  4. [gelöst] Node-Red Update auf v5.0.0 | Error
    6.1k
8 Beiträge 2 Kommentatoren 1.0k Aufrufe 2 Beobachtet
  • DillioD Offline
    DillioD Offline
    Dillio
    schrieb am zuletzt editiert von Dillio
    beim Update des Adapters Node-Red auf die Version 5.0.0 erhalte ich folgende Fehlermeldung:
    pi@iobroker-slave:~ $ iobroker upgrade node-red --debug
    This upgrade of "node-red" will introduce the following changes:
    -> 5.0.0:
    *NodeJS 16.4.x is required**
    *Please check instance configuration and re-enter your passwords (encryption has changed).**
    Updated Node-RED to 3.1.0. Please check your nodes for compatibility!
    Admin 5/6 JSON config for instance configuration
    Added sendTo node with callback
    Allow custom attribute name for "ioBroker in" node
    Added option to select editor (monaco, ace)
    Added table for custom env vars to instance configuration
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade node-red from @4.0.3 to @5.0.0 now? [(y)es, (n)o]: y
    Update node-red from @4.0.3 to @5.0.0
    host.iobroker-slave Adapter "system.adapter.node-red.0" is stopped.
    NPM version: 9.6.7
    Installing iobroker.node-red@5.0.0... (System call)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/bcrypt
    npm ERR! command failed
    npm ERR! command sh -c node-pre-gyp install --fallback-to-build
    npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
    npm ERR! node-pre-gyp info it worked if it ends with ok
    npm ERR! node-pre-gyp info using node-pre-gyp@1.0.11
    npm ERR! node-pre-gyp info using node@18.17.1 | linux | arm
    npm ERR! node-pre-gyp info check checked for "/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node" (not found)
    npm ERR! node-pre-gyp http GET https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
    npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
    npm ERR! node-pre-gyp WARN Pre-built binaries not installable for bcrypt@5.1.1 and node@18.17.1 (node-v108 ABI, glibc) (falling back to source compile with node-gyp)
    npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
    npm ERR! node:internal/modules/cjs/loader:1080
    npm ERR!   throw err;
    npm ERR!   ^
    npm ERR!
    npm ERR! Error: Cannot find module 'code-point-at'
    npm ERR! Require stack:
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/string-width/index.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/wide-truncate.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/render-template.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/plumbing.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/index.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/lib/log.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
    npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
    npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    npm ERR!     at Module._load (node:internal/modules/cjs/loader:922:27)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19)
    npm ERR!     at require (node:internal/modules/cjs/helpers:121:18)
    npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/string-width/index.js:3:19)
    npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    npm ERR!     at Module.load (node:internal/modules/cjs/loader:1119:32)
    npm ERR!     at Module._load (node:internal/modules/cjs/loader:960:12)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1143:19) {
    npm ERR!   code: 'MODULE_NOT_FOUND',
    npm ERR!   requireStack: [
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/string-width/index.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/wide-truncate.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/render-template.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/plumbing.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/lib/index.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/lib/log.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
    npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
    npm ERR!   ]
    npm ERR! }
    npm ERR!
    npm ERR! Node.js v18.17.1
    npm ERR! node-pre-gyp ERR! build error
    npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js clean' (1)
    npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
    npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
    npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1091:16)
    npm ERR! node-pre-gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
    npm ERR! node-pre-gyp ERR! System Linux 5.10.103-v7l+
    npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/bcrypt
    npm ERR! node-pre-gyp ERR! node -v v18.17.1
    npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.11
    npm ERR! node-pre-gyp ERR! not ok
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-28T18_08_00_752Z-debug-0.log
    upload [15] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
    upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    host.iobroker-slave Adapter "system.adapter.node-red.0" is started
    Ich kann damit leider nichts anfangen. Kann mir jemad helfen?
    • DillioD Dillio
      -> 5.0.0:
      NPM version: 9.6.7
      npm ERR! code 1
      npm ERR!   throw err;
      npm ERR!   ^
      npm ERR!
      npm ERR!   ]
      npm ERR! }
      npm ERR!
      @dillio
      Offenbar ist dein nodejs zu alt.
      iob nodejs-update
      DillioD 1 Antwort Letzte Antwort
        @dillio
        iob nodejs-update
        DillioD Offline
        DillioD Offline
        Dillio
        Laut System nicht:
        pi@iobroker-slave:~ $ nodejs -v
        v18.17.1
        • DillioD Dillio
          Laut System nicht:
          v18.17.1
          @dillio
          Trotzdem nicht die aktuelle Version.
            @dillio
            DillioD Offline
            DillioD Offline
            Dillio
            Wie bereits geschrieben, das System sagt was anderes:
            Es wird mir auch kein Update hierfür angezeigt. Welche Version sollte es denn sein?
            • DillioD Dillio
              @dillio
              18.18.2
              Update wie oben geschrieben
                @dillio
                18.18.2
                DillioD Offline
                DillioD Offline
                Dillio
                Du hattest Recht. Lag tatsächlich an der veralteten Nodejs Version. Ich habe es nach deiner Anleitung nochmal frisch neu installiert und dann ging es. Merkwürdig finde ich es aber trotzdem, dass mir dafür kein Update gezeigt wurde.
                Naja, nun funktioniert wieder alles, danke! :-)
                • DillioD Dillio
                  @dillio sagte in Node-Red Update auf v5.0.0 | Error:
                  Da war noch das veraltete Repository aktiv.
                  Aktuelles kommt nur noch über das aktuelle Repo rein.
