  3. Einsteigerfragen
  4. Installation
  5. Tokenerstellung, Importfehler
Geplant Angeheftet Gesperrt Verschoben Installation
2 Beiträge 2 Kommentatoren 333 Aufrufe 1 Beobachtet
    mpfistda
    schrieb am zuletzt editiert von mpfistda
    Guten Tag,
    Rasphberrypi 5
    Plattform: linux
    RAM: 3.9 GB
    Node.js: v20.17.0
    NPM: 10.8.2
    Mehrere Neuinstallationen des Homematic IP Adapters Version 1.23.3
    Der Button Token Erstellung erscheint einfach nicht !
    Hier das Logfile:
    Nachricht
    host.raspberrypi
    2024-09-17 08:18:22.555	info	instance system.adapter.hmip.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    hmip.0
    2024-09-17 08:18:22.539	info	terminating
    host.raspberrypi
    2024-09-17 08:18:22.077	info	stopInstance system.adapter.hmip.0 send kill signal
    hmip.0
    2024-09-17 08:18:22.038	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    hmip.0
    2024-09-17 08:18:22.037	info	terminating
    hmip.0
    2024-09-17 08:18:22.037	info	cleaned everything up...
    hmip.0
    2024-09-17 08:18:22.036	info	Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi
    2024-09-17 08:18:22.033	info	stopInstance system.adapter.hmip.0 (force=false, process=true)
    host.raspberrypi
    2024-09-17 08:18:22.033	info	"system.adapter.hmip.0" disabled
    hmip.0
    2024-09-17 08:18:13.935	info	token not yet created
    hmip.0
    2024-09-17 08:18:13.925	info	starting. Version 1.23.3 in /opt/iobroker/node_modules/iobroker.hmip, node: v20.17.0, js-controller: 6.0.11
    host.raspberrypi
    2024-09-17 08:18:13.198	info	instance system.adapter.hmip.0 in version "1.23.3" started with pid 2781
    host.raspberrypi
    2024-09-17 08:18:13.007	info	"system.adapter.hmip.0" enabled
    Ich habe noch folgenden Fehler als Text im Fenster bekommen:
    Cannot import from custom/customComponents.js: ChunkLoadError: Loading chunk vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_capitalize_capitalize_js-node-bfcaa8 failed. (error: http://192.168.2.54:8081/adapter/hmip/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_capitalize_capitalize_js-node-bfcaa8.475177e7.chunk.js)
    HMIP Token-Daten
    Auch andere Versionen wollen nicht funktionieren, welchem Problem sitze ich auf ??
    • M mpfistda
      Guten Tag,
      Rasphberrypi 5
      Plattform: linux
      RAM: 3.9 GB
      Node.js: v20.17.0
      NPM: 10.8.2
      Hier das Logfile:
      Nachricht
      host.raspberrypi
      hmip.0
      host.raspberrypi
      hmip.0
      hmip.0
      hmip.0
      hmip.0
      host.raspberrypi
      host.raspberrypi
      hmip.0
      hmip.0
      host.raspberrypi
      host.raspberrypi
      HMIP Token-Daten
      @mpfistda sagte in Keine Tokenerstellung möglich:
      bitte Threadtitel anpassen.
      zu diesem Thema gibt es bereits einige Beiträge.
