  4. Node-Red
  5. [Gelöst] Farbe in Text node ändern
    6.4k
node-red
2 Beiträge 1 Kommentatoren 832 Aufrufe 1 Beobachtet
    matthesjimte
    schrieb am zuletzt editiert von matthesjimte
    Guten Abend
    Ich versuche über Node Red meine Wallbox auszulesen und in Abhängig, ob aktiv oder pause, die Farbe des eingestellten Ladestrom im Dashboard anzuzeigen
    Generell den Ladestrom anzeigen ist ja kein Problem
    Versuche nun über das hier die Farbe zu ändern, komischerweise wird dann aber der angezeigte Wert in der richtigen Farbe hochgezählt
            "id": "59c32b5bc1facdbb",
            "type": "ioBroker get",
            "z": "da4e1b55.2906b",
            "name": "WB_load",
            "topic": "kecontact.0.currentUser",
            "attrname": "payload",
            "payloadType": "value",
            "x": 480,
            "y": 660,
            "wires": [
                    "3568d48737df6395"
            "id": "3568d48737df6395",
            "type": "function",
            "name": "f_WB_load",
            "func": "const str = msg.payload\nmsg.payload = str;\nreturn msg;",
            "outputs": 1,
            "timeout": "",
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 650,
            "y": 660,
            "wires": [
                    "b12b5ae3ad3944c8"
            "id": "1092b1c72d1424d3",
            "name": "Enable User",
            "topic": "kecontact.0.enableUser",
            "attrname": "incolor",
            "errOnInvalidState": "nothing",
            "x": 490,
            "y": 720,
            "wires": [
                    "b12b5ae3ad3944c8"
            "id": "b12b5ae3ad3944c8",
            "type": "switch",
            "name": "",
            "property": "incolor",
            "propertyType": "msg",
            "rules": [
                    "t": "true"
                    "t": "false"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 730,
            "y": 720,
            "wires": [
                    "2d21dd1c28d55a2b"
                    "b3142ddf6e6058e9"
            "id": "2d21dd1c28d55a2b",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "fcolor",
                    "pt": "msg",
                    "to": "blue",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 920,
            "y": 700,
            "wires": [
                    "5a457c3ab9243da4"
            "id": "b3142ddf6e6058e9",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "fcolor",
                    "pt": "msg",
                    "to": "green",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 920,
            "y": 740,
            "wires": [
                    "5a457c3ab9243da4"
            "id": "5a457c3ab9243da4",
            "type": "ui_text",
            "group": "291784c0.74fa7c",
            "order": 20,
            "width": 0,
            "height": 0,
            "name": "",
            "label": "WB_load",
            "format": "<font face='arial'><font size=4><font color={{fcolor}}>{{msg.payload}}",
            "layout": "row-spread",
            "className": "",
            "style": false,
            "font": "",
            "fontSize": 16,
            "color": "#000000",
            "x": 1120,
            "y": 680,
            "wires": []
            "id": "291784c0.74fa7c",
            "type": "ui_group",
            "name": "TWS",
            "tab": "ff1df1fe.ccf768",
            "order": 1,
            "disp": true,
            "width": "6",
            "collapse": true
            "id": "ff1df1fe.ccf768",
            "type": "ui_tab",
            "name": "Home",
            "icon": "dashboard",
            "disabled": false,
            "hidden": false
    Wenn ich das jetzt nochmal umstelle, wird der Wert richtig angezeigt
    wenn ich jetzt die Farben hinzunehme
    kommt das dabei raus
    Was mache ich falsch?
    • M matthesjimte
      Guten Abend
              "name": "WB_load",
              "x": 480,
              "y": 660,
              "wires": [
                      "3568d48737df6395"
              "type": "function",
              "outputs": 1,
              "timeout": "",
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 650,
              "y": 660,
              "wires": [
                      "b12b5ae3ad3944c8"
              "x": 490,
              "y": 720,
              "wires": [
                      "b12b5ae3ad3944c8"
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 730,
              "y": 720,
              "wires": [
                      "2d21dd1c28d55a2b"
                      "b3142ddf6e6058e9"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "fcolor",
                      "pt": "msg",
                      "to": "blue",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 920,
              "y": 700,
              "wires": [
                      "5a457c3ab9243da4"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "fcolor",
                      "pt": "msg",
                      "to": "green",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 920,
              "y": 740,
              "wires": [
                      "5a457c3ab9243da4"
              "type": "ui_text",
              "order": 20,
              "width": 0,
              "height": 0,
              "name": "",
              "label": "WB_load",
              "className": "",
              "style": false,
              "font": "",
              "fontSize": 16,
              "color": "#000000",
              "x": 1120,
              "y": 680,
              "wires": []
              "type": "ui_group",
              "name": "TWS",
              "order": 1,
              "disp": true,
              "width": "6",
              "collapse": true
              "type": "ui_tab",
              "name": "Home",
              "disabled": false,
              "hidden": false
      matthesjimte
      @matthesjimte
      Habe es jetzt nochmal geändert
      und es sieht so aus als wenn es jetzt funktionieren würde.
      Mal schauen ob es dann morgen grün wird, wenn die Wallbox aus ihrer Pause erwacht
      So geht es jetzt
