  3. Einsteigerfragen
  4. Adapter rot umrandet?
24 Beiträge 6 Kommentatoren 1.4k Aufrufe 6 Beobachtet
    @sailor_2011 sagte in Adapter rot umrandet?:
    Adapter "zigbee" : 1.10.1 , installed 1.8.23 [Updatable
    zigbee.0
    2024-02-26 20:02:52.122 info Installed Version: iobroker.zigbee@1.10.1
    verstehe ich irgendwie nicht so ganz
    sailor_2011
    @crunchip
    zigbee.0
    2024-02-26 20:26:42.021 error Error herdsman start
    zigbee.0
    2024-02-26 20:26:42.020 error Failed to start Zigbee
    zigbee.0
    2024-02-26 20:26:42.019 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2024-02-26 20:26:41.818 info Installed Version: iobroker.zigbee@1.10.2
    zigbee.0
    2024-02-26 20:26:41.805 info Starting Zigbee npm ...
    zigbee.0
    2024-02-26 20:26:41.804 info Try to reconnect. 1 attempts left
    zigbee.0
    2024-02-26 20:26:31.800 error Error herdsman start
    zigbee.0
    2024-02-26 20:26:31.800 error Failed to start Zigbee
    zigbee.0
    2024-02-26 20:26:31.799 error Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2024-02-26 20:26:31.686 error Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2024-02-26 20:26:31.686 error If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2024-02-26 20:26:31.685 error Please update configuration to prevent further issues.
    zigbee.0
    2024-02-26 20:26:31.684 error - Channel List: configured=11, adapter=11
    zigbee.0
    2024-02-26 20:26:31.684 error - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    2024-02-26 20:26:31.683 error - Extended PAN ID: configured=00124b002c3ae63d, adapter=00124b002c3ae63d
    zigbee.0
    2024-02-26 20:26:31.682 error - PAN ID: configured=1419, adapter=1417
    zigbee.0
    2024-02-26 20:26:31.681 error Configuration is not consistent with adapter state/backup!
    If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json. - das hab ich eben gemacht...
    Und jetzt... bleibt das Lämpchen auf G R Ü N - meine Güte, was für eine Wissenschaft...
    Vielen Dank nochmals Euch allen :-)
    • S sailor_2011
      @crunchip
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      Die muss übereinstimmen. Also im Adapter entsprechend ändern.
      S 2 Antworten Letzte Antwort
        sailor_2011
        Hallo Gemeinde.
        Ich wollte mich noch mal (abschließend) melden.
        Hatte noch mal einen neuen Post bez. des Zigbee-Adapters, Adapter war "Grün", trotzdem ließ sich nichts einbinden, auch keine Meldungen im Protololl.
        Viel (mit eurer Hilfe) ausprobiert, irgendwie führte nichts zum Erfolg.
        Nun habe ich einen letzten Schritt/Versuch gemacht: Sonoff-Stick zurück gesandt, Conbee bestellt - und nun läuft es - da gab es überhaupt keine Huddelei beim Einbinden, keine Fehlermeldungen, nichts dergleichen.
          sailor_2011
          Auch die Signalwerte sind bei dem Conbee höher. Bei dem Sonoff-Stick kam es nicht höher, als ca. 125
