  4. Test Adapter Telegram 3.4.1 - Blockly-Bausteine für Fragen
    6.0k
21 Beiträge 9 Kommentatoren 4.8k Aufrufe 15 Beobachtet
    bye08
    sowas habe ich auch schon länger gesucht.
    leider stürzt mein Telegram Adapater auch immer ab.
    anbei den LOG.
    Hoffe mir kann jemand helfen.
    Telegram 4.1.0
    Javascript 8.9.2
    ansonsten ist auch alles andere aktuell.
    2025-06-12 12:03:16.260 - error: telegram.0 (5815) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-06-12 12:03:16.261 - error: telegram.0 (5815) unhandled promise rejection: ETELEGRAM: 400 Bad Request: message to edit not found
    2025-06-12 12:03:16.262 - error: telegram.0 (5815) Error: ETELEGRAM: 400 Bad Request: message to edit not found
    at /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:316:15
    at tryCatcher (/opt/iobroker/node_modules/bluebird/js/release/util.js:16:23)
    at Promise._settlePromiseFromHandler (/opt/iobroker/node_modules/bluebird/js/release/promise.js:547:31)
    at Promise._settlePromise (/opt/iobroker/node_modules/bluebird/js/release/promise.js:604:18)
    at Promise._settlePromise0 (/opt/iobroker/node_modules/bluebird/js/release/promise.js:649:10)
    at Promise._settlePromises (/opt/iobroker/node_modules/bluebird/js/release/promise.js:729:18)
    at _drainQueueStep (/opt/iobroker/node_modules/bluebird/js/release/async.js:93:12)
    at _drainQueue (/opt/iobroker/node_modules/bluebird/js/release/async.js:86:9)
    at Async._drainQueues (/opt/iobroker/node_modules/bluebird/js/release/async.js:102:5)
    at Immediate.Async.drainQueues [as _onImmediate] (/opt/iobroker/node_modules/bluebird/js/release/async.js:15:14)
    at processImmediate (node:internal/timers:483:21)
    2025-06-12 12:03:16.262 - error: telegram.0 (5815) Exception-Code: ETELEGRAM: ETELEGRAM: 400 Bad Request: message to edit not found
    2025-06-12 12:03:16.792 - info: telegram.0 (5815) terminating
    2025-06-12 12:03:16.796 - warn: telegram.0 (5815) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-06-12 12:03:17.797 - info: telegram.0 (5815) terminating with timeout
    2025-06-12 12:03:18.044 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-06-12 12:03:18.045 - error: host.raspberrypi Caught by controller[1]: Error: ETELEGRAM: 400 Bad Request: message to edit not found
    2025-06-12 12:03:18.046 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:316:15
    2025-06-12 12:03:18.046 - error: host.raspberrypi Caught by controller[1]: at tryCatcher (/opt/iobroker/node_modules/bluebird/js/release/util.js:16:23)
    2025-06-12 12:03:18.046 - error: host.raspberrypi Caught by controller[1]: at Promise._settlePromiseFromHandler (/opt/iobroker/node_modules/bluebird/js/release/promise.js:547:31)
    2025-06-12 12:03:18.046 - error: host.raspberrypi Caught by controller[1]: at Promise._settlePromise (/opt/iobroker/node_modules/bluebird/js/release/promise.js:604:18)
    2025-06-12 12:03:18.046 - error: host.raspberrypi Caught by controller[1]: at Promise._settlePromise0 (/opt/iobroker/node_modules/bluebird/js/release/promise.js:649:10)
    2025-06-12 12:03:18.046 - error: host.raspberrypi Caught by controller[1]: at Promise._settlePromises (/opt/iobroker/node_modules/bluebird/js/release/promise.js:729:18)
    2025-06-12 12:03:18.047 - error: host.raspberrypi Caught by controller[1]: at _drainQueueStep (/opt/iobroker/node_modules/bluebird/js/release/async.js:93:12)
    2025-06-12 12:03:18.047 - error: host.raspberrypi Caught by controller[1]: at _drainQueue (/opt/iobroker/node_modules/bluebird/js/release/async.js:86:9)
    2025-06-12 12:03:18.047 - error: host.raspberrypi Caught by controller[1]: at Async._drainQueues (/opt/iobroker/node_modules/bluebird/js/release/async.js:102:5)
    2025-06-12 12:03:18.047 - error: host.raspberrypi Caught by controller[1]: at Immediate.Async.drainQueues [as _onImmediate] (/opt/iobroker/node_modules/bluebird/js/release/async.js:15:14)
    2025-06-12 12:03:18.047 - error: host.raspberrypi Caught by controller[1]: at processImmediate (node:internal/timers:483:21)
    2025-06-12 12:03:18.048 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
