  4. FritzBox Zigbee Antenne in ioBroker einbinden?
    5.8k
47 Beiträge 13 Kommentatoren 11.2k Aufrufe 11 Beobachtet
  • S searcher57
    @homoran said in FritzBox Zigbee Antenne in ioBroker einbinden?:
    @searcher57 sagte in FritzBox Zigbee Antenne in ioBroker einbinden?:
    Hier das Protokoll:
    bitte keinen Screenshot!
    als Text in code-tags posten.
    Bitte erkläre das!
    #41
    Bitte erkläre das!
    Jetzt bin ich überfordert, was genau bedarf zusätzlicher Erklärung?
    • S searcher57
      Hier das Protokoll:
      Bitte erkläre das!
      searcher57
      #42
      @searcher57 said in FritzBox Zigbee Antenne in ioBroker einbinden?:
      Hier das Protokoll:
      Bitte erkläre das!
      v7.6.3
      233
      Log-Größe: 439.1 KB
      Zeit
      smartmeter.0
      	2025-05-07 18:18:49.740	info	Received 13 values, 8 updated
      host.Raspi58GB
      	2025-05-07 18:16:52.611	info	instance system.adapter.openweathermap.0 having pid 2720211 terminated with code 0 (NO_ERROR)
      openweathermap.0
      	2025-05-07 18:16:52.102	info	Terminated (NO_ERROR): Without reason
      openweathermap.0
      	2025-05-07 18:16:43.181	info	starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 18:16:42.020	info	instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 2720211
      awtrix-light.0
      	2025-05-07 18:15:45.576	info	error ECONNABORTED from stats: timeout of 3000ms exceeded
      smartmeter.0
      	2025-05-07 18:13:46.108	info	Received 13 values, 8 updated
      smartmeter.0
      	2025-05-07 18:08:42.387	info	Received 13 values, 8 updated
      smartmeter.0
      	2025-05-07 18:03:38.767	info	Received 13 values, 6 updated
      smartmeter.0
      	2025-05-07 17:58:37.701	info	Received 13 values, 6 updated
      smartmeter.0
      	2025-05-07 17:53:36.342	info	Received 13 values, 6 updated
      zigbee.0
      	2025-05-07 17:50:17.995	info	Starting Zigbee-Herdsman
      zigbee.0
      	2025-05-07 17:50:17.994	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
      zigbee.0
      	2025-05-07 17:50:17.978	info	Starting Adapter npm ...
      zigbee.0
      	2025-05-07 17:50:17.977	info	--- creating device debug ---
      zigbee.0
      	2025-05-07 17:50:17.972	info	--> transmitPower : normal
      zigbee.0
      	2025-05-07 17:50:17.969	info	init localConfig
      zigbee.0
      	2025-05-07 17:50:17.959	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:50:16.818	info	instance system.adapter.zigbee.0 in version "2.0.5" started with pid 2716727
      host.Raspi58GB
      	2025-05-07 17:50:13.485	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zigbee.0
      	2025-05-07 17:50:13.441	info	terminating
      host.Raspi58GB
      	2025-05-07 17:50:13.008	info	stopInstance system.adapter.zigbee.0 send kill signal
      zigbee.0
      	2025-05-07 17:50:12.988	info	terminating
      zigbee.0
      	2025-05-07 17:50:12.988	warn	Failed to stop zigbee during startup
      zigbee.0
      	2025-05-07 17:50:12.987	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:315:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
      zigbee.0
      	2025-05-07 17:50:12.940	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      	2025-05-07 17:50:12.939	info	terminating
      zigbee.0
      	2025-05-07 17:50:12.938	info	Saved local configuration data
      zigbee.0
      	2025-05-07 17:50:12.937	info	local config saved
      zigbee.0
      	2025-05-07 17:50:12.936	info	cleaned everything up...
      zigbee.0
      	2025-05-07 17:50:12.935	info	Got terminate signal TERMINATE_YOURSELF
      host.Raspi58GB
      	2025-05-07 17:50:12.932	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      zigbee.0
      	2025-05-07 17:50:07.445	info	Starting Zigbee-Herdsman
      zigbee.0
      	2025-05-07 17:50:07.444	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
      zigbee.0
      	2025-05-07 17:50:07.428	info	Starting Adapter npm ...
      zigbee.0
      	2025-05-07 17:50:07.427	info	--- creating device debug ---
      zigbee.0
      	2025-05-07 17:50:07.422	info	--> transmitPower : normal
      zigbee.0
      	2025-05-07 17:50:07.419	info	init localConfig
      zigbee.0
      	2025-05-07 17:50:07.409	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:50:06.159	info	instance system.adapter.zigbee.0 in version "2.0.5" started with pid 2716711
      admin.0
      	2025-05-07 17:49:59.324	info	<== Disconnect system.user.admin from ::ffff:192.168.178.120
      host.Raspi58GB
      	2025-05-07 17:49:35.710	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	Caught by controller[1]: at processImmediate (node:internal/timers:483:21)
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	Caught by controller[1]: at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:368:37)
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	Caught by controller[1]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10953:34)
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	Caught by controller[1]: at Zigbee.emit (node:domain:489:12)
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	Caught by controller[1]: at Zigbee.emit (node:events:536:35)
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	Caught by controller[1]: at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:20:48)
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	Caught by controller[1]: at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:155:97)
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'CleanupRequired')
      host.Raspi58GB
      	2025-05-07 17:49:35.710	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      zigbee.0
      	2025-05-07 17:49:35.667	info	terminating
      zigbee.0
      	2025-05-07 17:49:35.191	info	terminating
      zigbee.0
      	2025-05-07 17:49:35.191	warn	Failed to stop zigbee during startup
      zigbee.0
      	2025-05-07 17:49:35.187	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:315:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
      zigbee.0
      	2025-05-07 17:49:35.167	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      	2025-05-07 17:49:35.167	info	terminating
      zigbee.0
      	2025-05-07 17:49:35.166	info	Saved local configuration data
      zigbee.0
      	2025-05-07 17:49:35.165	info	local config saved
      zigbee.0
      	2025-05-07 17:49:35.165	info	cleaned everything up...
      zigbee.0
      	2025-05-07 17:49:35.151	error	Cannot read properties of undefined (reading 'CleanupRequired')
      zigbee.0
      	2025-05-07 17:49:35.150	error	TypeError: Cannot read properties of undefined (reading 'CleanupRequired') at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:155:97) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:20:48) at Zigbee.emit (node:events:536:35) at Zigbee.emit (node:domain:489:12) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10953:34) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:368:37) at processImmediate (node:internal/timers:483:21)
      zigbee.0
      	2025-05-07 17:49:35.031	error	unhandled promise rejection: Cannot read properties of undefined (reading 'CleanupRequired')
      zigbee.0
      	2025-05-07 17:49:35.031	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      admin.0
      	2025-05-07 17:49:34.977	info	==> Connected system.user.admin from ::ffff:192.168.178.120
      web.0
      	2025-05-07 17:49:29.651	info	socket.io server listening on port 8082
      web.0
      	2025-05-07 17:49:29.562	info	http server listening on port 8082
      web.0
      	2025-05-07 17:49:29.444	info	starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:49:28.305	info	instance system.adapter.web.0 in version "7.0.8" started with pid 2716693
      vis-2.0
      	2025-05-07 17:49:25.387	info	vis-2 license is OK.
      vis-2.0
      	2025-05-07 17:49:25.212	info	starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:49:24.266	info	instance system.adapter.vis-2.0 in version "2.9.64" started with pid 2716678
      text2command.0
      	2025-05-07 17:49:21.593	info	starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.text2command, node: v20.19.1, js-controller: 7.0.6
      tankerkoenig.0
      	2025-05-07 17:49:20.815	info	Start first request
      host.Raspi58GB
      	2025-05-07 17:49:20.263	info	instance system.adapter.text2command.0 in version "3.0.3" started with pid 2716641
      shelly.1
      	2025-05-07 17:49:19.622	info	[MQTT] Device with client id "shellyplusplugs-b0b21c0ec52c" connected from 192.168.178.100!
      tankerkoenig.0
      	2025-05-07 17:49:17.228	info	Sync time set to 30 minutes or 1800000 ms
      tankerkoenig.0
      	2025-05-07 17:49:17.228	info	Adapter is already in daemon mode
      tankerkoenig.0
      	2025-05-07 17:49:17.209	info	starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:49:16.258	info	instance system.adapter.tankerkoenig.0 in version "3.4.0" started with pid 2716626
      simple-api.0
      	2025-05-07 17:49:13.410	info	http server listening on port 8087
      simple-api.0
      	2025-05-07 17:49:13.403	info	Allow states only when user is owner: false
      simple-api.0
      	2025-05-07 17:49:13.402	info	simpleAPI server listening on port 8087
      simple-api.0
      	2025-05-07 17:49:13.391	info	starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.simple-api, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:49:12.374	info	instance system.adapter.simple-api.0 in version "2.8.0" started with pid 2716611
      host.Raspi58GB
      	2025-05-07 17:49:12.321	info	instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      yr.0
      	2025-05-07 17:49:11.492	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      yr.0
      	2025-05-07 17:49:11.492	info	Data updated.
      iot.0
      	2025-05-07 17:49:10.166	info	Connection changed: connect "wolff_netphen_web_de"
      iot.0
      	2025-05-07 17:49:09.557	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.0
      	2025-05-07 17:49:09.511	info	starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:49:08.279	info	instance system.adapter.iot.0 in version "3.3.0" started with pid 2716594
      fritzdect.0
      	2025-05-07 17:49:08.240	error	login not possible, check user and permissions
      fritzdect.0
      	2025-05-07 17:49:08.239	error	API err => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
      fritzdect.0
      	2025-05-07 17:49:08.239	error	no response part in returned error message
      fritzdect.0
      	2025-05-07 17:49:08.239	error	API funct => login_SID
      fritzdect.0
      	2025-05-07 17:49:08.238	error	API msg => error calling executeCommand
      fritzdect.0
      	2025-05-07 17:49:08.237	error	--------------- error calling the fritzbox -----------
      fritzdect.0
      	2025-05-07 17:49:06.316	info	fritzdect uses USER: admin
      fritzdect.0
      	2025-05-07 17:49:06.300	info	fritzdect entered ready
      fritzdect.0
      	2025-05-07 17:49:06.286	info	starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v20.19.1, js-controller: 7.0.6
      shelly.1
      	2025-05-07 17:49:05.550	info	[MQTT] Device with client id "shellyplusplugs-d48afc7b9540" connected from 192.168.178.96!
      shelly.1
      	2025-05-07 17:49:05.278	info	[MQTT] Device with client id "shellyplusplugs-e465b8b302bc" connected from 192.168.178.95!
      host.Raspi58GB
      	2025-05-07 17:49:05.003	info	instance system.adapter.fritzdect.0 in version "2.6.1" started with pid 2716579
      followthesun.0
      	2025-05-07 17:49:03.027	info	Daily sun parameter calculation scheduled for 00:00:36
      followthesun.0
      	2025-05-07 17:49:03.026	info	Sun position calculation will be done every 60 seconds
      followthesun.0
      	2025-05-07 17:49:03.025	info	Started with JSON-Explorer version 0.1.16
      followthesun.0
      	2025-05-07 17:49:03.014	info	starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.followthesun, node: v20.19.1, js-controller: 7.0.6
      shelly.1
      	2025-05-07 17:49:01.927	info	[MQTT] Device with client id "shellyplusplugs-e465b8456ff4" connected from 192.168.178.98!
      host.Raspi58GB
      	2025-05-07 17:49:01.537	info	instance system.adapter.followthesun.0 in version "0.5.2" started with pid 2716564
      shelly.1
      	2025-05-07 17:49:00.901	info	[MQTT] Device with client id "shellyplusplugs-b0b21c1243bc" connected from 192.168.178.102!
      shelly.1
      	2025-05-07 17:48:56.540	info	[MQTT] Device with client id "shellyplusplugs-d48afc7a4830" connected from 192.168.178.97!
      echarts.0
      	2025-05-07 17:48:54.613	info	starting. Version 1.9.2 in /opt/iobroker/node_modules/iobroker.echarts, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:48:53.726	info	instance system.adapter.echarts.0 in version "1.9.2" started with pid 2716549
      doorbird.0
      	2025-05-07 17:48:51.398	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.doorbird, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:48:50.532	info	instance system.adapter.doorbird.0 in version "3.0.0" started with pid 2716534
      discovery.0
      	2025-05-07 17:48:47.316	info	starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.19.1, js-controller: 7.0.6
      shelly.1
      	2025-05-07 17:48:46.772	info	[MQTT] Device with client id "shellyplus1pm-d48afc598e4c" connected from 192.168.178.94!
      host.Raspi58GB
      	2025-05-07 17:48:46.199	info	instance system.adapter.discovery.0 in version "5.0.0" started with pid 2716519
      zigbee.0
      	2025-05-07 17:48:45.452	info	Starting Zigbee-Herdsman
      zigbee.0
      	2025-05-07 17:48:45.451	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
      zigbee.0
      	2025-05-07 17:48:45.436	info	Starting Adapter npm ...
      zigbee.0
      	2025-05-07 17:48:45.435	info	--- creating device debug ---
      zigbee.0
      	2025-05-07 17:48:45.430	info	--> transmitPower : normal
      zigbee.0
      	2025-05-07 17:48:45.427	info	init localConfig
      zigbee.0
      	2025-05-07 17:48:45.418	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:48:44.243	info	instance system.adapter.zigbee.0 in version "2.0.5" started with pid 2716503
      awtrix-light.0
      	2025-05-07 17:48:42.443	info	Starting - connecting to http://192.168.178.83:80/
      awtrix-light.0
      	2025-05-07 17:48:42.348	info	starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v20.19.1, js-controller: 7.0.6
      yr.0
      	2025-05-07 17:48:41.778	info	longitude/longitude will be set by self-Config - longitude: 7.0362624235667255 latitude: 50.622376836807405
      yr.0
      	2025-05-07 17:48:41.757	info	starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:48:40.856	info	instance system.adapter.awtrix-light.0 in version "1.7.0" started with pid 2716484
      shelly.0
      	2025-05-07 17:48:40.312	info	[CoAP] Device 192.168.178.45 (shelly1pm / shelly1pm-E09806A9FFDF / SHSW-PM#E09806A9FFDF#1) connected! Polltime set to 15 sec.
      host.Raspi58GB
      	2025-05-07 17:48:40.264	info	instance system.adapter.yr.0 in version "5.3.0" started with pid 2716473
      host.Raspi58GB
      	2025-05-07 17:48:40.260	info	instance scheduled system.adapter.yr.0 40 * * * *
      shelly.0
      	2025-05-07 17:48:38.797	info	[CoAP] Device 192.168.178.88 (shelly1pm / shelly1pm-C45BBE6A38D2 / SHSW-PM#C45BBE6A38D2#1) connected! Polltime set to 15 sec.
      tr-064.0
      	2025-05-07 17:48:37.888	info	starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:48:37.165	info	instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
      openweathermap.0
      	2025-05-07 17:48:36.607	info	Terminated (NO_ERROR): Without reason
      host.Raspi58GB
      	2025-05-07 17:48:36.367	info	instance system.adapter.tr-064.0 in version "4.3.0" started with pid 2716458
      shelly.0
      	2025-05-07 17:48:36.162	info	[CoAP] Device 192.168.178.43 (shellyplug-s / shellyplug-s-B52D91 / SHPLG-S#B52D91#1) connected! Polltime set to 15 sec.
      shelly.0
      	2025-05-07 17:48:36.059	info	[CoAP] Device 192.168.178.60 (shelly1pm / shelly1pm-349454783D53 / SHSW-PM#349454783D53#1) connected! Polltime set to 15 sec.
      smartmeter.0
      	2025-05-07 17:48:35.723	info	Received 13 values, 13 updated
      smartmeter.0
      	2025-05-07 17:48:34.915	info	starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:48:32.604	info	instance system.adapter.smartmeter.0 in version "3.4.0" started with pid 2716443
      host.Raspi58GB
      	2025-05-07 17:48:31.167	error	cannot call visUtils: Not exists
      shelly.0
      	2025-05-07 17:48:30.940	info	[CoAP] Device 192.168.178.37 (shellyem3 / shellyem3-E89F6D84ABB5 / SHEM-3#E89F6D84ABB5#1) connected! Polltime set to 15 sec.
      admin.0
      	2025-05-07 17:48:30.856	info	==> Connected system.user.admin from ::ffff:192.168.178.120
      shelly.0
      	2025-05-07 17:48:30.001	info	[CoAP] Device 192.168.178.61 (shelly1pm / shelly1pm-34945475C0D4 / SHSW-PM#34945475C0D4#1) connected! Polltime set to 15 sec.
      shelly.0
      	2025-05-07 17:48:29.875	info	[CoAP] Device 192.168.178.27 (shellyplug-s / shellyplug-s-B4BD04 / SHPLG-S#B4BD04#1) connected! Polltime set to 15 sec.
      shelly.1
      	2025-05-07 17:48:29.832	info	Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
      shelly.0
      	2025-05-07 17:48:29.687	info	[CoAP] Device 192.168.178.59 (shelly1pm / shelly1pm-349454783F33 / SHSW-PM#349454783F33#1) connected! Polltime set to 15 sec.
      shelly.1
      	2025-05-07 17:48:29.372	info	starting. Version 9.2.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.19.1, js-controller: 7.0.6
      shelly.0
      	2025-05-07 17:48:29.178	info	[CoAP] Device 192.168.178.73 (shellygas / shellygas-3C6105F68FE8 / SHGS-1#3C6105F68FE8#1) connected! Polltime set to 3600 sec.
      host.Raspi58GB
      	2025-05-07 17:48:28.258	info	instance system.adapter.shelly.1 in version "9.2.0" started with pid 2716414
      shelly.0
      	2025-05-07 17:48:25.830	info	[CoAP Server] Listening for packets in the network
      shelly.0
      	2025-05-07 17:48:25.805	info	Starting in CoAP mode. Listening on 192.168.178.57:5683
      shelly.0
      	2025-05-07 17:48:25.601	info	starting. Version 9.2.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:48:24.254	info	instance system.adapter.shelly.0 in version "9.2.0" started with pid 2716395
      rpi2.0
      	2025-05-07 17:48:21.210	info	starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:48:20.281	info	instance system.adapter.rpi2.0 in version "2.4.0" started with pid 2716354
      openweathermap.0
      	2025-05-07 17:48:17.307	info	starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.1, js-controller: 7.0.6
      host.Raspi58GB
      	2025-05-07 17:48:16.284	info	instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 2716339
      host.Raspi58GB
      	2025-05-07 17:48:16.280	info	instance scheduled system.adapter.openweathermap.0 16 * * * *
      mqtt.0
      	2025-05-07 17:48:14.052	info	All states published
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.status.ws
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.status.sys
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.status.plugs_ui
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.status.ffs
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.status.ble
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.events.rpc
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.status.ws
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.online
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.status.cloud
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.status.mqtt
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.status.switch:0
      mqtt.0
      	2025-05-07 17:48:13.444	info	Publishing state mqtt.0.shellyplusplugs-e465b8b302bc.status.wifi
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.status.sys
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.status.plugs_ui
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.status.ffs
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.status.ble
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.events.rpc
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.status.wifi
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.status.switch:0
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.status.plugs_ui
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.status.sys
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.status.ws
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.online
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.status.cloud
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.status.mqtt
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.status.switch:0
      mqtt.0
      	2025-05-07 17:48:13.443	info	Publishing state mqtt.0.shellyplusplugs-e465b8456ff4.status.wifi
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.status.ffs
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.status.ble
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.shellyplus1pm-d48afc598e4c.status
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.events.rpc
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.status.wifi
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.status.switch:0
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.status.mqtt
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.status.ffs
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.status.plugs_ui
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.status.sys
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.status.ws
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.online
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.shellyplus1pm-d48afc598e4c.status.on
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.status.cloud
      mqtt.0
      	2025-05-07 17:48:13.442	info	Publishing state mqtt.0.shellyplusplugs-d48afc7b9540.status.mqtt
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.status.ble
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.events.rpc
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-b0b21c1243bc.status.wifi
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-b0b21c1243bc.status.switch:0
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-b0b21c1243bc.status.mqtt
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-b0b21c1243bc.status.ffs
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-b0b21c1243bc.status.plugs_ui
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-b0b21c1243bc.status.sys
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-b0b21c1243bc.status.ws
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.online
      mqtt.0
      	2025-05-07 17:48:13.441	info	Publishing state mqtt.0.shellyplusplugs-d48afc7a4830.status.cloud
      • S searcher57
        Hier das Protokoll:
        Bitte erkläre das!
        v7.6.3
        233
        Log-Größe: 439.1 KB
        Zeit
        smartmeter.0
        host.Raspi58GB
        openweathermap.0
        openweathermap.0
        host.Raspi58GB
        awtrix-light.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.Raspi58GB
        host.Raspi58GB
        zigbee.0
        host.Raspi58GB
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.Raspi58GB
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.Raspi58GB
        admin.0
        host.Raspi58GB
        host.Raspi58GB
        host.Raspi58GB
        host.Raspi58GB
        host.Raspi58GB
        host.Raspi58GB
        host.Raspi58GB
        host.Raspi58GB
        host.Raspi58GB
        host.Raspi58GB
        host.Raspi58GB
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        admin.0
        web.0
        web.0
        web.0
        host.Raspi58GB
        vis-2.0
        vis-2.0
        host.Raspi58GB
        text2command.0
        tankerkoenig.0
        host.Raspi58GB
        shelly.1
        tankerkoenig.0
        tankerkoenig.0
        tankerkoenig.0
        host.Raspi58GB
        simple-api.0
        simple-api.0
        simple-api.0
        simple-api.0
        host.Raspi58GB
        host.Raspi58GB
        yr.0
        yr.0
        iot.0
        iot.0
        iot.0
        host.Raspi58GB
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        fritzdect.0
        shelly.1
        shelly.1
        host.Raspi58GB
        followthesun.0
        followthesun.0
        followthesun.0
        followthesun.0
        shelly.1
        host.Raspi58GB
        shelly.1
        shelly.1
        echarts.0
        host.Raspi58GB
        doorbird.0
        host.Raspi58GB
        discovery.0
        shelly.1
        host.Raspi58GB
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.Raspi58GB
        awtrix-light.0
        awtrix-light.0
        yr.0
        yr.0
        host.Raspi58GB
        shelly.0
        host.Raspi58GB
        host.Raspi58GB
        shelly.0
        tr-064.0
        host.Raspi58GB
        openweathermap.0
        host.Raspi58GB
        shelly.0
        shelly.0
        smartmeter.0
        smartmeter.0
        host.Raspi58GB
        host.Raspi58GB
        shelly.0
        admin.0
        shelly.0
        shelly.0
        shelly.1
        shelly.0
        shelly.1
        shelly.0
        host.Raspi58GB
        shelly.0
        shelly.0
        shelly.0
        host.Raspi58GB
        rpi2.0
        host.Raspi58GB
        openweathermap.0
        host.Raspi58GB
        host.Raspi58GB
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        mqtt.0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #43
        @searcher57 Dein Log zeigt das du den Adapter angehalten hast bevor das Zigbee-Subsystem vollständig gestartet war. Besagter Start kann insbesondere bei einem ersten Start mit 'neuer' Konifiguration bis zu 5 Minuten dauern.
        Bitte folgendes machen:
        • Zigbee Adapter anhalten.
        • 60 s Warten
        • Log löschen
        • Zigbee Adapter starten
        • Umschalten auf die Log-Ansicht
        • Abwarten bis einer von 2 Events eintritt:
          -- Fehlermeldung das der Adapter nicht gestartet werden kann
          -- Meldung das der Adapter erfolgreich gestartet wurde.
        Besagte Meldungen dann hier posten.
        A.
        • AsgothianA Asgothian
          • 60 s Warten
          • Log löschen
          A.
          searcher57
          #44
          @asgothian said in FritzBox Zigbee Antenne in ioBroker einbinden?:
          • 60 s Warten
          • Log löschen
          A.
          Ich hoffe, dass ich nicht wieder zu ungeduldig war!
          admin.0
          	2025-05-07 19:33:41.984	info	==> Connected system.user.admin from ::ffff:192.168.178.120
          admin.0
          	2025-05-07 19:33:41.530	info	<== Disconnect system.user.admin from ::ffff:192.168.178.120 admin
          admin.0
          	2025-05-07 19:33:41.525	info	==> Connected system.user.admin from ::ffff:192.168.178.120
          admin.0
          	2025-05-07 19:33:41.483	info	<== Disconnect system.user.admin from ::ffff:192.168.178.120 admin
          smartmeter.0
          	2025-05-07 19:29:29.882	info	Received 13 values, 4 updated
          smartmeter.0
          	2025-05-07 19:24:25.886	info	Received 13 values, 6 updated
          host.Raspi58GB
          	2025-05-07 19:22:42.280	error	cannot call visUtils: Not exists
          admin.0
          	2025-05-07 19:22:42.049	info	==> Connected system.user.admin from ::ffff:192.168.178.120
          admin.0
          	2025-05-07 19:22:41.610	info	<== Disconnect system.user.admin from ::ffff:192.168.178.120 admin
          admin.0
          	2025-05-07 19:22:41.602	info	==> Connected system.user.admin from ::ffff:192.168.178.120
          admin.0
          	2025-05-07 19:22:41.549	info	<== Disconnect system.user.admin from ::ffff:192.168.178.120 admin
          smartmeter.0
          	2025-05-07 19:19:25.076	info	Received 13 values, 6 updated
          admin.0
          	2025-05-07 19:18:55.025	info	<== Disconnect system.user.admin from ::ffff:192.168.178.120 javascript
          admin.0
          	2025-05-07 19:18:53.355	info	==> Connected system.user.admin from ::ffff:192.168.178.120
          host.Raspi58GB
          	2025-05-07 19:16:51.969	info	instance system.adapter.openweathermap.0 having pid 2721694 terminated with code 0 (NO_ERROR)
          openweathermap.0
          	2025-05-07 19:16:51.460	info	Terminated (NO_ERROR): Without reason
          openweathermap.0
          	2025-05-07 19:16:43.034	info	starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.1, js-controller: 7.0.6
          host.Raspi58GB
          	2025-05-07 19:16:42.019	info	instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 2721694
          smartmeter.0
          	2025-05-07 19:14:21.120	info	Received 13 values, 4 updated
          zigbee.0
          	2025-05-07 19:12:59.441	info	Starting Zigbee-Herdsman
          zigbee.0
          	2025-05-07 19:12:59.440	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
          zigbee.0
          	2025-05-07 19:12:59.424	info	Starting Adapter npm ...
          zigbee.0
          	2025-05-07 19:12:59.423	info	--- creating device debug ---
          zigbee.0
          	2025-05-07 19:12:59.418	info	--> transmitPower : normal
          zigbee.0
          	2025-05-07 19:12:59.415	info	init localConfig
          zigbee.0
          	2025-05-07 19:12:59.405	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.1, js-controller: 7.0.6
          host.Raspi58GB
          	2025-05-07 19:12:58.274	info	instance system.adapter.zigbee.0 in version "2.0.5" started with pid 2721587
          • S searcher57
            • 60 s Warten
            • Log löschen
            A.
            admin.0
            admin.0
            admin.0
            admin.0
            smartmeter.0
            smartmeter.0
            host.Raspi58GB
            admin.0
            admin.0
            admin.0
            admin.0
            smartmeter.0
            admin.0
            admin.0
            host.Raspi58GB
            openweathermap.0
            openweathermap.0
            host.Raspi58GB
            smartmeter.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            host.Raspi58GB
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #45
            @searcher57 Im Log steht nichts drin. Bitte mal die Einstellungen des Zigbee Adapters zeigen.
            Anscheinend wird versucht den Herdsman zu starten, aber der kommt nicht zurück.
            A.
            S 2 Antworten Letzte Antwort
              A.
              searcher57
              #46
              A.
              Zigbee-Adapter
                  Einstellungen
                  Local Overrides
                  Geräte
                  Entwickler
              COM-Anschlussname
              arrow_drop_down
              Typ
              Baudate Deconz/Conbee
              Countdown zwischen 10 und 240 Sek während der Kopplung
              Network
              Erweiterte Pan ID
              Die erweiterte PAN-ID ist die Hauptnetzwerk-ID, vergleichbar mit der SSID von WLAN-Netzwerken. Diese ID darf sich für vorhandene Netzwerke niemals ändern, da Sie sonst deine Geräte zurücksetzen und Sie neu koppeln müssen. Wenn Sie mehrere ZigBee-Adapter verwenden, müssen Sie sicherstellen, dass diese eindeutige ExtPanIDs verwenden. Geben Sie einfach 16 zufällige Hex-Zeichen ein (a-f und 0-9).
              Pan ID
              Pan ID ist eine vereinfachte ID (wird von Zigbee anstelle von ExtPanID verwendet, wo immer dies möglich ist). Dies sollte auch einzigartig sein. Hinweis: Das ZigBee-Netzwerk wählt möglicherweise eine andere Pan-ID als die hier angegebene, falls ID-Konflikte erkannt werden.
              Kanal
              graphic_eq
              Kanal stellt die verwendete Funkfrequenz ein. Es kann geändert werden, um Konflikte mit vorhandenen WLAN-Netzwerken zu vermeiden. Alle Geräte müssen beim Wechsel neu gelernt werden!
              Transportschlüssel
              CC1352P and CC26X2R1 Sendeleistung
              andere Einstellungen
              External converters
              Paths to files, semicolon (;) splitted
              save
              Speichern
              save
              close
              Speichern und schließen
              close
              Schließen
                A.
                searcher57
                #47
                A.
                Also ich habe alles wieder in den Alt-Zustand gebracht. Ich werde mir dann doch das FRITZ!Smart Gateway bestellen und versuche damit die drei Zigbee Komponenten in den IO Broker zu bringen. Wenn's nicht funktioniert, sende ich es zurück.
                Danke für Eure Hilfe!
