  4. Wrong Type
    1.0k
    6.1k
Wrong Type
5 Beiträge 3 Kommentatoren 1.0k Aufrufe
  • kmxakK Offline
    kmxakK Offline
    kmxak
    Hi
    habe in den Logs folgende Fehlermeldung:
    javascript.0	2017-09-14 18:51:09.643	warn	Wrong type of javascript.0.User.Alarmserver.Treppenhaus: "boolean". Please fix, while deprecated and will not work in next versions.
      "common": {
        "name": "Treppenhaus",
        "type": "boolean",
        "role": "javascript",
        "read": true,
        "write": true
      "native": {
        "type": "undefined",
        "name": "Name",
        "read": true,
        "write": true
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "javascript.0.User.Alarmserver.Treppenhaus",
      "type": "state"
    Das Script setzt bei dem Objekt true oder false
    Kann mir einer sagen was ich falsch gemacht habe und es mir ggf erklären wieso und warum?
    Hier das Blockly
    <block xmlns="http://www.w3.org/1999/xhtml" type="on" id="N6C2ZjF4]-0asMUuag4`" x="-112" y="-12"><field name="OID">javascript.0.User.Alarmserver.Treppenhaus</field>
    <field name="CONDITION">true</field>
    <statement name="STATEMENT"><block type="control_ex" id="LHY@M73y2DBgl9nNdV,%"><field name="TYPE">false</field>
    <value name="OID"><shadow type="field_oid" id="x9A+=[4oakX[Gp^DLn?v"><field name="oid">javascript.0.scriptEnabled.User.Telegram.Alarm_Bild_Treppenhaus</field></shadow></value>
    <value name="VALUE"><shadow type="logic_boolean" id="x`.4(37R1r9*[7LewyXQ"><field name="BOOL">TRUE</field></shadow></value>
    <value name="DELAY_MS"><shadow type="math_number" id="3%1oXQ2lYz?hRe[]YrFP"><field name="NUM">0</field></shadow></value>
    <next><block type="control_ex" id="vpSJ;5:laVtc!X/TDs;p"><field name="TYPE">true</field>
    <value name="OID"><shadow type="field_oid" id="vw;C`uoF[N@gidGB_U9r"><field name="oid">javascript.0.User.Alarmserver.Treppenhaus</field></shadow></value>
    <value name="VALUE"><shadow type="logic_boolean" id=";gpo*/6nnO_RK``l5SQt"><field name="BOOL">FALSE</field></shadow></value>
    <value name="DELAY_MS"><shadow type="math_number" id="R{utQ?^!d#-lN[W/imNq"><field name="NUM">15000</field></shadow></value>
    <next><block type="debug" id="9Iul0^cpGL/CcnZPX#so"><field name="Severity">debug</field>
    <value name="TEXT"><shadow type="text" id="|LopY4TO7ir8*^T=FSY~"><field name="TEXT">test</field></shadow></value></block></next></block></next></block></statement></block>
    Gruß Alex
    • paul53P Offline
      Sieh so das Objekt wirklich aus ? Wenn ja, dann ist eine öffnende geschweifte Klammer zu viel (1. oder 2. Zeile).
      • kmxakK Offline
        kmxakK Offline
        kmxak
        tippfehler sorry in den objekten ist es richtig
        Gruß Alex
        • apollon77A Offline
          Die Fehlermeldung bedeutet das ein anderer Wert geschrieben wird bei "setState".
          Schick mal den generierten JavaScript code bitte
          • kmxakK Offline
            kmxakK Offline
            kmxak
            on({id: "javascript.0.User.Alarmserver.Treppenhaus"/*Treppenhaus*/, val: true}, function (obj) {
              var value = obj.state.val;
              setStateDelayed('javascript.0.scriptEnabled.User.Telegram.Alarm_Bild_Treppenhaus', true, false, parseInt(0, 10), false);
              setStateDelayed('javascript.0.User.Alarmserver.Treppenhaus', false, true, parseInt(15000, 10), false);
              console.debug('test');
            Bitte
            Gruß Alex
