifo\",\"maxTotalSockets\":null,\"totalSocketCount\":0,\"maxCachedSessions\":100,\"_sessionCache\":{\"map\":{},\"list\":[]}}},\"code\":\"ERR_BAD_REQUEST\",\"status\":401}"},"done":["mount","iobroker"],"types":["iobroker"]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"11. Dezember 2024 um 11:57 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
          [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
          11:57:40.513DEBUGumountumount successfully completed
          11:57:40.557DEBUGumountdone
          11:57:40.840DEBUGemail[iobroker] used E-Mail-Instance: email.0
          11:57:40.877DEBUGemaildone
          [DEBUG] [email] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz"],"errors":{"grafana":"{\"message\":\"Request failed with status code 401\",\"name\":\"AxiosError\",\"stack\":\"AxiosError: Request failed with status code 401\\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\\n at IncomingMessage.emit (node:events:530:35)\\n at IncomingMessage.emit (node:domain:489:12)\\n at endReadableNT (node:internal/streams/readable:1698:12)\\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\\n at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43\",\"config\":{\"transitional\":{\"silentJSONParsing\":true,\"forcedJSONParsing\":true,\"clarifyTimeoutError\":false},\"adapter\":[\"xhr\",\"http\",\"fetch\"],\"transformRequest\":[null],\"transformResponse\":[null],\"timeout\":0,\"xsrfCookieName\":\"XSRF-TOKEN\",\"xsrfHeaderName\":\"X-XSRF-TOKEN\",\"maxContentLength\":-1,\"maxBodyLength\":-1,\"env\":{},\"headers\":{\"Accept\":\"application/json, text/plain, */*\",\"Authorization\":\"Bearer 060fZi4mJKPmTHgPQRYmuaEKqL0lOUP-yvIVEPgyBB2ZZ1FBjhU-AMNOT7vQCNfRyx9_reM5l01bR27Mgop_9g==\",\"User-Agent\":\"axios/1.7.9\",\"Accept-Encoding\":\"gzip, compress, deflate, br\"},\"method\":\"get\",\"url\":\"http://192.168.178.23:3000/api/search\",\"responseType\":\"json\",\"httpsAgent\":{\"_events\":{},\"_eventsCount\":2,\"_maxListeners\":100,\"defaultPort\":443,\"protocol\":\"https:\",\"options\":{\"rejectUnauthorized\":true,\"noDelay\":true,\"path\":null},\"requests\":{},\"sockets\":{},\"freeSockets\":{},\"keepAliveMsecs\":1000,\"keepAlive\":false,\"maxSockets\":null,\"maxFreeSockets\":256,\"scheduling\":\"lifo\",\"maxTotalSockets\":null,\"totalSocketCount\":0,\"maxCachedSessions\":100,\"_sessionCache\":{\"map\":{},\"list\":[]}}},\"code\":\"ERR_BAD_REQUEST\",\"status\":401}"},"done":["mount","iobroker","umount"],"types":["iobroker"]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de","time":"11. Dezember 2024 um 11:57 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
          [DEBUG] [notification] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz"],"errors":{"grafana":"{\"message\":\"Request failed with status code 401\",\"name\":\"AxiosError\",\"stack\":\"AxiosError: Request failed with status code 401\\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\\n at IncomingMessage.emit (node:events:530:35)\\n at IncomingMessage.emit (node:domain:489:12)\\n at endReadableNT (node:internal/streams/readable:1698:12)\\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\\n at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43\",\"config\":{\"transitional\":{\"silentJSONParsing\":true,\"forcedJSONParsing\":true,\"clarifyTimeoutError\":false},\"adapter\":[\"xhr\",\"http\",\"fetch\"],\"transformRequest\":[null],\"transformResponse\":[null],\"timeout\":0,\"xsrfCookieName\":\"XSRF-TOKEN\",\"xsrfHeaderName\":\"X-XSRF-TOKEN\",\"maxContentLength\":-1,\"maxBodyLength\":-1,\"env\":{},\"headers\":{\"Accept\":\"application/json, text/plain, */*\",\"Authorization\":\"Bearer 060fZi4mJKPmTHgPQRYmuaEKqL0lOUP-yvIVEPgyBB2ZZ1FBjhU-AMNOT7vQCNfRyx9_reM5l01bR27Mgop_9g==\",\"User-Agent\":\"axios/1.7.9\",\"Accept-Encoding\":\"gzip, compress, deflate, br\"},\"method\":\"get\",\"url\":\"http://192.168.178.23:3000/api/search\",\"responseType\":\"json\",\"httpsAgent\":{\"_events\":{},\"_eventsCount\":2,\"_maxListeners\":100,\"defaultPort\":443,\"protocol\":\"https:\",\"options\":{\"rejectUnauthorized\":true,\"noDelay\":true,\"path\":null},\"requests\":{},\"sockets\":{},\"freeSockets\":{},\"keepAliveMsecs\":1000,\"keepAlive\":false,\"maxSockets\":null,\"maxFreeSockets\":256,\"scheduling\":\"lifo\",\"maxTotalSockets\":null,\"totalSocketCount\":0,\"maxCachedSessions\":100,\"_sessionCache\":{\"map\":{},\"list\":[]}}},\"code\":\"ERR_BAD_REQUEST\",\"status\":401}"},"done":["mount","iobroker","umount"],"types":["iobroker"]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de","time":"11. Dezember 2024 um 11:57 Uhr"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
          11:57:42.881DEBUGnotificationAdmin notification will be sent
          11:57:42.917DEBUGnotificationdone
          11:57:43.031INFOguiDas Backup wurde erfolgreich erstellt!
          Das steht im ioboker log
          backitup.0
          2024-12-11 11:57:34.017	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
          backitup.0
          2024-12-11 11:57:32.060	error	[iobroker/grafana] cannot found Grafana Backup files
          backitup.0
          2024-12-11 11:57:32.046	error	[iobroker/grafana] Error on Grafana Dashboard Request: AxiosError: Request failed with status code 401
          backitup.0
          2024-12-11 11:57:32.042	error	[iobroker/grafana] Error on Grafana Datasource Request
          Und das im Detail
          11.12.2024, 11:57:42
          • S Snopy_16
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            Und das im Detail
            "smb":"vers=2.0"
            Versuch mal eine höhere Protokoll-Version. Eigentlich sollte alles was halbwegs aktuell ist smb=3.1.1 sprechen.
            Und das da sowohl von NFS wie auch von CIFS die Rede ist irritiert mich auch. Was soll es denn am Ende sein?
              Snopy_16
              Hab jetzt im backitupadapter unter grafana nochmal alles neu eingetragen.
              Dazu nochmal einen neuen Service-Token aus grafana geholt - jetzt funktionierts😁
              Aber jedenfalls danke für deine Mithilfe👍
                "smb":"vers=2.0"
                Snopy_16
                @thomas-braun sagte in Fehler beim Backup von Grafana:
                NFS ist im Adapter eingetragen. Woher das CIFS kommt, weiss ich nicht.
