  4. Warnmeldungen beim updaten von Adaptern
    6.1k
20 Beiträge 2 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • 0 Offline
    0 Offline
    0__Nik__0
    Hardwaresystem: NUC
    Arbeitsspeicher: 4GB
    Festplattenart: HDD
    Betriebssystem: Debian 12
    Node-Version: v18.19.0
    Nodejs-Version: v18.19.0
    NPM-Version: 10.2.3
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    ich hab mein System upgedatet (mit der Anleitung hier aus dem Forum) von Debian 9 auf Debian 12.
    Das ist zwar ohne Fehler durchgelaufen aber jetzt hab ich bei dem Aktualisieren von Adaptern Warnmeldungen.
    $ iobroker upgrade yahka@1.0.3 --debug
    Update yahka from @0.13.1 to @1.0.3
    NPM version: 10.2.3
    Installing iobroker.yahka@1.0.3... (System call)
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
    npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
    npm WARN deprecated domexception@4.0.0: Use your platform's native DOMException instead
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    added 6 packages, removed 850 packages, and changed 1193 packages in 5m
    118 packages are looking for funding run `npm fund` for details
    Cannot install "pam-devel": E: Paket pam-devel kann nicht gefunden werden.
    Installed the following apt-get packages: pam-develThese apt-get packages were already installed: libavahi-compat-libdnssd-dev
    Update "system.adapter.yahka.0"
    upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
    Process exited with code 0
    Kann ich das Fixen oder ist es einfacher das System neu zu installieren?
    0 Thomas BraunT 2 Antworten Letzte Antwort
    • 0 0__Nik__0
      Hardwaresystem: NUC
      Festplattenart: HDD
      NPM-Version: 10.2.3
      Image genutzt: Nein
      NPM version: 10.2.3
      0 Offline
      0 Offline
      0__Nik__0
      schrieb am zuletzt editiert von 0__Nik__0
      Seitdem kommt es mir auch so vor als ob das ganze System sehr langsam geworden ist.
      • Thomas BraunT Online
        @0__nik__0 sagte in Warnmeldungen beim updaten von Adaptern:
        Das Paket heißt bei Debian auch nicht pam-devel sondern libpam0g-dev:
        sudo apt update
        sudo apt install libpam0g-dev
        0 2 Antworten Letzte Antwort
        • 0 0__Nik__0
          Hardwaresystem: NUC
          Festplattenart: HDD
          NPM-Version: 10.2.3
          Image genutzt: Nein
          NPM version: 10.2.3
          Welche Anleitung? Solch große Sprünge sind mit Vorsicht zu genießen.
          Du hast auch die Version 10 und 11 mitgenommen?
            0 Offline
            0 Offline
            0__Nik__0
            @thomas-braun Ja
            • 0 0__Nik__0
              @thomas-braun Ja
              @0__nik__0
              libpam0g-dev installiert?
              apt policy libpam0g-dev
              iob diag
              sagt?
              0 4 Antworten Letzte Antwort
                0 Offline
                0 Offline
                0__Nik__0
                Da hatte ich aber eine andere Anleitung. Erst von 11 auf 12 hab ich deine Anleitung verwendet.
                  @0__nik__0
                  iob diag
                  sagt?
                  0 Offline
                  0 Offline
                  0__Nik__0
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                   Static hostname: iobroker
                         Icon name: computer-vm
                           Chassis: vm 🖴
                    Virtualization: kvm
                            Kernel: Linux 6.1.0-17-amd64
                      Architecture: x86-64
                   Hardware Vendor: QEMU
                    Hardware Model: Standard PC _i440FX + PIIX, 1996_
                  Firmware Version: rel-1.11.1-0-g0551a4be2c-prebuilt.qemu-project.org
                  model name      : Common KVM processor
                  Docker          : false
                  Virtualization  : kvm
                  Kernel          : x86_64
                  Userland        : amd64
                  Systemuptime and Load:
                   00:12:51 up 19 days,  5:06,  2 users,  load average: 0.33, 0.42, 0.52
                  CPU threads: 8
                  *** Time and Time Zones ***
                                 Local time: Tue 2024-01-23 00:12:52 CET
                             Universal time: Mon 2024-01-22 23:12:52 UTC
                                   RTC time: Mon 2024-01-22 23:12:52
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  iobroker
                  /home/iobroker
                  iobroker tty dialout cdrom floppy audio dip video plugdev netdev
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.1G        460M        2.7G        548K        1.3G        3.6G
                  Swap:           3.2G        5.7M        3.2G
                  Total:          7.3G        466M        5.9G
                           3893 M total memory
                            439 M used memory
                            482 M active memory
                            611 M inactive memory
                           2538 M free memory
                            155 M buffer memory
                           1046 M swap cache
                           3071 M total swap
                              5 M used swap
                           3066 M free swap
                  *** FAILED SERVICES ***
                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                  * iobroker.service loaded failed failed ioBroker Server
                  1 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.9G     0  1.9G   0% /dev
                  tmpfs          tmpfs     390M  604K  389M   1% /run
                  /dev/sda1      ext4       20G  9.2G  9.4G  50% /
                  tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                  tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                  tmpfs          tmpfs     390M     0  390M   0% /run/user/1000
                  [Wed Jan  3 19:06:28 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                  [Wed Jan  3 19:06:29 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                  Show mounted filesystems \(real ones only\):
                  TARGET SOURCE    FSTYPE OPTIONS
                  /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                  /var:
                  2.2G    /var/
                  1.2G    /var/cache/apt
                  1.2G    /var/cache
                  1.1G    /var/cache/apt/archives
                  790M    /var/log
                  Archived and active journals take up 525.9M in the file system.
                  /opt/iobroker/backups:
                  69M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  902M    /opt/iobroker/iobroker-data/
                  493M    /opt/iobroker/iobroker-data/history
                  226M    /opt/iobroker/iobroker-data/files
                  118M    /opt/iobroker/iobroker-data/backup-objects
                  51M     /opt/iobroker/iobroker-data/files/javascript.admin
                  21M     /opt/iobroker/iobroker-data/objects.jsonl
                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                  20M     /opt/iobroker/iobroker-data/states.jsonl
                  11M     /opt/iobroker/iobroker-data/objects.json.migrated
                  11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                  /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L11007YM-if03
                  /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L11007YM-if00
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.19.0
                  /usr/bin/node           v18.19.0
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  /usr/bin/corepack       0.22.0
                  nodejs:
                    Installed: 18.19.0-1nodesource1
                    Candidate: 18.19.0-1nodesource1
                    Version table:
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                   *** 18.19.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                          100 /var/lib/dpkg/status
                       18.18.2-1nodesource1 1001
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0+dfsg1-1 500
                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                  No problems detected
                    @0__nik__0
                    iob diag
                    sagt?
                    0 Offline
                    0 Offline
                    0__Nik__0
                    Errors in npm tree:
                    npm ERR! code ELSPROBLEMS
                    npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                    npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                    npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                    npm ERR! invalid: iobroker.tr-064-community@npm:iobroker.tr-064@4.2.18 /opt/iobroker/node_modules/iobroker.tr-064-community
                    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
                    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
                    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                    npm ERR! extraneous: @aashutoshrathi/word-wrap@1.2.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
                    npm ERR! extraneous: @alcalzone/pak@0.10.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
                    npm ERR! extraneous: @alcalzone/release-script-core@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
                    npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
                    npm ERR! extraneous: @alcalzone/release-script-plugin-exec@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
                    npm ERR! extraneous: @alcalzone/release-script-plugin-git@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
                    npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
                    npm ERR! extraneous: @alcalzone/release-script-plugin-license@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
                    npm ERR! extraneous: @alcalzone/release-script-plugin-package@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
                    npm ERR! extraneous: @alcalzone/release-script-plugin-version@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
                    npm ERR! extraneous: @alcalzone/release-script@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
                    npm ERR! extraneous: @eslint-community/eslint-utils@4.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
                    npm ERR! extraneous: @eslint-community/regexpp@4.10.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
                    npm ERR! extraneous: @eslint/eslintrc@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrc
                    npm ERR! extraneous: @eslint/js@8.56.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
                    npm ERR! extraneous: @humanwhocodes/config-array@0.11.14 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
                    npm ERR! extraneous: @humanwhocodes/module-importer@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
                    npm ERR! extraneous: @humanwhocodes/object-schema@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
                    npm ERR! extraneous: @iobroker/dev-server@0.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
                    npm ERR! extraneous: @iobroker/testing@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
                    npm ERR! extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
                    npm ERR! extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
                    npm ERR! extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walk
                    npm ERR! extraneous: @sinonjs/commons@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commons
                    npm ERR! extraneous: @sinonjs/fake-timers@9.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
                    npm ERR! extraneous: @sinonjs/samsam@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
                    npm ERR! extraneous: @sinonjs/text-encoding@0.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
                    npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
                    npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
                    npm ERR! extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
                    npm ERR! extraneous: @types/expect@1.20.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
                    npm ERR! extraneous: @types/http-proxy@1.17.14 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
                    npm ERR! extraneous: @types/vinyl@2.0.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
                    npm ERR! extraneous: @ungap/structured-clone@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
                    npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
                    npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
                    npm ERR! extraneous: acorn-globals@1.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
                    npm ERR! extraneous: acorn-jsx@5.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
                    npm ERR! extraneous: acorn@8.11.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
                    npm ERR! extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/aggregate-error
                    npm ERR! extraneous: alcalzone-shared@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-shared
                    npm ERR! extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
                    npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
                    npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
                    npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
                    npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
                    npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
                    npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
                    npm ERR! extraneous: append-buffer@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
                    npm ERR! extraneous: archy@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
                    npm ERR! extraneous: argparse@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
                    npm ERR! extraneous: arr-diff@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
                    npm ERR! extraneous: arr-filter@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
                    npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
                    npm ERR! extraneous: arr-map@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
                    npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
                    npm ERR! extraneous: array-each@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
                    npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
                    npm ERR! extraneous: array-initial@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
                    npm ERR! extraneous: array-last@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
                    npm ERR! extraneous: array-slice@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
                    npm ERR! extraneous: array-sort@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
                    npm ERR! extraneous: array-union@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-union
                    npm ERR! extraneous: array-unique@0.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
                    npm ERR! extraneous: assertion-error@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
                    npm ERR! extraneous: assign-symbols@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
                    npm ERR! extraneous: astral-regex@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
                    npm ERR! extraneous: async-done@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
                    npm ERR! extraneous: async-each-series@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
                    npm ERR! extraneous: async-each@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
                    npm ERR! extraneous: async-settle@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
                    npm ERR! extraneous: async@2.6.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
                    npm ERR! extraneous: atob@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
                    npm ERR! extraneous: axios@1.6.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/axios
                    npm ERR! extraneous: bach@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
                    npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
                    npm ERR! extraneous: base@0.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
                    npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
                    npm ERR! extraneous: batch@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
                    npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
                    npm ERR! extraneous: binaryextensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensions
                    npm ERR! extraneous: body-parser@1.20.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
                    npm ERR! extraneous: boxen@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
                    npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
                    npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
                    npm ERR! extraneous: browser-request@0.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
                    npm ERR! extraneous: browser-stdout@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
                    npm ERR! extraneous: browser-sync-client@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
                    npm ERR! extraneous: browser-sync-ui@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
                    npm ERR! extraneous: browser-sync@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
                    npm ERR! extraneous: bs-html-injector@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector
                    npm ERR! extraneous: bs-recipes@1.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
                    npm ERR! extraneous: buffer-equal@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
                    npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
                    npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
                    npm ERR! extraneous: cache-base@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
                    npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
                    npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
                    npm ERR! extraneous: chai-as-promised@7.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promised
                    npm ERR! extraneous: chai@4.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
                    npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
                    npm ERR! extraneous: check-error@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
                    npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
                    npm ERR! extraneous: class-utils@0.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
                    npm ERR! extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clean-stack
                    npm ERR! extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
                    npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
                    npm ERR! extraneous: clone-buffer@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
                    npm ERR! extraneous: clone-stats@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
                    npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
                    npm ERR! extraneous: cloneable-readable@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
                    npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
                    npm ERR! extraneous: collection-map@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
                    npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visit
                    npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
                    npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
                    npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
                    npm ERR! extraneous: colors@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
                    npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
                    npm ERR! extraneous: component-emitter@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
                    npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
                    npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
                    npm ERR! extraneous: connect-history-api-fallback@1.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
                    npm ERR! extraneous: connect@3.6.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
                    npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
                    npm ERR! extraneous: content-type@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
                    npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
                    npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signature
                    npm ERR! extraneous: cookie@0.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
                    npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
                    npm ERR! extraneous: copy-props@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
                    npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
                    npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
                    npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
                    npm ERR! extraneous: cssstyle@0.2.37 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
                    npm ERR! extraneous: d@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                    npm ERR! extraneous: decamelize@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
                    npm ERR! extraneous: decode-uri-component@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
                    npm ERR! extraneous: deep-eql@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
                    npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
                    npm ERR! extraneous: default-compare@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
                    npm ERR! extraneous: default-resolution@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
                    npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
                    npm ERR! extraneous: del@6.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/del
                    npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
                    npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
                    npm ERR! extraneous: detect-file@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
                    npm ERR! extraneous: dev-ip@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
                    npm ERR! extraneous: diff@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
                    npm ERR! extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dir-glob
                    npm ERR! extraneous: doctrine@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
                    npm ERR! extraneous: dom-compare-temp@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-temp
                    npm ERR! extraneous: dom-serializer@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
                    npm ERR! extraneous: domelementtype@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
                    npm ERR! extraneous: domhandler@2.4.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
                    npm ERR! extraneous: domutils@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
                    npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
                    npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
                    npm ERR! extraneous: each-props@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
                    npm ERR! extraneous: easy-extender@2.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
                    npm ERR! extraneous: eazy-logger@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
                    npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
                    npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
                    npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
                    npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
                    npm ERR! extraneous: engine.io-client@6.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client
                    npm ERR! extraneous: engine.io-parser@5.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parser
                    npm ERR! extraneous: engine.io@6.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
                    npm ERR! extraneous: enquirer@2.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
                    npm ERR! extraneous: entities@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
                    npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
                    npm ERR! extraneous: es5-ext@0.10.62 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
                    npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
                    npm ERR! extraneous: es6-symbol@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
                    npm ERR! extraneous: es6-weak-map@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
                    npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
                    npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
                    npm ERR! extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
                    npm ERR! extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
                    npm ERR! extraneous: eslint-scope@7.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
                    npm ERR! extraneous: eslint-visitor-keys@3.4.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
                    npm ERR! extraneous: eslint@8.56.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
                    npm ERR! extraneous: espree@9.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
                    npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
                    npm ERR! extraneous: esquery@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
                    npm ERR! extraneous: esrecurse@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
                    npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
                    npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
                    npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
                    npm ERR! extraneous: event-stream@3.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
                    npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
                    npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
                    npm ERR! extraneous: expand-brackets@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
                    npm ERR! extraneous: expand-tilde@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
                    npm ERR! extraneous: express@4.18.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
                    npm ERR! extraneous: ext@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
                    npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
                    npm ERR! extraneous: extglob@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
                    npm ERR! extraneous: fancy-log@1.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
                    npm ERR! extraneous: fast-glob@3.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
                    npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshtein
                    npm ERR! extraneous: fastq@1.16.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
                    npm ERR! extraneous: file-entry-cache@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cache
                    npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
                    npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
                    npm ERR! extraneous: find-up@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
                    npm ERR! extraneous: findup-sync@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync
                    npm ERR! extraneous: fined@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined
                    npm ERR! extraneous: flagged-respawn@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flagged-respawn
                    npm ERR! extraneous: flat-cache@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat-cache
                    npm ERR! extraneous: flat@5.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat
                    npm ERR! extraneous: flatted@3.2.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flatted
                    npm ERR! extraneous: flush-write-stream@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/flush-write-stream
                    npm ERR! extraneous: follow-redirects@1.15.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects
                    npm ERR! extraneous: for-in@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-in
                    npm ERR! extraneous: for-own@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-own
                    npm ERR! extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/forwarded
                    npm ERR! extraneous: fragment-cache@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fragment-cache
                    npm ERR! extraneous: fresh@0.5.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fresh
                    npm ERR! extraneous: from@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/from
                    npm ERR! extraneous: fs-extra@10.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-extra
                    npm ERR! extraneous: fs-mkdirp-stream@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-mkdirp-stream
                    npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs.realpath
                    npm ERR! extraneous: get-caller-file@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-caller-file
                    npm ERR! extraneous: get-func-name@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-func-name
                    npm ERR! extraneous: get-stream@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-stream
                    npm ERR! extraneous: get-value@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-value
                    npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-parent
                    npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream
                    npm ERR! extraneous: glob-watcher@5.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher
                    npm ERR! extraneous: glob@7.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
                    npm ERR! extraneous: global-modules@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-modules
                    npm ERR! extraneous: global-prefix@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix
                    npm ERR! extraneous: globals@13.24.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globals
                    npm ERR! extraneous: globalyzer@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globalyzer
                    npm ERR! extraneous: globby@11.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globby
                    npm ERR! extraneous: globrex@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/globrex
                    npm ERR! extraneous: glogg@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glogg
                    npm ERR! extraneous: graceful-fs@4.2.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs
                    npm ERR! extraneous: graphemer@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/graphemer
                    npm ERR! extraneous: gulp-cli@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli
                    npm ERR! extraneous: gulp-rename@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
                    npm ERR! extraneous: gulp-replace@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
                    npm ERR! extraneous: gulp@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
                    npm ERR! extraneous: gulplog@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulplog
                    npm ERR! extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-flag
                    npm ERR! extraneous: has-value@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-value
                    npm ERR! extraneous: has-values@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values
                    npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/he
                    npm ERR! extraneous: homedir-polyfill@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/homedir-polyfill
                    npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/hosted-git-info
                    npm ERR! extraneous: htmlparser2@3.10.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2
                    npm ERR! extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-errors
                    npm ERR! extraneous: http-proxy-middleware@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy-middleware
                    npm ERR! extraneous: http-proxy@1.18.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy
                    npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
                    npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
                    npm ERR! extraneous: ignore-by-default@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore-by-default
                    npm ERR! extraneous: ignore@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
                    npm ERR! extraneous: immutable@3.8.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/immutable
                    npm ERR! extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
                    npm ERR! extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
                    npm ERR! extraneous: indent-string@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/indent-string
                    npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
                    npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
                    npm ERR! extraneous: interpret@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
                    npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
                    npm ERR! extraneous: ipaddr.js@1.9.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ipaddr.js
                    npm ERR! extraneous: is-absolute@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
                    npm ERR! extraneous: is-accessor-descriptor@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
                    npm ERR! extraneous: is-arrayish@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
                    npm ERR! extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
                    npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
                    npm ERR! extraneous: is-core-module@2.13.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
                    npm ERR! extraneous: is-data-descriptor@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
                    npm ERR! extraneous: is-descriptor@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
                    npm ERR! extraneous: is-extendable@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
                    npm ERR! extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
                    npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
                    npm ERR! extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
                    npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
                    npm ERR! extraneous: is-number-like@1.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-like
                    npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
                    npm ERR! extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-cwd
                    npm ERR! extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
                    npm ERR! extraneous: is-plain-obj@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
                    npm ERR! extraneous: is-plain-object@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
                    npm ERR! extraneous: is-relative@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
                    npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-stream
                    npm ERR! extraneous: is-unc-path@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
                    npm ERR! extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
                    npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
                    npm ERR! extraneous: is-valid-glob@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
                    npm ERR! extraneous: is-windows@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
                    npm ERR! extraneous: is-wsl@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-wsl
                    npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/isexe
                    npm ERR! extraneous: isobject@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/isobject
                    npm ERR! extraneous: istextorbinary@3.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/istextorbinary
                    npm ERR! extraneous: js-yaml@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/js-yaml
                    npm ERR! extraneous: jsdom@6.5.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom
                    npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer
                    npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stable-stringify-without-jsonify
                    npm ERR! extraneous: jsonfile@6.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonfile
                    npm ERR! extraneous: just-debounce@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-debounce
                    npm ERR! extraneous: just-extend@6.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-extend
                    npm ERR! extraneous: keyv@4.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv
                    npm ERR! extraneous: kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/kind-of
                    npm ERR! extraneous: last-run@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/last-run
                    npm ERR! extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream
                    npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lcid
                    npm ERR! extraneous: lead@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lead
                    npm ERR! extraneous: levn@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/levn
                    npm ERR! extraneous: liftoff@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff
                    npm ERR! extraneous: limiter@1.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/limiter
                    npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/load-json-file
                    npm ERR! extraneous: localtunnel@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel
                    npm ERR! extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/locate-path
                    npm ERR! extraneous: lodash.get@4.4.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.get
                    npm ERR! extraneous: lodash.isfinite@3.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.isfinite
                    npm ERR! extraneous: lodash.merge@4.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.merge
                    npm ERR! extraneous: lodash.truncate@4.4.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.truncate
                    npm ERR! extraneous: lodash@4.17.21 /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash
                    npm ERR! extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/log-symbols
                    npm ERR! extraneous: loupe@2.3.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/loupe
                    npm ERR! extraneous: make-iterator@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator
                    npm ERR! extraneous: map-cache@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-cache
                    npm ERR! extraneous: map-stream@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-stream
                    npm ERR! extraneous: map-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-visit
                    npm ERR! extraneous: matchdep@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep
                    npm ERR! extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/media-typer
                    npm ERR! extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-descriptors
                    npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-stream
                    npm ERR! extraneous: merge2@1.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge2
                    npm ERR! extraneous: methods@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/methods
                    npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch
                    npm ERR! extraneous: mime@1.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime
                    npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-fn
                    npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
                    npm ERR! extraneous: mitt@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mitt
                    npm ERR! extraneous: mixin-deep@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep
                    npm ERR! extraneous: mocha@10.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
                    npm ERR! extraneous: mute-stdout@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mute-stdout
                    npm ERR! extraneous: nanoid@3.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanoid
                    npm ERR! extraneous: nanomatch@1.2.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch
                    npm ERR! extraneous: natural-compare@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/natural-compare
                    npm ERR! extraneous: negotiator@0.6.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/negotiator
                    npm ERR! extraneous: next-tick@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/next-tick
                    npm ERR! extraneous: nise@5.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise
                    npm ERR! extraneous: nodemon@2.0.22 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon
                    npm ERR! extraneous: nopt@1.0.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nopt
                    npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data
                    npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-path
                      @0__nik__0
                      iob diag
                      sagt?
                      0 Offline
                      0 Offline
                      0__Nik__0
                      npm ERR! extraneous: now-and-later@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/now-and-later
                      npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/npm-run-path
                      npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/number-is-nan
                      npm ERR! extraneous: nwmatcher@1.4.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nwmatcher
                      npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign
                      npm ERR! extraneous: object-copy@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy
                      npm ERR! extraneous: object-inspect@1.13.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-inspect
                      npm ERR! extraneous: object-visit@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-visit
                      npm ERR! extraneous: object.assign@4.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign
                      npm ERR! extraneous: object.defaults@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.defaults
                      npm ERR! extraneous: object.map@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.map
                      npm ERR! extraneous: object.pick@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.pick
                      npm ERR! extraneous: object.reduce@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.reduce
                      npm ERR! extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/on-finished
                      npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
                      npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/onetime
                      npm ERR! extraneous: openurl@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/openurl
                      npm ERR! extraneous: opn@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/opn
                      npm ERR! extraneous: optionator@0.9.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/optionator
                      npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ordered-read-streams
                      npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/os-locale
                      npm ERR! extraneous: p-limit@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-limit
                      npm ERR! extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-locate
                      npm ERR! extraneous: p-map@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-map
                      npm ERR! extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parent-module
                      npm ERR! extraneous: parse-filepath@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-filepath
                      npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-json
                      npm ERR! extraneous: parse-node-version@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-node-version
                      npm ERR! extraneous: parse-passwd@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-passwd
                      npm ERR! extraneous: parse5@1.5.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5
                      npm ERR! extraneous: parseurl@1.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/parseurl
                      npm ERR! extraneous: pascalcase@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pascalcase
                      npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-dirname
                      npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-exists
                      npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
                      npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-key
                      npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-parse
                      npm ERR! extraneous: path-root-regex@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root-regex
                      npm ERR! extraneous: path-root@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root
                      npm ERR! extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-to-regexp
                      npm ERR! extraneous: path-type@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-type
                      npm ERR! extraneous: pathval@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pathval
                      npm ERR! extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pause-stream
                      npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/picomatch
                      npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pify
                      npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise
                      npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie
                      npm ERR! extraneous: portscanner@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/portscanner
                      npm ERR! extraneous: posix-character-classes@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/posix-character-classes
                      npm ERR! extraneous: prelude-ls@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/prelude-ls
                      npm ERR! extraneous: pretty-hrtime@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pretty-hrtime
                      npm ERR! extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-addr
                      npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-from-env
                      npm ERR! extraneous: ps-tree@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ps-tree
                      npm ERR! extraneous: pstree.remy@1.1.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pstree.remy
                      npm ERR! extraneous: pump@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pump
                      npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/pumpify
                      npm ERR! extraneous: qs@6.11.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/qs
                      npm ERR! extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/queue-microtask
                      npm ERR! extraneous: randombytes@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/randombytes
                      npm ERR! extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/range-parser
                      npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/raw-body
                      npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up
                      npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg
                      npm ERR! extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp
                      npm ERR! extraneous: rechoir@0.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/rechoir
                      npm ERR! extraneous: regex-not@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not
                      npm ERR! extraneous: remove-bom-buffer@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-buffer
                      npm ERR! extraneous: remove-bom-stream@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-stream
                      npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-trailing-separator
                      npm ERR! extraneous: repeat-element@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-element
                      npm ERR! extraneous: repeat-string@1.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-string
                      npm ERR! extraneous: replace-ext@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-ext
                      npm ERR! extraneous: replace-homedir@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-homedir
                      npm ERR! extraneous: replacestream@4.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream
                      npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-directory
                      npm ERR! extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-from-string
                      npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-main-filename
                      npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/requires-port
                      npm ERR! extraneous: resolve-dir@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-dir
                      npm ERR! extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-from
                      npm ERR! extraneous: resolve-options@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-options
                      npm ERR! extraneous: resolve-url@0.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-url
                      npm ERR! extraneous: resolve@1.22.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve
                      npm ERR! extraneous: resp-modifier@6.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier
                      npm ERR! extraneous: ret@0.1.15 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ret
                      npm ERR! extraneous: reusify@1.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/reusify
                      npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
                      npm ERR! extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/run-parallel
                      npm ERR! extraneous: rx@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/rx
                      npm ERR! extraneous: safe-regex@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-regex
                      npm ERR! extraneous: semver-greatest-satisfied-range@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver-greatest-satisfied-range
                      npm ERR! extraneous: send@0.16.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send
                      npm ERR! extraneous: serialize-javascript@6.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialize-javascript
                      npm ERR! extraneous: serve-index@1.9.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index
                      npm ERR! extraneous: serve-static@1.13.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-static
                      npm ERR! extraneous: server-destroy@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/server-destroy
                      npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-blocking
                      npm ERR! extraneous: set-value@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value
                      npm ERR! extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/setprototypeof
                      npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-command
                      npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-regex
                      npm ERR! extraneous: side-channel@1.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/side-channel
                      npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/signal-exit
                      npm ERR! extraneous: simple-update-notifier@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier
                      npm ERR! extraneous: sinon-chai@3.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon-chai
                      npm ERR! extraneous: sinon@14.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon
                      npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/slash
                      npm ERR! extraneous: slice-ansi@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/slice-ansi
                      npm ERR! extraneous: snapdragon-node@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node
                      npm ERR! extraneous: snapdragon-util@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util
                      npm ERR! extraneous: snapdragon@0.8.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon
                      npm ERR! extraneous: socket.io-adapter@2.5.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter
                      npm ERR! extraneous: socket.io-client@4.7.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-client
                      npm ERR! extraneous: socket.io-parser@4.2.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-parser
                      npm ERR! extraneous: socket.io@4.7.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io
                      npm ERR! extraneous: source-map-resolve@0.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-resolve
                      npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support
                      npm ERR! extraneous: source-map-url@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-url
                      npm ERR! extraneous: source-map@0.7.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map
                      npm ERR! extraneous: sparkles@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/sparkles
                      npm ERR! extraneous: spdx-correct@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-correct
                      npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-exceptions
                      npm ERR! extraneous: spdx-expression-parse@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-expression-parse
                      npm ERR! extraneous: spdx-license-ids@3.0.16 /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-license-ids
                      npm ERR! extraneous: split-string@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string
                      npm ERR! extraneous: split@0.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/split
                      npm ERR! extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stack-trace
                      npm ERR! extraneous: static-extend@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend
                      npm ERR! extraneous: statuses@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/statuses
                      npm ERR! extraneous: stream-combiner@0.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-combiner
                      npm ERR! extraneous: stream-exhaust@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-exhaust
                      npm ERR! extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-shift
                      npm ERR! extraneous: stream-throttle@0.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-throttle
                      npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/string-width
                      npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-ansi
                      npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-bom
                      npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-final-newline
                      npm ERR! extraneous: strip-json-comments@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-json-comments
                      npm ERR! extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-color
                      npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-preserve-symlinks-flag
                      npm ERR! extraneous: sver-compat@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/sver-compat
                      npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/symbol-tree
                      npm ERR! extraneous: table@6.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/table
                      npm ERR! extraneous: text-table@0.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/text-table
                      npm ERR! extraneous: textextensions@3.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/textextensions
                      npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/through
                      npm ERR! extraneous: through2-filter@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2-filter
                      npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2
                      npm ERR! extraneous: time-stamp@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/time-stamp
                      npm ERR! extraneous: timekeeper@2.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
                      npm ERR! extraneous: tiny-glob@0.2.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/tiny-glob
                      npm ERR! extraneous: to-absolute-glob@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-absolute-glob
                      npm ERR! extraneous: to-object-path@0.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path
                      npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex-range
                      npm ERR! extraneous: to-regex@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex
                      npm ERR! extraneous: to-through@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-through
                      npm ERR! extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/toidentifier
                      npm ERR! extraneous: touch@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/touch
                      npm ERR! extraneous: tr46@0.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr46
                      npm ERR! extraneous: type-check@0.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-check
                      npm ERR! extraneous: type-detect@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-detect
                      npm ERR! extraneous: type-fest@0.20.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-fest
                      npm ERR! extraneous: type-is@1.6.18 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-is
                      npm ERR! extraneous: type@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/type
                      npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/typedarray
                      npm ERR! extraneous: ua-parser-js@1.0.37 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ua-parser-js
                      npm ERR! extraneous: unc-path-regex@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unc-path-regex
                      npm ERR! extraneous: undefsafe@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undefsafe
                      npm ERR! extraneous: undertaker-registry@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker-registry
                      npm ERR! extraneous: undertaker@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker
                      npm ERR! extraneous: union-value@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value
                      npm ERR! extraneous: unique-stream@2.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unique-stream
                      npm ERR! extraneous: universalify@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/universalify
                      npm ERR! extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unpipe
                      npm ERR! extraneous: unset-value@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value
                      npm ERR! extraneous: upath@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/upath
                      npm ERR! extraneous: urix@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/urix
                      npm ERR! extraneous: use@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/use
                      npm ERR! extraneous: utils-merge@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/utils-merge
                      npm ERR! extraneous: v8flags@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/v8flags
                      npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/validate-npm-package-license
                      npm ERR! extraneous: value-or-function@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/value-or-function
                      npm ERR! extraneous: vary@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vary
                      npm ERR! extraneous: vinyl-fs@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-fs
                      npm ERR! extraneous: vinyl-sourcemap@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap
                      npm ERR! extraneous: vinyl@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl
                      npm ERR! extraneous: whatwg-url-compat@0.6.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/whatwg-url-compat
                      npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-module
                      npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/which
                      npm ERR! extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/widest-line
                      npm ERR! extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/word-wrap
                      npm ERR! extraneous: workerpool@6.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/workerpool
                      npm ERR! extraneous: wrap-ansi@7.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrap-ansi
                      npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
                      npm ERR! extraneous: ws@8.16.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ws
                      npm ERR! extraneous: xml-name-validator@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml-name-validator
                      npm ERR! extraneous: xmldom@0.1.16 /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmldom
                      npm ERR! extraneous: xmlhttprequest-ssl@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest-ssl
                      npm ERR! extraneous: xmlhttprequest@1.8.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest
                      npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend
                      npm ERR! extraneous: y18n@5.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/y18n
                      npm ERR! extraneous: yargs-parser@21.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-parser
                      npm ERR! extraneous: yargs-unparser@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser
                      npm ERR! extraneous: yargs@17.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs
                      npm ERR! extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yocto-queue
                      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                      npm ERR! extraneous: execa@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak/node_modules/execa
                      npm ERR! extraneous: axios@0.27.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server/node_modules/axios
                      npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server/node_modules/form-data
                      npm ERR! extraneous: @sinonjs/commons@1.8.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
                      npm ERR! extraneous: acorn@2.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals/node_modules/acorn
                      npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial/node_modules/is-number
                      npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last/node_modules/is-number
                      npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/node_modules/form-data
                      npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/define-property
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/debug
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/ms
                      npm ERR! extraneous: raw-body@2.5.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/raw-body
                      npm ERR! extraneous: fs-extra@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/fs-extra
                      npm ERR! extraneous: jsonfile@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/jsonfile
                      npm ERR! extraneous: universalify@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/universalify
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/debug
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/ms
                      npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/define-property
                      npm ERR! extraneous: is-descriptor@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-descriptor
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/debug
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/ms
                      npm ERR! invalid: argparse@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
                      npm ERR! invalid: colors@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
                      npm ERR! extraneous: domelementtype@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/domelementtype
                      npm ERR! extraneous: entities@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/entities
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props/node_modules/is-plain-object
                      npm ERR! extraneous: ws@8.11.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client/node_modules/ws
                      npm ERR! extraneous: cookie@0.4.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/cookie
                      npm ERR! extraneous: ws@8.11.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/ws
                      npm ERR! extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/estraverse
                      npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/levn
                      npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/optionator
                      npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/prelude-ls
                      npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/source-map
                      npm ERR! extraneous: type-check@0.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/type-check
                      npm ERR! extraneous: glob-parent@6.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint/node_modules/glob-parent
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/debug
                      npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/define-property
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/extend-shallow
                      npm ERR! extraneous: is-descriptor@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-descriptor
                      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-extendable
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/ms
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/debug
                      npm ERR! extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/finalhandler
                      npm ERR! extraneous: mime@1.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/mime
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/ms
                      npm ERR! extraneous: send@0.18.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send
                      npm ERR! extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/serve-static
                      npm ERR! extraneous: type@2.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext/node_modules/type
                      npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/define-property
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/extend-shallow
                      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/is-extendable
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/debug
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/ms
                      npm ERR! extraneous: on-finished@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/on-finished
                      npm ERR! extraneous: statuses@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/statuses
                      npm ERR! extraneous: braces@2.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces
                      npm ERR! extraneous: fill-range@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range
                      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-extendable
                      npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/kind-of
                      npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/micromatch
                      npm ERR! extraneous: to-regex-range@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/to-regex-range
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined/node_modules/is-plain-object
                      npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/glob-parent
                      npm ERR! extraneous: is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/is-glob
                      npm ERR! extraneous: anymatch@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch
                      npm ERR! extraneous: binary-extensions@1.13.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/binary-extensions
                      npm ERR! extraneous: braces@2.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces
                      npm ERR! extraneous: chokidar@2.1.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/chokidar
                      npm ERR! extraneous: fill-range@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range
                      npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent
                      npm ERR! extraneous: is-binary-path@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-binary-path
                      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-extendable
                      npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-number
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/kind-of
                      npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch
                      npm ERR! extraneous: readdirp@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/readdirp
                      npm ERR! extraneous: to-regex-range@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/to-regex-range
                      npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix/node_modules/which
                      npm ERR! extraneous: ansi-colors@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-colors
                      npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-regex
                      npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/camelcase
                      npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/cliui
                      npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/decamelize
                      npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/get-caller-file
                      npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/is-fullwidth-code-point
                      npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/string-width
                      npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/strip-ansi
                      npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/wrap-ansi
                      npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/y18n
                      npm ERR! extraneous: yargs-parser@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs-parser
                      npm ERR! extraneous: yargs@7.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs
                      npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number
                      npm ERR! extraneous: kind-of@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/kind-of
                      npm ERR! extraneous: readable-stream@3.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/node_modules/readable-stream
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable/node_modules/is-plain-object
                      npm ERR! extraneous: acorn@2.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom/node_modules/acorn
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff/node_modules/is-plain-object
                      npm ERR! extraneous: axios@0.21.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/axios
                      npm ERR! extraneous: cliui@7.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/cliui
                      npm ERR! extraneous: debug@4.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/debug
                      npm ERR! extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs-parser
                      npm ERR! extraneous: yargs@17.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator/node_modules/kind-of
                      npm ERR! extraneous: braces@2.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces
                      npm ERR! extraneous: fill-range@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range
                      npm ERR! extraneous: findup-sync@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/findup-sync
                      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-extendable
                      npm ERR! extraneous: is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-glob
                      npm ERR! extraneous: is-number@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/kind-of
                      npm ERR! extraneous: micromatch@3.1.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/micromatch
                      npm ERR! extraneous: to-regex-range@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/to-regex-range
                      npm ERR! extraneous: ansi-colors@4.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ansi-colors
                      npm ERR! extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/brace-expansion
                      npm ERR! extraneous: cliui@7.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/cliui
                      npm ERR! extraneous: minimatch@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/minimatch
                      npm ERR! extraneous: ms@2.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ms
                      npm ERR! extraneous: supports-color@8.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/supports-color
                      npm ERR! extraneous: yargs-parser@20.2.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs-parser
                      npm ERR! extraneous: yargs@16.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/kind-of
                      npm ERR! extraneous: @sinonjs/commons@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/commons
                      npm ERR! extraneous: @sinonjs/fake-timers@11.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers
                      npm ERR! extraneous: path-to-regexp@6.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/path-to-regexp
                      npm ERR! extraneous: debug@3.2.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/debug
                      npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/has-flag
                      npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/semver
                      npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/supports-color
                      npm ERR! extraneous: semver@5.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data/node_modules/semver
                      npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/define-property
                      npm ERR! extraneous: is-descriptor@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/kind-of
                      npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/find-up
                      npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/path-exists
                      npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg/node_modules/path-type
                      npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream/node_modules/escape-string-regexp
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/debug
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/ms
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/debug
                      npm ERR! extraneous: depd@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/depd
                      npm ERR! extraneous: destroy@1.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/destroy
                      npm ERR! extraneous: http-errors@1.6.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/http-errors
                      npm ERR! extraneous: inherits@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/inherits
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/ms
                      npm ERR! extraneous: on-finished@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/on-finished
                      npm ERR! extraneous: setprototypeof@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/setprototypeof
                      npm ERR! extraneous: statuses@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/statuses
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/debug
                      npm ERR! extraneous: depd@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/depd
                      npm ERR! extraneous: http-errors@1.6.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/http-errors
                      npm ERR! extraneous: inherits@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/inherits
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/ms
                      npm ERR! extraneous: setprototypeof@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/setprototypeof
                      npm ERR! extraneous: statuses@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/statuses
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/extend-shallow
                      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-extendable
                      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-plain-object
                      npm ERR! extraneous: semver@7.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier/node_modules/semver
                      npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/define-property
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util/node_modules/kind-of
                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/debug
                      npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/define-property
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/extend-shallow
                      npm ERR! extraneous: is-descriptor@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-descriptor
                      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-extendable
                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/ms
                      npm ERR! extraneous: source-map@0.5.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/source-map
                      npm ERR! extraneous: ws@8.11.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter/node_modules/ws
                      npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support/node_modules/source-map
                      npm ERR! extraneous: define-property@0.2.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/define-property
                      npm ERR! extraneous: is-descriptor@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-descriptor
                      npm ERR! extraneous: ajv@8.12.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/ajv
                      npm ERR! extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/json-schema-traverse
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path/node_modules/kind-of
                      npm ERR! extraneous: fast-levenshtein@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker/node_modules/fast-levenshtein
                      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value/node_modules/is-extendable
                      npm ERR! extraneous: has-value@0.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value
                      npm ERR! extraneous: has-values@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-values
                      npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap/node_modules/normalize-path
                      npm ERR! extraneous: is-plain-obj@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser/node_modules/is-plain-obj
                      npm ERR! extraneous: ms@2.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send/node_modules/ms
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces/node_modules/extend-shallow
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range/node_modules/extend-shallow
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number/node_modules/kind-of
                      npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch/node_modules/normalize-path
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces/node_modules/extend-shallow
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range/node_modules/extend-shallow
                      npm ERR! extraneous: is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent/node_modules/is-glob
                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch/node_modules/kind-of
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number/node_modules/kind-of
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces/node_modules/extend-shallow
                      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range/node_modules/extend-shallow
                      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number/node_modules/kind-of
                      npm ERR! extraneous: isobject@2.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value/node_modules/isobject
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T23_12_58_664Z-debug-0.log
                        @0__nik__0
                        libpam0g-dev installiert?
                        apt policy libpam0g-dev
                        iob diag
                        sagt?
                        0 Offline
                        0 Offline
                        0__Nik__0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        iobroker is not running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.17
                        admin:          6.12.0
                        javascript:     6.1.4
                        npm ERR! code ELSPROBLEMS
                        npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                        npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                        npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                        npm ERR! invalid: iobroker.tr-064-community@npm:iobroker.tr-064@4.2.18 /opt/iobroker/node_modules/iobroker.tr-064-community
                        npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
                        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                        npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
                        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T23_13_29_667Z-debug-0.log
                        Adapters from github:   1
                        Adapter State
                          system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                          system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                          system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                          system.adapter.habpanel.0               : habpanel              : iobroker                                 -  enabled
                          system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
                          system.adapter.history.0                : history               : iobroker                                 -  enabled
                          system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                          system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                          system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                          system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
                          system.adapter.mqtt.1                   : mqtt                  : iobroker                                 - disabled, port: 1900, bind: 0.0.0.0
                          system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                          system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                          system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                          system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
                          system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                          system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.wled.0                   : wled                  : iobroker                                 - disabled
                          system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                          system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L11007YM-if00
                        + instance is alive
                        ioBroker-Repositories
                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.12.0   , installed 6.12.0
                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                        Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
                        Adapter    "daswetter"    : 3.1.12   , installed 3.1.4  [Updatable]
                        Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
                        Adapter    "fullybrowser" : 3.0.9    , installed 3.0.6  [Updatable]
                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                        Adapter    "info"         : 2.0.0    , installed 1.9.19 [Updatable]
                        Adapter    "iot"          : 2.0.11   , installed 1.11.9 [Updatable]
                        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                        Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
                        Controller "js-controller": 5.0.17   , installed 5.0.17
                        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                        Adapter    "mqtt-client"  : 1.7.0    , installed 1.6.3  [Updatable]
                        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                        Adapter    "shelly"       : 6.6.1    , installed 5.3.2  [Updatable]
                        Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
                        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                        Adapter    "systeminfo"   : 1.1.0    , installed 0.3.1  [Updatable]
                        Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                        Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
                        Adapter    "vis"          : 1.5.4    , installed 1.5.4
                        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.0  [Updatable]
                        Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.1.1
                        Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
                        Adapter    "web"          : 6.1.10   , installed 6.1.10
                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                        Adapter    "ws"           : 2.5.8    , installed 2.5.8
                        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                        Adapter    "zigbee"       : 1.10.1   , installed 1.8.10 [Updatable]
                        Objects and States
                        Objects:        9651
                        States:         10866
                        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 3
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15705      774/exim4
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17411      551/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          159        1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          17422      551/sshd: /usr/sbin
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          1170       1/init
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15706      774/exim4
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        728        447/avahi-daemon: r
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15322      462/dhclient
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13116      1/init
                        udp        0      0 0.0.0.0:37010           0.0.0.0:*                           107        730        447/avahi-daemon: r
                        udp6       0      0 :::53919                :::*                                107        731        447/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                107        729        447/avahi-daemon: r
                        udp6       0      0 :::111                  :::*                                0          162        1/init
                        2024-01-23 00:03:07.471  - info: shelly.0 (877) terminating with timeout
                        2024-01-23 00:03:07.575  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                        2024-01-23 00:03:07.576  - info: host.iobroker instance system.adapter.heizoel.0 terminated with code 0 (NO_ERROR)
                        2024-01-23 00:03:07.869  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                        2024-01-23 00:03:07.870  - info: host.iobroker All instances are stopped.
                        2024-01-23 00:03:07.870  - info: host.iobroker instance system.adapter.fullybrowser.0 terminated with code 0 (NO_ERROR)
                        2024-01-23 00:03:07.973  - info: host.iobroker instance system.adapter.terminal.0 terminated with code 0 (NO_ERROR)
                        2024-01-23 00:03:07.973  - info: host.iobroker All instances are stopped.
                        2024-01-23 00:03:07.974  - info: host.iobroker instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                        2024-01-23 00:03:07.974  - info: host.iobroker All instances are stopped.
                        2024-01-23 00:03:07.975  - info: host.iobroker instance system.adapter.pollenflug.0 terminated with code 0 (NO_ERROR)
                        2024-01-23 00:03:07.975  - info: host.iobroker All instances are stopped.
                        2024-01-23 00:03:08.011  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        2024-01-23 00:03:08.011  - error: host.iobroker Caught by controller[0]: Error: DB closed
                        2024-01-23 00:03:08.011  - error: host.iobroker Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                        2024-01-23 00:03:08.012  - error: host.iobroker Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                        2024-01-23 00:03:08.012  - error: host.iobroker Caught by controller[0]:     at Object.onceWrapper (node:events:632:26)
                        2024-01-23 00:03:08.012  - error: host.iobroker Caught by controller[0]:     at Socket.emit (node:events:517:28)
                        2024-01-23 00:03:08.012  - error: host.iobroker Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                        2024-01-23 00:03:08.012  - error: host.iobroker Caught by controller[0]:     at TCP.<anonymous> (node:net:350:12)
                        2024-01-23 00:03:08.012  - warn: host.iobroker instance system.adapter.shelly.0 terminated due to SIGTERM
                        2024-01-23 00:03:08.012  - info: host.iobroker instance system.adapter.shelly.0 terminated with code null ()
                        2024-01-23 00:03:08.013  - info: host.iobroker All instances are stopped.
                        2024-01-23 00:03:08.254  - info: host.iobroker terminated
                          @0__nik__0 sagte in Warnmeldungen beim updaten von Adaptern:
                          Cannot install "pam-devel": E: Paket pam-devel kann nicht gefunden werden.
                          Das Paket heißt bei Debian auch nicht pam-devel sondern libpam0g-dev:
                          sudo apt update
                          sudo apt install libpam0g-dev
                          0 Offline
                          0 Offline
                          0__Nik__0
                          @thomas-braun said in Warnmeldungen beim updaten von Adaptern:
                          Da kommt das ich schon die neuste Version habe
                          iobroker@iobroker:~$ sudo apt install libpam0g-dev
                          libpam0g-dev ist schon die neueste Version (1.5.2-6+deb12u1).
                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 3 nicht aktualisiert.
                            sudo apt update
                            0 Offline
                            0 Offline
                            0__Nik__0
                            sudo apt update
                            OK:1 http://deb.debian.org/debian bookworm InRelease
                            OK:2 http://deb.debian.org/debian bookworm-updates InRelease
                            OK:3 http://security.debian.org/debian-security bookworm-security InRelease
                            OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                            iobroker@iobroker:~$ ^C
                            iobroker@iobroker:~$ apt list --upgradable
                            Auflistung… Fertig
                            exim4-base/stable-security 4.96-15+deb12u4 amd64 [aktualisierbar von: 4.96-15+deb12u3]
                            exim4-config/stable-security 4.96-15+deb12u4 all [aktualisierbar von: 4.96-15+deb12u3]
                            exim4-daemon-light/stable-security 4.96-15+deb12u4 amd64 [aktualisierbar von: 4.96-15+deb12u3]
                            • 0 0__Nik__0
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                               Static hostname: iobroker
                                     Icon name: computer-vm
                                       Chassis: vm 🖴
                                Virtualization: kvm
                                        Kernel: Linux 6.1.0-17-amd64
                                  Architecture: x86-64
                               Hardware Vendor: QEMU
                                Hardware Model: Standard PC _i440FX + PIIX, 1996_
                              Firmware Version: rel-1.11.1-0-g0551a4be2c-prebuilt.qemu-project.org
                              model name      : Common KVM processor
                              Docker          : false
                              Virtualization  : kvm
                              Kernel          : x86_64
                              Userland        : amd64
                              Systemuptime and Load:
                               00:12:51 up 19 days,  5:06,  2 users,  load average: 0.33, 0.42, 0.52
                              CPU threads: 8
                              *** Time and Time Zones ***
                                             Local time: Tue 2024-01-23 00:12:52 CET
                                         Universal time: Mon 2024-01-22 23:12:52 UTC
                                               RTC time: Mon 2024-01-22 23:12:52
                                            NTP service: active
                                        RTC in local TZ: no
                              *** User and Groups ***
                              iobroker
                              /home/iobroker
                              iobroker tty dialout cdrom floppy audio dip video plugdev netdev
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            4.1G        460M        2.7G        548K        1.3G        3.6G
                              Swap:           3.2G        5.7M        3.2G
                              Total:          7.3G        466M        5.9G
                                       3893 M total memory
                                        439 M used memory
                                        482 M active memory
                                        611 M inactive memory
                                       2538 M free memory
                                        155 M buffer memory
                                       1046 M swap cache
                                       3071 M total swap
                                          5 M used swap
                                       3066 M free swap
                              *** FAILED SERVICES ***
                                UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                              * iobroker.service loaded failed failed ioBroker Server
                              1 loaded units listed.
                              *** FILESYSTEM ***
                              udev           devtmpfs  1.9G     0  1.9G   0% /dev
                              tmpfs          tmpfs     390M  604K  389M   1% /run
                              /dev/sda1      ext4       20G  9.2G  9.4G  50% /
                              tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs          tmpfs     390M     0  390M   0% /run/user/1000
                              [Wed Jan  3 19:06:28 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                              [Wed Jan  3 19:06:29 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                              Show mounted filesystems \(real ones only\):
                              TARGET SOURCE    FSTYPE OPTIONS
                              /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                              /var:
                              2.2G    /var/
                              1.2G    /var/cache/apt
                              1.2G    /var/cache
                              1.1G    /var/cache/apt/archives
                              790M    /var/log
                              Archived and active journals take up 525.9M in the file system.
                              /opt/iobroker/backups:
                              69M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              902M    /opt/iobroker/iobroker-data/
                              493M    /opt/iobroker/iobroker-data/history
                              226M    /opt/iobroker/iobroker-data/files
                              118M    /opt/iobroker/iobroker-data/backup-objects
                              51M     /opt/iobroker/iobroker-data/files/javascript.admin
                              21M     /opt/iobroker/iobroker-data/objects.jsonl
                              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                              20M     /opt/iobroker/iobroker-data/states.jsonl
                              11M     /opt/iobroker/iobroker-data/objects.json.migrated
                              11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              USB-Devices by-id:
                              USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                              /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L11007YM-if03
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.19.0
                              /usr/bin/node           v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              /usr/bin/corepack       0.22.0
                              nodejs:
                                Installed: 18.19.0-1nodesource1
                                Candidate: 18.19.0-1nodesource1
                                Version table:
                                   18.19.0+dfsg-6~deb12u1 500
                                      500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                               *** 18.19.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   18.18.2-1nodesource1 1001
                                   18.18.1-1nodesource1 1001
                                   18.18.0-1nodesource1 1001
                                   18.17.1-1nodesource1 1001
                                   18.17.0-1nodesource1 1001
                                   18.16.1-1nodesource1 1001
                                   18.16.0-1nodesource1 1001
                                   18.15.0-1nodesource1 1001
                                   18.14.2-1nodesource1 1001
                                   18.14.1-1nodesource1 1001
                                   18.14.0-1nodesource1 1001
                                   18.13.0+dfsg1-1 500
                                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                   18.13.0-1nodesource1 1001
                                   18.12.0-1nodesource1 1001
                                   18.11.0-1nodesource1 1001
                                   18.10.0-1nodesource1 1001
                                   18.9.1-1nodesource1 1001
                                   18.9.0-1nodesource1 1001
                                   18.8.0-1nodesource1 1001
                                   18.7.0-1nodesource1 1001
                                   18.6.0-1nodesource1 1001
                                   18.5.0-1nodesource1 1001
                                   18.4.0-1nodesource1 1001
                                   18.3.0-1nodesource1 1001
                                   18.2.0-1nodesource1 1001
                                   18.1.0-1nodesource1 1001
                                   18.0.0-1nodesource1 1001
                              No problems detected
                              Boot Target: graphical.target
                              sudo systemctl set-default multi-user.target
                              • iobroker.service loaded failed failed ioBroker Server
                              Wassen da los?
                              systemctl status iobroker.service
                              sudo usermod -a -G adm DEINUSER
                              0 1 Antwort Letzte Antwort
                                Wassen da los?
                                0 Offline
                                0 Offline
                                0__Nik__0
                                Wassen da los?
                                • 0 0__Nik__0
                                  sudo apt update
                                  Auflistung… Fertig
                                  @0__nik__0
                                  iobroker del tr-064-community
                                  iobroker add tr-064
                                    @0__nik__0
                                    iobroker add tr-064
                                    0 Offline
                                    0 Offline
                                    0__Nik__0
                                    Meinst du das der Benutzer iobroker ist?
                                    Den Hinweis das man das nicht machen sollte gab es damals noch nicht ^^
                                    • 0 0__Nik__0
                                      Dan leg halt jetzt einen an.
                                      Und auch 'damals' war das schon eine doofe Idee. Ganz ohne Hinweis.
                                        0 Offline
                                        0 Offline
                                        0__Nik__0
                                        Da ich bis zu dem Zeitpunkt nur Windows User war, war das für mich nur ein Benutzername -.-
                                        Wie mache ich das und muss ich da noch was ändern, dass ich mit dem neuen/geänderten Benutzer mich wieder einloggen kann und es noch alles funktioniert?
                                        Löst das dann das Problem mit den Warnmeldungen?
                                        • 0 0__Nik__0
                                          @0__nik__0
                                          https://debiananwenderhandbuch.de/benutzerverwaltung.html
