  4. Milight Adapter Error nach JS Update auf 18.16.1
    1.0k
    6.1k
7 Beiträge 3 Kommentatoren 670 Aufrufe 2 Beobachtet
  • U Offline
    U Offline
    URI3L
    ich habe den JS Controller auf 18.16.1 upgedated und jetzt spuckt der Milight Adapter folgende Fehlermeldungen aus:
    Aus den Fehlermeldungen werde ich nicht schlau. Kann mir jemand bitte helfen?
    2024-09-01 17:12:17.364 - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.milight/milight.js:472
    2024-09-01 17:12:17.364 - error: host.iobroker Caught by controller[0]: adapter = new utils.Adapter(options);
    2024-09-01 17:12:17.364 - error: host.iobroker Caught by controller[0]: ^
    2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: TypeError: utils.Adapter is not a constructor
    2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.milight/milight.js:472:16)
    2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.milight/milight.js:682:5)
    2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2024-09-01 17:12:17.365 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:23:47
    2024-09-01 17:12:17.366 - error: host.iobroker Caught by controller[0]: Node.js v18.16.1
    2024-09-01 17:12:17.367 - error: host.iobroker instance system.adapter.milight.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-09-01 17:12:17.367 - info: host.iobroker Restart adapter system.adapter.milight.2 because enabled
    Thomas BraunT Ro75R 2 Antworten Letzte Antwort
    • U URI3L
      @uri3l Bring es auf nodejs@20 und schau es dir dann nochmal an.
      iob nodejs-update 20
      • U URI3L
        Ro75R Online
        Ro75R Online
        Ro75
        @uri3l sagte in Milight Adapter Error nach JS Update auf 18.16.1:
        von was eigentlich? 16.x? Welches BS läuft denn da (noch) ? GGfs. Debian Buster?
        Ro75
        U 1 Antwort Letzte Antwort
        • Ro75R Ro75
          Ro75
          U Offline
          U Offline
          URI3L
          @ro75 Raspbian 10 ist installiert. Welche Node Version vorher war, kann ich nicht sagen. war aber kein großer Versionssprung, da ich öfters mal update. Könnte man das aus den Backitup-Sicherungen auslesen?
          @Thomas-Braun Wenn ich auf 20 update, kommt folgende Meldung:
          ioBroker nodejs fixer 2024-05-23
          You requested to install latest version from nodejs v20 tree.
          Your current setup is:
          /usr/bin/node 		v18.16.1
          /usr/local/bin/npm 		9.6.7
          /usr/local/bin/npx 		9.6.7
          /usr/local/bin/corepack 	0.18.0
          *** nodejs is NOT correctly installed ***
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 18.16.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
               18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
           *** 18.16.1-deb-1nodesource1 100
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u3 500
          Your nodejs-Installation seems to be faulty. Shall we try to fix it?
          Press <y> to continue or any other key to quit
          Ro75R Thomas BraunT 2 Antworten Letzte Antwort
          • U URI3L
            nodejs:
              Version table:
            Ro75R Online
            Ro75R Online
            Ro75
            @uri3l Mit Buster kommst du nicht auf Nodejs 20! Viel zu alt.
            Ro75.
            • U URI3L
              nodejs:
                Version table:
              @uri3l
              Da siehste auch schon die Fehler. OS zu alt und nodejs ist da irgendwie reingeklatscht worden.
              Installier da NEU ein Raspberry OS 12.
                @uri3l
                U Offline
                U Offline
                URI3L
                @thomas-braun Vielen Dank. Ich bin jetzt auf OS12 und es läuft wieder.
                Danke an alle
