  4. Node Red startet immer wieder neu
    1.0k
    6.1k
2 Beiträge 2 Kommentatoren 215 Aufrufe 2 Beobachtet
    Schwarzermann
    Guten Morgen bei mir startet der Nod Red adapter immer wieder neu
    das ganze läuft auf einem Raspberry pi 4 mit 8gb ram ist frisch instaliert ,könte mir da jemand helfen?
    Plattform: linux
    RAM: 7.6 GB
    Node.js: v20.18.0
    NPM: 10.8.2
    2024-10-31 10:45:55.649  - info: node-red.0 (3932) Requested NPM packages: []
    2024-10-31 10:45:55.665  - warn: node-red.0 (3932) Cannot enable the dynamic object read as admin has authentication
    2024-10-31 10:45:55.896  - info: node-red.0 (3932) Starting node-red: --max-old-space-size=200 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js --safe
    2024-10-31 10:45:55.902  - info: node-red.0 (3932) Node-RED started successfully (PID: 3947)
    2024-10-31 10:45:56.898  - info: node-red.0 (3932) Node-RED exited with 1
    2024-10-31 10:46:01.900  - info: node-red.0 (3932) Starting node-red: --max-old-space-size=200 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js --safe
    2024-10-31 10:46:01.908  - info: node-red.0 (3932) Node-RED started successfully (PID: 3954)
    2024-10-31 10:46:02.912  - info: node-red.0 (3932) Node-RED exited with 1
    2024-10-31 10:46:07.915  - info: node-red.0 (3932) Starting node-red: --max-old-space-size=200 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js --safe
    2024-10-31 10:46:07.924  - info: node-red.0 (3932) Node-RED started successfully (PID: 3961)
    2024-10-31 10:46:08.994  - info: node-red.0 (3932) Node-RED exited with 1
    2024-10-31 10:46:13.995  - info: node-red.0 (3932) Starting node-red: --max-old-space-size=200 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js --safe
    2024-10-31 10:46:14.007  - info: node-red.0 (3932) Node-RED started successfully (PID: 3968)
    2024-10-31 10:46:15.057  - info: node-red.0 (3932) Node-RED exited with 1
    2024-10-31 10:46:20.058  - info: node-red.0 (3932) Starting node-red: --max-old-space-size=200 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js --safe
    2024-10-31 10:46:20.069  - info: node-red.0 (3932) Node-RED started successfully (PID: 3975)
    2024-10-31 10:46:21.307  - info: node-red.0 (3932) Node-RED exited with 1
    2024-10-31 10:46:24.196  - info: host.raspberrypi "system.adapter.node-red.0" disabled
    2024-10-31 10:46:24.198  - info: host.raspberrypi stopInstance system.adapter.node-red.0 (force=false, process=true)
    2024-10-31 10:46:26.308  - info: node-red.0 (3932) Starting node-red: --max-old-space-size=200 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js --safe
    2024-10-31 10:46:26.320  - info: node-red.0 (3932) Node-RED started successfully (PID: 4005)
    2024-10-31 10:46:27.364  - info: node-red.0 (3932) Node-RED exited with 1
    2024-10-31 10:46:29.200  - info: host.raspberrypi stopInstance timeout 5000 system.adapter.node-red.0 killing pid 3932
    2024-10-31 10:46:29.236  - warn: host.raspberrypi instance system.adapter.node-red.0 terminated due to SIGKILL
    2024-10-31 10:46:29.237  - info: host.raspberrypi instance system.adapter.node-red.0 terminated with code null ()
    folgendes wird ausgegeben, vielen Dank schn mal sollte jemand helfen.
    • mickymM Offline
      mickymM Offline
      mickym
      kann dir wahrscheinlich nicht helfen, da ich keine Authentifizierungseinstellungen nutze, ansonste schalte halt ggf. mal im Adapter alle Authentifizierungseinstellungen aus.
      ggf. sichere Dir Deine Flows.json weg und installiere den Audapter ohne Auth-einstellungen neu.
