  4. Fehlermeldung bei Adapter installation.
    6.1k
11 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • MalleRalleM Offline
    MalleRalleM Offline
    MalleRalle
    Moin @foxriver76
    Moin @apollon77
    Moin @ All
    Weiß jemand etwas mit diesen Fehlermeldungen etwas anzufangen?
    Ist der deyeidc Adapter von raschy
    Habe Issues angelegt, aber er weiß damit nichts anzufangen.
    2024-05-06 13:41:14.897 - info: host.rockpro64 iobroker url https://github.com/raschy/ioBroker.deyeidc --host rockpro64 --debug
    2024-05-06 13:41:17.819 - info: host.rockpro64 iobroker install raschy/ioBroker.deyeidc#c8e6ee63f93e3bc8f6bef811e9dc77a6061b1dcb
    2024-05-06 13:41:18.826 - info: host.rockpro64 iobroker NPM version: 10.5.0
    2024-05-06 13:41:18.828 - info: host.rockpro64 iobroker Installing raschy/ioBroker.deyeidc#c8e6ee63f93e3bc8f6bef811e9dc77a6061b1dcb... (System call)
    2024-05-06 13:41:30.679 - info: host.rockpro64 iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/raschy/ioBroker.deyeidc.git
    2024-05-06 13:41:33.640 - info: host.rockpro64 iobroker npm ERR! code 1
    2024-05-06 13:41:33.642 - info: host.rockpro64 iobroker npm ERR! path /opt/iobroker/node_modules/utf-8-validate
    2024-05-06 13:41:33.650 - info: host.rockpro64 iobroker npm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! make: Entering directory '/opt/iobroker/node_modules/utf-8-validate/build'npm ERR! CC(target) Release/obj.target/validation/src/validation.onpm ERR! make: Leaving directory '/opt/iobroker/node_modules/utf-8-validate/build'npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@10.1.0npm ERR! gyp info using node@18.20.2 | linux | arm64npm ERR! gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/utf-8-validate/build/config.gypi',
    2024-05-06 13:41:33.657 - info: host.rockpro64 iobroker npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.20.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.20.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.20.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/utf-8-validate',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! make: cc: No such file or directorynpm ERR! make: *** [validation.target.mk:111: Release/obj.target/validation/src/validation.o] Error 127npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess. (/opt/iobroker/node_modules/node-gyp/lib/build.js:209:23)npm ERR! gyp ERR! System Linux 5.15.93-rockchip64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validatenpm ERR! gyp ERR! node -v v18.20.2npm ERR! gyp ERR! node-gyp -v v10.1.0npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T11_41_19_591Z-debug-0.log
    2024-05-06 13:41:33.708 - error: host.rockpro64 iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/raschy/ioBroker.deyeidc.git npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/utf-8-validatenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! make: Entering directory '/opt/iobroker/node_modules/utf-8-validate/build'npm ERR! CC(target) Release/obj.target/validation/src/validation.onpm ERR! make: Leaving directory '/opt/iobroker/node_modules/utf-8-validate/build'npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@10.1.0npm ERR! gyp info using node@18.20.2 | linux | arm64npm ERR! gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/utf-8-validate/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.20.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.20.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.20.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/utf-8-validate',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! make: cc: No such file or directorynpm ERR! make: *** [validation.target.mk:111: Release/obj.target/validation/src/validation.o] Error 127npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess. (/opt/iobroker/node_modules/node-gyp/lib/build.js:209:23)npm ERR! gyp ERR! System Linux 5.15.93-rockchip64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validatenpm ERR! gyp ERR! node -v v18.20.2npm ERR! gyp ERR! node-gyp -v v10.1.0npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T11_41_19_591Z-debug-0.log
    2024-05-06 13:41:33.710 - error: host.rockpro64 iobroker host.rockpro64 Cannot install raschy/ioBroker.deyeidc#c8e6ee63f93e3bc8f6bef811e9dc77a6061b1dcb: 1
    2024-05-06 13:41:34.773 - info: host.rockpro64 iobroker exit 25
    • MalleRalleM MalleRalle
      Moin @foxriver76
      Moin @apollon77
      Moin @ All
      @malleralle sagte in Fehlermeldung bei Adapter installation.:
      Schau in das Log.
      MalleRalleM 1 Antwort Letzte Antwort
        Schau in das Log.
        MalleRalleM Offline
        MalleRalleM Offline
        MalleRalle
        schrieb am zuletzt editiert von MalleRalle
        info run bufferutil@4.0.8 install node_modules/bufferutil node-gyp-build
        63 info run bufferutil@4.0.8 install { code: 1, signal: null }
        64 timing reify:rollback:createSparse Completed in 21ms
        65 timing reify:rollback:retireShallow Completed in 0ms
        66 timing command:i Completed in 11362ms
        67 verbose stack Error: command failed
        67 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
        67 verbose stack     at ChildProcess.emit (node:events:517:28)
        67 verbose stack     at maybeClose (node:internal/child_process:1098:16)
        67 verbose stack     at Socket.<anonymous> (node:internal/child_process:450:11)
        67 verbose stack     at Socket.emit (node:events:517:28)
        67 verbose stack     at Pipe.<anonymous> (node:net:350:12)
        68 verbose pkgid bufferutil@4.0.8
        69 verbose cwd /opt/iobroker/node_modules
        70 verbose Linux 5.15.93-rockchip64
        71 verbose node v18.20.2
        72 verbose npm  v10.5.0
        73 error code 1
        74 error path /opt/iobroker/node_modules/bufferutil
        75 error command failed
        76 error command sh -c node-gyp-build
        77 error make: Entering directory '/opt/iobroker/node_modules/bufferutil/build'
        77 error   CC(target) Release/obj.target/bufferutil/src/bufferutil.o
        77 error make: Leaving directory '/opt/iobroker/node_modules/bufferutil/build'
        78 error gyp info it worked if it ends with ok
        78 error gyp info using node-gyp@10.1.0
        78 error gyp info using node@18.20.2 | linux | arm64
        78 error gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"
        78 error gyp info spawn /usr/bin/python3
        78 error gyp info spawn args [
        78 error gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
        78 error gyp info spawn args 'binding.gyp',
        78 error gyp info spawn args '-f',
        78 error gyp info spawn args 'make',
        78 error gyp info spawn args '-I',
        78 error gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',
        78 error gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',
        78 error gyp info spawn args '/home/iobroker/.cache/node-gyp/18.20.2/include/node/common.gypi',
        78 error gyp info spawn args '-Dlibrary=shared_library',
        78 error gyp info spawn args '-Dvisibility=default',
        78 error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.20.2',
        78 error gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
        78 error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.20.2/<(target_arch)/node.lib',
        78 error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',
        78 error gyp info spawn args '-Dnode_engine=v8',
        78 error gyp info spawn args '--depth=.',
        78 error gyp info spawn args '--no-parallel',
        78 error gyp info spawn args '--generator-output',
        78 error gyp info spawn args 'build',
        78 error gyp info spawn args '-Goutput_dir=.'
        78 error gyp info spawn args ]
        78 error gyp info spawn make
        78 error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        78 error make: cc: No such file or directory
        78 error make: *** [bufferutil.target.mk:111: Release/obj.target/bufferutil/src/bufferutil.o] Error 127
        78 error gyp ERR! build error
        78 error gyp ERR! stack Error: `make` failed with exit code: 2
        78 error gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-gyp/lib/build.js:209:23)
        78 error gyp ERR! System Linux 5.15.93-rockchip64
        78 error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        78 error gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
        78 error gyp ERR! node -v v18.20.2
        78 error gyp ERR! node-gyp -v v10.1.0
        78 error gyp ERR! not ok
          73 error code 1
          buildenvironment vollständig?
          apt policy build-essential
            MalleRalleM Offline
            MalleRalleM Offline
            MalleRalle
            $ apt policy build-essential
            build-essential:
              Installiert:           12.9ubuntu3
              Installationskandidat: 12.9ubuntu3
              Versionstabelle:
             *** 12.9ubuntu3 500
                    500 http://ports.ubuntu.com jammy/main arm64 Packages
                    100 /var/lib/dpkg/status
            • Thomas BraunT Online
              @malleralle
              Ist dein nodejs senkrecht installiert?
              iob diag
              anschauen.
                @malleralle
                iob diag
                anschauen.
                MalleRalleM Offline
                MalleRalleM Offline
                MalleRalle
                Skript v.2024-04-21
                *** BASE SYSTEM ***
                 Static hostname: rockpro64
                       Icon name: computer
                Operating System: Ubuntu 22.04.4 LTS
                          Kernel: Linux 5.15.93-rockchip64
                    Architecture: arm64
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 64 bit
                Systemuptime and Load:
                 15:55:10 up  2:55,  1 user,  load average: 1.30, 1.23, 1.08
                CPU threads: 6
                *** Time and Time Zones ***
                               Local time: Mon 2024-05-06 15:55:10 CEST
                           Universal time: Mon 2024-05-06 13:55:10 UTC
                                 RTC time: Mon 2024-05-06 13:55:10
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                rockpro64
                HOME=/home/rockpro64
                GROUPS=rockpro64 tty disk dialout sudo audio video plugdev games users systemd-journal input netdev _ssh lpadmin iobroker
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev i2c bluetooth
                *** Display-Server-Setup ***
                Display-Server: false
                Desktop:
                Terminal: 	tty
                Boot Target: 	multi-user.target
                *** MEMORY ***
                Mem:            3.9G        3.0G        164M         10M        715M        781M
                Swap:           1.9G        1.1G        812M
                Total:          5.8G        4.1G        977M
                Active iob-Instances: 	39
                         3863 M total memory
                         2983 M used memory
                         1544 M active memory
                         1337 M inactive memory
                          164 M free memory
                           81 M buffer memory
                          634 M swap cache
                         1931 M total swap
                         1119 M used swap
                          812 M free swap
                top - 15:55:11 up  2:55,  1 user,  load average: 1.30, 1.23, 1.08
                Tasks: 260 total,   1 running, 259 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  8.1 us,  4.8 sy,  0.0 ni, 87.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3863.0 total,    164.0 free,   2983.5 used,    715.5 buff/cache
                MiB Swap:   1931.5 total,    812.3 free,   1119.2 used.    781.2 avail Mem
                *** FAILED SERVICES ***
                  UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                * rc-local.service loaded failed failed /etc/rc.local Compatibility
                1 loaded units listed.
                *** FILESYSTEM ***
                Filesystem     Type   Size  Used Avail Use% Mounted on
                tmpfs          tmpfs  387M   21M  366M   6% /run
                /dev/sda1      ext4    59G   25G   33G  43% /
                tmpfs          tmpfs  1.9G  4.0K  1.9G   1% /dev/shm
                tmpfs          tmpfs  5.0M  4.0K  5.0M   1% /run/lock
                tmpfs          tmpfs  1.9G  920K  1.9G   1% /tmp
                /dev/zram1     ext4    47M   18M   26M  41% /var/log
                tmpfs          tmpfs  387M     0  387M   0% /run/user/1000
                [Mon May  6 12:59:49 2024] Kernel command line:  root=UUID=fbc89545-e72e-44f3-bbbc-44a3ff945d2a rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
                [Mon May  6 12:59:59 2024] EXT4-fs (sda1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
                [Mon May  6 13:00:03 2024] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
                [Mon May  6 13:00:08 2024] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none.
                Show mounted filesystems:
                TARGET                                        SOURCE              FSTYPE      OPTIONS
                /                                             /dev/sda1           ext4        rw,noatime,errors=remount-ro,commit=600
                |-/sys                                        sysfs               sysfs       rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/security                      securityfs          securityfs  rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/cgroup                            cgroup2             cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                | |-/sys/fs/pstore                            pstore              pstore      rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/bpf                               bpf                 bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                | |-/sys/kernel/debug                         debugfs             debugfs     rw,nosuid,nodev,noexec,relatime
                | | `-/sys/kernel/debug/tracing               tracefs             tracefs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/tracing                       tracefs             tracefs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/fuse/connections                  fusectl             fusectl     rw,nosuid,nodev,noexec,relatime
                | `-/sys/kernel/config                        configfs            configfs    rw,nosuid,nodev,noexec,relatime
                |-/proc                                       proc                proc        rw,nosuid,nodev,noexec,relatime
                | `-/proc/sys/fs/binfmt_misc                  systemd-1           autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                |   `-/proc/sys/fs/binfmt_misc                binfmt_misc         binfmt_misc rw,nosuid,nodev,noexec,relatime
                |-/dev                                        udev                devtmpfs    rw,nosuid,relatime,size=1902140k,nr_inodes=475535,mode=755
                | |-/dev/pts                                  devpts              devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                | |-/dev/shm                                  tmpfs               tmpfs       rw,nosuid,nodev
                | |-/dev/hugepages                            hugetlbfs           hugetlbfs   rw,relatime,pagesize=2M
                | `-/dev/mqueue                               mqueue              mqueue      rw,nosuid,nodev,noexec,relatime
                |-/run                                        tmpfs               tmpfs       rw,nosuid,nodev,noexec,relatime,size=395576k,mode=755
                | |-/run/lock                                 tmpfs               tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                | |-/run/credentials/systemd-sysusers.service none                ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                | |-/run/rpc_pipefs                           sunrpc              rpc_pipefs  rw,relatime
                | `-/run/user/1000                            tmpfs               tmpfs       rw,nosuid,nodev,relatime,size=395572k,nr_inodes=98893,mode=700,uid=1000,gid=1000
                |-/tmp                                        tmpfs               tmpfs       rw,nosuid,relatime
                |-/var/log.hdd                                /dev/sda1[/var/log] ext4        rw,noatime,errors=remount-ro,commit=600
                `-/var/log                                    /dev/zram1          ext4        rw,relatime,discard
                /var:
                4.7G	/var/
                4.4G	/var/lib
                3.5G	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server
                Archived and active journals take up 19.3M in the file system.
                /opt/iobroker/backups:
                230M	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                820M	/opt/iobroker/iobroker-data/
                581M	/opt/iobroker/iobroker-data/files
                146M	/opt/iobroker/iobroker-data/backup-objects
                121M	/opt/iobroker/iobroker-data/files/javascript.admin
                101M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                43M	/opt/iobroker/iobroker-data/states.jsonl
                39M	/opt/iobroker/iobroker-data/objects.jsonl
                38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
                27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_68a1518bde1aec11b17674e5f01c6278-if00-port0
                HINT:
                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                /dev/SONOFF
                *** NodeJS-Installation ***
                /usr/bin/nodejs 	v18.20.2
                /usr/bin/node 		v18.20.2
                /usr/bin/npm 		10.5.0
                /usr/bin/npx 		10.5.0
                /usr/bin/corepack 	0.25.2
                nodejs:
                  Installed: 18.20.2-1nodesource1
                  Candidate: 18.20.2-1nodesource1
                  Version table:
                 *** 18.20.2-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                     18.20.1-1nodesource1 1001
                     18.20.0-1nodesource1 1001
                     18.19.1-1nodesource1 1001
                     18.19.0-1nodesource1 1001
                     18.18.2-1nodesource1 1001
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                     12.22.9~dfsg-1ubuntu3.5 500
                        500 http://ports.ubuntu.com jammy-security/universe arm64 Packages
                        500 http://ports.ubuntu.com jammy-updates/universe arm64 Packages
                     12.22.9~dfsg-1ubuntu3 500
                        500 http://ports.ubuntu.com jammy/universe arm64 Packages
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller: 	5.0.19
                admin: 		6.17.6
                javascript: 	8.1.1
                nodejs modules from github: 	7
                +-- iobroker.broadlink@0.1.5 (git+ssh://git@github.com/hieblmedia/ioBroker.broadlink.git#8ae2d84e3641e3dc98029d77d7072502e5e55346)
                +-- iobroker.epson_workforce@0.0.4 (git+ssh://git@github.com/rrov1/ioBroker.epson_workforce.git#429c9a158984e8e3e197bc05d965e6810dff551e)
                +-- iobroker.google-sharedlocations@2.1.6 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#387af5f4ecd91225484f996a291232d04c9745a8)
                +-- iobroker.hiob@0.1.4 (git+ssh://git@github.com/moba15/ioBroker.hiob.git#6c6affd82241bc6e6bcaae766cb498804e2b2413)
                +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                +-- iobroker.rtl_433@1.1.6 (git+ssh://git@github.com/phillipssc/ioBroker.rtl_433.git#09e16f677bb29548939493c8c2aba6b5be75bc5e)
                +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                Adapter State
                + system.adapter.admin.0                  : admin                 : rockpro64                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : rockpro64                                -  enabled
                  system.adapter.alexa-timer-vis.1        : alexa-timer-vis       : rockpro64                                - disabled
                + system.adapter.alexa2.0                 : alexa2                : rockpro64                                -  enabled
                  system.adapter.alexa2.1                 : alexa2                : rockpro64                                - disabled
                + system.adapter.amazon-dash.0            : amazon-dash           : rockpro64                                -  enabled
                + system.adapter.backitup.0               : backitup              : rockpro64                                -  enabled
                + system.adapter.broadlink.0              : broadlink             : rockpro64                                -  enabled
                + system.adapter.broadlink2.0             : broadlink2            : rockpro64                                -  enabled
                  system.adapter.coronavirus-statistics.0 : coronavirus-statistics: rockpro64                                - disabled
                  system.adapter.daswetter.0              : daswetter             : rockpro64                                -  enabled
                  system.adapter.discovery.0              : discovery             : rockpro64                                - disabled
                  system.adapter.dwd.0                    : dwd                   : rockpro64                                -  enabled
                + system.adapter.email.0                  : email                 : rockpro64                                -  enabled
                + system.adapter.enigma2.0                : enigma2               : rockpro64                                -  enabled
                + system.adapter.enigma2.1                : enigma2               : rockpro64                                -  enabled
                  system.adapter.enigma2.2                : enigma2               : rockpro64                                - disabled
                  system.adapter.enigma2.3                : enigma2               : rockpro64                                - disabled
                + system.adapter.epson_workforce.0        : epson_workforce       : rockpro64                                -  enabled
                  system.adapter.feiertage.0              : feiertage             : rockpro64                                -  enabled
                  system.adapter.firetv.0                 : firetv                : rockpro64                                - disabled
                  system.adapter.flot.0                   : flot                  : rockpro64                                - disabled
                + system.adapter.google-sharedlocations.0 : google-sharedlocations: rockpro64                                -  enabled
                + system.adapter.hiob.0                   : hiob                  : rockpro64                                -  enabled, port: 7999
                + system.adapter.history.0                : history               : rockpro64                                -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : rockpro64                                -  enabled
                + system.adapter.hm-rpc.2                 : hm-rpc                : rockpro64                                -  enabled, port: 0
                + system.adapter.hm-rpc.3                 : hm-rpc                : rockpro64                                -  enabled, port: 12001
                  system.adapter.hs100.0                  : hs100                 : rockpro64                                - disabled
                  system.adapter.ical.0                   : ical                  : rockpro64                                -  enabled
                  system.adapter.ical.1                   : ical                  : rockpro64                                -  enabled
                  system.adapter.ical.2                   : ical                  : rockpro64                                -  enabled
                  system.adapter.ical.3                   : ical                  : rockpro64                                -  enabled
                  system.adapter.ical.4                   : ical                  : rockpro64                                -  enabled
                  system.adapter.ical.5                   : ical                  : rockpro64                                -  enabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: rockpro64                                - disabled
                  system.adapter.icons-icons8.0           : icons-icons8          : rockpro64                                - disabled
                  system.adapter.icons-material-svg.0     : icons-material-svg    : rockpro64                                - disabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : rockpro64                                - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rockpro64                                - disabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: rockpro64                                - disabled
                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : rockpro64                                - disabled
                + system.adapter.info.0                   : info                  : rockpro64                                -  enabled
                + system.adapter.iot.0                    : iot                   : rockpro64                                -  enabled
                + system.adapter.javascript.0             : javascript            : rockpro64                                -  enabled
                  system.adapter.mobile.0                 : mobile                : rockpro64                                - disabled
                  system.adapter.mqtt.0                   : mqtt                  : rockpro64                                - disabled, port: 1883, bind: 192.168.123.248
                + system.adapter.mytime.0                 : mytime                : rockpro64                                -  enabled
                + system.adapter.nut.0                    : nut                   : rockpro64                                -  enabled
                + system.adapter.paw.0                    : paw                   : rockpro64                                -  enabled, port: 9876
                  system.adapter.pollenflug.0             : pollenflug            : rockpro64                                - disabled
                + system.adapter.radar2.0                 : radar2                : rockpro64                                -  enabled
                + system.adapter.rtl_433.0                : rtl_433               : rockpro64                                -  enabled
                  system.adapter.schoolfree.0             : schoolfree            : rockpro64                                -  enabled
                + system.adapter.shelly.0                 : shelly                : rockpro64                                -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.simple-api.0             : simple-api            : rockpro64                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  system.adapter.socketio.0               : socketio              : rockpro64                                - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                + system.adapter.sourceanalytix.0         : sourceanalytix        : rockpro64                                -  enabled
                  system.adapter.statistics.0             : statistics            : rockpro64                                - disabled
                + system.adapter.tado.0                   : tado                  : rockpro64                                -  enabled
                + system.adapter.tankerkoenig.0           : tankerkoenig          : rockpro64                                -  enabled
                + system.adapter.telegram.0               : telegram              : rockpro64                                -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.tr-064.0                 : tr-064                : rockpro64                                -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : rockpro64                                -  enabled
                + system.adapter.tuya.0                   : tuya                  : rockpro64                                -  enabled
                  system.adapter.tvspielfilm.0            : tvspielfilm           : rockpro64                                - disabled
                  system.adapter.vis-bars.0               : vis-bars              : rockpro64                                - disabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : rockpro64                                - disabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : rockpro64                                - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : rockpro64                                - disabled
                  system.adapter.vis-history.0            : vis-history           : rockpro64                                - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : rockpro64                                - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : rockpro64                                - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : rockpro64                                -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : rockpro64                                - disabled
                  system.adapter.vis-justgage.0           : vis-justgage          : rockpro64                                - disabled
                  system.adapter.vis-keyboard.0           : vis-keyboard          : rockpro64                                - disabled
                  system.adapter.vis-lcars.0              : vis-lcars             : rockpro64                                - disabled
                  system.adapter.vis-map.0                : vis-map               : rockpro64                                - disabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : rockpro64                                - disabled
                  system.adapter.vis-material.0           : vis-material          : rockpro64                                - disabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : rockpro64                                - disabled
                  system.adapter.vis-metro.0              : vis-metro             : rockpro64                                - disabled
                  system.adapter.vis-players.0            : vis-players           : rockpro64                                - disabled
                  system.adapter.vis-rgraph.0             : vis-rgraph            : rockpro64                                - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : rockpro64                                - disabled
                  system.adapter.vis-weather.0            : vis-weather           : rockpro64                                - disabled
                  system.adapter.vis.0                    : vis                   : rockpro64                                -  enabled
                  system.adapter.weatherunderground.0     : weatherunderground    : rockpro64                                -  enabled
                + system.adapter.web.0                    : web                   : rockpro64                                -  enabled, port: 8082, bind: 192.168.123.248, run as: admin
                + system.adapter.ws.0                     : ws                    : rockpro64                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                + system.adapter.zigbee.0                 : zigbee                : rockpro64                                -  enabled, port: /dev/SONOFF
                + instance is alive
                ioBroker-Repositories
                Active repo(s): beta
                Installed ioBroker-Instances
                Used repository: beta
                Adapter    "admin"        : 6.17.6   , installed 6.17.6
                Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                Adapter    "broadlink2"   : 2.2.0    , installed 2.2.0
                Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
                Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                Adapter    "email"        : 1.3.0    , installed 1.3.0
                Adapter    "enigma2"      : 2.1.0    , installed 2.1.0
                Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                Adapter    "firetv"       : 2.1.0    , installed 2.1.0
                Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                Adapter    "hs100"        : 2.2.0    , installed 2.2.0
                Adapter    "ical"         : 1.15.0   , installed 1.15.0
                Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
                Adapter    "iot"          : 3.2.2    , installed 3.2.2
                Adapter    "javascript"   : 8.1.1    , installed 8.1.1
                Controller "js-controller": 5.0.19   , installed 5.0.19
                Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                Adapter    "nut"          : 1.6.0    , installed 1.6.0
                Adapter    "paw"          : 0.3.2    , installed 0.3.2
                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                Adapter    "radar2"       : 2.2.0    , installed 2.2.0
                Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
                Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                Adapter    "tado"         : 0.5.4    , installed 0.5.4
                Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                Adapter    "telegram"     : 3.2.1    , installed 3.2.1
                Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
                Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
                Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                Adapter    "ws"           : 2.6.1    , installed 2.6.1
                Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                Objects and States
                Objects: 	26986
                States: 	27627
                Hit:1 https://downloads.plex.tv/repo/deb public InRelease
                Hit:2 http://ports.ubuntu.com jammy InRelease
                Hit:3 http://ports.ubuntu.com jammy-security InRelease
                Hit:4 http://ports.ubuntu.com jammy-updates InRelease
                Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                Hit:6 http://ports.ubuntu.com jammy-backports InRelease
                Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          24751      2995/sendmail: MTA:
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17698      1/init
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          20108      1810/apache2
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19970      1401/sshd: /usr/sbi
                tcp        0      0 127.0.0.1:587           0.0.0.0:*               LISTEN      0          24752      2995/sendmail: MTA:
                tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          20094      1792/dnsmasq
                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       22056      1247/iobroker.js-co
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22051      1247/iobroker.js-co
                tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          22981      1242/cupsd
                tcp        0      0 192.168.123.248:12001   0.0.0.0:*               LISTEN      1001       24823      3167/io.hm-rpc.3
                tcp        0      0 0.0.0.0:7575            0.0.0.0:*               LISTEN      0          21685      1402/vhusbdarm64
                tcp        0      0 127.0.0.1:33979         0.0.0.0:*               LISTEN      998        20123      1841/Plex Plug-in [
                tcp        0      0 192.168.123.248:8082    0.0.0.0:*               LISTEN      1001       31879      4065/io.web.0
                tcp        0      0 192.168.123.248:2010    0.0.0.0:*               LISTEN      1001       31208      3774/io.hm-rpc.2
                tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          21727      1512/upsd
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       25165      3607/io.shelly.0
                tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      998        21833      1329/Plex Media Ser
                tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      998        11083      2212/Plex Tuner Ser
                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        19765      759/systemd-resolve
                tcp6       0      0 :::111                  :::*                    LISTEN      0          17700      1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          19972      1401/sshd: /usr/sbi
                tcp6       0      0 :::631                  :::*                    LISTEN      0          22982      1242/cupsd
                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       32777      4076/io.ws.0
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30467      3944/io.simple-api.
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22181      2270/io.admin.0
                tcp6       0      0 :::7999                 :::*                    LISTEN      1001       22446      3058/io.hiob.0
                tcp6       0      0 :::9876                 :::*                    LISTEN      1001       29182      3914/io.paw.0
                tcp6       0      0 :::32400                :::*                    LISTEN      998        21831      1329/Plex Media Ser
                udp        0      0 127.0.0.1:56223         0.0.0.0:*                           998        23095      1329/Plex Media Ser
                udp        0      0 192.168.123.248:33835   0.0.0.0:*                           998        23103      1329/Plex Media Ser
                udp        0      0 10.0.3.1:40080          0.0.0.0:*                           998        23096      1329/Plex Media Ser
                udp        0      0 0.0.0.0:46472           0.0.0.0:*                           1001       27181      3753/io.broadlink.0
                udp        0      0 192.168.123.248:60817   0.0.0.0:*                           998        23100      1329/Plex Media Ser
                udp        0      0 0.0.0.0:52857           0.0.0.0:*                           1001       31151      3753/io.broadlink.0
                udp        0      0 0.0.0.0:32410           0.0.0.0:*                           998        20131      1329/Plex Media Ser
                udp        0      0 0.0.0.0:32412           0.0.0.0:*                           998        23093      1329/Plex Media Ser
                udp        0      0 0.0.0.0:32413           0.0.0.0:*                           998        23094      1329/Plex Media Ser
                udp        0      0 0.0.0.0:32414           0.0.0.0:*                           998        20130      1329/Plex Media Ser
                udp        0      0 0.0.0.0:1901            0.0.0.0:*                           998        23101      1329/Plex Media Ser
                udp        0      0 0.0.0.0:49102           0.0.0.0:*                           1001       24742      2646/io.broadlink2.
                udp        0      0 192.168.123.248:43060   0.0.0.0:*                           998        23097      1329/Plex Media Ser
                udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          20093      1792/dnsmasq
                udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        19764      759/systemd-resolve
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       27917      3525/io.radar2.0
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          20090      1792/dnsmasq
                udp        0      0 127.0.0.1:39015         0.0.0.0:*                           998        23098      1329/Plex Media Ser
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17699      1/init
                udp        0      0 10.0.3.1:39124          0.0.0.0:*                           998        23099      1329/Plex Media Ser
                udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          10767      1323/chronyd
                udp        0      0 0.0.0.0:39302           0.0.0.0:*                           1001       164134     2646/io.broadlink2.
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       29023      3644/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       29024      3644/io.tuya.0
                udp        0      0 10.0.3.1:45595          0.0.0.0:*                           998        23102      1329/Plex Media Ser
                udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       22289      2646/io.broadlink2.
                udp        0      0 0.0.0.0:54028           0.0.0.0:*                           1001       24743      2646/io.broadlink2.
                udp6       0      0 :::111                  :::*                                0          10337      1/init
                udp6       0      0 ::1:323                 :::*                                0          10768      1323/chronyd
                2024-05-06 15:33:10.390  - info: ical.3 (36291) Terminated (NO_ERROR): Without reason
                2024-05-06 15:33:10.954  - info: host.rockpro64 instance system.adapter.ical.3 terminated with code 0 (NO_ERROR)
                2024-05-06 15:34:00.041  - info: host.rockpro64 instance system.adapter.ical.4 started with pid 36380
                2024-05-06 15:34:03.404  - info: ical.4 (36380) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
                2024-05-06 15:34:10.379  - info: ical.4 (36380) Terminated (NO_ERROR): Without reason
                2024-05-06 15:34:10.949  - info: host.rockpro64 instance system.adapter.ical.4 terminated with code 0 (NO_ERROR)
                2024-05-06 15:35:00.121  - info: host.rockpro64 instance system.adapter.ical.5 started with pid 36734
                2024-05-06 15:35:00.285  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200
                2024-05-06 15:35:00.368  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200
                2024-05-06 15:35:03.821  - info: ical.5 (36734) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
                2024-05-06 15:35:10.644  - info: ical.5 (36734) Terminated (NO_ERROR): Without reason
                2024-05-06 15:35:11.210  - info: host.rockpro64 instance system.adapter.ical.5 terminated with code 0 (NO_ERROR)
                2024-05-06 15:40:00.225  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200
                2024-05-06 15:40:00.336  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200
                2024-05-06 15:45:00.240  - info: javascript.0 (2559) script.js.Datenpunkte.TPLinkVerbrauch: hs100 Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 6
                2024-05-06 15:45:00.242  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200
                2024-05-06 15:45:00.289  - info: javascript.0 (2559) script.js.Datenpunkte.ShellyVerbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 13 | Reboots korrigiert: 0 | Unveränderte Werte: 18
                2024-05-06 15:45:00.330  - info: javascript.0 (2559) script.js.Datenpunkte.HomematicVerbrauch: Homematic Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
                2024-05-06 15:45:00.371  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200
                2024-05-06 15:50:00.336  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200
                2024-05-06 15:50:00.445  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200
                2024-05-06 15:55:00.286  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk: Response is 200
                2024-05-06 15:55:00.394  - info: javascript.0 (2559) script.js.Datenpunkte.Balkonkraftwerk-Jogi: Response is 200
                			v.2024-04-21
                       Icon name: computer
                    Architecture: arm64
                Installation: 		native
                Kernel: 		aarch64
                Userland: 		64 bit
                Timezone: 		Europe/Berlin (CEST, +0200)
                User-ID: 		1000
                Pending OS-Updates: 	0
                Pending iob updates: 	0
                Nodejs-Installation:
                /usr/bin/npm 		10.5.0
                /usr/bin/npx 		10.5.0
                Recommended versions are nodejs 18.20.2 and npm 10.5.0
                MEMORY:
                Mem:            3.9G        2.8G        217M        7.0M        882M        988M
                Swap:           1.9G        1.4G        496M
                Total:          5.8G        4.2G        713M
                ioBroker Core: 		js-controller 		5.0.19
                			admin 			6.17.6
                ioBroker Status: 	iobroker is running on this host.
                Objects type: jsonl
                States  type: jsonl
                Objects: 		26986
                States: 		27627
                Size of iob-Database:
                46M	/opt/iobroker/iobroker-data/states.jsonl
                  Skript v.2024-04-21
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 6
                                NTP service: active
                            RTC in local TZ: no
                  rockpro64
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                           3863 M total memory
                           2983 M used memory
                            164 M free memory
                             81 M buffer memory
                            634 M swap cache
                           1931 M total swap
                           1119 M used swap
                            812 M free swap
                  *** FILESYSTEM ***
                  /var:
                  4.7G	/var/
                  4.4G	/var/lib
                  USB-Devices by-id:
                  HINT:
                  /dev/SONOFF
                  /usr/bin/npm 		10.5.0
                  /usr/bin/npx 		10.5.0
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.17.6
                  javascript: 	8.1.1
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects: 	26986
                  States: 	27627
                  Pending Updates: 0
                  			v.2024-04-21
                         Icon name: computer
                      Architecture: arm64
                  Kernel: 		aarch64
                  Userland: 		64 bit
                  User-ID: 		1000
                  /usr/bin/npm 		10.5.0
                  /usr/bin/npx 		10.5.0
                  MEMORY:
                  			admin 			6.17.6
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		26986
                  States: 		27627
                  @malleralle
                  Nimm mal die Links zu Reginas Kalendern aus dem Log (letzte Zeilen) raus.
                    @malleralle
                    MalleRalleM Offline
                    MalleRalleM Offline
                    MalleRalle
                    Danke, ist raus. Shit übersehen...
                      @malleralle
                      Wo hängt denn bufferutil bei dir im System?
                      cd /opt/iobroker && npm ls bufferutil
                        @malleralle
                        MalleRalleM Offline
                        MalleRalleM Offline
                        MalleRalle
                        r$ npm ls bufferutil
                        iobroker.inst@3.0.0 /opt/iobroker
                        └── (empty)
