  4. NPM komplettes Update machen?
32 Beiträge 4 Kommentatoren 6.5k Aufrufe 3 Beobachtet
    mooly
    Hallo zusammen.
    Ich stehe etwas auf dem Schlauch. Warscheinlich eine Noob-Frage ;-)
    Schon ziemlich lange bekomme ich NPM Warnungen (siehe unten).
    Installierte node.js Version: v18.19.0
    Installierte NPM Version: 10.2.3
    Installierter js-controller: 5.0.17
    Muss ich jedes einzelnes NPM Modul zu dem es eine Warnung gibt aktualisieren? Oder kann ich das alles auf einmal machen?
    Einfach nach Anleitung den NPM updaten?
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
    npm WARN deprecated npmlog@5.0.1: This package is no longer supported.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated npmlog@4.1.2: This package is no longer supported.
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm WARN deprecated are-we-there-yet@2.0.0: This package is no longer supported.
    npm WARN deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    npm WARN deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
    npm WARN deprecated npm WARN deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm WARN deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated gauge@3.0.2: This package is no longer supported.
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated gauge@2.7.4: This package is no longer supported.
    • M mooly
      Hallo zusammen.
      @mooly sagte in NPM komplettes Update machen?:
      wo findest du dazu eine Anleitung?
      npm wird nicht upgedatet.
      Das kommt immer passend mit der jeweiligen nodejs Version.
      • M mooly
        Hallo zusammen.
        @mooly
        Nein, einfach die Finger davon lassen. Das muss alles in den jeweiligen Adaptern und deren Dependencies angepackt werden.
        Du könntest aber deine Installation auf nodejs@20 umstellen.
        iob nodejs-update 20
          mooly
          schrieb am zuletzt editiert von mooly
          @homoran @Thomas-Braun
          Danke euch! Ihr habt mir sehr geholfen. Ich lerne noch ;-)
          Ich update auf nodejs 20 wenn ihr das empfehlt.
          Die Warnungen haben mich irritiert und die Installationen dauern auch relativ lange gefühlt.
          • M mooly
            Ja, 20 ist die derzeitige offizielle Empfehlung für den ioBroker.
              mooly
              @thomas-braun said in NPM komplettes Update machen?:
              Sorry, ich muss mich nochmal melden.
              Gibt es eine aktuelle Anleitung wie man auf nodejs 20 updatet? Ich habe nur Anleitungen gefunden die keine Relation zu iobroker haben.
              • M mooly
                @mooly
                Mittels
                iob nodejs-update
                M 2 Antworten Letzte Antwort
                  @mooly
                  Mittels
                  iob nodejs-update
                  mooly
                  Das war die schnellste Antwort die ich je bekommen habe in einem Forum! DANKE!
                    @mooly
                    Mittels
                    iob nodejs-update
                    mooly
                    iob nodejs-update
                    Nothing to do - Your installation is using the correct paths.
                    You are running nodejs v18.19.0. Do you want to install recommended version 18.20.3?
                    Er findet die v20 nicht?
                    • M mooly
                      iob nodejs-update
                      bitte alles zeigen!
                      hier fragt er dich doch noch.
                      was sagt iob diag in der Langfassung?
                      möglich dass für dich noch 18 irgendwo eingetragen ist.
                      • M mooly
                        iob nodejs-update
                        @mooly
                        Die Meldung kommt im Moment noch falsch rein, weil das im ioBroker noch so drin ist.
                        Es wird trotzdem die 20 installiert.
                        Du kannst aber auch per
                        eine Version fest vorgeben.
                          @mooly
                          mooly
                          @Homoran
                          Super! Er ist am installieren...
                            @mooly
                            mooly
                            Es scheint, dass da etwas nicht geklappt hat. -v gibt mir einen Fehler, iobroker läuft nicht.
                            Problem:
                            ioBroker nodejs fixer 2024-05-23
                            You requested to install latest version from nodejs v20 tree.
                            Your current setup is:
                            nodejs: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
                            /usr/bin/nodejs
                            node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
                            /usr/bin/node
                            /usr/bin/npm
                            /usr/bin/npx
                            /usr/bin/corepack
                            We found these nodejs versions available for installation:
                            nodejs:
                              Installed: 20.14.0-1nodesource1
                              Candidate: 20.14.0-1nodesource1
                              Version table:
                             *** 20.14.0-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                    100 /var/lib/dpkg/status
                                 20.13.1-1nodesource1 1001
                                 20.13.0-1nodesource1 1001
                                 20.12.2-1nodesource1 1001
                                 20.12.1-1nodesource1 1001
                                 20.12.0-1nodesource1 1001
                                 20.11.1-1nodesource1 1001
                                 20.11.0-1nodesource1 1001
                                 20.10.0-1nodesource1 1001
                                 20.9.0-1nodesource1 1001
                                 20.8.1-1nodesource1 1001
                                 20.8.0-1nodesource1 1001
                                 20.7.0-1nodesource1 1001
                                 20.6.1-1nodesource1 1001
                                 20.6.0-1nodesource1 1001
                                 20.5.1-1nodesource1 1001
                                 20.5.0-1nodesource1 1001
                                 20.4.0-1nodesource1 1001
                                 20.3.1-1nodesource1 1001
                                 20.3.0-1nodesource1 1001
                                 20.2.0-1nodesource1 1001
                                 20.1.0-1nodesource1 1001
                                 20.0.0-1nodesource1 1001
                                 10.24.0~dfsg-1~deb10u3 500
                            You are running nodejs . Do you want to install latest version from nodejs v.20 tree?
                            Press <y> to continue or any other key to quit
                            Trying to fix your installation now. Please be patient.
                            Waiting for ioBroker to shut down - Give me a minute...
                            *** These repos are active on your system:
                            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            Hit:3 https://repo.homebridge.io stable InRelease
                            Reading package lists... Done
                            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                            Package: nodejs
                            Pin: origin deb.nodesource.com
                            Pin-Priority: 1001
                            *** These repos are active after the adjustments:
                            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                            Get:3 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                            Hit:4 https://repo.homebridge.io stable InRelease
                            Get:5 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [7805 B]
                            Fetched 19.9 kB in 1s (18.8 kB/s)
                            Installing nodejs now!
                            /home/iobroker/.nodejs-update.sh: line 370: [: : integer expression expected
                            Exact recommended version unknown, installing a fallback!
                            dpkg: warning: downgrading nodejs from 20.14.0-1nodesource1 to 20.0.0-1nodesource1
                            (Reading database ... 127364 files and directories currently installed.)
                            Preparing to unpack .../nodejs_20.0.0-1nodesource1_armhf.deb ...
                            Detected old npm client, removing...
                            Unpacking nodejs (20.0.0-1nodesource1) over (20.14.0-1nodesource1) ...
                            Setting up nodejs (20.0.0-1nodesource1) ...
                            Processing triggers for man-db (2.8.5-2+deb10u1) ...
                            Updating fallback to latest nodejs v20 release
                            (Reading database ... 127448 files and directories currently installed.)
                            Preparing to unpack .../nodejs_20.14.0-1nodesource1_armhf.deb ...
                            Unpacking nodejs (20.14.0-1nodesource1) over (20.0.0-1nodesource1) ...
                            Setting up nodejs (20.14.0-1nodesource1) ...
                             has been installed! You are using the latest version now!
                            /home/iobroker/.nodejs-update.sh: line 387: [: : integer expression expected
                            Installing the nodejs!
                            We tried our best to fix your nodejs. Please run iob diag again to verify.
                            *** RESTARTING ioBroker NOW! ***
                             Please refresh or restart your browser in a few moments.
                            pi@raspberrypi:~ $ node -v
                            • M mooly
                              Problem:
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              /usr/bin/npx
                              /usr/bin/corepack
                              nodejs:
                                Version table:
                              Package: nodejs
                              Pin-Priority: 1001
                              @mooly
                              Dein Problem ist, das du mit einem veralteten Betreibssyystem herumfährst. Das hat keinen TÜV mehr.
                              Ersetz das durch ein aktuelles Debain 12 'Bookworm'.
                                @mooly
                                mooly
                                Kann ich sonst nichts mehr machen? kann ich zurück auf version 18?
                                Ich muss mich damit beschäftigen wenn das jetzt in ein komplettes update ausartet... shit
                                Hab ich jetzt das ganze System zerschossen...
                                • M mooly
                                  Du hast das System durch deine Untätigkeit zerschossen. Buster ist schon geraume Zeit nicht mehr angezeigt gewesen.
                                  iob nodejs-update 18
                                  Dann mit einem Backup von der Kiste auf was lebendiges umziehen...
                                    mooly
                                    Ja, das stimmt wohl.
                                    pi@raspberrypi:/opt/iobroker $ node -v
                                    18.19.0 hat nicht funktioniert, gleicher Fehler.
                                    You requested to install latest version from nodejs v18 tree.
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/bin/npx
                                    /usr/bin/corepack
                                    nodejs:
                                      Version table:
                                    You are running nodejs . Do you want to install latest version from nodejs v.18 tree?
                                    @Thomas-Braun er scheint die alte Version nicht zu installieren...
                                    • M mooly
                                      @homoran sagte in NPM komplettes Update machen?:
                                      damit wüssten wir deutlich mehr.
                                      • M mooly
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        /usr/bin/npx
                                        /usr/bin/corepack
                                        nodejs:
                                          Version table:
                                        @mooly
                                        Dann was aktuelles installieren, mit deinem Backup umziehen.
                                          mooly
                                          ======== Start marking the full check here =========
                                          Skript v.2024-05-22
                                          *** BASE SYSTEM ***
                                             Static hostname: raspberrypi
                                                   Icon name: computer
                                            Operating System: Raspbian GNU/Linux 10 (buster)
                                                      Kernel: Linux 5.10.103-v7l+
                                                Architecture: arm
                                          Model		: Raspberry Pi 4 Model B Rev 1.4
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : armv7l
                                          Userland        : 32 bit
                                          Systemuptime and Load:
                                           14:52:03 up 2 min,  1 user,  load average: 3.02, 1.11, 0.41
                                          CPU threads: 4
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          *** Time and Time Zones ***
                                                         Local time: Thu 2024-06-20 14:52:03 CEST
                                                     Universal time: Thu 2024-06-20 12:52:03 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          pi
                                          HOME=/home/pi
                                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          *** Display-Server-Setup ***
                                          Display-Server: false
                                          Desktop:
                                          Terminal: 	tty
                                          Boot Target: 	graphical.target
                                          *** MEMORY ***
                                          Mem:           3.8G        1.3G        1.8G        8.0M        672M        2.3G
                                          Swap:           99M          0B         99M
                                          Total:         3.9G        1.3G        1.9G
                                          Active iob-Instances: 	15
                                                   3837 M total memory
                                                   1342 M used memory
                                                    214 M active memory
                                                   1666 M inactive memory
                                                   1822 M free memory
                                                    115 M buffer memory
                                                    557 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          top - 14:52:04 up 2 min,  1 user,  load average: 3.02, 1.11, 0.41
                                          Tasks: 162 total,   5 running, 157 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 68.5 us, 12.3 sy,  0.0 ni, 17.8 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
                                          MiB Mem :   3837.7 total,   1797.7 free,   1367.4 used,    672.6 buff/cache
                                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2310.0 avail Mem
                                          *** FAILED SERVICES ***
                                            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                                          * lightdm.service loaded failed failed Light Display Manager
                                          1 loaded units listed. Pass --all to see loaded but inactive units, too.
                                          To show all installed unit files use 'systemctl list-unit-files'.
                                          *** FILESYSTEM ***
                                          /dev/root      ext4      110G   17G   89G  16% /
                                          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                                          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                          tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
                                          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                                          /dev/sda1      vfat      253M   49M  204M  20% /boot
                                          tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                                          [Thu Jun 20 14:49:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:14:A2:2C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                          [Thu Jun 20 14:50:01 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                          [Thu Jun 20 14:50:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                          [Thu Jun 20 14:50:02 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                                          Show mounted filesystems:
                                          TARGET                                SOURCE     FSTYPE     OPTIONS
                                          /                                     /dev/sda2  ext4       rw,noatime
                                          |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=1800056k,nr_inodes=84157,mode=755
                                          | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
                                          | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                          | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
                                          |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
                                          | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
                                          | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
                                          | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
                                          | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                                          | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
                                          | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
                                          | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
                                          | | |-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
                                          | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
                                          | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
                                          | | `-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
                                          | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                                          | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
                                          | `-/sys/kernel/config                configfs   configfs   rw,relatime
                                          |-/proc                               proc       proc       rw,relatime
                                          | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=37,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                          |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
                                          | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                                          | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
                                          | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid=1000
                                          `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          2.5G	/var/
                                          2.0G	/var/cache/apt/archives
                                          2.0G	/var/cache/apt
                                          2.0G	/var/cache
                                          260M	/var/lib
                                          Archived and active journals take up 8.0M in the file system.
                                          /opt/iobroker/backups:
                                          287M	/opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          743M	/opt/iobroker/iobroker-data/
                                          360M	/opt/iobroker/iobroker-data/files
                                          204M	/opt/iobroker/iobroker-data/history
                                          126M	/opt/iobroker/iobroker-data/backup-objects
                                          57M	/opt/iobroker/iobroker-data/files/javascript.admin
                                          38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
                                          28M	/opt/iobroker/iobroker-data/objects.jsonl
                                          22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                                          13M	/opt/iobroker/iobroker-data/states.jsonl
                                          9.6M	/opt/iobroker/iobroker-data/files/vis.0/WohnEss301022.png
                                          USB-Devices by-id:
                                          /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                          /dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO75C42C-if00-port0
                                          HINT:
                                          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                          /dev/ttyUSB0
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs 	v18.20.3
                                          /usr/bin/node 		v18.20.3
                                          /usr/bin/npm 		10.7.0
                                          /usr/bin/npx 		10.7.0
                                          /usr/bin/corepack 	0.28.0
                                          nodejs:
                                            Installed: 18.20.3-1nodesource1
                                            Candidate: 18.20.3-1nodesource1
                                            Version table:
                                           *** 18.20.3-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                               18.20.2-1nodesource1 1001
                                               18.20.1-1nodesource1 1001
                                               18.20.0-1nodesource1 1001
                                               18.19.1-1nodesource1 1001
                                               18.19.0-1nodesource1 1001
                                               18.18.2-1nodesource1 1001
                                               18.18.1-1nodesource1 1001
                                               18.18.0-1nodesource1 1001
                                               18.17.1-1nodesource1 1001
                                               18.17.0-1nodesource1 1001
                                               18.16.1-1nodesource1 1001
                                               18.16.0-1nodesource1 1001
                                               18.15.0-1nodesource1 1001
                                               18.14.2-1nodesource1 1001
                                               18.14.1-1nodesource1 1001
                                               18.14.0-1nodesource1 1001
                                               18.13.0-1nodesource1 1001
                                               18.12.0-1nodesource1 1001
                                               18.11.0-1nodesource1 1001
                                               18.10.0-1nodesource1 1001
                                               18.9.1-1nodesource1 1001
                                               18.9.0-1nodesource1 1001
                                               18.8.0-1nodesource1 1001
                                               18.7.0-1nodesource1 1001
                                               18.6.0-1nodesource1 1001
                                               18.5.0-1nodesource1 1001
                                               18.4.0-1nodesource1 1001
                                               18.3.0-1nodesource1 1001
                                               18.2.0-1nodesource1 1001
                                               18.1.0-1nodesource1 1001
                                               18.0.0-1nodesource1 1001
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller: 	6.0.5
                                          admin: 		6.17.14
                                          javascript: 	7.8.0
                                          nodejs modules from github: 	0
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                            system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                            system.adapter.enocean.0                : enocean               : raspberrypi                              -  enabled
                                            system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
                                            system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                                            system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
                                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                                          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                            system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
                                          + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                                            system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                                          + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
                                          + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                                          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1888, bind: 0.0.0.0
                                            system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                                          + system.adapter.tahoma.0                 : tahoma                : raspberrypi                              -  enabled
                                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                                            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
                                            system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                                            system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                                            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
                                            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                            system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): beta
                                          Installed ioBroker-Instances
                                          Used repository: beta
                                          Adapter    "admin"        : 6.17.14  , installed 6.17.14
                                          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                          Adapter    "backitup"     : 3.0.5    , installed 2.11.0 [Updatable]
                                          Adapter    "cloud"        : 5.0.1    , installed 4.4.1  [Updatable]
                                          Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
                                          Adapter    "enocean"      : 0.9.3    , installed 0.9.3
                                          Adapter    "eusec"        : 1.2.1    , installed 1.2.1
                                          Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                          Adapter    "iot"          : 3.3.0    , installed 3.2.2  [Updatable]
                                          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                          Adapter    "javascript"   : 8.6.0    , installed 7.8.0  [Updatable]
                                          Controller "js-controller": 6.0.5    , installed 6.0.5
                                          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                          Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.1  [Updatable]
                                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                          Adapter    "nuki"         : 2.0.0    , installed 1.6.0  [Updatable]
                                          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                                          Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
                                          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                          Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                                          Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
                                          Adapter    "ring"         : 5.0.10   , installed 5.0.10
                                          Adapter    "scenes"       : 3.0.4    , installed 2.4.2  [Updatable]
                                          Adapter    "shelly"       : 7.0.0    , installed 6.8.0  [Updatable]
                                          Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
                                          Adapter    "tado"         : 0.5.4    , installed 0.5.4
                                          Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
                                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.3.7  [Updatable]
                                          Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
                                          Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                                          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
                                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
                                          Adapter    "vis-map"      : 1.1.0    , installed 1.0.5  [Updatable]
                                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                          Adapter    "weatherunderground": 3.7.0, installed 3.6.0 [Updatable]
                                          Adapter    "web"          : 6.2.6    , installed 6.2.3  [Updatable]
                                          Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
                                          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                          Objects and States
                                          Objects: 	6795
                                          States: 	5643
                                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 127.0.0.1:39793         0.0.0.0:*               LISTEN      1001       22982      1144/io.yahka.0
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17272      625/sshd
                                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16965      439/cupsd
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20193      940/io.mqtt.0
                                          tcp        0      0 127.0.0.1:34751         0.0.0.0:*               LISTEN      1001       22978      1144/io.yahka.0
                                          tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       21698      960/io.shelly.0
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19732      613/iobroker.js-con
                                          tcp        0      0 127.0.0.1:38473         0.0.0.0:*               LISTEN      1001       23309      1144/io.yahka.0
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20777      613/iobroker.js-con
                                          tcp        0      0 127.0.0.1:41775         0.0.0.0:*               LISTEN      1001       23166      1144/io.yahka.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21089      710/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22650      1064/io.web.0
                                          tcp6       0      0 :::38389                :::*                    LISTEN      1001       24210      1144/io.yahka.0
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          17274      625/sshd
                                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16964      439/cupsd
                                          tcp6       0      0 :::1984                 :::*                    LISTEN      1001       29129      2768/go2rtc
                                          tcp6       0      0 :::8581                 :::*                    LISTEN      116        19012      683/hb-service
                                          tcp6       0      0 :::51399                :::*                    LISTEN      116        19063      717/homebridge
                                          tcp6       0      0 :::8554                 :::*                    LISTEN      1001       29123      2768/go2rtc
                                          tcp6       0      0 :::8555                 :::*                    LISTEN      1001       29126      2768/go2rtc
                                          udp        0      0 0.0.0.0:43996           0.0.0.0:*                           1001       29045      1791/io.eusec.0
                                          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       21600      893/io.radar2.0
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17043      612/dhcpcd
                                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17531      472/cups-browsed
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        19064      717/homebridge
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        19009      683/hb-service
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15689      418/avahi-daemon: r
                                          udp        0      0 0.0.0.0:60685           0.0.0.0:*                           108        15691      418/avahi-daemon: r
                                          udp        0      0 0.0.0.0:35679           0.0.0.0:*                           1001       29040      1791/io.eusec.0
                                          udp6       0      0 :::5353                 :::*                                108        15690      418/avahi-daemon: r
                                          udp6       0      0 :::58643                :::*                                108        15692      418/avahi-daemon: r
                                          udp6       0      0 :::8555                 :::*                                1001       29127      2768/go2rtc
                                          2024-06-20 14:51:58.764  - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
                                          2024-06-20 14:52:00.990  - info: iot.0 (1244) Connection changed: connect "pascal_pbennoit_de"
                                          2024-06-20 14:52:01.369  - info: host.raspberrypi instance system.adapter.pvforecast.0 started with pid 2067
                                          2024-06-20 14:52:01.733  - info: tado.0 (1508) starting. Version 0.5.4 in /opt/iobroker/node_modules/iobroker.tado, node: v18.20.3, js-controller: 6.0.5
                                          2024-06-20 14:52:01.867  - info: tado.0 (1508) Started with JSON-Explorer version 0.1.15
                                          2024-06-20 14:52:04.148  - info: tado.0 (1508) Connected to Tado cloud, initialyzing...
                                          2024-06-20 14:52:05.940  - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 2313
                                          2024-06-20 14:52:07.712  - info: vis-inventwo.0 (1769) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.20.3, js-controller: 6.0.5
                                          2024-06-20 14:52:08.078  - info: opendtu.0 (1794) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.opendtu, node: v18.20.3, js-controller: 6.0.5
                                          2024-06-20 14:52:08.596  - info: eusec.0 (1791) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.3, js-controller: 6.0.5
                                          2024-06-20 14:52:09.044  - info: info.0 (1031) Reading network data every 3 seconds.
                                          2024-06-20 14:52:09.147  - info: opendtu.0 (1794) Connect to OpenDTU over websocket connection.
                                          2024-06-20 14:52:18.398  - info: eusec.0 (1791) Connected to station T8010P2322101A9A on host 192.168.0.24 and port 16267
                                          2024-06-20 14:52:19.340  - info: enocean.0 (2313) starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.enocean, node: v18.20.3, js-controller: 6.0.5
                                          2024-06-20 14:52:19.429  - info: pvforecast.0 (2067) starting. Version 2.9.1 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v18.20.3, js-controller: 6.0.5
                                          2024-06-20 14:52:19.417  - error: eusec.0 (1791) Station: T8010P2322101A9A command CMD_SDINFO_EX failed with error: undefined (-148)
                                          2024-06-20 14:52:20.116  - warn: enocean.0 (2313) An error occured at serial port: Error: Error Resource temporarily unavailable Cannot lock port
                                          2024-06-20 14:52:20.358  - info: eusec.0 (1791) go2rtc started: 14:52:19.735 INF go2rtc version 1.8.5 linux/arm
                                          14:52:19.738 INF [rtsp] listen addr=:8554
                                          14:52:19.739 INF [api] listen addr=:1984
                                          14:52:19.741 INF [webrtc] listen addr=:8555
                                          2024-06-20 14:52:25.111  - info: tado.0 (1508) Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
                                          2024-06-20 14:52:28.793  - info: pvforecast.0 (2067) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
                                          2024-06-20 14:52:32.628  - info: eusec.0 (1791) Push notification connection successfully established
                                          iob diag has finished.
                                          Press any key for a summary
