  4. Node-Red
  5. Muster Stromzähler per Modbus
    6.4k
1 Beiträge 1 Kommentatoren 344 Aufrufe 1 Beobachtet
    peterfido
    anbei mein Node-Red-Flow, welches mehrere Stromzähler an einem gemeinsamen Modbus abfragt.
    Der Modbus-LAN Adapter ist ein U.S.R. USR-TCP232-304
    Folgende Zähler hängen am Bus:
    • DZG DVH4013
    • EASTRON SDM72D-M
    • Orno OR-WE 14
            "id": "c24431d8.d16be",
            "type": "tab",
            "label": "Stromzaehler",
            "disabled": false,
            "info": ""
            "id": "eda79e7e.a523a",
            "type": "function",
            "z": "c24431d8.d16be",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nvar I=0;\nvar P=0;\nvar S=0;\nif(arr.length===2){\n    I=parseFloat(arr[1])/1000;\n    if(!isNaN(I)){\n        var PF=flow.get(\"PF\");\n        var U=flow.get(\"UL1\");\n        if(!isNaN(U) && !isNaN(PF)){\n            P=Math.round(I*U*PF *100)/100;\n            S=Math.round(I*U *100)/100;\n            node.status({text:\"I:\"+I+\"A; P:\"+P+\"W; S:\"+S+\"VA\"});   \n            flow.set(\"I1\",I);\n            flow.set(\"P1\",P);\n            flow.set(\"S1\",S);\n        }\n    }\n\n    return [\n        {\n            payload: I, topic:Pfad+'I1', stateUnit: 'A'\n        },\n        {\n            payload: P, topic:Pfad+'P1', stateUnit: 'W'\n        },\n        {\n            payload: S, topic:Pfad+'S1', stateUnit: 'VA'\n                \n        }\n    ];\n}\n/*    {\n        payload: i1, topic:Pfad+'I1', stateUnit: 'A', stateType: 'number', stateRole: 'value'\n    },\n*/",
            "outputs": 3,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 610,
            "y": 300,
            "wires": [
                    "743b4448.e11c9c"
                    "743b4448.e11c9c"
                    "743b4448.e11c9c"
            "id": "c52e1e95.b8f1f",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nvar I=0;\nvar P=0;\nvar S=0;\nif(arr.length===2){\n    I=parseFloat(arr[1])/1000;\n    if(!isNaN(I)){\n        var PF=flow.get(\"PF\");\n        var U=flow.get(\"UL2\");\n        if(!isNaN(U) && !isNaN(PF)){\n            P=Math.round(I*U*PF *100)/100;\n            S=Math.round(I*U *100)/100;\n            node.status({text:\"I:\"+I+\"A; P:\"+P+\"W; S:\"+S+\"VA\"});   \n            flow.set(\"I2\",I);\n            flow.set(\"P2\",P);\n            flow.set(\"S2\",S);\n        }\n    }\n\n    return [\n        {\n            payload: I, topic:Pfad+'I2', stateUnit: 'A'\n        },\n        {\n            payload: P, topic:Pfad+'P2', stateUnit: 'W'\n        },\n        {\n            payload: S, topic:Pfad+'S2', stateUnit: 'VA'\n                \n        }\n    ];\n}\n/*    {\n        payload: i1, topic:Pfad+'I1', stateUnit: 'A', stateType: 'number', stateRole: 'value'\n    },\n*/",
            "outputs": 3,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 610,
            "y": 380,
            "wires": [
                    "743b4448.e11c9c"
                    "743b4448.e11c9c"
                    "743b4448.e11c9c"
            "id": "9730857f.daf338",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nvar I=0;\nvar P=0;\nvar S=0;\nvar Ig=0;\nif(arr.length===2){\n    I=parseFloat(arr[1])/1000;\n    if(!isNaN(I)){\n        var PF=flow.get(\"PF\");\n        var U=flow.get(\"UL3\");\n        if(!isNaN(U) && !isNaN(PF)){\n            P=Math.round(I*U*PF *100)/100;\n            S=Math.round(I*U *100)/100;\n            Ig=Math.round((flow.get(\"I1\")+flow.get(\"I2\")+I) *100)/100\n            node.status({text:\"I:\"+I+\"A; P:\"+P+\"W; S:\"+S+\"VA; Ig:\"+Ig+\"A\"});\n            flow.set(\"I3\",I);\n            flow.set(\"P3\",P);\n            flow.set(\"S3\",S);\n        }\n    }\n    return [\n        {\n            payload: I, topic:Pfad+'I3', stateUnit: 'A'\n        },\n        {\n            payload: P, topic:Pfad+'P3', stateUnit: 'W'\n        },\n        {\n            payload: S, topic:Pfad+'S3', stateUnit: 'VA'\n                \n        },\n        {\n            payload: Ig, topic:Pfad+'I', stateUnit: 'A'\n                \n        }\n        \n    ];    \n    \n}\n",
            "outputs": 4,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 610,
            "y": 460,
            "wires": [
                    "743b4448.e11c9c"
                    "743b4448.e11c9c"
                    "743b4448.e11c9c"
                    "743b4448.e11c9c"
            "id": "822f53a0.e1937",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nif(arr.length===2){\n    var wert=parseFloat(arr[1])/100;\n    flow.set(\"UL1\", wert);\n    node.status({text:wert+\"V\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'U1', stateUnit: 'V'\n        }\n    ];\n}    ",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 610,
            "y": 120,
            "wires": [
                    "743b4448.e11c9c"
            "id": "59509a99.453d34",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nif(arr.length===2){\n    var wert=parseFloat(arr[1])/100;\n    flow.set(\"UL2\", wert);\n    node.status({text:wert+\"V\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'U2', stateUnit: 'V', stateRole: 'value'\n        }\n    ];\n}   ",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 610,
            "y": 180,
            "wires": [
                    "743b4448.e11c9c"
            "id": "d127f414.df7908",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nif(arr.length===2){\n    var wert=parseFloat(arr[1])/100;\n    flow.set(\"UL3\", wert);\n    node.status({text:wert+\"V\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'U3', stateUnit: 'V'\n        }\n    ];\n}   ",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 610,
            "y": 240,
            "wires": [
                    "743b4448.e11c9c"
            "id": "c007e291.21884",
            "type": "function",
            "name": "Leistungen",
            "func": "var arr=msg.payload;\nconst Warngrenze = 2.5*60*60; //2,5 Stunden\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nvar Pz = 0;\nif(arr.length === 2){\n    Pz=parseFloat(arr[1])/10;\n}\n\nvar S1 = parseFloat(flow.get(\"S1\"));\nvar S2 = parseFloat(flow.get(\"S2\"));\nvar S3 = parseFloat(flow.get(\"S3\"));\nvar S = parseFloat(Math.round(S1+S2+S3));\nvar Zk = parseFloat(flow.get(\"Zk\"));\nvar Zg = parseFloat(flow.get(\"Zg\"));\nvar Sk = parseFloat(flow.get(\"Sk\"));\nvar Sg = parseFloat(flow.get(\"Sg\"));\nvar Warnung = false;\n\nif (S > 1){\n    Zk = 60;\n    Sk = Sk + 10;    \n}else{    \n    if (Zk>10){\n        Zk = Zk - 10;\n        Sk = Sk + 10;\n    }else{\n        Zk = 0;\n        Sk = 0;\n    }\n}\n\n\nif (S > 100){\n    Zg = 180;\n    Sg = Sg + 10;    \n}else{    \n\n    if (Zg>10){\n        Zg = Zg -10;\n    }else{\n        Zg = 0;\n        Sg = 0;\n    }\n}\n\nflow.set(\"Zg\", Zg);\nflow.set(\"Zk\", Zk);\nflow.set(\"Sg\", Sg);\nflow.set(\"Sk\", Sk);\n\nvar Klein = new Date(Sk * 1000).toISOString().substr(11, 8);\nvar Gross = new Date(Sg * 1000).toISOString().substr(11, 8);\n\nWarnung = Zg > Warngrenze;\n\n//flow.set(\"UL1\", wert);\n\nnode.status({text:\"ausgelesen P:\"+Pz+\"W; S:\"+S+\"VA\"});\n//node.status({text:\"P1:\"+P1+\"; P2:\"+P2+\"; P3:\"+P3});\n//node.status({text:\"S1:\"+S1+\"; S2:\"+S2+\"; S3:\"+S3});\n//topic:Pfad+'CosPhi', stateUnit: '', stateType: 'number', stateRole: 'value'\nreturn [\n    {\n        payload: Pz, topic:Pfad+'P', stateUnit: 'W'\n    },\n    {\n        payload: S, topic:Pfad+'S', stateUnit: 'VA'\n    },\n    {\n        payload: Klein, topic:Pfad+'Sklein'\n    },\n    {\n        payload: Gross, topic:Pfad+'Sgross'\n    },\n    {\n        payload: Warnung, topic:Pfad+'Warnung'\n    }      \n    \n];",
            "outputs": 5,
            "noerr": 0,
            "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"Zg\", 0);\nflow.set(\"Zk\", 0);\nflow.set(\"Sg\", 0);\nflow.set(\"Sk\", 0);",
            "finalize": "",
            "libs": [],
            "x": 630,
            "y": 620,
            "wires": [
                    "743b4448.e11c9c"
                    "743b4448.e11c9c"
                    "101c66cccacac37f"
                    "101c66cccacac37f"
                    "66237a931617967c"
            "id": "743b4448.e11c9c",
            "type": "ioBroker out",
            "name": "ioB number",
            "topic": "",
            "ack": "true",
            "autoCreate": "true",
            "stateName": "",
            "role": "state",
            "payloadType": "number",
            "readonly": "false",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 1010,
            "y": 320,
            "wires": []
            "id": "a0e8c509.265ee8",
            "type": "function",
            "name": "extract buffer data",
            "func": "let voltageL1 = round(msg.payload.buffer.readFloatBE(0,4)) // 1,2\nlet voltageL2 = round(msg.payload.buffer.readFloatBE(4,4)) // 3,4\nlet voltageL3 = round(msg.payload.buffer.readFloatBE(8,4)) // 5,6\n\nlet currentL1 = round(msg.payload.buffer.readFloatBE(12,4)) // 7,8\nlet currentL2 = round(msg.payload.buffer.readFloatBE(16,4)) // 9,10\nlet currentL3 = round(msg.payload.buffer.readFloatBE(20,4)) // 11,12\n\nlet powerL1 = round(msg.payload.buffer.readFloatBE(24,4)) // 13,14\nlet powerL2 = round(msg.payload.buffer.readFloatBE(28,4)) // 15,16\nlet powerL3 = round(msg.payload.buffer.readFloatBE(32,4)) // 17,18\n\nlet spowerL1 = round(msg.payload.buffer.readFloatBE(36,4)) // 19,20\nlet spowerL2 = round(msg.payload.buffer.readFloatBE(40,4)) // 21,22\nlet spowerL3 = round(msg.payload.buffer.readFloatBE(44,4)) // 23,24\n\nlet voltageAVG = round(msg.payload.buffer.readFloatBE(84,8)) // 43-46\nlet currentAVG = round(msg.payload.buffer.readFloatBE(92,4)) // 47,48\n\nreturn [\n    {\n        payload: {\n            L1: {\n                voltage: voltageL1,\n                current: currentL1,\n                power: powerL1,\n                spower: spowerL1\n            },\n            L2: {\n                voltage: voltageL2,\n                current: currentL2,\n                power: powerL2,\n                spower: spowerL2\n            },\n            L3: {\n                voltage: voltageL3,\n                current: currentL3,\n                power: powerL3,\n                spower: spowerL3\n            },\n            voltageAVG: voltageAVG,\n            currentAVG: currentAVG,            \n        }\n    }\n];\n\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}",
            "outputs": "1",
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 470,
            "y": 1300,
            "wires": [
                    "ab2b7f84.fff3b",
                    "9cc4ad2e.71602",
                    "ee889fb2.e024f"
            "id": "ab2b7f84.fff3b",
            "type": "function",
            "name": "Ströme",
            "func": "node.status({text:\"L1:\"+msg.payload.L1.current+\"; L2:\"+msg.payload.L2.current+\"; L3:\"+msg.payload.L3.current+\"; 0:\"+msg.payload.currentAVG});\n\n\nreturn [\n    {payload: msg.payload.L1.current, topic:'0_userdata.0.Wallbox.Strom.Auslese.I1'}, \n    {payload: msg.payload.L2.current, topic:'0_userdata.0.Wallbox.Strom.Auslese.I2'}, \n    {payload: msg.payload.L3.current, topic:'0_userdata.0.Wallbox.Strom.Auslese.I3'},\n    {payload: msg.payload.currentAVG, topic:'0_userdata.0.Wallbox.Strom.Auslese.I'}\n];",
            "outputs": "4",
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 900,
            "y": 1160,
            "wires": [
                    "38b34ea4.11e192"
                    "38b34ea4.11e192"
                    "38b34ea4.11e192"
                    "38b34ea4.11e192"
            "id": "9cc4ad2e.71602",
            "type": "function",
            "name": "Spannungen",
            "func": "node.status({text:\"L1:\"+msg.payload.L1.voltage+\"; L2:\"+msg.payload.L2.voltage+\"; L3:\"+msg.payload.L3.voltage+\"; 0:\"+msg.payload.voltageAVG});\n\n\nreturn [\n    {payload: msg.payload.L1.voltage, topic:'0_userdata.0.Wallbox.Strom.Auslese.U1'}, \n    {payload: msg.payload.L2.voltage, topic:'0_userdata.0.Wallbox.Strom.Auslese.U2'}, \n    {payload: msg.payload.L3.voltage, topic:'0_userdata.0.Wallbox.Strom.Auslese.U3'},\n    {payload: msg.payload.voltageAVG, topic:'0_userdata.0.Wallbox.Strom.Auslese.ULN'}\n];",
            "outputs": "4",
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 910,
            "y": 1240,
            "wires": [
                    "96217b86.779a28"
                    "96217b86.779a28"
                    "96217b86.779a28"
                    "96217b86.779a28"
            "id": "ee889fb2.e024f",
            "type": "function",
            "func": "node.status({text:\"L1:\"+msg.payload.L1.power+\"; L2:\"+msg.payload.L2.power+\"; L3:\"+msg.payload.L3.power});\n\n\nreturn [\n    {payload: msg.payload.L1.power, topic:'0_userdata.0.Wallbox.Strom.Auslese.P1'}, \n    {payload: msg.payload.L2.power, topic:'0_userdata.0.Wallbox.Strom.Auslese.P2'}, \n    {payload: msg.payload.L3.power, topic:'0_userdata.0.Wallbox.Strom.Auslese.P3'},\n    {payload: msg.payload.L1.spower, topic:'0_userdata.0.Wallbox.Strom.Auslese.S1'}, \n    {payload: msg.payload.L2.spower, topic:'0_userdata.0.Wallbox.Strom.Auslese.S2'}, \n    {payload: msg.payload.L3.spower, topic:'0_userdata.0.Wallbox.Strom.Auslese.S3'}    \n];\n",
            "outputs": 6,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 910,
            "y": 1340,
            "wires": [
                    "204b7607.8b4d5a"
                    "204b7607.8b4d5a"
                    "204b7607.8b4d5a"
                    "204b7607.8b4d5a"
                    "204b7607.8b4d5a"
                    "204b7607.8b4d5a"
            "id": "39853145.37685e",
            "type": "function",
            "func": "let currentSum = round(msg.payload.buffer.readFloatBE(0,8))\nlet powerSum = round(msg.payload.buffer.readFloatBE(8,8))\nif(powerSum < 0){\n    powerSum=0;\n}\n\nreturn [\n    {\n        payload: currentSum, topic:'0_userdata.0.Wallbox.Strom.Watt.StromTotal'\n    },\n    {\n        payload: powerSum, topic:'0_userdata.0.Wallbox.Strom.Watt.LeistungTotal'\n            \n    }\n];\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}\n\n",
            "outputs": 2,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 390,
            "y": 800,
            "wires": [
                    "7d6e2cb1.25cf94"
                    "7d6e2cb1.25cf94"
            "id": "525c624.e1e5b9c",
            "type": "function",
            "func": "let frequency = round(msg.payload.buffer.readFloatBE(0,4)) // 71,72\nlet ImportActiveEnergy = round(msg.payload.buffer.readFloatBE(4,4)) // 73,74\nlet ampHourSinceLastReset = round(msg.payload.buffer.readFloatBE(24,4)) // 83,84\nlet totalSystemPowerDemand = round(msg.payload.buffer.readFloatBE(28,4)) // 85,86\nlet maxTotalSystemPowerDemand = round(msg.payload.buffer.readFloatBE(32,4)) // 87,88\n\nreturn [\n    { \n        payload: frequency, topic:'0_userdata.0.Wallbox.Strom.Auslese.Frequenz'\n    },\n    { \n        payload: ImportActiveEnergy, topic:'0_userdata.0.Wallbox.Strom.Auslese.ArbeitT1'\n    },\n    {\n        payload: ampHourSinceLastReset / 1000.0, topic:'0_userdata.0.Wallbox.Strom.Watt.ampHourSinceLastReset'\n    },    \n    {\n        payload: totalSystemPowerDemand / 1000.0, topic:'0_userdata.0.Wallbox.Strom.Watt.totalSystemPowerDemand'\n    },\n    {\n        payload: maxTotalSystemPowerDemand / 1000.0, topic:'0_userdata.0.Wallbox.Strom.Watt.maxTotalSystemPowerDemand'\n    }\n];\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}\n",
            "outputs": 5,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 390,
            "y": 920,
            "wires": [
                    "5b800497.8d630c"
                    "5b800497.8d630c"
                    "5b800497.8d630c"
                    "5b800497.8d630c"
                    "5b800497.8d630c"
            "id": "2c8be1dc.543d2e",
            "type": "function",
            "func": "let voltageL12 = round(msg.payload.buffer.readFloatBE(0,4)) // 1,2\nlet voltageL23 = round(msg.payload.buffer.readFloatBE(4,4)) // 3,4\nlet voltageL31 = round(msg.payload.buffer.readFloatBE(8,4)) // 5,6\nlet voltageAVG = round(msg.payload.buffer.readFloatBE(12,4)) // 7,8\n\nnode.status({text:\"L12:\"+voltageL12+\"; L23:\"+voltageL23+\"; L31:\"+voltageL31+\"; 0:\"+voltageAVG});\n\nreturn [\n    {payload: voltageL12, topic:'0_userdata.0.Wallbox.Strom.Auslese.U12'}, \n    {payload: voltageL23, topic:'0_userdata.0.Wallbox.Strom.Auslese.U23'}, \n    {payload: voltageL31, topic:'0_userdata.0.Wallbox.Strom.Auslese.U31'},\n    {payload: voltageAVG, topic:'0_userdata.0.Wallbox.Strom.Auslese.ULL'}\n];\n\n\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}",
            "outputs": 4,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 390,
            "y": 1020,
            "wires": [
                    "ee04a046.d40ac"
                    "ee04a046.d40ac"
                    "ee04a046.d40ac"
                    "ee04a046.d40ac"
            "id": "a4aa7b2f.ea6278",
            "type": "function",
            "func": "let arbeit = round(msg.payload.buffer.readFloatBE(0,4)) // 1,2\nnode.status({text:\"Arbeit:\"+arbeit+\"kWh\"});\nreturn [\n    {\n        payload: arbeit, topic:'0_userdata.0.Wallbox.Strom.Auslese.Arbeit'\n        \n    }\n];\n\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}",
            "outputs": "1",
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 430,
            "y": 1120,
            "wires": [
                    "2209a5e3.4e547a"
            "id": "38b34ea4.11e192",
            "name": "Ströme",
            "topic": "",
            "ack": "true",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 1160,
            "y": 1140,
            "wires": []
            "id": "96217b86.779a28",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 1170,
            "y": 1220,
            "wires": []
            "id": "204b7607.8b4d5a",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 1170,
            "y": 1320,
            "wires": []
            "id": "7d6e2cb1.25cf94",
            "name": "I P Total",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 580,
            "y": 820,
            "wires": []
            "id": "ee04a046.d40ac",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 670,
            "y": 1020,
            "wires": []
            "id": "2209a5e3.4e547a",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 640,
            "y": 1120,
            "wires": []
            "id": "fa2c309d.e85bf",
            "type": "function",
            "func": "let lf = round(msg.payload.buffer.readFloatBE(0,4)) // 1,2\nif (lf < 0 ){\n    lf=0;\n}\nnode.status({text:\"LF:\"+lf});\nreturn [\n    {\n        payload: lf, topic:'0_userdata.0.Wallbox.Strom.Auslese.LF'\n        \n    }\n];\n\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}",
            "outputs": "1",
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 430,
            "y": 1180,
            "wires": [
                    "2209a5e3.4e547a"
            "id": "5b800497.8d630c",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 600,
            "y": 900,
            "wires": []
            "id": "513c1518.2442cc",
            "type": "catch",
            "name": "",
            "scope": [
                "743b4448.e11c9c",
                "38b34ea4.11e192",
                "96217b86.779a28",
                "204b7607.8b4d5a",
                "7d6e2cb1.25cf94",
                "ee04a046.d40ac",
                "2209a5e3.4e547a",
                "5b800497.8d630c",
                "101c66cccacac37f",
                "66237a931617967c",
                "6b8bbc65.099ef4",
                "f855b57f.5901a8",
                "968d7a0b.0fe808",
                "efab8902.f736e8",
                "dfe61d4d.a1bfb",
                "e9657bb2.688a58",
                "cdf0c6e39f6fa40c",
                "ddf59ada8cf40eec",
                "9b3eeb1d11c036d1",
                "14b581abc78ba857",
                "c4f57b115fabadf1",
                "ba122be31cfb23f3",
                "ca5120478f8ce267",
                "0ef7ac1c223df769",
                "32187279838c66f9",
                "0c430f6fd725e2e9",
                "7e37843a9056e0ef",
                "f4b12dc83ea99fe7",
                "26670495e6e675c2"
            "uncaught": false,
            "x": 160,
            "y": 1880,
            "wires": [
                    "4c34a6dc.573be8"
            "id": "4c34a6dc.573be8",
            "type": "debug",
            "name": "",
            "active": false,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "statusType": "auto",
            "x": 370,
            "y": 1880,
            "wires": []
            "id": "1e4ce668f6fc1d33",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nif(arr.length===2){\n    var wert=parseFloat(arr[1])/1000;\n    flow.set(\"PF\", wert);\n\n    node.status({text:\"Cos Phi:\"+wert});\n\n    return [\n        {\n            payload: wert, topic:'0_userdata.0.Zaehler.Strom.Herd.ist.LF'\n            \n        }\n    ];\n}    ",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 610,
            "y": 60,
            "wires": [
                    "743b4448.e11c9c"
            "id": "101c66cccacac37f",
            "name": "ioB string",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "string",
            "payloadType": "string",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 1000,
            "y": 480,
            "wires": []
            "id": "66237a931617967c",
            "name": "ioB boolean",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "state",
            "payloadType": "boolean",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 1010,
            "y": 560,
            "wires": []
            "id": "f626796a7eedb661",
            "type": "delay",
            "name": "",
            "pauseType": "delay",
            "timeout": "5",
            "timeoutUnits": "seconds",
            "rate": "1",
            "nbRateUnits": "1",
            "rateUnits": "second",
            "randomFirst": "1",
            "randomLast": "5",
            "randomUnits": "seconds",
            "drop": false,
            "allowrate": false,
            "outputs": 1,
            "x": 120,
            "y": 720,
            "wires": [
                    "cdf0c6e39f6fa40c"
            "id": "777228346e35b408",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "10",
            "crontab": "",
            "once": true,
            "onceDelay": "1",
            "topic": "",
            "payload": "",
            "payloadType": "date",
            "x": 90,
            "y": 160,
            "wires": [
                    "f4b12dc83ea99fe7",
                    "f626796a7eedb661"
            "id": "168ad1b7fad7e8a2",
            "type": "function",
            "name": "Tariflos 1.8.0",
            "func": "const Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\n\nvar arr=msg.payload;\nvar T0=0;\n\nif(arr.length===2){\n    var f=parseFloat(arr[0])*65536;\n    f=f+parseFloat(arr[1]);\n    f=f/1000;\n    T0=f;\n}\nnode.status({text:\"Arbeit:\"+T0+\"kWh\"});\n\nreturn [\n    {\n        payload: T0,  topic:Pfad+'Arbeit', stateUnit: 'kWh'\n    }\n];\n\n",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 630,
            "y": 540,
            "wires": [
                    "743b4448.e11c9c"
            "id": "6b8bbc65.099ef4",
            "type": "modbus-getter",
            "name": "U2",
            "showStatusActivities": false,
            "showErrors": true,
            "logIOActivities": false,
            "unitid": "151",
            "dataType": "HoldingRegister",
            "adr": "6",
            "quantity": "2",
            "server": "f4e69f0c.3ab6c",
            "useIOFile": false,
            "ioFile": "",
            "useIOForPayload": false,
            "emptyMsgOnFail": false,
            "keepMsgProperties": false,
            "x": 310,
            "y": 200,
            "wires": [
                    "59509a99.453d34"
                    "f855b57f.5901a8"
            "id": "f855b57f.5901a8",
            "name": "U3",
            "showErrors": true,
            "unitid": "151",
            "adr": "8",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 310,
            "y": 260,
            "wires": [
                    "d127f414.df7908"
                    "968d7a0b.0fe808"
            "id": "968d7a0b.0fe808",
            "name": "I1",
            "showErrors": true,
            "unitid": "151",
            "adr": "10",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 310,
            "y": 320,
            "wires": [
                    "eda79e7e.a523a"
                    "efab8902.f736e8"
            "id": "efab8902.f736e8",
            "name": "I2",
            "showErrors": true,
            "unitid": "151",
            "adr": "12",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 310,
            "y": 400,
            "wires": [
                    "c52e1e95.b8f1f"
                    "dfe61d4d.a1bfb"
            "id": "dfe61d4d.a1bfb",
            "name": "I3",
            "showErrors": true,
            "unitid": "151",
            "adr": "14",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 310,
            "y": 460,
            "wires": [
                    "9730857f.daf338"
                    "26670495e6e675c2"
            "id": "e9657bb2.688a58",
            "name": "P",
            "showErrors": true,
            "unitid": "151",
            "adr": "0",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 310,
            "y": 620,
            "wires": [
                    "c007e291.21884"
            "id": "0ef7ac1c223df769",
            "name": "U1",
            "showErrors": true,
            "unitid": "151",
            "adr": "4",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 310,
            "y": 140,
            "wires": [
                    "822f53a0.e1937"
                    "6b8bbc65.099ef4"
            "id": "ba122be31cfb23f3",
            "name": "70+42",
            "showErrors": true,
            "unitid": "11",
            "dataType": "InputRegister",
            "adr": "70",
            "quantity": "42",
            "useIOFile": false,
            "ioFile": "",
            "x": 150,
            "y": 860,
            "wires": [
                    "525c624.e1e5b9c",
                    "ca5120478f8ce267"
            "id": "ca5120478f8ce267",
            "name": "200+12",
            "showErrors": true,
            "unitid": "11",
            "adr": "200",
            "quantity": "12",
            "useIOFile": false,
            "ioFile": "",
            "x": 160,
            "y": 940,
            "wires": [
                    "2c8be1dc.543d2e",
                    "32187279838c66f9"
            "id": "32187279838c66f9",
            "name": "1280+2",
            "showErrors": true,
            "unitid": "11",
            "adr": "1280",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 160,
            "y": 1060,
            "wires": [
                    "a4aa7b2f.ea6278",
                    "0c430f6fd725e2e9"
            "id": "0c430f6fd725e2e9",
            "name": "60+2",
            "showErrors": true,
            "unitid": "11",
            "adr": "60",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 150,
            "y": 1180,
            "wires": [
                    "fa2c309d.e85bf",
                    "7e37843a9056e0ef"
            "id": "7e37843a9056e0ef",
            "name": "0+50",
            "showErrors": true,
            "unitid": "11",
            "adr": "0",
            "quantity": "50",
            "useIOFile": false,
            "ioFile": "",
            "x": 150,
            "y": 1320,
            "wires": [
                    "ddf59ada8cf40eec"
                    "a0e8c509.265ee8"
            "id": "cdf0c6e39f6fa40c",
            "name": "48+8",
            "showErrors": true,
            "unitid": "11",
            "adr": "48",
            "quantity": "8",
            "useIOFile": false,
            "ioFile": "",
            "x": 170,
            "y": 780,
            "wires": [
                    "39853145.37685e",
                    "ba122be31cfb23f3"
            "id": "f4b12dc83ea99fe7",
            "name": "Cos Phi",
            "showErrors": true,
            "unitid": "151",
            "adr": "16",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 300,
            "y": 80,
            "wires": [
                    "1e4ce668f6fc1d33"
                    "0ef7ac1c223df769"
            "id": "26670495e6e675c2",
            "name": "kWh",
            "showErrors": false,
            "unitid": "151",
            "adr": "16384",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 310,
            "y": 540,
            "wires": [
                    "168ad1b7fad7e8a2"
                    "e9657bb2.688a58"
            "id": "ddf59ada8cf40eec",
            "name": "OR-WE 14 U",
            "showErrors": true,
            "unitid": "4",
            "adr": "305",
            "quantity": "1",
            "useIOFile": false,
            "ioFile": "",
            "x": 170,
            "y": 1500,
            "wires": [
                    "82950a49f8fc4c42",
                    "9b3eeb1d11c036d1"
            "id": "bf2809c2e7ae4ffd",
            "type": "debug",
            "name": "debug 3",
            "active": false,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "true",
            "targetType": "full",
            "statusVal": "",
            "x": 540,
            "y": 1820,
            "wires": []
            "id": "9b3eeb1d11c036d1",
            "name": "OR-WE 14 I",
            "showErrors": true,
            "unitid": "4",
            "adr": "313",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 170,
            "y": 1580,
            "wires": [
                    "14b581abc78ba857",
                    "cb050a79f5f96008"
            "id": "14b581abc78ba857",
            "name": "OR-WE 14 P",
            "showErrors": true,
            "unitid": "4",
            "adr": "320",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 170,
            "y": 1660,
            "wires": [
                    "7b030f2291475e82",
                    "0ed251949763c827",
                    "bf2809c2e7ae4ffd"
            "id": "c4f57b115fabadf1",
            "name": "OR-WE 14 kWh",
            "showErrors": true,
            "showWarnings": true,
            "unitid": "4",
            "adr": "40960",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "delayOnStart": false,
            "startDelayTime": "",
            "x": 180,
            "y": 1820,
            "wires": [
                    "07e78de48e963783",
                    "dfabf7acb25b33dc"
            "id": "82950a49f8fc4c42",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===1){\n    var wert=parseFloat(arr[0])/100;\n    node.status({text:wert+\"V\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'U1', stateUnit: 'V'\n        }\n    ];\n}    ",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 370,
            "y": 1500,
            "wires": [
                    "8b4a362dc5bd1f51"
            "id": "cb050a79f5f96008",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===2){\n    var wert = parseFloat(arr[0]) * 65536 + parseFloat(arr[1])\n    \n    wert=wert/1000;\n    \n    node.status({text:wert+\"A\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'I1', stateUnit: 'A'\n        }\n    ];\n}    ",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 370,
            "y": 1560,
            "wires": [
                    "8b4a362dc5bd1f51"
            "id": "7b030f2291475e82",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===2){\n    var wert = parseFloat(arr[0]) * 65536 + parseFloat(arr[1])\n   // wert = wert / 1000;\n    node.status({text:wert+\"W\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'P1', stateUnit: 'W'\n        }\n    ];\n}    ",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 370,
            "y": 1640,
            "wires": [
                    "8b4a362dc5bd1f51"
            "id": "07e78de48e963783",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===2){\n    var wert = parseFloat(arr[0]) * 65536 + parseFloat(arr[1])\n    wert = wert / 100;\n\n    node.status({ text: wert + \"kWh\"});\n    return [\n        {\n            payload: wert, topic:Pfad+'Arbeit', stateUnit: 'kWh'\n        }\n    ];\n}    ",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 370,
            "y": 1780,
            "wires": [
                    "8b4a362dc5bd1f51"
            "id": "8b4a362dc5bd1f51",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "state",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 650,
            "y": 1640,
            "wires": []
            "id": "0ed251949763c827",
            "name": "OR-WE 14 S",
            "showErrors": true,
            "unitid": "4",
            "adr": "336",
            "quantity": "2",
            "useIOFile": false,
            "ioFile": "",
            "x": 170,
            "y": 1740,
            "wires": [
                    "d4116f75baeadc71",
                    "c4f57b115fabadf1"
            "id": "d4116f75baeadc71",
            "type": "function",
            "name": "Faktor",
            "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===2){\n    var wert = parseFloat(arr[0]) * 65536 + parseFloat(arr[1])\n   // wert = wert / 1000;\n    node.status({text:wert+\"VA\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'S1', stateUnit: 'VA'\n        }\n    ];\n}    ",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 370,
            "y": 1700,
            "wires": [
                    "8b4a362dc5bd1f51"
            "id": "dfabf7acb25b33dc",
            "type": "debug",
            "name": "debug 7",
            "active": false,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "true",
            "statusVal": "",
            "x": 540,
            "y": 1860,
            "wires": []
            "id": "f8bd2c635d269c86",
            "type": "comment",
            "name": "DZG DVH4013",
            "info": "",
            "x": 320,
            "y": 20,
            "wires": []
            "id": "59f5de91d229a142",
            "type": "comment",
            "name": "EASTRON SDM72D-M",
            "info": "EASTRON SDM72D-M",
            "x": 400,
            "y": 720,
            "wires": []
            "id": "49f1bbf094d20d2c",
            "type": "comment",
            "name": "Orno OR-WE 14",
            "info": "",
            "x": 180,
            "y": 1440,
            "wires": []
            "id": "f4e69f0c.3ab6c",
            "type": "modbus-client",
            "name": "USRIOT",
            "clienttype": "tcp",
            "bufferCommands": true,
            "stateLogEnabled": false,
            "queueLogEnabled": true,
            "failureLogEnabled": false,
            "tcpHost": "192.168.2.96",
            "tcpPort": "502",
            "tcpType": "TELNET",
            "serialPort": "/dev/ttyUSB",
            "serialType": "RTU-BUFFERD",
            "serialBaudrate": "9600",
            "serialDatabits": "8",
            "serialStopbits": "1",
            "serialParity": "none",
            "serialConnectionDelay": "100",
            "serialAsciiResponseStartDelimiter": "",
            "unit_id": "1",
            "commandDelay": "300",
            "clientTimeout": "1000",
            "reconnectOnTimeout": true,
            "reconnectTimeout": "5000",
            "parallelUnitIdsAllowed": true
    Peterfido
