  3. Einsteigerfragen
  4. Installation
  5. Installation bricht ab, chown: ungültige Gruppe: „uwe:uwe“
    2.7k
    2.9k
Geplant Angeheftet Gesperrt Verschoben Installation
7 Beiträge 2 Kommentatoren 690 Aufrufe 1 Beobachtet
  • N Offline
    N Offline
    Nr5lebt
    hallo zusammen,
    irgendwie ist der wurm drin. versuche auf einem neuen nas (amd64) und openmediavault 7 (debian) iobroker zu installieren.
    $ curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2024-05-24
        Welcome to the ioBroker installer!
        Installer version: 2024-01-04
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Holen:1 file:/var/cache/openmediavault/archives  InRelease
    Ign:1 file:/var/cache/openmediavault/archives  InRelease
    Holen:2 file:/var/cache/openmediavault/archives  Release
    Ign:2 file:/var/cache/openmediavault/archives  Release
    Holen:3 file:/var/cache/openmediavault/archives  Packages
    Ign:3 file:/var/cache/openmediavault/archives  Packages
    Holen:4 file:/var/cache/openmediavault/archives  Translation-en
    Ign:4 file:/var/cache/openmediavault/archives  Translation-en
    Holen:5 file:/var/cache/openmediavault/archives  Translation-de
    Ign:5 file:/var/cache/openmediavault/archives  Translation-de
    Holen:6 file:/var/cache/openmediavault/archives  Translation-de_DE
    Ign:6 file:/var/cache/openmediavault/archives  Translation-de_DE
    OK:7 http://packages.openmediavault.org/public sandworm InRelease
    OK:8 http://deb.debian.org/debian bookworm InRelease
    OK:9 http://deb.debian.org/debian bookworm-updates InRelease
    OK:10 http://security.debian.org/debian-security bookworm-security InRelease
    OK:11 https://openmediavault-plugin-developers.github.io/packages/debian sandworm InRelease
    OK:12 https://download.docker.com/linux/debian bookworm InRelease
    OK:13 https://openmediavault.github.io/packages sandworm InRelease
    OK:14 https://deb.nodesource.com/node_20.x nodistro InRelease
        Creating ioBroker user and directory (2/4)
    Created /etc/sudoers.d/iobroker
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    npm error code 22
    npm error path /opt/iobroker/node_modules/iobroker.js-controller
    npm error command failed
    npm error command sh -c node iobroker.js setup first
    npm error creating conf/iobroker.json
    npm error Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    npm error A complete log of this run can be found in: /home/uwe/.npm/_logs/2024-09-15T14_04_09_867Z-debug-0.log
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.178.50:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    da scheint was mit meinem user falsch zu sein
    Ro75R 2 Antworten Letzte Antwort
    • N Nr5lebt
      hallo zusammen,
      library: loaded
      npm error code 22
      Autostart enabled!
      Ro75R Online
      Ro75R Online
      Ro75
      schrieb am zuletzt editiert von Ro75
      @nr5lebt ich denke nicht, dass du OMV und iobroker auf der selben Linux-Installation installiert bekommst. Bei der Installation von OMV wird einiges "gebogen" bei der eigentlichen Linux-Installation. Von daher auch die Anzeige.
      Und wenn du dort drin "rumfriemelst", wird OMV nicht mehr laufen.
      Ro75.
      N 1 Antwort Letzte Antwort
      • Ro75R Ro75
        Ro75.
        N Offline
        N Offline
        Nr5lebt
        @ro75 hmmm, mir ist meines altes nas kaputt gegangen und da hatte ich auch omv und iobroker drauf. allerdings noch unter root
        Ro75R 1 Antwort Letzte Antwort
        • N Nr5lebt
          Ro75R Online
          Ro75R Online
          Ro75
          @nr5lebt ich würde es trennen. Stabilität ist bei einem NAS das Wichtigste. Wenn du mal liest, hier im Forum, wie man so seinen ioBroker durch unbewusstes (nicht vorhandene Wissen oder Halbwissen) quälen und destabilisieren kann, ist es nur ratsam beides zu trennen.
          ioBroker neu aufsetzen ist im Notfall innerhalb von 2 Stunden erledigt. Ein NAS neu aufzusetzen (vor allem die Daten) das dürfte dann schon länger dauern.
          Ro75.
          • Ro75R Ro75
            Ro75.
            Ro75R Online
            Ro75R Online
            Ro75
            ich habe auch OMV im Einsatz. Aber OMV und ioBroker befinden sich auf zwei getrennten Geräten.
            Ro75.
            • Ro75R Ro75
              Ro75.
              N Offline
              N Offline
              Nr5lebt
              @ro75 ich hatte vor jahren versucht iobroker über docker laufen zu lassen hatte aber nur probleme damit. hatte es dann unter omv jahre lang laufen aber wie gesagt unter root. ich denke nicht das das problem bei omv liegt sondern irgendeine einstellung.
              • N Nr5lebt
                hallo zusammen,
                library: loaded
                npm error code 22
                Autostart enabled!
                Ro75R Online
                Ro75R Online
                Ro75
                Die "Updateverwaltung" wurde bei der Installation umgebogen. Die primäre Kontrolle hat OMV, was für meine Begriffe auch korrekt ist.
                Von meiner Seite nur ein Überlegung. Letztlich ist es deine Entscheidung.
                Ro75.
