  4. harmony - Terminated (UNCAUGHT_EXCEPTION): Without reason
    1.0k
    6.1k
7 Beiträge 4 Kommentatoren 941 Aufrufe 5 Beobachtet
  • Chris0706C Offline
    Chris0706C Offline
    Chris0706
    seit ein paar Tagen stützt mein Harmony Adapter immer wieder ab. Mit den Fehlermeldungen im Log kann ich nicht wirklich was anfangen.. Hab im IOBroker und in der Harmony App eigentlich nichts geändert..
    Log - Level Silly
    harmony.0
    2024-11-19 17:07:26.661	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v20.16.0, js-controller: 6.0.11
    harmony.0
    2024-11-19 17:07:26.688	info	[DISCOVER] Searching for Harmony Hubs on 255.255.255.255
    harmony.0
    2024-11-19 17:07:36.971	info	[DISCOVER] Discovered Wohnzimmer (192.168.2.108) and will try to connect
    harmony.0
    2024-11-19 17:07:36.974	info	[DISCOVER] Discovered Schlafzimmer (192.168.2.114) and will try to connect
    harmony.0
    2024-11-19 17:07:36.987	info	[DISCOVER] Discovered Dachfenster (192.168.2.109) and will try to connect
    harmony.0
    2024-11-19 17:07:37.101	info	[CONNECT] Connecting to Wohnzimmer (192.168.2.108)
    harmony.0
    2024-11-19 17:07:37.122	info	[CONNECT] Connecting to Schlafzimmer (192.168.2.114)
    harmony.0
    2024-11-19 17:07:37.179	info	[CONNECT] Connecting to Dachfenster (192.168.2.109)
    harmony.0
    2024-11-19 17:07:37.200	error	uncaught exception: Unexpected server response: 401
    harmony.0
    2024-11-19 17:07:37.201	error	Error: Unexpected server response: 401 at ClientRequest.<anonymous> (/opt/iobroker/node_modules/harmonyhubws/node_modules/ws/lib/websocket.js:595:7) at ClientRequest.emit (node:events:519:28) at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:698:27) at HTTPParser.parserOnHeadersComplete (node:_http_common:119:17) at Socket.socketOnData (node:_http_client:540:22) at Socket.emit (node:events:519:28) at addChunk (node:internal/streams/readable:559:12) at readableAddChunkPushByteMode (node:internal/streams/readable:510:3) at Readable.push (node:internal/streams/readable:390:5) at TCP.onStreamRead (node:internal/stream_base_commons:191:23)
    harmony.0
    2024-11-19 17:07:37.201	error	Unexpected server response: 401
    harmony.0
    2024-11-19 17:07:37.206	info	[END] Terminating
    harmony.0
    2024-11-19 17:07:37.207	info	terminating
    harmony.0
    2024-11-19 17:07:37.207	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    CPU: 14,2 %
    RAM: 52 %
    Betriebszeit: 72d18h
    Verfügbar: 6.0.11
    Installiert: 6.0.11
    Ereignisse: ⇥21 / ↦13
    Plattform: linux
    Betriebssystem: linux
    Architektur: x64
    CPUs: 2
    Geschwindigkeit: 0 MHz
    Modell: Intel(R) Pentium(R) Gold G5420 CPU @ 3.80GHz
    RAM: 5.7 GB
    System-Betriebszeit: 96 T. 05:26:55
    Node.js: v20.16.0
    time: 1732031459740
    timeOffset: -60
    NPM: 10.8.1
    Adapter-Anzahl: 547
    Datenträgergröße: 36.1 GB
    Freier Festplattenspeicher: 22.2 GB
    Aktive Instanzen: 21
    Pfad: /opt/iobroker/
    Betriebszeit: 72 T. 18:34:08
    Was könnte das sein?
    Christian
    • Chris0706C Chris0706
      Log - Level Silly
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      harmony.0
      CPU: 14,2 %
      RAM: 52 %
      Verfügbar: 6.0.11
      Installiert: 6.0.11
      Plattform: linux
      Architektur: x64
      CPUs: 2
      RAM: 5.7 GB
      Node.js: v20.16.0
      time: 1732031459740
      timeOffset: -60
      NPM: 10.8.1
      Adapter-Anzahl: 547
      Christian
      Meister MopperM Online
      Meister Mopper
      @chris0706
      Da können offenbar die Geräte nicht mit dem Hub kommunizieren.
      Ich würde den Hub mal ein paar Minuten stromlos machen und neu verbinden. Vielleicht ist auch das Netzteil des Hub eines natürlichen Todes gestorben. :woman-shrugging:
      Proxmox und HA ...
      • wendy2702W Offline
        wendy2702W Offline
        wendy2702
        Sind die Hubs noch per Ping vom iobroker aus erreichbar?
        Wurde was am Netzwerk geändert?
          Chris0706C Offline
          Chris0706
          Hubs sind alle per Harmony App erreichbar und Steuerbar. Aber werde sie mal alle stromlos machen und nach und nach einschalten.
          Habe das Netzwerk um einen Repeater erweitert, da aber alle Hubs erreichbar sind dachte / denke ich nicht das es da dran liegt?
          wendy2702W Samson71S 2 Antworten Letzte Antwort
            wendy2702W Offline
            wendy2702W Offline
            wendy2702
            @chris0706 doch, kann am Repeater liegen.
            Du hast also dein Netzwerk verändert, das wird dann wahrscheinlich doch die Ursache sein.
              Samson71S Offline
              Samson71S Offline
              Samson71
              @chris0706
              Gegentest: Repeater wieder aus und nochmal probieren. Wenn es dann (wieder) tut, liegt es an den Dingern.
              Markus
              Bitte beachten:
              Chris0706C 1 Antwort Letzte Antwort
              • Samson71S Samson71
                @chris0706
                Chris0706C Offline
                Chris0706C Offline
                Chris0706
                @samson71 also am Repeater liegts nicht, sondern an einem der drei Harmony Hubs.. Sobald der mit ins Netz geht, stürzt die Harmony Instanz ab.
                Werde wohl mal den Hub zurücksetzen.
