  3. Off Topic
  4. Grafana
  5. Fehler beim Grafana Backup-Recovery
    6.7k
Geplant Angeheftet Gesperrt Verschoben Grafana
1 Beiträge 1 Kommentatoren 215 Aufrufe 1 Beobachtet
  • W Offline
    W Offline
    wibear
    Hallo zusammen, bei einem Backup-Recovery von Grafana werden einige Fehler protokolliert:
    15:28:31.862INFOguistarting Restore...
    15:28:32.099DEBUGgrafanaStart Grafana Restore ...
    15:28:32.144DEBUGgrafanafilename for restore: /opt/iobroker/backups/grafana_2024_10_15-02_41_40_backupiobroker.tar.gz
    15:28:32.148DEBUGgrafanaGrafana tmp directory created: /opt/iobroker/backups/grafana_tmp
    15:28:32.153DEBUGgrafanastart decompress
    15:28:41.529DEBUGgrafanaGrafana request started
    15:28:41.936DEBUGgrafanaGrafana is available ... Status: 200
    15:28:42.466DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/infinity.json
    15:28:42.553DEBUGgrafanacannot restore datasource "infinity": "data source with the same name already exists"
    15:28:42.690DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/influxdb.json
    15:28:42.768DEBUGgrafanacannot restore datasource "influxdb": "data source with the same name already exists"
    15:28:45.195DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/batterie-ladeleistung.json
    15:28:45.207DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/batterie-soc.json
    15:28:45.214DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/energie.json
    15:28:45.224DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/funk.json
    15:28:45.256DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/gauges.json
    15:28:45.260DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/signalstarke.json
    15:28:45.263DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/temperatur-shelly.json
    15:28:45.267DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/temperaturen-ww-hz.json
    15:28:45.276DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/umwalzpumpe.json
    15:28:45.288DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/heizung.json
    15:28:45.293DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/leistung-solar.json
    15:28:45.297DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/leistung-waschmaschiene.json
    15:28:45.353DEBUGgrafanacannot restore dashboard "energie": {"message":"Dashboard cannot be changed to a folder"}
    15:28:45.453DEBUGgrafanadashboard restore for "batterie-ladeleistung" finish: {"folderUid":"","id":12,"slug":"batterie-ladeleistung","status":"success","uid":"cdmrf8v69vf9ce","url":"/d/cdmrf8v69vf9ce/batterie-ladeleistung","version":8}
    15:28:45.594DEBUGgrafanadashboard restore for "signalstarke" finish: {"folderUid":"","id":4,"slug":"signalstarke","status":"success","uid":"f5c6aaad-a8af-48b8-a06e-c31f681f85ba","url":"/d/f5c6aaad-a8af-48b8-a06e-c31f681f85ba/signalstarke","version":31}
    15:28:45.654DEBUGgrafanadashboard restore for "batterie-soc" finish: {"folderUid":"","id":11,"slug":"batterie-soc","status":"success","uid":"ddkomyxkzjdvkb","url":"/d/ddkomyxkzjdvkb/batterie-soc","version":17}
    15:28:45.663DEBUGgrafanacannot restore dashboard "funk": {"message":"Dashboard cannot be changed to a folder"}
    15:28:45.719DEBUGgrafanadashboard restore for "temperaturen-ww-hz" finish: {"folderUid":"","id":2,"slug":"temperaturen-ww-hz","status":"success","uid":"f0af631a-f93d-433f-af45-580eb590c18b","url":"/d/f0af631a-f93d-433f-af45-580eb590c18b/temperaturen-ww-hz","version":38}
    15:28:45.795DEBUGgrafanadashboard restore for "gauges" finish: {"folderUid":"","id":9,"slug":"gauges","status":"success","uid":"a51720fc-9ef3-4cb3-8646-410af4052f15","url":"/d/a51720fc-9ef3-4cb3-8646-410af4052f15/gauges","version":42}
    15:28:45.842DEBUGgrafanadashboard restore for "temperatur-shelly" finish: {"folderUid":"","id":10,"slug":"temperatur-shelly","status":"success","uid":"bdiis07joxiiof","url":"/d/bdiis07joxiiof/temperatur-shelly","version":8}
    15:28:45.850DEBUGgrafanacannot restore dashboard "heizung": {"message":"Dashboard cannot be changed to a folder"}
    15:28:45.888DEBUGgrafanadashboard restore for "leistung-solar" finish: {"folderUid":"","id":8,"slug":"leistung-solar","status":"success","uid":"a998f478-50b0-4707-9e0e-ba587d052c41","url":"/d/a998f478-50b0-4707-9e0e-ba587d052c41/leistung-solar","version":13}
    15:28:45.937DEBUGgrafanadashboard restore for "leistung-waschmaschiene" finish: {"folderUid":"","id":7,"slug":"leistung-waschmaschiene","status":"success","uid":"a8916d8e-00b0-4ee4-a03d-c9f10cbc8d06","url":"/d/a8916d8e-00b0-4ee4-a03d-c9f10cbc8d06/leistung-waschmaschiene","version":11}
    15:28:45.977DEBUGgrafanadashboard restore for "verbrauch-hz-taglich" finish: {"folderUid":"","id":14,"slug":"verbrauch-hz-taglich","status":"success","uid":"cdrbhjzqr76kgb","url":"/d/cdrbhjzqr76kgb/verbrauch-hz-taglich","version":6}
    15:28:46.022DEBUGgrafanadashboard restore for "verbrauch-ww-taglich" finish: {"folderUid":"","id":13,"slug":"verbrauch-ww-taglich","status":"success","uid":"edr8ax5wzaozka","url":"/d/edr8ax5wzaozka/verbrauch-ww-taglich","version":9}
    15:28:53.283DEBUGgrafanadashboard restore for "umwalzpumpe" finish: {"folderUid":"","id":16,"slug":"umwalzpumpe","status":"success","uid":"bdtlwgmd34iyoa","url":"/d/bdtlwgmd34iyoa/umwalzpumpe","version":3}
    15:28:53.327DEBUGgrafanaGrafana request ended
    15:28:53.334DEBUGgrafanaTry deleting the Grafana tmp directory
    15:28:53.343DEBUGgrafanaGrafana tmp directory was successfully deleted
    15:28:55.304DEBUGgrafanaGrafana Restore completed successfully
    Danach gibt's Fehlermeldungen (Access denied...) in den Charts:
    Was soll ich überprüfen?
    Danke und Grüße
