  4. Javascript Adapter 7.8.0 stuerzt ab
    1.0k
    6.1k
53 Beiträge 9 Kommentatoren 4.3k Aufrufe 7 Beobachtet
  • H Offline
    Hawkiobroker 0
    FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
    Plattform: docker (official image - v9.1.1)
    Betriebssystem: linux
    Architektur: x64
    CPUs: 4
    Geschwindigkeit: 1501 MHz
    Modell: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    RAM: 15.4 GB
    System-Betriebszeit: 1 T. 05:32:39
    Node.js: v18.19.1
    time: 1710096680638
    timeOffset: -60
    NPM: 10.2.4
    Adapter-Anzahl: 534
    Datenträgergröße: 7145.1 GB
    Freier Festplattenspeicher: 4743.5 GB
    Aktive Instanzen: 16
    Pfad: /opt/iobroker/
    Betriebszeit: 01:14:32
    aktiv
    • Adaptername: javascript
    • Adapterversion: 7.8.0
    • js.controller: 5.0.19
    • admin: 6.13.16
                            v.2023-10-10
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v9.1.1
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     1
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                            /usr/bin/node           v18.19.1
                            /usr/bin/npm            10.2.4
                            /usr/bin/npx            10.2.4
                            /usr/bin/corepack       0.22.0
    Recommended versions are nodejs 18.19.1 and npm 10.2.4
    MEMORY:
    Mem:             16G        6.3G        2.9G        157M        7.9G         10G
    Swap:            12G        193M         11G
    Total:           28G        6.5G         14G
    Active iob-Instances:   17
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.19
                            admin                   6.13.16
    ^[[B^[[BioBroker Status:        iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobrokerSchozach01                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : iobrokerSchozach01                       -  enabled, port: 8082, bind: 0.0.0.0, run as: iobrokerhawk
    Objects:                16473
    States:                 13760
    Size of iob-Database:
    304M    /opt/iobroker/iobroker-data/objects.jsonl
    9.0M    /opt/iobroker/iobroker-data/objects.json.migrated
    9.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    12M     /opt/iobroker/iobroker-data/states.jsonl
    1.3M    /opt/iobroker/iobroker-data/states.json.migrated
    1.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    • H Hawkiobroker 0
      Architektur: x64
      CPUs: 4
      RAM: 15.4 GB
      Node.js: v18.19.1
      time: 1710096680638
      timeOffset: -60
      NPM: 10.2.4
      Adapter-Anzahl: 534
      aktiv
      • admin: 6.13.16
                              v.2023-10-10
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.1
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
                              /usr/bin/npm            10.2.4
                              /usr/bin/npx            10.2.4
      MEMORY:
      Swap:            12G        193M         11G
      Total:           28G        6.5G         14G
                              admin                   6.13.16
      Objects type: jsonl
      States  type: jsonl
      Objects:                16473
      States:                 13760
      @hawkiobroker-0 sagte in Javascript Adapter 7.8.0 stuerzt ab:
      Da hast du dir offenbar ein Skript falsch zusammen gebaut.
      H 1 Antwort Letzte Antwort
        Hawkiobroker 0
        @thomas-braun : ich habe alle Skripte deaktiviert. Trotzdem kommt es zum Absturz.
        • H Hawkiobroker 0
          Schau ins Log.
          Oder in die Langfassung von
          iob diag
          • H Hawkiobroker 0
            hast du mal die Instanz neu gestartet. Möglicherweise können da irgendwelche timeouts nicht mehr gestoppt werden o.ä.
            H 2 Antworten Letzte Antwort
              Hawkiobroker 0
              @homoran mehrfach Instanz neu gestartet. Auch andere Instanzen/ Adapter deaktiviert. Bei Aktivierung von Javascript immer dasselbe verhalt: Absturz.
              • H Hawkiobroker 0
                Schau ins Log...
                  Schau ins Log.
                  iob diag
                  Hawkiobroker 0
                  @thomas-braun Danke fuer den Hinweis. Das habe ich mir angeschaut. Ich bin bei weitem kein Experte und kann da nichts erkennen. Irgend eine Idee?
                  • H Hawkiobroker 0
                    Ich auch nicht. Scheint geheim zu sein.
                      Hawkiobroker 0
                      @homoran Nur zur Vollstaendigkeit: Auch iobroker und den Synology Server habe ich beim troubleshooting mehrfach neu gestartet.
                        Hawkiobroker 0
                        @thomas-braun Na dann trotzdem Danke fuer die Muehe.
                        • H Hawkiobroker 0
                          @hawkiobroker-0
                          Poste das geheime Log halt, dann kann man da vielleicht auch was sehen.
                          Alternativ die Langfassung von
                          iob diag
                          halt.
                            @hawkiobroker-0
                            iob diag
                            halt.
                            Hawkiobroker 0
                            @thomas-braun wie gesagt, ich bin kein Profi. In meinem orginaeren Post habe ich folgenden Log-Ausschitt mitgeliefert.
                            Was waere noch hilfreich (ausser der Langversion von iob diag.
                            DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                            • H Hawkiobroker 0
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              nur diese Ausgabe in der Langfassung.
                              Ist doch kein Hexenwerk.
                              In der Konsolse
                              iob diag
                              eingeben und dann einfach alles in Codetags hier posten, dann kann man da besser helfen ;)
                              Lehrling seit 1975 !!!
                              • H Hawkiobroker 0
                                Was ist das für ein Log?
                                Und als Screenshot kann man damit auch nix anfangen.
                                • DJMarc75D DJMarc75
                                  In der Konsolse
                                  iob diag
                                  Hawkiobroker 0
                                  @djmarc75 hier ist das Log aus iobroker und der output aus iob diag. Beides habe ich erstellt nach einem iobroker Neustart (davor javascript instance ausgeschaltet) und danach javascript Instanz wieder aktiviert.
                                  ======== Start marking the full check here =========
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                  Hardware Vendor : Synology
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  Docker          : v9.1.1
                                  Virtualization  : Docker
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  Systemuptime and Load:
                                   20:22:29 up 2 days,  6:03,  0 user,  load average: 3.04, 1.87, 1.65
                                  CPU threads: 4
                                  *** Time and Time Zones ***
                                  Mon Mar 11 19:22:29 UTC 2024
                                  Mon Mar 11 20:22:29 CET 2024
                                  CET +0100
                                  Etc/UTC
                                  *** User and Groups ***
                                  root
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:
                                  *** MEMORY ***
                                  Mem:             16G        8.8G        1.8G        151M        6.6G        7.9G
                                  Swap:            12G        351M         11G
                                  Total:           28G        9.1G         13G
                                          15854 M total memory
                                           8359 M used memory
                                           9125 M active memory
                                           3649 M inactive memory
                                           1681 M free memory
                                             39 M buffer memory
                                           6246 M swap cache
                                          11563 M total swap
                                            334 M used swap
                                          11229 M free swap
                                  *** FILESYSTEM ***
                                  Filesystem             Type   Size  Used Avail Use% Mounted on
                                  /dev/mapper/cachedev_0 btrfs  7.0T  2.4T  4.7T  34% /
                                  tmpfs                  tmpfs   64M     0   64M   0% /dev
                                  tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
                                  shm                    tmpfs   64M     0   64M   0% /dev/shm
                                  /dev/mapper/cachedev_0 btrfs  7.0T  2.4T  4.7T  34% /opt/iobroker
                                  /dev/mapper/cachedev_0 btrfs  7.0T  2.4T  4.7T  34% /etc/hosts
                                  sudo: unable to resolve host iobrokerSchozach01: Name or service not known
                                  [Sat Mar  9 14:19:51 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
                                  [Sat Mar  9 14:19:51 2024] EXT4-fs (md0): mounted filesystem with ordered data m
                                  [Sat Mar  9 14:19:53 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
                                  [Sat Mar  9 14:19:53 2024] EXT4-fs (md0): mounted filesystem with ordered data m
                                  [Sat Mar  9 14:19:53 2024] EXT4-fs (loop0): couldn't mount as ext3 due to featur
                                  [Sat Mar  9 14:19:53 2024] EXT4-fs (loop0): mounted filesystem with ordered data
                                  [Sat Mar  9 14:19:57 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
                                  [Sat Mar  9 14:19:57 2024] EXT4-fs (md0): mounted filesystem with ordered data m
                                  [Sat Mar  9 14:19:58 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
                                  [Sat Mar  9 14:19:58 2024] EXT4-fs (md0): mounted filesystem with ordered data m
                                  [Sat Mar  9 14:20:25 2024] EXT4-fs (loop0): mounted filesystem with ordered data
                                  Show mounted filesystems \(real ones only\):
                                  TARGET             SOURCE
                                  IONS
                                  /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/7fc7ee
                                  nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,s
                                  606484219300d6f0f94a804c3a4ccf9de8fa57950133361b70e104e
                                  |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobrokerSchozach01]
                                  |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/b7031f18c8ab
                                  0577f801f8ba9fc9c72e03eb707055b3233e3162eacd3d52/resolv.conf
                                  |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/b7031f18c8ab
                                  0577f801f8ba9fc9c72e03eb707055b3233e3162eacd3d52/hostname
                                  `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/b7031f18c8ab
                                  0577f801f8ba9fc9c72e03eb707055b3233e3162eacd3d52/hosts
                                  /var:
                                  34M     /var/
                                  32M     /var/lib
                                  19M     /var/lib/apt/lists
                                  19M     /var/lib/apt
                                  13M     /var/lib/dpkg
                                  /opt/iobroker/backups:
                                  14G     /opt/iobroker/backups/
                                  0       /opt/iobroker/backups/redistmp
                                  /opt/iobroker/iobroker-data:
                                  16G     /opt/iobroker/iobroker-data/
                                  15G     /opt/iobroker/iobroker-data/history
                                  295M    /opt/iobroker/iobroker-data/files
                                  97M     /opt/iobroker/iobroker-data/backup-objects
                                  89M     /opt/iobroker/iobroker-data/files/echarts.admin
                                  130M    /opt/iobroker/iobroker-data/objects.jsonl
                                  24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7
                                  23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.
                                  22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.m
                                  USB-Devices by-id:
                                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always
                                  find: '/dev/serial/by-id/': No such file or directory
                                  *** NodeJS-Installation ***
                                  /usr/bin/npm            10.2.4
                                  /usr/bin/npx            10.2.4
                                  nodejs:
                                    Installed: 18.19.1-1nodesource1
                                    Candidate: 18.19.1-1nodesource1
                                    Version table:
                                   *** 18.19.1-1nodesource1 1001
                                         1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                          100 /var/lib/dpkg/status
                                       18.19.0+dfsg-6~deb12u1 500
                                          500 http://deb.debian.org/debian-security bookworm-security/main amd64 P
                                       18.19.0-1nodesource1 1001
                                       18.18.2-1nodesource1 1001
                                       18.18.1-1nodesource1 1001
                                       18.18.0-1nodesource1 1001
                                       18.17.1-1nodesource1 1001
                                       18.17.0-1nodesource1 1001
                                       18.16.1-1nodesource1 1001
                                       18.16.0-1nodesource1 1001
                                       18.15.0-1nodesource1 1001
                                       18.14.2-1nodesource1 1001
                                       18.14.1-1nodesource1 1001
                                       18.14.0-1nodesource1 1001
                                       18.13.0+dfsg1-1 500
                                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                       18.13.0-1nodesource1 1001
                                       18.12.0-1nodesource1 1001
                                       18.11.0-1nodesource1 1001
                                       18.10.0-1nodesource1 1001
                                       18.9.1-1nodesource1 1001
                                   18.9.0-1nodesource1 1001
                                       18.8.0-1nodesource1 1001
                                       18.7.0-1nodesource1 1001
                                       18.6.0-1nodesource1 1001
                                       18.5.0-1nodesource1 1001
                                       18.4.0-1nodesource1 1001
                                       18.3.0-1nodesource1 1001
                                       18.2.0-1nodesource1 1001
                                       18.1.0-1nodesource1 1001
                                       18.0.0-1nodesource1 1001
                                  No problems detected
                                  Errors in npm tree:
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  js-controller:  5.0.19
                                  admin:          6.13.16
                                  javascript:     7.8.0
                                  Adapters from github:   1
                                  Adapter State
                                  n as: admin
                                  + system.adapter.backitup.0               : backitup              : iobrokerScho
                                  + system.adapter.bydhvs.0                 : bydhvs                : iobrokerScho
                                  + system.adapter.daikin.1                 : daikin                : iobrokerScho
                                  + system.adapter.daikin.2                 : daikin                : iobrokerScho
                                  + system.adapter.daikin.3                 : daikin                : iobrokerScho
                                    system.adapter.daswetter.1              : daswetter             : iobrokerScho
                                    system.adapter.discovery.0              : discovery             : iobrokerScho
                                    system.adapter.echarts.0                : echarts               : iobrokerScho
                                  + system.adapter.email.0                  : email                 : iobrokerScho
                                    system.adapter.flot.0                   : flot                  : iobrokerScho
                                    system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobrokerScho
                                  + system.adapter.fronius.0                : fronius               : iobrokerScho
                                    system.adapter.gruenbeck.0              : gruenbeck             : iobrokerScho
                                  + system.adapter.history.0                : history               : iobrokerScho
                                  + system.adapter.hmip.0                   : hmip                  : iobrokerScho
                                    system.adapter.javascript.0             : javascript            : iobrokerScho
                                    system.adapter.javascript.1             : javascript            : iobrokerScho
                                  + system.adapter.modbus.0                 : modbus                : iobrokerScho
                                  + system.adapter.modbus.1                 : modbus                : iobrokerScho
                                  + system.adapter.modbus.2                 : modbus                : iobrokerScho
                                    system.adapter.modbus.3                 : modbus                : iobrokerScho
                                  + system.adapter.modbus.4                 : modbus                : iobrokerScho
                                    system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobrokerScho
                                    system.adapter.parser.0                 : parser                : iobrokerScho
                                    system.adapter.porsche.0                : porsche               : iobrokerScho
                                    system.adapter.pvforecast.0             : pvforecast            : iobrokerScho
                                  + system.adapter.sonoff.0                 : sonoff                : iobrokerScho
                                    system.adapter.statistics.0             : statistics            : iobrokerScho
                                    system.adapter.weatherunderground.0     : weatherunderground    : iobrokerScho
                                  iobrokerhawk
                                    system.adapter.wmswebcontrol.0          : wmswebcontrol         : iobrokerScho
                                  + instance is alive
                                  n as: admin
                                  iobrokerhawk
                                  ioBroker-Repositories
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "admin"        : 6.13.16  , installed 6.13.16
                                  Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                                  Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
                                  Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                                  Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                  Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                  Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                  Adapter    "email"        : 1.2.2    , installed 1.2.2
                                  Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                                  Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                                  Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
                                  Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                  Controller "js-controller": 5.0.19   , installed 5.0.19
                                  Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                                  Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                  Adapter    "parser"       : 2.1.0    , installed 2.1.0
                                  Adapter    "porsche"      : 0.0.3    , installed 0.2.0
                                  Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                                  Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                  Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                                  Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                  Adapter    "web"          : 6.2.3    , installed 6.2.3
                                  Adapter    "wmswebcontrol": 0.0.5    , installed 0.0.5
                                  Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                  Objects and States
                                  Objects:        16479
                                  States:         13775
                                  Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Reading package lists...
                                  Pending Updates: 1
                                  *** Listening Ports ***
                                  Proto Recv-Q Send-Q Local Address           Foreign Address         State
                                  tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN
                                  tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN
                                  tcp        0      0 192.168.178.5:49160     0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:9900            0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:9901            0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
                                  tcp        0      0 192.168.178.5:50001     0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:50002           0.0.0.0:*               LISTEN
                                  tcp        0      0 192.168.178.5:49170     0.0.0.0:*               LISTEN
                                  tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN
                                  tcp        0      0 127.0.0.1:33300         0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:725             0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN
                                  tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN
                                  tcp        0      0 127.0.0.1:18617         0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:6011            0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:6012            0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:6013            0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
                                  tcp        0      0 0.0.0.0:6014            0.0.0.0:*               LISTEN
                                  tcp6       0      0 :::3264                 :::*                    LISTEN
                                  tcp6       0      0 :::3265                 :::*                    LISTEN
                                  tcp6       0      0 :::6690                 :::*                    LISTEN
                                  tcp6       0      0 :::5000                 :::*                    LISTEN
                                  tcp6       0      0 :::5001                 :::*                    LISTEN
                                  tcp6       0      0 :::139                  :::*                    LISTEN
                                  tcp6       0      0 :::9900                 :::*                    LISTEN
                                  tcp6       0      0 :::9901                 :::*                    LISTEN
                                  tcp6       0      0 :::5357                 :::*                    LISTEN
                                  tcp6       0      0 :::1935                 :::*                    LISTEN
                                  tcp6       0      0 :::80                   :::*                    LISTEN
                                  tcp6       0      0 :::8081                 :::*                    LISTEN
                                  tcp6       0      0 :::5201                 :::*                    LISTEN
                                  tcp6       0      0 :::8082                 :::*                    LISTEN
                                  tcp6       0      0 :::725                  :::*                    LISTEN
                                  tcp6       0      0 :::443                  :::*                    LISTEN
                                  tcp6       0      0 :::3261                 :::*                    LISTEN
                                  tcp6       0      0 :::445                  :::*                    LISTEN
                                  tcp6       0      0 :::3263                 :::*                    LISTEN
                                  udp        0      0 0.0.0.0:35136           0.0.0.0:*
                                  udp        0      0 127.0.0.1:60185         0.0.0.0:*
                                  udp        0      0 0.0.0.0:19996           0.0.0.0:*
                                  udp        0      0 0.0.0.0:19997           0.0.0.0:*
                                  udp        0      0 0.0.0.0:19998           0.0.0.0:*
                                  udp        0      0 0.0.0.0:3702            0.0.0.0:*
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*
                                  udp        0      0 192.168.178.5:55900     0.0.0.0:*
                                  udp        0      0 192.168.178.5:55901     0.0.0.0:*
                                  udp        0      0 192.168.178.5:55902     0.0.0.0:*
                                  udp        0      0 127.0.0.1:47750         0.0.0.0:*
                                  udp        0      0 172.17.0.1:123          0.0.0.0:*
                                  udp        0      0 192.168.178.10:123      0.0.0.0:*
                                  udp        0      0 192.168.178.5:123       0.0.0.0:*
                                  udp        0      0 127.0.0.1:123           0.0.0.0:*
                                  udp        0      0 0.0.0.0:123             0.0.0.0:*
                                  udp        0      0 192.168.178.255:137     0.0.0.0:*
                                  udp        0      0 192.168.178.5:137       0.0.0.0:*
                                  udp        0      0 192.168.178.10:137      0.0.0.0:*
                                  udp        0      0 0.0.0.0:137             0.0.0.0:*
                                  udp        0      0 192.168.178.255:138     0.0.0.0:*
                                  udp        0      0 192.168.178.5:138       0.0.0.0:*
                                  udp        0      0 192.168.178.10:138      0.0.0.0:*
                                  udp        0      0 0.0.0.0:138             0.0.0.0:*
                                  udp        0      0 127.0.0.1:161           0.0.0.0:*
                                  udp        0      0 127.0.0.1:58098         0.0.0.0:*
                                  udp        0      0 0.0.0.0:59087           0.0.0.0:*
                                  udp        0      0 0.0.0.0:9997            0.0.0.0:*
                                  udp        0      0 0.0.0.0:9998            0.0.0.0:*
                                  udp        0      0 0.0.0.0:9999            0.0.0.0:*
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*
                                  udp6       0      0 :::3702                 :::*
                                  udp6       0      0 :::5353                 :::*
                                  udp6       0      0 :::38969                :::*
                                  udp6       0      0 2003:c9:6f14:6200:2:123 :::*
                                  udp6       0      0 fe80::6006:26ff:fea:123 :::*
                                  udp6       0      0 fe80::48d5:c1ff:fec:123 :::*
                                  udp6       0      0 fe80::10c3:75ff:fe5:123 :::*
                                  udp6       0      0 fe80::42:97ff:fe5f::123 :::*
                                  udp6       0      0 fe80::211:32ff:fea6:123 :::*
                                  udp6       0      0 ::1:123                 :::*
                                  udp6       0      0 :::123                  :::*
                                  2024-03-11 20:23:25.222  - silly: javascript.0 (1530) writeFile(filename: "node_
                                  2024-03-11 20:23:25.222  - silly: javascript.0 (1530)   creating new file with v
                                  2024-03-11 20:23:25.240  - silly: javascript.0 (1530) writeFile(filename: "node_
                                  true
                                  2024-03-11 20:23:25.241  - silly: javascript.0 (1530)   creating new file with v
                                  2024-03-11 20:23:25.241  - silly: javascript.0 (1530) writeFile(filename: "node_
                                  e
                                  2024-03-11 20:23:25.245  - debug: javascript.0 (1530) Loaded TypeScript definiti
                                  types/request/index.d.ts"]
                                  2024-03-11 20:23:25.245  - silly: javascript.0 (1530) writeFile(filename: "node_
                                  2024-03-11 20:23:25.245  - silly: javascript.0 (1530)   creating new file with v
                                  2024-03-11 20:23:25.246  - silly: javascript.0 (1530) writeFile(filename: "node_
                                  2024-03-11 20:23:25.246  - silly: javascript.0 (1530)   creating new file with v
                                  2024-03-11 20:23:25.247  - silly: javascript.0 (1530) writeFile(filename: "node_
                                  2024-03-11 20:23:25.247  - silly: javascript.0 (1530)   creating new file with v
                                  2024-03-11 20:23:25.301  - silly: javascript.0 (1530) redis psubscribe cfg.o.*
                                  2024-03-11 20:23:25.306  - silly: javascript.0 (1530) States system redis pmessa
                                  :{"val":"silly","ack":true,"ts":1710185005251,"q":0,"from":"system.adapter.javas
                                  2024-03-11 20:23:25.410  - info: javascript.0 (1530) requesting all states
                                  2024-03-11 20:23:25.411  - info: javascript.0 (1530) requesting all objects
                                  2024-03-11 20:23:49.823  - silly: javascript.0 (1530) Objects user redis pmessag
                                  mmon":{"name":"Plugin States"},"native":{},"_id":"system.host.iobrokerSchozach01
                                  em.user.admin","ownerGroup":"system.group.administrator"}}
                                  2024-03-11 20:23:49.825  - silly: javascript.0 (1530) Objects user redis pmessag
                                  te","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":tru
                                  sentry.enabled","acl":{"object":1636,"state":1636,"file":1632,"owner":"system.us
                                  • H Hawkiobroker 0
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    Docker          : v9.1.1
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    CPU threads: 4
                                    CET +0100
                                    Etc/UTC
                                    root
                                    X-Server:       false
                                    Desktop:
                                    Terminal:
                                    *** MEMORY ***
                                    Swap:            12G        351M         11G
                                    Total:           28G        9.1G         13G
                                             8359 M used memory
                                             1681 M free memory
                                               39 M buffer memory
                                             6246 M swap cache
                                            11563 M total swap
                                              334 M used swap
                                            11229 M free swap
                                    *** FILESYSTEM ***
                                    TARGET             SOURCE
                                    IONS
                                    /var:
                                    34M     /var/
                                    32M     /var/lib
                                    19M     /var/lib/apt
                                    13M     /var/lib/dpkg
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.4
                                    /usr/bin/npx            10.2.4
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.13.16
                                    javascript:     7.8.0
                                    Adapter State
                                    n as: admin
                                    iobrokerhawk
                                    + instance is alive
                                    n as: admin
                                    iobrokerhawk
                                    Objects and States
                                    Objects:        16479
                                    States:         13775
                                    Pending Updates: 1
                                    true
                                    e
                                    Hawkiobroker 0
                                    @hawkiobroker-0 und hier der iobroker log Auszug von javascript nach Aktivierung.
                                    240311 iobroker javascript log.txt
                                    Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                                    • H Hawkiobroker 0
                                      @hawkiobroker-0
                                      2024-03-11 20:41:05.745	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                      Da dürfte ein Skript schief sein.
                                      • H Hawkiobroker 0
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        @hawkiobroker-0
                                        die ganzen SILLY musste mal weg machen, das macht Dein System platt.
                                        Stell das bitte auf mindestens INFO um ;)
                                          @hawkiobroker-0
                                          Hawkiobroker 0
                                          @thomas-braun Danke! Warum habe ich Probleme, wenn ich alle Skripte deaktiviert habe?
