  3. Off Topic
  4. Microcontroller
  5. Sonoff-Adapter: Tasmota Stromzähler spinnt
    5.9k
Geplant Angeheftet Gesperrt Verschoben Microcontroller
42 Beiträge 2 Kommentatoren 4.8k Aufrufe 2 Beobachtet
  • MartinPM Online
    MartinPM Online
    MartinP
    Merkwürdige Loggings:
    Regelmäßig immer wieder Herdenweise folgende Loggings:
    2024-11-05 11:51:19.464  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730803810835_6216 sends publish. Ignore! Actual secret is 1730803877628_235
    2024-11-05 11:51:19.469  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730803810835_6216 sends publish. Ignore! Actual secret is 1730803877628_235
    2024-11-05 11:54:04.225  - warn: sonoff.0 (439) Client [Stromzaehler_B5F63F] cannot parse data"SENSOR": _{"T0Utele/Stromzaehler_B5F63F/SENSOR{"Time":"2024-_ - SyntaxError: Bad control character in string literal in JSON at position 5
    2024-11-05 11:54:04.225  - info: sonoff.0 (439) Client [Stromzaehler_B5F63F] connection closed: Error: Cannot parse topic
    2024-11-05 11:54:04.371  - info: sonoff.0 (439) Client [Stromzaehler_B5F63F] connected with secret 1730804044370_7708
    2024-11-05 12:01:06.536  - info: sonoff.0 (439) Client [Stromzaehler_B5F63F] connection closed: Error: Cannot parse topic
    2024-11-05 12:01:07.263  - info: sonoff.0 (439) Client [Stromzaehler_B5F63F] connected with secret 1730804467263_2997
    2024-11-05 12:06:10.899  - info: sonoff.0 (439) Client [Stromzaehler_B5F63F] reconnected. Old secret 1730804467263_2997 ==> New secret 1730804770899_6234
    2024-11-05 12:06:16.844  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730804467263_2997 sends publish. Ignore! Actual secret is 1730804770899_6234
    2024-11-05 12:06:16.845  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730804467263_2997 sends publish. Ignore! Actual secret is 1730804770899_6234
    2024-11-05 12:06:16.846  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730804467263_2997 sends publish. Ignore! Actual secret is 1730804770899_6234
    2024-11-05 12:06:16.847  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730804467263_2997 sends publish. Ignore! Actual secret is 1730804770899_6234
    2024-11-05 12:06:16.850  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730804467263_2997 sends publish. Ignore! Actual secret is 1730804770899_6234
    2024-11-05 12:06:16.851  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730804467263_2997 sends publish. Ignore! Actual secret is 1730804770899_6234
    2024-11-05 12:06:16.852  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730804467263_2997 sends publish. Ignore! Actual secret is 1730804770899_6234
    2024-11-05 12:06:16.853  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730804467263_2997 sends publish. Ignore! Actual secret is 1730804770899_6234
    2024-11-05 12:06:16.854  - warn: sonoff.0 (439) Old client Stromzaehler_B5F63F with secret 1730804467263_2997 sends publish. Ignore! Actual secret is 1730804770899_6234
    2024-11-05 12:13:35.383  - warn: sonoff.0 (439) Client [Stromzaehler_B5F63F] cannot parse data"SENSOR": _{"Time":"2024-11-05T12:13:23",0Utele/Stromzaehler_B_ - SyntaxError: Expected double-quoted property name in JSON at position 30
    2024-11-05 12:13:35.431  - info: sonoff.0 (439) Client [Stromzaehler_B5F63F] connection closed: Error: Cannot parse topic
    2024-11-05 12:13:35.667  - info: sonoff.0 (439) Client [Stromzaehler_B5F63F] connected with secret 1730805215660_4830
    martin@iobroker-test-sicher:/opt/iobroker/log$
    Kann sich da jemand einen Reim machen?
    49 Tage und 6 Stunden sind bei 1 Millisekunde Takt noch nicht ganz 2^32, aber schon auffällig, dass nach 49 Tagen Uptime die Probleme anfangen ...
    Habe mal den Stecker gezogen ...
    • MartinPM MartinP
      MartinPM Online
      MartinPM Online
      MartinP
      @martinp Auch nach Reset der Tasmota Hardware keine Besserung ...
      Habe jetzt probeweise den Sonoff Adapter (v3.1.2 aus Stable) neu gestartet.
      Bisher keine warn-Loggings
      EDIT: Immer noch diese "sends publish. Ignore! Actual secret is ..." Meldungen ca alle 30 Minuten ...
      • MartinPM Online
        MartinPM Online
        MartinP
        @martinp System scheint sich beruhigt zu haben keine einzige Log-Meldung vom Sonoff Adapter heute ...
        • MartinPM MartinP
          MartinPM Online
          MartinPM Online
          MartinP
          @martinp Zu früh gefreut ...
          Ablauf ist immer folgender:
          	Client [Stromzaehler_B5F63F] reconnected. Old secret 1730964423476_3511 ==> New secret 1730969832217_3563
          sonoff.0
          	2024-11-07 09:58:00.338	info	Client [Stromzaehler_B5F63F] connection closed: closed
          sonoff.0
          	2024-11-07 09:58:00.801	info	Client [Stromzaehler_B5F63F] connected with secret 1730969880800_8875
          sonoff.0
          	2024-11-07 09:58:10.019	warn	Old client Stromzaehler_B5F63F with secret 1730964423476_3511 sends publish. Ignore! Actual secret is 1730969880800_8875
          Es wird also zweimal hintereinander ein neue Secret zugeteilt, und dann kommen noch Messages mit dem alten vorletzten (!) Secret hinein...
          Könnte das an einer instabilen WLAN-Verbindung liegen?
          Zählerschrank hängt am Fuß der Kellertreppe, Fritzbox hängt am Kopf der Kellertreppe, hinter der Fritzbox (Kanal 6) aus Sicht des Node MCU, an dem der Zähler hängt steht im Obergeschoss ein Fritz-Repeater 1200AX (Kanal 11)
          WIFI im Tasmota Info-Menu:
           6 (70%, -65 dBm) 11n
          Schwankt zwischen -60 und -65... finde ich viel Schwankung, aber von den Absolutwerten ok...
          • MartinPM MartinP
            sonoff.0
            sonoff.0
            sonoff.0
            MartinPM Online
            MartinPM Online
            MartinP
            Habe das gefunden:
            https://forum.iobroker.net/topic/17351/sonoff-adapter-old-client-with-secret-send-pingreq
            Habe aufgrund des letzten Posts auch mal probeweise versucht, WifiPower auf 15 zu setzen. Die Tasmota-Konsole war vorher super Zäh...
            Nachdem ich WifiPower auf 15 gesetzt hatte, ist das "Zähe" der Konsole besser geworden ... Vielleicht hilft es ja ...
            • MartinPM MartinP
              Habe das gefunden:
              BananaJoeB Online
              BananaJoeB Online
              BananaJoe
              @martinp 15 wäre ja schwächer ... wie wäre es den Wert auf 0 zu setzen, dann sollte sich Tasmota dynamisch an den AccessPoint anpassen
              • BananaJoeB BananaJoe
                MartinPM Online
                MartinPM Online
                MartinP
                @bananajoe Ist das so bei Tasmota?
                Bisher scheint die sporadische Kommunikationsunterbrechung nach dem Wechsel 15 -> 13 weg zu sein ...
                Wo hast Du das mit "WifiPower 0" her?
                In der Doku finde ich dazu nichts:
                https://tasmota.github.io/docs/WifiPower/
                lasse das estmal bei 15 ...
                Hier noch ein ESP32-S2
                Und meine ESP32-CAM
                Da habe ich das mit WifiPower ausprobiert
                7:36:24.971 CMD: wifipower
                17:36:24.977 MQT: stat/tasmota_CBA21C/RESULT = {"WifiPower":16.0}
                17:36:38.330 CMD: wifipower 0
                17:36:38.334 MQT: stat/tasmota_CBA21C/RESULT = {"WifiPower":16.0}
                17:38:30.022 CMD: wifipower 15
                17:38:30.127 MQT: stat/tasmota_CBA21C/RESULT = {"WifiPower":15.0}
                17:38:35.615 CMD: wifipower
                17:38:35.621 MQT: stat/tasmota_CBA21C/RESULT = {"WifiPower":15.0}
                17:38:40.976 CMD: wifipower 0
                17:38:40.980 MQT: stat/tasmota_CBA21C/RESULT = {"WifiPower":15.0}
                17:38:43.613 CMD: wifipower 0
                17:38:43.618 MQT: stat/tasmota_CBA21C/RESULT = {"WifiPower":14.0}
                17:38:46.325 CMD: wifipower 0
                17:38:46.330 MQT: stat/tasmota_CBA21C/RESULT = {"WifiPower":14.0}```
                BananaJoeB 2 Antworten Letzte Antwort
                • MartinPM MartinP
                  Und meine ESP32-CAM
                  BananaJoeB Online
                  BananaJoeB Online
                  BananaJoe
                  @martinp Ok, die Docs gibt es auch, ich schaue immer in die ''Commands'' Liste:
                  https://tasmota.github.io/docs/Commands/
                  Ich setze auch immer noch (WifiPower habe ich bisher nicht angefasst)
                  Ich überwache bei mir an welchen AccessPoint die Tasmota-Geräte sich gerade befinden, wenn ich den in der Unterverteilung neu starte kann ich schön sehen wie diese dann alle an den AP in der Küche wechseln und im laufe der nächsten Stunde wieder zurück.
                  Bei neuen Geräten ist das per Default an, bei älteren muss man das ggf. setzen. Der Befehl ohne Parameter zeigt ja immer den aktuellen Status an.
                  • MartinPM MartinP
                    Und meine ESP32-CAM
                    BananaJoeB Online
                    BananaJoeB Online
                    BananaJoe
                    @martinp Nachtrag: Die Signalstärke die dir angezeigt wird sagt dir genau genommen weniger als man denkt.
                    Das ist ja wie gut stark das Empfangssignal ist (Signalqualität ist etwas anderes).
                    Wobei ich sehe gerade - das ist wohl aus der FritzBox, also wie gut diese Empfängt. Naja, dann müsste der Wert bei 17 besser sein als bei 15 weil er stärker sendet ...
                    Über -60dBm ist im "gelben" Bereich. Ist ok für die kleinen Miniplatinen ohne extra Antennen.
                    Bei Kameras hast du natürlich höhere Bandbreitennutzung, die normalen Tasmota senden ja nicht viel bzw. nur kleine Pakete. Wenn der Stream ständig abgerufen wird, geht das natürlich von der Bandbreite der anderen Geräte runter
                      MartinPM Online
                      MartinPM Online
                      MartinP
                      @bananajoe
                      Vielleicht gibt es bei 17 = Maximum gewisse Probleme, dass z.B. das Empfangen nach dem Senden nicht sofort wieder gut klappt, und das Umschalten besser funktioniert, wenn man mit "angezogener Handbremse" sendet ....
                      Auch bei WifiPower 0 kommt je nach Tasmota Version entweder der erste "ausgewürfelte" Wert zurück, oder die "0.0"
                      Hier die Werte von meiner Nous A1T
                      NOUS A1T
                      Tasmota
                      Program Version	12.1.1(tasmota)
                      17:52:23.111 CMD: wifipower
                      17:52:23.117 MQT: stat/tasmota_17AB7E/RESULT = {"WifiPower":"0.0"}
                      • MartinPM MartinP
                        @bananajoe
                        NOUS A1T
                        Tasmota
                        BananaJoeB Online
                        BananaJoeB Online
                        BananaJoe
                        @martinp eventuell gibst du auch einer aktuelleren Tasmota-Version mal eine Chance ...
                        ABER VORSICHT, du müsstest unbedingt eine SML-Version für den Stromzähler nehmen, bei allen anderen passen in der Regel die normalen, auf meinen Nous A1T habe ich 14.3.0 - aber nur weil ich zufällig letztes Wochenende eine große Updateorgie gemacht habe.
                        Dein Stromzähler hat ja schon 13.1, das ist ja nur etwas mehr als ein Jahr alt. Gab aber schon einige Version dazwischen, müsste man mal in den Release-Notes schauen: https://github.com/arendst/Tasmota/releases?page=1
                          MartinPM Online
                          MartinPM Online
                          MartinP
                          @bananajoe Beim Stromzähler bin ich auf 13.1
                          Die Nous A1T hat noch ihre Version aus dem Lieferzustand ...
                          Den Stromzähler habe ich selber compiliert, da habe ich sentimentale Erinnerungen ;-) (aber vielleicht habe ich da auch verdrängt ....)
                          Generic
                          Tasmota
                          Program Version	13.1.0(tasmota-4M)
                          Build Date & Time	2023-09-02T18:48:01
                          • MartinPM MartinP
                            Generic
                            Tasmota
                            MartinPM Online
                            MartinPM Online
                            MartinP
                            Mit "WifiPower 0" läuft der Tasmota Node MCU am Lesekopf wieder unauffällig - seit einem Tag keine Logmeldungen bzgl. Problemen.
                            • MartinPM MartinP
                              MartinPM Online
                              MartinPM Online
                              MartinP
                              Die Logmeldungen sind wieder aufgetreten ... bin etwas ratlos ...
                              Wifipower steht auf 0, hat sich auf 14 eingepegelt ...
                              Da ich die Pulse vom induktiven Näherungsschalter am Gaszähler durch ein Blockly zählen lasse gehen iobroker da jetzt ein paar Pulse pro Tag durch die Lappen, wenn die Verbindung mal wieder kippelt ...
                              Da scheinen Tasmota und Sonoff nicht einig, welches Secret denn nun gilt ...
                              sonoff.0
                              	2024-11-12 13:54:06.055	warn	Client [Stromzaehler_B5F63F] received pubrec on Stromzaehler_B5F63F for unknown message ID: 28005
                              sonoff.0
                              	2024-11-12 13:54:06.055	info	Client [Stromzaehler_B5F63F] connection closed: Error: Cannot parse topic
                              sonoff.0
                              	2024-11-12 13:54:06.271	info	Client [Stromzaehler_B5F63F] connected with secret 1731416046271_618
                              sonoff.0
                              	2024-11-12 14:01:45.115	info	Client [Stromzaehler_B5F63F] reconnected. Old secret 1731416046271_618 ==> New secret 1731416505115_5102
                              sonoff.0
                              	2024-11-12 14:01:56.626	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              	2024-11-12 14:01:56.627	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              sonoff.0
                              sonoff.0
                              sonoff.0
                              	2024-11-12 14:01:56.628	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              	2024-11-12 14:01:56.637	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              sonoff.0
                              	2024-11-12 14:01:56.638	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              sonoff.0
                              	2024-11-12 14:01:56.639	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              	2024-11-12 14:01:56.643	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              	2024-11-12 14:01:56.643	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends pingreq. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              	2024-11-12 14:01:56.644	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              	2024-11-12 14:01:56.646	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              sonoff.0
                              	2024-11-12 14:01:56.647	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              sonoff.0
                              	2024-11-12 14:01:56.648	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              sonoff.0
                              sonoff.0
                              	2024-11-12 14:01:56.649	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              sonoff.0
                              sonoff.0
                              sonoff.0
                              	2024-11-12 14:01:56.650	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              	2024-11-12 14:01:56.651	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              sonoff.0
                              sonoff.0
                              	2024-11-12 14:01:56.652	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              	2024-11-12 14:01:56.653	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              sonoff.0
                              sonoff.0
                              sonoff.0
                              	2024-11-12 14:01:56.654	warn	Old client Stromzaehler_B5F63F with secret 1731416046271_618 sends publish. Ignore! Actual secret is 1731416505115_5102
                              • MartinPM MartinP
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                sonoff.0
                                BananaJoeB Online
                                BananaJoeB Online
                                BananaJoe
                                @martinp Hast du auch MQTT im Einsatz? Dann könntest du den Tasmota dahin senden lassen, musst das ganze dann halt nur selbst auswerten (was für einen Impuls nicht so wild sein wird).
                                  MartinPM Online
                                  MartinPM Online
                                  MartinP
                                  @bananajoe Mit dem MQTT Client/Server Adapter habe ich teilweise ähnliche Probleme... Da müsste ich mich auch um das Auseinanderfummeln der JSON-Verpackung der Zählerwerte selber kümmern ..
                                  Was ist von einer zwischengeschalteten Mosquitto Instanz zu halten?
                                  • MartinPM MartinP
                                    BananaJoeB Online
                                    BananaJoeB Online
                                    BananaJoe
                                    @martinp sagte in Sonoff-Adapter: Tasmota Stromzähler spinnt:
                                    Ich persönlich ganz viel. Ich habe da alles drüber laufen (Shelly, Tasmota und alles andere)
                                    Der Mosquitto ist unheimlich Leistungsfähig, der kann tausende von Geräten gleichzeitig bedienen, dann den MQTT-Broker/Client im Client-Modus damit verbinden.
                                    Da geht nicht verloren, wenn der Adapter ein paar Millisekunden später reagiert ist das dann egal.
                                    In Tasmota kann man einstellen wie er die MQTT-Daten sendet, wenn man stateretain 1 setzt erhält der Client die Info auch wenn er mal kurz offline war.
                                    • MartinPM MartinP
                                      BananaJoeB Online
                                      BananaJoeB Online
                                      BananaJoe
                                      @martinp wenn du die Daten hast die der Stromzähler sendet, die müssten unterhalb mqtt.0.tele.xxxx landen, poste was der Datenpunkt da ausspuckt (SENSOR?), das auseinandernehmen ist nicht weiter schwierig
                                        MartinPM Online
                                        MartinPM Online
                                        MartinP
                                        @bananajoe Ich werde dann wohl eher "Nägel mit Köpfen" machen, und mich mit Mosquitto beschäftigen, da ich wie gesagt auch mit dem MQTT Broker/Client schon ähnliche Probleme hatte.
                                        Nutzt man Mosquitto da eher als "Rangierbahnhof" für komplette Topics, oder wird darin z. B. JSON auseinandergepflückt und umgebaut und neu in MQTT Topics verpackt?
                                        • MartinPM MartinP
                                          BananaJoeB Online
                                          BananaJoeB Online
                                          BananaJoe
                                          @martinp als Rangierbahnhof. Besser: Als Nachrichtenzentrale. Jeder kann da alles ablegen, und über alles Informiert werden was einen Interessiert.
                                          Den MQTT Broker/Client als Client kann ich aber in Verbindung mit dem Mosquitto empfehlen, läuft bei mir ganz wunderbar, bei 162 aktiven Clients:
