  4. Test Adapter vbus-gw v0.3.x Latest
    6.8k
resol vbus serial-to-tcp
6 Beiträge 1 Kommentatoren 781 Aufrufe 1 Beobachtet
    pdbjjens
    schrieb am zuletzt editiert von pdbjjens
    Aktuelle Test Version 0.3.2
    Veröffentlichungsdatum 04.03.2026
    Github Link https://github.com/pdbjjens/ioBroker.vbus-gw.git
    npm Link https://www.npmjs.com/package/iobroker.vbus-gw
    vbus-gw adapter for ioBroker
    Allows TCP access to serial port based VBus devices
    This ioBroker Adapter is based on work by Daniel Wippermann.
    https://github.com/danielwippermann/resol-vbus/tree/master/examples/serial-to-tcp
    Overview
    There are two types of VBus hardware adapters:
    TCP based: DL2, DL3, KM2, VBus/LAN
    Serial port based: VBus/USB, USB port of DeltaSol SLT and other controllers
    This ioBroker adapter connects to one or more serial port based hardware adapters and exposes them over TCP. This allows:
    • transmitting VBus data over longer distances than USB or serial ports would normally permit
    • accessing serial port based adapters from applications that only support TCP based ones
    Configuration
    See README on GitHub
    Changelog
    P 1 Antwort Letzte Antwort
    • P pdbjjens
      Overview
      Configuration
      Changelog
      pdbjjens
      v0.0.7 was released on 2024-02-24.
      Changes:
      (pdbjjens) Fix: VBus write fixed
      (pdbjjens) Fix: Password logging removed
      Note: This adapter version has been released to ioBroker latest repository and can be installed from there from now on.
      I hope you may find this adapter useful and I am looking forward to your testing feedback.
      • P pdbjjens
        Changes:
        pdbjjens
        The 2024H2 maintenance release v0.1.0 was released on 2024-08-13.
        Changelog:
        (pdbjjens) Change: node>=18, js-contoller>=5 and admin>=6 required
        (pdbjjens) New: Updated dependencies
        (pdbjjens) New: Ensure that vbus-gw is started before myvbus or resol
        • P pdbjjens
          Changelog:
          pdbjjens
          0.2.0 (2025-01-29) - 2025H1 maintenance release
          (pdbjjens) Change: Migration to ESLint 9
          (pdbjjens) New: Accept serial port paths /dev/serial/by-id/usb-xxxxxxxxxxxxxxxxxxx or /dev/serial/by-path/platform-xxxxxxxxxxxxxxxxxxx
          (pdbjjens) Change: Responsive Design optimizations
          • P pdbjjens
            pdbjjens
            @pdbjjens
            0.3.0 (2025-08-29) - 2025H1 maintenance release
            (pdbjjens) Change: node>=20, js-controller>=7.0.7 and admin>=7.6.17 required
            (pdbjjens) Change: Cleanup devDependencies
            • P pdbjjens
              @pdbjjens
              pdbjjens
              0.3.2 (2026-03-04) - 2026H1 maintenance release
              (pdbjjens) Changed: node>=20, js-controller>=7.0.7 and admin>=7.7.22 required
              (pdbjjens) Fixed: update release-script (#149)
