  4. Zigbee Bodenfeuchtesensor: Nur 1 von 3 funzt
    5.1k
26 Beiträge 3 Kommentatoren 3.5k Aufrufe 3 Beobachtet
  • AsgothianA Asgothian
    @delphinis die ieee ist der 16-Stellige wert. Es reichen meistens aber die letzten 6 stellen
    Nachtrag: log Einträge bitte immer in code Tags (</>)
    A.
    Delphinis
    @asgothian
    Hier mal der zweite:
    script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":21248,"dpValues":[{"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,29]}}]},"linkquality":29,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":40,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    ELEVATED publishToState: message received '{"soil_moisture":33}' from device a4c138e06e49cf5d type 'TS0601_soil'
    Hier die ganze Meldegruppe:
    javascript.0
    	2024-08-16 10:53:38.652	warn	script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":22016,"dpValues":[{"dp":14,"datatype":4,"data":{"type":"Buffer","data":[2]}}]},"linkquality":29,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":43,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    javascript.0
    	2024-08-16 10:53:38.532	warn	script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":21760,"dpValues":[{"dp":15,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,70]}}]},"linkquality":29,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":42,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    javascript.0
    	2024-08-16 10:53:38.407	warn	script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":21504,"dpValues":[{"dp":3,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,50]}}]},"linkquality":29,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":41,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    javascript.0
    	2024-08-16 10:53:38.228	warn	script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":21248,"dpValues":[{"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,29]}}]},"linkquality":29,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":40,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2024-08-16 10:51:15.094	warn	ELEVATED publishToState: value generated '"high"' from device a4c138e06e49cf5d for 'State of the battery'
    zigbee.0
    	2024-08-16 10:51:15.094	warn	ELEVATED publishToState: message received '{"battery_state":"high"}' from device a4c138e06e49cf5d type 'TS0601_soil'
    zigbee.0
    	2024-08-16 10:51:15.092	warn	ELEVATED publishToState: value generated '98' from device a4c138e06e49cf5d for 'Link quality'
    zigbee.0
    	2024-08-16 10:51:15.091	warn	ELEVATED publishToState: message received '{"linkquality":98}' from device a4c138e06e49cf5d type 'TS0601_soil'
    zigbee.0
    	2024-08-16 10:51:14.982	warn	ELEVATED publishToState: value generated '100' from device a4c138e06e49cf5d for 'Battery percent'
    zigbee.0
    	2024-08-16 10:51:14.982	warn	ELEVATED publishToState: message received '{"battery":100}' from device a4c138e06e49cf5d type 'TS0601_soil'
    zigbee.0
    	2024-08-16 10:51:14.978	warn	ELEVATED publishToState: value generated '87' from device a4c138e06e49cf5d for 'Link quality'
    zigbee.0
    	2024-08-16 10:51:14.977	warn	ELEVATED publishToState: message received '{"linkquality":87}' from device a4c138e06e49cf5d type 'TS0601_soil'
    zigbee.0
    	2024-08-16 10:51:14.860	warn	ELEVATED publishToState: value generated '33' from device a4c138e06e49cf5d for 'Measured soil moisture value'
    zigbee.0
    	2024-08-16 10:51:14.860	warn	ELEVATED publishToState: message received '{"soil_moisture":33}' from device a4c138e06e49cf5d type 'TS0601_soil'
    zigbee.0
    	2024-08-16 10:51:14.858	warn	ELEVATED publishToState: value generated '98' from device a4c138e06e49cf5d for 'Link quality'
    zigbee.0
    	2024-08-16 10:51:14.857	warn	ELEVATED publishToState: message received '{"linkquality":98}' from device a4c138e06e49cf5d type 'TS0601_soil'
    zigbee.0
    	2024-08-16 10:51:14.747	warn	ELEVATED publishToState: value generated '23' from device a4c138e06e49cf5d for 'Temperature'
    zigbee.0
    	2024-08-16 10:51:14.746	warn	ELEVATED publishToState: message received '{"temperature":23}' from device a4c138e06e49cf5d type 'TS0601_soil'
    zigbee.0
    	2024-08-16 10:51:14.743	warn	ELEVATED publishToState: value generated '94' from device a4c138e06e49cf5d for 'Link quality'
    zigbee.0
    	2024-08-16 10:51:14.742	warn	ELEVATED publishToState: message received '{"linkquality":94}' from device a4c138e06e49cf5d type 'TS0601_soil'
      A.
      Delphinis
      schrieb am zuletzt editiert von Delphinis
      @asgothian
      Der dritte hat nur die eine Meldung herausgespuckt:
      Sorry, das war nicht aus der selben Meldegruppe, hab ich nun hier korrigiert:
      zigbee.0
      	2024-08-16 11:08:58.747	warn	ELEVATED publishToState: message received '{"soil_moisture":87}' from device a4c13860f5c2fffa type 'TS0601_soil'
      zigbee.0
      	2024-08-16 11:08:58.988	warn	ELEVATED publishToState: value generated '"high"' from device a4c13860f5c2fffa for 'State of the battery'
      zigbee.0
      	2024-08-16 11:08:58.988	warn	ELEVATED publishToState: message received '{"battery_state":"high"}' from device a4c13860f5c2fffa type 'TS0601_soil'
      zigbee.0
      	2024-08-16 11:08:58.986	warn	ELEVATED publishToState: value generated '94' from device a4c13860f5c2fffa for 'Link quality'
      zigbee.0
      	2024-08-16 11:08:58.985	warn	ELEVATED publishToState: message received '{"linkquality":94}' from device a4c13860f5c2fffa type 'TS0601_soil'
      zigbee.0
      	2024-08-16 11:08:58.937	warn	ELEVATED publishToState: value generated '90' from device a4c13860f5c2fffa for 'Battery percent'
      zigbee.0
      	2024-08-16 11:08:58.937	warn	ELEVATED publishToState: message received '{"battery":90}' from device a4c13860f5c2fffa type 'TS0601_soil'
      zigbee.0
      	2024-08-16 11:08:58.933	warn	ELEVATED publishToState: value generated '87' from device a4c13860f5c2fffa for 'Link quality'
      zigbee.0
      	2024-08-16 11:08:58.933	warn	ELEVATED publishToState: message received '{"linkquality":87}' from device a4c13860f5c2fffa type 'TS0601_soil'
      zigbee.0
      	2024-08-16 11:08:58.747	warn	ELEVATED publishToState: value generated '87' from device a4c13860f5c2fffa for 'Measured soil moisture value'
      zigbee.0
      zigbee.0
      	2024-08-16 11:08:58.744	warn	ELEVATED publishToState: value generated '91' from device a4c13860f5c2fffa for 'Link quality'
      zigbee.0
      	2024-08-16 11:08:58.744	warn	ELEVATED publishToState: message received '{"linkquality":91}' from device a4c13860f5c2fffa type 'TS0601_soil'
      zigbee.0
      	2024-08-16 11:08:58.644	warn	ELEVATED publishToState: value generated '24' from device a4c13860f5c2fffa for 'Temperature'
      zigbee.0
      	2024-08-16 11:08:58.644	warn	ELEVATED publishToState: message received '{"temperature":24}' from device a4c13860f5c2fffa type 'TS0601_soil'
      zigbee.0
      	2024-08-16 11:08:58.640	warn	ELEVATED publishToState: value generated '91' from device a4c13860f5c2fffa for 'Link quality'
      zigbee.0
      	2024-08-16 11:08:58.640	warn	ELEVATED publishToState: message received '{"linkquality":91}' from device a4c13860f5c2fffa type 'TS0601_soil'
      Hier scheint es, dass da linkquality und soil_moisture teilweise den selben wert haben, aber nicht immer.
      Hier mal alle Meldungen bisher von linkquality und soil_moisture:
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      	2024-08-16 11:04:09.459	warn	ELEVATED publishToState: message received '{"soil_moisture":94}' from device a4c13860f5c2fffa type 'TS0601_soil'
      zigbee.0
      	2024-08-16 11:04:09.455	warn	ELEVATED publishToState: value generated '94' from device a4c13860f5c2fffa for 'Link quality'
      zigbee.0
      zigbee.0
      	2024-08-16 11:01:23.702	warn	ELEVATED publishToState: message received '{"soil_moisture":100}' from device a4c13860f5c2fffa type 'TS0601_soil'
      zigbee.0
      	2024-08-16 11:01:23.698	warn	ELEVATED publishToState: value generated '94' from device a4c13860f5c2fffa for 'Link quality'
      zigbee.0
      	2024-08-16 11:01:23.697	warn	ELEVATED publishToState: message received '{"linkquality":94}' from device a4c13860f5c2fffa type 'TS0601_soil'
      Dieser Sensor ist vermutlich defekt, respektive vielleicht ein bug in der neuen Software. Beide Sensoren mit der neuen Version verhalten sich sehr seltsam. Der eine ist meist bei 90-98% ob sehr trocken oder nass, und der andere zwischen 20 und 60%.
      Muss die wohl wegschmeissen.
      • D Delphinis
        @asgothian
        Ok, ich hab hier mal eine solche Meldungskombination des "vermeintlich" funktionierenden Sensors:
        script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":20480,"dpValues":[{"dp":3,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,52]}}]},"linkquality":32,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":37,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        warn	ELEVATED publishToState: message received '{"soil_moisture":52}' from device a4c138763d011c76 type 'TS0601_soil'
        Aber offensichtlich gibt auch der eine Warning heraus...
        Hier noch alle Meldungen aus der selben sekunde:
        javascript.0
        	2024-08-16 10:41:56.758	warn	script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":20992,"dpValues":[{"dp":14,"datatype":4,"data":{"type":"Buffer","data":[2]}}]},"linkquality":36,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":39,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        	2024-08-16 10:41:56.752	warn	ELEVATED publishToState: value generated '"high"' from device a4c138763d011c76 for 'State of the battery'
        zigbee.0
        	2024-08-16 10:41:56.752	warn	ELEVATED publishToState: message received '{"battery_state":"high"}' from device a4c138763d011c76 type 'TS0601_soil'
        zigbee.0
        	2024-08-16 10:41:56.748	warn	ELEVATED publishToState: value generated '36' from device a4c138763d011c76 for 'Link quality'
        zigbee.0
        	2024-08-16 10:41:56.748	warn	ELEVATED publishToState: message received '{"linkquality":36}' from device a4c138763d011c76 type 'TS0601_soil'
        javascript.0
        	2024-08-16 10:41:56.629	warn	script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":20736,"dpValues":[{"dp":15,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,70]}}]},"linkquality":32,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":38,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        	2024-08-16 10:41:56.630	warn	ELEVATED publishToState: value generated '70' from device a4c138763d011c76 for 'Battery percent'
        zigbee.0
        	2024-08-16 10:41:56.630	warn	ELEVATED publishToState: message received '{"battery":70}' from device a4c138763d011c76 type 'TS0601_soil'
        zigbee.0
        	2024-08-16 10:41:56.627	warn	ELEVATED publishToState: value generated '32' from device a4c138763d011c76 for 'Link quality'
        zigbee.0
        	2024-08-16 10:41:56.627	warn	ELEVATED publishToState: message received '{"linkquality":32}' from device a4c138763d011c76 type 'TS0601_soil'
        javascript.0
        	2024-08-16 10:41:56.510	warn	script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":20480,"dpValues":[{"dp":3,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,52]}}]},"linkquality":32,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":37,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        	2024-08-16 10:41:56.510	warn	ELEVATED publishToState: value generated '52' from device a4c138763d011c76 for 'Measured soil moisture value'
        zigbee.0
        	2024-08-16 10:41:56.510	warn	ELEVATED publishToState: message received '{"soil_moisture":52}' from device a4c138763d011c76 type 'TS0601_soil'
        zigbee.0
        	2024-08-16 10:41:56.506	warn	ELEVATED publishToState: value generated '32' from device a4c138763d011c76 for 'Link quality'
        zigbee.0
        	2024-08-16 10:41:56.506	warn	ELEVATED publishToState: message received '{"linkquality":32}' from device a4c138763d011c76 type 'TS0601_soil'
        javascript.0
        	2024-08-16 10:41:56.335	warn	script.js.Eigene_Scripte.Test.ZigbeeTestBlockly: Msg_From_Zigbee{"type":"commandDataReport","data":{"seq":20224,"dpValues":[{"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,26]}}]},"linkquality":36,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":36,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        	2024-08-16 10:41:56.335	warn	ELEVATED publishToState: value generated '26' from device a4c138763d011c76 for 'Temperature'
        zigbee.0
        	2024-08-16 10:41:56.334	warn	ELEVATED publishToState: message received '{"temperature":26}' from device a4c138763d011c76 type 'TS0601_soil'
        zigbee.0
        	2024-08-16 10:41:56.331	warn	ELEVATED publishToState: value generated '36' from device a4c138763d011c76 for 'Link quality'
        zigbee.0
        	2024-08-16 10:41:56.331	warn	ELEVATED publishToState: message received '{"linkquality":36}' from device a4c138763d011c76 type 'TS0601_soil'
        Sehe mir mal die anderen an...
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @delphinis das sieht schon gut aus. Die beiden zusammenkopierten Meldungen sind genau die nach denen ich gesucht hätte. Wär mal interessant wie die bei den anderen Meldungen aussehen.
        Scheint die Feuchtigkeit vom Sensor zu melden.
        A.
          A.
          Delphinis
          @asgothian
          Hätte nun anydesk mit einem neuen Account installiert, falls du noch lust hast.
          Ich glaube, die zwei Bodenfeuchtigkeitssensoren senden zwar daten (siehe obige Einträge), die technisch korrekt sind, sind aber nicht glaubwürdig. Ich glaube dort ist ein Firmware-Bock in der neuen Version.
          Die kann ich wohl schmeissen..
          Aber den Bewässerungsautomaten hätte ich gerne eingebunden. Wie oben schon mal beschrieben, kann ich den nicht einbinden, obwohl er unter https://www.zigbee2mqtt.io/devices/GX02.html eingetragen ist.
          Das ist auch wieder so ein Tuya TS0601 😁
          Da kommt aber wieder nur so ein halb eingebundener Sensor im Zigbee Adapter:
              modelZigbee:TS0601
              type:EndDevice
              nwk:40485
              manuf id:4417
              manufacturer:_TZE200_7ytb3h8u
              power:Battery
              app version:72
              hard version:1
              zcl version:3
              stack version:0
              date code:
              interviewed:true
              configured:false
              endpoint:1
              profile:260
              input clusters:genGroups (4)
              genScenes (5)
              manuSpecificTuya (61184)
              genBasic (0)
              output clusters:genOta (25)
              genTime (10)
          • D Delphinis
            @asgothian
                modelZigbee:TS0601
                type:EndDevice
                nwk:40485
                manuf id:4417
                power:Battery
                app version:72
                hard version:1
                zcl version:3
                stack version:0
                date code:
                interviewed:true
                configured:false
                endpoint:1
                profile:260
                genScenes (5)
                genBasic (0)
                genTime (10)
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @delphinis das können wir versuchen, aber frühestens Sonntag Nachmittag. Ich bin unterwegs.
            A.
              A.
              Delphinis
              @asgothian
              👍 Ok, muss mal schauen, ob wir dann zuhause sind.
