  3. Off Topic
  4. Fehler bei ..............&& sudo apt upgrade [gelöst]
    6.0k
7 Beiträge 2 Kommentatoren 413 Aufrufe 2 Beobachtet
  • DuffyD Offline
    DuffyD Offline
    Duffy
    schrieb am zuletzt editiert von Duffy
    Schönen guten Morgen,
    mein Testpi hat gestern einen Fehler bei:
    sudo apt update && sudo apt full-upgrade
    ausgegeben.
    testpi@Testpi:~ $ sudo apt update && sudo apt full-upgrade
    Get:2 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
    Get:3 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB]
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Get:5 https://apt.grafana.com stable InRelease [5,983 B]
    Get:6 http://archive.raspberrypi.org/debian bookworm InRelease [23.6 kB]
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Get:8 http://security.debian.org/debian-security bookworm-security/main Sources [79.6 kB]
    Get:9 http://security.debian.org/debian-security bookworm-security/main armhf Packages [132 kB]
    Get:10 http://security.debian.org/debian-security bookworm-security/main arm64 Packages [134 kB]
    Get:11 https://apt.grafana.com stable/main arm64 Packages [157 kB]
    Get:12 https://apt.grafana.com stable/main armhf Packages [123 kB]
    Get:13 http://archive.raspberrypi.org/debian bookworm/main armhf Packages [362 kB]
    Get:14 http://archive.raspberrypi.org/debian bookworm/main arm64 Packages [353 kB]
    Fetched 1,470 kB in 2s (752 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    All packages are up to date.
    Calculating upgrade... Done
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    1 not fully installed or removed.
    After this operation, 0 B of additional disk space will be used.
    Do you want to continue? [Y/n]
    Setting up raspi-firmware (1:1.20231024+ds-1+rpt5) ...
    stat: cannot read file system information for '/boot/firmware': No such file or directory
    Error: missing /boot/firmware, did you forget to mount it?
    dpkg: error processing package raspi-firmware (--configure):
     installed raspi-firmware package post-installation script subprocess returned error exit status 1
    Processing triggers for initramfs-tools (0.142) ...
    Errors were encountered while processing:
     raspi-firmware
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    testpi@Testpi:~ $
    Ich muss bestimmt nicht erwähnen das ich wieder mal auf dem Schlauch stehe, ist zum Glück nur der Testpi :-)
    Bekommt man den Fehler wieder los ohne Neuinstallation?
    VG Duffy
    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
    Node.js: v22.23.2
    NPM: 10.9.4
    js-controller 7.1.2
    Linux: Trixie
    • DuffyD Duffy
      ausgegeben.
       raspi-firmware
      testpi@Testpi:~ $
      VG Duffy
      @duffy
      Kann es sein, dass du das System nicht neuaufgesetzt hast sondern von Debian 11 'Bullseye' kommend ein Dist-Upgrade gemacht hast?
      DuffyD 1 Antwort Letzte Antwort
        @duffy
        DuffyD Offline
        DuffyD Offline
        Duffy
        Puhh, ich glaube nicht. Ich glaube es neu installiert zu haben. Ich nehme den Testpi nur sehr wenig und kann es nicht zu 100% sagen.
        Ich meine aber auch zum testen direkt Bookworm installiert zu haben.
        Wenn sich das nicht lösen lässt würde ich es halt noch mal neu installieren.
        VG Duffy
        Node.js: v22.23.2
        NPM: 10.9.4
        js-controller 7.1.2
        Linux: Trixie
        • DuffyD Duffy
          VG Duffy
          @duffy
          Gib mal die Langfassung von
          iob diag
          bekannt. Da kann man das sehen.
            @duffy
            iob diag
            DuffyD Offline
            DuffyD Offline
            Duffy
            Sehr gerne.
            Skript v.2023-10-10
            *** BASE SYSTEM ***
             Static hostname: Testpi
                   Icon name: computer
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             11:12:38 up 1 day, 11 min,  2 users,  load average: 0.21, 0.15, 0.14
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Fri 2024-02-09 11:12:38 CET
                       Universal time: Fri 2024-02-09 10:12:38 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            testpi
            /home/testpi
            testpi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            4.0G        1.2G        773M        1.2M        2.1G        2.7G
            Swap:           104M          0B        104M
            Total:          4.1G        1.2G        878M
                     3793 M total memory
                     1172 M used memory
                     1445 M active memory
                     1422 M inactive memory
                      737 M free memory
                      111 M buffer memory
                     1848 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            lifetime oom required: 0 Mbytes
            total time in oom handler: 0 ms
            max time spent in oom handler: 0 ms
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       30G  7.2G   21G  26% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.2M  758M   1% /run
            tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
            /dev/sda1      vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
            [Thu Feb  8 11:01:16 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:B3:1A:9B vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=f4ef48f9-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Thu Feb  8 11:01:19 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
            [Thu Feb  8 11:01:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [Thu Feb  8 11:01:21 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
            Show mounted filesystems \(real ones only\):
            TARGET  SOURCE    FSTYPE OPTIONS
            /       /dev/sda2 ext4   rw,noatime
            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            1.9G    /var/
            1006M   /var/cache
            1000M   /var/cache/apt
            887M    /var/cache/apt/archives
            529M    /var/log
            Archived and active journals take up 524.1M in the file system.
            /opt/iobroker/backups:
            501M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            658M    /opt/iobroker/iobroker-data/
            554M    /opt/iobroker/iobroker-data/files
            138M    /opt/iobroker/iobroker-data/files/vis-2
            89M     /opt/iobroker/iobroker-data/files/echarts.admin
            78M     /opt/iobroker/iobroker-data/files/vis-2/static
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            28M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
            23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
            USB-Devices by-id:
            USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
            find: '/dev/serial/by-id/': No such file or directory
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
             *** 18.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                    100 /var/lib/dpkg/status
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.13.16
            javascript:     7.1.6
            Adapters from github:   0
            Adapter State
            + system.adapter.admin.0                  : admin                 : Testpi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : Testpi                                   -  enabled
              system.adapter.device-reminder.0        : device-reminder       : Testpi                                   - disabled
            + system.adapter.discovery.0              : discovery             : Testpi                                   -  enabled
            + system.adapter.influxdb.0               : influxdb              : Testpi                                   -  enabled, port: 8086
            + system.adapter.influxdb.1               : influxdb              : Testpi                                   -  enabled, port: 8086
              system.adapter.iot.0                    : iot                   : Testpi                                   - disabled
              system.adapter.javascript.0             : javascript            : Testpi                                   - disabled
            + system.adapter.rpi2.0                   : rpi2                  : Testpi                                   -  enabled
              system.adapter.sonoff.0                 : sonoff                : Testpi                                   - disabled, port: 1883, bind: 0.0.0.0
              system.adapter.vis-2.0                  : vis-2                 : Testpi                                   - disabled
              system.adapter.vis.0                    : vis                   : Testpi                                   - disabled
              system.adapter.web.0                    : web                   : Testpi                                   - disabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.zigbee.0                 : zigbee                : Testpi                                   - disabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.13.16  , installed 6.13.16
            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "discovery"    : 4.2.0    , installed 4.2.0
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.17   , installed 5.0.17
            Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
            Adapter    "socketio"     : 6.6.0    , installed 6.6.0
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "vis"          : 1.5.4    , installed 1.5.4
            Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
            Adapter    "web"          : 6.2.3    , installed 6.2.3
            Adapter    "ws"           : 2.5.10   , installed 2.5.10
            Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
            Objects and States
            Objects:        729
            States:         435
            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
            Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
            Hit:5 https://repos.influxdata.com/debian stable InRelease
            Hit:6 https://apt.grafana.com stable InRelease
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12229      629/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50512      1828/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       49760      1828/iobroker.js-co
            tcp6       0      0 :::22                   :::*                    LISTEN      0          12231      629/sshd: /usr/sbin
            tcp6       0      0 :::3000                 :::*                    LISTEN      110        15464      806/grafana
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        1978       746/influxd
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       57821      4045/io.admin.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1790       474/avahi-daemon: r
            udp        0      0 0.0.0.0:34813           0.0.0.0:*                           108        1792       474/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1898       740/dhcpcd
            udp6       0      0 :::33934                :::*                                108        1793       474/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        1791       474/avahi-daemon: r
            2024-02-09 03:57:06.846  - info: host.Testpi stopInstance system.adapter.backitup.0 (force=false, process=true)
            2024-02-09 03:57:06.866  - info: backitup.0 (4742) Got terminate signal TERMINATE_YOURSELF
            2024-02-09 03:57:06.878  - info: backitup.0 (4742) cleaned everything up...
            2024-02-09 03:57:06.879  - info: backitup.0 (4742) terminating
            2024-02-09 03:57:06.880  - info: backitup.0 (4742) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-02-09 03:57:06.908  - info: host.Testpi stopInstance system.adapter.backitup.0 send kill signal
            2024-02-09 03:57:07.382  - info: backitup.0 (4742) terminating
            2024-02-09 03:57:07.442  - info: host.Testpi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-02-09 03:57:09.971  - info: host.Testpi instance system.adapter.backitup.0 started with pid 33498
            2024-02-09 03:57:12.070  - info: backitup.0 (33498) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
            2024-02-09 03:57:12.141  - info: backitup.0 (33498) [iobroker] backup will be activated at 03:55 every 1 day(s)
            Node.js: v22.23.2
            NPM: 10.9.4
            js-controller 7.1.2
            Linux: Trixie
            • Thomas BraunT Online
              @duffy
              Das ist das alte Boot-Layout.
              Die Boot-Partition wird auf /boot eingehängt, aktuell wird aber /boot/firmware erwartet. Das führt dann auch zu der Meldung beim apt upgrade.
              Und diese Änderungen sind auch der Grund warum diesmal bei Raspberry OS die Empfehlung ganz klar eine Neuinstallation von 'Bookworm' war.
                @duffy
                DuffyD Offline
                DuffyD Offline
                Duffy
                Ok danke für deine Expertiese. Dann werde ich den Testpi neu installieren.
                Danke dir vielmals.
                Das Aktivsystem habe ich aber sicher neu installiert :-)
                Gruß Duffy
                Node.js: v22.23.2
                NPM: 10.9.4
                js-controller 7.1.2
                Linux: Trixie
