  4. error Caught by controller[1] nach apt full-upgrade [gelöst]
7 Beiträge 3 Kommentatoren 852 Aufrufe 2 Beobachtet
    reutli
    schrieb am zuletzt editiert von reutli
    Hallo Leute,
    habe soeben meine Systeme (Master und zwei Slaves) per apt update und apt full-upgrade auf Vordermann gebracht und habe jetzt unangenehme Fehler im Log:
    host.iobroker-master
    	2024-01-07 10:10:09.396	info	Restart adapter system.adapter.info.0 because enabled
    	2024-01-07 10:10:09.396	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: Node.js v18.19.0
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: at node:internal/main/run_main_module:28:49
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: ^
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
    	2024-01-07 10:10:09.396	error	Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
    	2024-01-07 10:10:09.396	error	Caught by controller[0]: /bin/sh: 1: npm: not foun
    Hier mal die Daten des Masters aus diag Sicht. Wenn ich das korrekt verstehe, hat's mir bei NodeJS was verhagelt???
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker-master
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-17-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
    model name	: QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     10:11:35 up 17 min,  2 users,  load average: 0.36, 0.52, 0.54
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sun 2024-01-07 10:11:35 CET
               Universal time: Sun 2024-01-07 09:11:35 UTC
                     RTC time: Sun 2024-01-07 09:11:36
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    admin
    /home/admin
    admin sudo users iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            6.2G        3.5G        2.4G        524K        632M        2.7G
    Swap:           1.0G          0B        1.0G
    Total:          7.2G        3.5G        3.4G
             5924 M total memory
             3315 M used memory
              265 M active memory
             3045 M inactive memory
             2264 M free memory
               70 M buffer memory
              532 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs          tmpfs     593M  512K  592M   1% /run
    /dev/sda1      ext4       97G  4.7G   88G   6% /
    tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     593M     0  593M   0% /run/user/1001
    [Sun Jan  7 09:53:38 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Jan  7 09:53:38 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    576M	/var/
    268M	/var/cache
    260M	/var/cache/apt
    184M	/var/cache/apt/archives
    171M	/var/lib
    Archived and active journals take up 33.9M in the file system.
    /opt/iobroker/backups:
    1.3M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    403M	/opt/iobroker/iobroker-data/
    254M	/opt/iobroker/iobroker-data/files
    97M	/opt/iobroker/iobroker-data/backup-objects
    67M	/opt/iobroker/iobroker-data/files/javascript.admin
    48M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    33M	/opt/iobroker/iobroker-data/objects.jsonl
    33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    20M	/opt/iobroker/iobroker-data/states.jsonl
    18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.0
    /usr/bin/node 		v18.19.0
    /home/iobroker/.diag.sh: line 279: npm: command not found
    /home/iobroker/.diag.sh: line 280: npx: command not found
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    /home/iobroker/.diag.sh: line 290: npm: command not found
    /home/iobroker/.diag.sh: line 291: npx: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u1
      Candidate: 18.19.0+dfsg-6~deb12u1
      Version table:
     *** 18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
            100 /var/lib/dpkg/status
         18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    /home/iobroker/.diag.sh: line 360: npm: command not found
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		6.12.0
    javascript: 	7.1.6
    /home/iobroker/.diag.sh: line 375: npm: command not found
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-master                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : iobroker-master                          -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker-master                          -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker-master                          -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker-master                          -  enabled
      system.adapter.backitup.2               : backitup              : iobroker2                                - disabled
      system.adapter.backitup.3               : backitup              : iobroker                                 - disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker-master                          -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker-master                          -  enabled
      system.adapter.devices.0                : devices               : iobroker-master                          -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-master                          -  enabled
    + system.adapter.ds18b20.1                : ds18b20               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker-master                          -  enabled
    + system.adapter.email.1                  : email                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker-master                          -  enabled
      system.adapter.flot.0                   : flot                  : iobroker-master                          -  enabled
    + system.adapter.followthesun.0           : followthesun          : iobroker-master                          -  enabled
    + system.adapter.fronius.0                : fronius               : iobroker-master                          -  enabled
    + system.adapter.history.0                : history               : iobroker-master                          -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-master                          -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
    + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker-master                          -  enabled
      system.adapter.ical.0                   : ical                  : iobroker-master                          -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker-master                          -  enabled, port: 8086
      system.adapter.info.0                   : info                  : iobroker-master                          -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker-master                          -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker-master                          -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-master                          -  enabled
    + system.adapter.linkeddevices.0          : linkeddevices         : iobroker-master                          -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-master                          -  enabled, port: 1887, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker-master                          -  enabled
    + system.adapter.panasonic-viera.0        : panasonic-viera       : iobroker-master                          -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker-master                          -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker-master                          -  enabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker-master                          -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker-master                          -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker-master                          -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker-master                          -  enabled, port: 8087, bind: 192.168.200.5, run as: admin
    + system.adapter.smartgarden.0            : smartgarden           : iobroker-master                          -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker-master                          -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.synology.0               : synology              : iobroker-master                          -  enabled, port: 5001
    + system.adapter.telegram.0               : telegram              : iobroker-master                          -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : iobroker-master                          -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : iobroker-master                          -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker-master                          -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker-master                          -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker-master                          -  enabled
    + system.adapter.web.0                    : web                   : iobroker-master                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : iobroker-master                          -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker2                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "device-watcher": 2.9.6   , installed 2.9.6
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "email"        : 1.2.1    , installed 1.2.1
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.2
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "scenes"       : 2.3.9    , installed 2.3.3  [Updatable]
    Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects: 	15902
    States: 	13503
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1002       29438      2266/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1002       30836      2266/iobroker.js-co
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1002       32405      2798/io.jarvis.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15082      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17090      542/sshd: /usr/sbin
    tcp        0      0 192.168.200.5:2001      0.0.0.0:*               LISTEN      1002       31086      2451/io.hm-rpc.0
    tcp        0      0 192.168.200.5:2010      0.0.0.0:*               LISTEN      1002       29688      2466/io.hm-rpc.1
    tcp        0      0 192.168.200.5:8701      0.0.0.0:*               LISTEN      1002       28530      2481/io.hm-rpc.2
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       31205      2571/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       28625      2556/io.shelly.1
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1002       31825      2511/io.mqtt.0
    tcp        0      0 0.0.0.0:59169           0.0.0.0:*               LISTEN      103        21431      955/rpc.statd
    tcp        0      0 192.168.200.5:8087      0.0.0.0:*               LISTEN      1002       33386      2859/io.simple-api.
    tcp6       0      0 :::53341                :::*                    LISTEN      103        21435      955/rpc.statd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          15083      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17092      542/sshd: /usr/sbin
    tcp6       0      0 :::8090                 :::*                    LISTEN      1002       34847      2897/io.terminal.0
    tcp6       0      0 :::8089                 :::*                    LISTEN      1002       30911      2300/io.admin.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       32666      2942/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       30879      2284/io.admin.0
    tcp6       0      0 :::36691                :::*                    LISTEN      1002       34928      2957/io.yahka.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15359      388/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          461        1/init
    udp        0      0 0.0.0.0:49713           0.0.0.0:*                           103        21429      955/rpc.statd
    udp        0      0 127.0.0.1:707           0.0.0.0:*                           0          21425      955/rpc.statd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       34929      2957/io.yahka.0
    udp        0      0 192.168.200.5:5353      0.0.0.0:*                           1002       33816      2601/io.tr-064.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1002       31866      2541/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1002       32978      2616/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1002       32979      2616/io.tuya.0
    udp6       0      0 :::44779                :::*                                103        21433      955/rpc.statd
    udp6       0      0 :::111                  :::*                                0          12720      1/init
    2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at node:internal/main/run_main_module:28:49
    2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]: Node.js v18.19.0
    2024-01-07 10:11:10.439  - error: host.iobroker-master instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-07 10:11:10.439  - info: host.iobroker-master Restart adapter system.adapter.info.0 because enabled
    2024-01-07 10:11:40.510  - info: host.iobroker-master instance system.adapter.info.0 started with pid 3251
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[0]: /bin/sh: 1: npm: not found
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]: 		adapter.log.error("Could not check npm version: " + e);
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]: 		        ^
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-01-07 10:11:40.930  - error: host.iobroker-master Caught by controller[1]:     at node:internal/main/run_main_module:28:49
    2024-01-07 10:11:40.930  - error: host.iobroker-master Caught by controller[1]: Node.js v18.19.0
    2024-01-07 10:11:40.930  - error: host.iobroker-master instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-07 10:11:40.930  - info: host.iobroker-master Restart adapter system.adapter.info.0 because enabled
    iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
    *Wer freundlich ist, dem wird freundlich geholfen *
    Thomas BraunT R HomoranH 3 Antworten Letzte Antwort
    • R reutli
      Hallo Leute,
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      admin
      /home/admin
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
               5924 M total memory
               3315 M used memory
                265 M active memory
               2264 M free memory
                 70 M buffer memory
                532 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      576M	/var/
      268M	/var/cache
      260M	/var/cache/apt
      171M	/var/lib
      USB-Devices by-id:
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.12.0
      javascript: 	7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	15902
      States: 	13503
      Pending Updates: 0
      Thomas BraunT Offline
      @reutli
      Schau in die Ankündigungen. Dein Problem ist da festgetackert. Du hast die dfsg-Version am Wickel.
      R 1 Antwort Letzte Antwort
      • R reutli
        Hallo Leute,
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        admin
        /home/admin
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
                 5924 M total memory
                 3315 M used memory
                  265 M active memory
                 2264 M free memory
                   70 M buffer memory
                  532 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        *** FILESYSTEM ***
        /var:
        576M	/var/
        268M	/var/cache
        260M	/var/cache/apt
        171M	/var/lib
        USB-Devices by-id:
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.12.0
        javascript: 	7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	15902
        States: 	13503
        Pending Updates: 0
        reutli
        Im debug gibt's leider auch nicht mehr:
        	2024-01-07 10:34:03.709	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: Node.js v18.19.0
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: at node:internal/main/run_main_module:28:49
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1013:12)
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1197:32)
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: ^
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
        	2024-01-07 10:34:03.709	error	Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
        	2024-01-07 10:34:03.709	error	Caught by controller[0]: /bin/sh: 1: npm: not found
        @Thomas-Braun : Habe mal im Forum gesucht aber nichts gefunden, was darauf hinweist.
        passt nicht zu
        admin@iobroker-master:~$ nodejs -v
        v18.19.0
          @reutli
          reutli
          Mist, danke. Ich schau.
          • R reutli
            @reutli
            https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
            • R reutli
              Hallo Leute,
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Chassis: vm 🖴
                Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 4
                            NTP service: active
                        RTC in local TZ: no
              admin
              /home/admin
              X-Server: 	false
              Desktop:
              Terminal: 	tty
              *** MEMORY ***
              Swap:           1.0G          0B        1.0G
                       5924 M total memory
                       3315 M used memory
                        265 M active memory
                       2264 M free memory
                         70 M buffer memory
                        532 M swap cache
                        974 M total swap
                          0 M used swap
                        974 M free swap
              *** FILESYSTEM ***
              /var:
              576M	/var/
              268M	/var/cache
              260M	/var/cache/apt
              171M	/var/lib
              USB-Devices by-id:
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.12.0
              javascript: 	7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	15902
              States: 	13503
              Pending Updates: 0
              @reutli sagte in error Caught by controller[1] nach apt full-upgrade:
              @Thomas-Braun war schneller
                reutli
                @homoran & @Thomas-Braun
                Danke, hat geklappt!
