  3. Einsteigerfragen
  4. Nodejs Problem
    1.6k
    2.3k
Nodejs Problem
5 Beiträge 3 Kommentatoren 682 Aufrufe 3 Beobachtet
    andi_grafa
    schrieb am zuletzt editiert von andi_grafa
    meine bisher funktionierende Javascript-Datei startet nicht mehr mit der Fehlermeldung "instanz ist deaktiviert. Ein iob-diag zeigte aber ein Problem mit nodejs.
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: RaspiEnergie
       Pretty hostname: Raspi_Energie
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     22:41:43 up 15 min,  1 user,  load average: 0.81, 0.62, 0.49
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-01-29 22:41:44 CET
               Universal time: Mon 2024-01-29 21:41:44 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    ip
    /home/ip
    ip adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.3G        1.1G        1.0M        1.4G        2.4G
    Swap:             0B          0B          0B
    Total:          3.8G        1.3G        1.1G
             3793 M total memory
             1349 M used memory
             2408 M active memory
              187 M inactive memory
             1065 M free memory
               48 M buffer memory
             1329 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
      UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
    * dphys-swapfile.service loaded failed failed dphys-swapfile - set up, mount/unmount, and delete a swap file
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      118G   40G   73G  36% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
    [Mon Jan 29 22:26:38 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:55:53:E5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=1b96fbb9-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Jan 29 22:26:40 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jan 29 22:26:40 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Jan 29 22:26:43 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    7.8G    /var/
    6.2G    /var/lib
    6.0G    /var/lib/influxdb/engine
    5.9G    /var/lib/influxdb/engine/data/ca870feeb67efca8/autogen
    Archived and active journals take up 1.1G in the file system.
    /opt/iobroker/backups:
    27G     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    223M    /opt/iobroker/iobroker-data/
    149M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
    8.9M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.5
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : RaspiEnergie                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : RaspiEnergie                             -  enabled
    + system.adapter.ble.0                    : ble                   : RaspiEnergie                             -  enabled
      system.adapter.devices.0                : devices               : RaspiEnergie                             -  enabled
    + system.adapter.discovery.0              : discovery             : RaspiEnergie                             -  enabled
    + system.adapter.email.0                  : email                 : RaspiEnergie                             -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : RaspiEnergie                             -  enabled
    + system.adapter.influxdb.0               : influxdb              : RaspiEnergie                             -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : RaspiEnergie                             -  enabled
      system.adapter.javascript.0             : javascript            : RaspiEnergie                             - disabled
    + system.adapter.modbus.0                 : modbus                : RaspiEnergie                             -  enabled
    + system.adapter.modbus.1                 : modbus                : RaspiEnergie                             -  enabled
    + system.adapter.modbus.2                 : modbus                : RaspiEnergie                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : RaspiEnergie                             -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : RaspiEnergie                             -  enabled
    + system.adapter.opendtu.0                : opendtu               : RaspiEnergie                             -  enabled
    + system.adapter.ping.0                   : ping                  : RaspiEnergie                             -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : RaspiEnergie                             -  enabled
    + system.adapter.shelly.0                 : shelly                : RaspiEnergie                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.socketio.0               : socketio              : RaspiEnergie                             -  enabled, port: 8084, bind: 127.0.0.1, run as: admin
      system.adapter.sonoff.0                 : sonoff                : RaspiEnergie                             - disabled, port: 1883, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.5  [Updatable]
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "modbus"       : 6.0.1    , installed 6.0.1
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Objects and States
    Objects:        1416
    States:         1150
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://giteduberger.fr rpimonitor/ InRelease
    Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://repos.influxdata.com/debian stable InRelease
    Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
    Update rpimonitor Packages Status
    Fetched 4586 B in 2s (2049 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:60025           0.0.0.0:*               LISTEN      0          14562      623/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          14705      758/perl
    tcp        0      0 127.0.0.1:8084          0.0.0.0:*               LISTEN      1001       18366      1701/io.socketio.0
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15501      618/vncserver-x11-c
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       14992      1037/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       14991      1037/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       16633      994/io.shelly.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14595      562/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14824      874/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14831      874/iobroker.js-con
    tcp6       0      0 :::3000                 :::*                    LISTEN      116        15743      873/grafana
    tcp6       0      0 :::60025                :::*                    LISTEN      0          14564      623/sshd: /usr/sbin
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          15500      618/vncserver-x11-c
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14594      562/cupsd
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        17424      578/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17497      922/io.admin.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13169      695/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15398      431/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      505/dhcpcd
    udp        0      0 0.0.0.0:41066           0.0.0.0:*                           108        15400      431/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        15399      431/avahi-daemon: r
    udp6       0      0 :::38439                :::*                                108        15401      431/avahi-daemon: r
    2024-01-29 22:28:36.891  - info: pvforecast.0 (1437) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
    2024-01-29 22:28:37.620  - info: fritzdect.0 (1465) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.17.1, js-controller: 5.0.17
    2024-01-29 22:28:37.675  - info: fritzdect.0 (1465) fritzdect entered ready
    2024-01-29 22:28:37.734  - info: fritzdect.0 (1465) fritzdect uses USER: admin
    2024-01-29 22:28:37.868  - error: fritzdect.0 (1465) --------------- error calling the fritzbox -----------
    2024-01-29 22:28:37.871  - error: fritzdect.0 (1465) API msg   => error calling executeCommand
    2024-01-29 22:28:37.872  - error: fritzdect.0 (1465) API funct => login_SID
    2024-01-29 22:28:37.874  - error: fritzdect.0 (1465) no response part in returned error message
    2024-01-29 22:28:37.876  - error: fritzdect.0 (1465) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"192.168.x.x"}}}
    2024-01-29 22:28:37.879  - error: fritzdect.0 (1465) login not possible, check user and permissions
    2024-01-29 22:28:38.155  - info: host.RaspiEnergie instance system.adapter.socketio.0 started with pid 1701
    2024-01-29 22:28:41.169  - info: socketio.0 (1701) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.17.1, js-controller: 5.0.17
    2024-01-29 22:28:41.249  - warn: socketio.0 (1701) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    2024-01-29 22:28:41.336  - info: socketio.0 (1701) socket.io server listening on port 8084
    2024-01-29 22:28:41.759  - info: shelly.0 (994) [MQTT] Device with client id "shellyem-485519D9E523" connected!
    2024-01-29 22:28:43.918  - info: opendtu.0 (1256) Connect to OpenDTU over websocket connection.
    2024-01-29 22:28:52.968  - info: admin.0 (922) <== Disconnect system.user.admin from ::ffff:192.168.198.201 javascript
    2024-01-29 22:28:52.975  - info: admin.0 (922) <== Disconnect system.user.admin from ::ffff:192.168.198.201 admin
    2024-01-29 22:28:53.176  - info: admin.0 (922) ==> Connected system.user.admin from ::ffff:192.168.198.201
    2024-01-29 22:28:53.913  - info: admin.0 (922) <== Disconnect system.user.admin from ::ffff:192.168.198.201 javascript
    2024-01-29 22:28:54.733  - info: admin.0 (922) ==> Connected system.user.admin from ::ffff:192.168.198.201
    2024-01-29 22:29:02.899  - info: admin.0 (922) ==> Connected system.user.admin from ::ffff:192.168.198.201
    2024-01-29 22:38:25.227  - info: admin.0 (922) <== Disconnect system.user.admin from ::ffff:192.168.198.201 javascript
    2024-01-29 22:39:27.194  - info: admin.0 (922) ==> Connected system.user.admin from ::ffff:192.168.198.201
    2024-01-29 22:41:08.501  - info: admin.0 (922) <== Disconnect system.user.admin from ::ffff:192.168.198.201 javascript
    iob diag has finished.
    Press any key for a summary
    Da ich mehrfach gelesen habe, dass man keinesfalls manuell etwas installieren soll, ist
    sudo apt install nodejs=WUNSCHVERSION
    der richtige Weg?
    Ich bitte um eure Unterstützung. (den Javascript-Adapter habe ich um eine Version zurückgesetzt, um zu sehen, ob das Instanzproblem verschwindet, leider ohne Erfolg)
    Andreas
    • A andi_grafa
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      ip
      /home/ip
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:             0B          0B          0B
               3793 M total memory
               1349 M used memory
               1065 M free memory
                 48 M buffer memory
               1329 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      7.8G    /var/
      6.2G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.5
      Adapter State
      + instance is alive
      Objects and States
      Objects:        1416
      States:         1150
      Pending Updates: 0
      der richtige Weg?
      Andreas
      @andi_grafa
      Es gibt mittlerweile ein Kommando dafür:
      iob nodejs-update
      Wenn das nicht direkt funktioniert den
      iob fix
      zuvor ausführen.
      • A andi_grafa
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        ip
        /home/ip
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:             0B          0B          0B
                 3793 M total memory
                 1349 M used memory
                 1065 M free memory
                   48 M buffer memory
                 1329 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        7.8G    /var/
        6.2G    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.5
        Adapter State
        + instance is alive
        Objects and States
        Objects:        1416
        States:         1150
        Pending Updates: 0
        der richtige Weg?
        Andreas
        @andi_grafa
        Dein username ip ist ungünstig, es gibt nämlich auch einen Befehl 'ip'
        Dann würde ich d´swap wieder einschalten. Ein wenig swap ist erforderlich.
        warum hältst du da das Wissen der Menschheit vor?
        JLegJ 1 Antwort Letzte Antwort
          @andi_grafa
          JLegJ Offline
          JLegJ Offline
          JLeg
          @thomas-braun sagte in Nodejs Problem:
          warum sollte das ungünstig sein?
          Es gibt ja auch einen "Befehl" nginx, und einen User nginx, einen Befehl sshd, und einen User sshd, usw usf...
          • JLegJ JLeg
            @jleg
            Ja. Aber das sind auch systemuser.
            ip@hostname:~ $ sudo -u ip ip a
            ist halt 'ungünstig' und schwerer zu lesen.
            Gleiches gilt für ähnliches wie
            iobroker@iobroker:~ $ sudo -u iobroker iobroker commando
            Wenn du dann auf der Konsole nicht sattelfest bist können da viel leichter ungewollte Befehle draus werden.
            83.2k
