  4. Raspi 4 bootet extrem langsam
6 Beiträge 2 Kommentatoren 731 Aufrufe 2 Beobachtet
    stoffel67
    Hallo, habe ein Raspi 4 mir 4gB RAm und 256 GB SSD an USB.
    das Ding bootet so langsam, dauert ewig bis ioBroker dann mal startet.
    Ich hab wenig Ahnung, vlt. kann mal ein Wissender auf das log schauen… ist ein log von „dmesg“.
    was kann da schief laufen?
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.10.103-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:24:00 GMT 2022
    [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    [    0.000000] random: fast init done
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [    0.000000]   Normal   empty
    [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
    [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
    [    0.000000] On node 0 totalpages: 1012480
    [    0.000000]   DMA zone: 1728 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 815872 pages, LIFO batch:63
    [    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
    [    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010752
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x1024M@60 smsc95xx.macaddr=DC:A6:32:45:C1:49 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a4b718ee-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                   Please use sysfs to set IO scheduler for individual devices.
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
    [    0.000000] Memory: 3600116K/4049920K available (10240K kernel code, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 122124K reserved, 327680K cma-reserved, 3263488K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 34355 entries in 101 pages
    [    0.000000] ftrace: allocated 101 pages with 4 groups
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] 	Rude variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
    [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
    [    0.000027] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
    [    0.000090] bcm2835: system timer (irq = 25)
    [    0.000739] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [    0.000757] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [    0.000776] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [    0.000790] Switching to timer-based delay loop, resolution 18ns
    [    0.001053] Console: colour dummy device 80x30
    [    0.001125] printk: console [tty1] enabled
    [    0.001177] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [    0.001211] pid_max: default: 32768 minimum: 301
    [    0.001377] LSM: Security Framework initializing
    [    0.001565] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.001591] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.003080] cgroup: Disabling memory control group subsystem
    [    0.003314] CPU: Testing write buffer coherency: ok
    [    0.003793] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.005014] Setting up static identity map for 0x200000 - 0x20003c
    [    0.005212] rcu: Hierarchical SRCU implementation.
    [    0.006136] smp: Bringing up secondary CPUs ...
    [    0.007368] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.008755] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.010064] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.010240] smp: Brought up 1 node, 4 CPUs
    [    0.010262] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [    0.010277] CPU: All CPU(s) started in HYP mode.
    [    0.010291] CPU: Virtualization extensions available.
    [    0.011266] devtmpfs: initialized
    [    0.025802] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [    0.026041] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.026073] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.034362] pinctrl core: initialized pinctrl subsystem
    [    0.035461] NET: Registered protocol family 16
    [    0.039556] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.040305] audit: initializing netlink subsys (disabled)
    [    0.040577] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
    [    0.041213] thermal_sys: Registered thermal governor 'step_wise'
    [    0.042032] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.042050] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.042473] Serial: AMBA PL011 UART driver
    [    0.076210] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [    0.090856] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-05-09T12:16:34, variant start
    [    0.100868] raspberrypi-firmware soc:firmware: Firmware hash is 30aa0d70ab280427ba04ebc718c81d4350b9d394
    [    0.142009] Kprobes globally optimized
    [    0.147484] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [    0.151725] vgaarb: loaded
    [    0.152197] SCSI subsystem initialized
    [    0.152426] usbcore: registered new interface driver usbfs
    [    0.152487] usbcore: registered new interface driver hub
    [    0.152575] usbcore: registered new device driver usb
    [    0.152929] usb_phy_generic phy: supply vcc not found, using dummy regulator
    [    0.154999] clocksource: Switched to clocksource arch_sys_counter
    [    1.101946] VFS: Disk quotas dquot_6.6.0
    [    1.102040] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.102207] FS-Cache: Loaded
    [    1.102424] CacheFiles: Loaded
    [    1.103462] simple-framebuffer 3e5c3000.framebuffer: framebuffer at 0x3e5c3000, 0x500000 bytes, mapped to 0x(ptrval)
    [    1.103482] simple-framebuffer 3e5c3000.framebuffer: format=a8r8g8b8, mode=1280x1024x32, linelength=5120
    [    1.103963] Console: switching to colour frame buffer device 160x64
    [    1.110505] simple-framebuffer 3e5c3000.framebuffer: fb0: simplefb registered!
    [    1.120965] NET: Registered protocol family 2
    [    1.121233] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    1.122737] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    1.122779] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    1.122844] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    1.122916] TCP: Hash tables configured (established 8192 bind 8192)
    [    1.123086] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.123123] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    1.123357] NET: Registered protocol family 1
    [    1.124146] RPC: Registered named UNIX socket transport module.
    [    1.124163] RPC: Registered udp transport module.
    [    1.124178] RPC: Registered tcp transport module.
    [    1.124193] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.124216] PCI: CLS 0 bytes, default 64
    [    1.127833] Initialise system trusted keyrings
    [    1.128083] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [    1.136564] zbud: loaded
    [    1.138355] FS-Cache: Netfs 'nfs' registered for caching
    [    1.139107] NFS: Registering the id_resolver key type
    [    1.139150] Key type id_resolver registered
    [    1.139166] Key type id_legacy registered
    [    1.139317] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.139334] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    1.140393] Key type asymmetric registered
    [    1.140411] Asymmetric key parser 'x509' registered
    [    1.140605] bounce: pool size: 64 pages
    [    1.140667] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    1.140881] io scheduler mq-deadline registered
    [    1.140899] io scheduler kyber registered
    [    1.145612] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    1.145645] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [    1.145727] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
    [    1.145816] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
    [    1.187160] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
    [    1.187552] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    1.187574] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.187595] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
    [    1.187688] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    1.187933] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    1.191450] PCI: bus0: Fast back to back transfers disabled
    [    1.191475] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    1.191851] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    1.191979] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    1.192414] pci 0000:01:00.0: PME# supported from D0 D3cold
    [    1.195943] PCI: bus1: Fast back to back transfers disabled
    [    1.195965] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    1.196010] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    1.196034] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [    1.196117] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    1.196143] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    1.196575] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    1.196808] pcieport 0000:00:00.0: PME: Signaling with IRQ 64
    [    1.205988] iproc-rng200 fe104000.rng: hwrng registered
    [    1.206304] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
    [    1.207199] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [    1.219597] brd: module loaded
    [    1.232173] loop: module loaded
    [    1.233997] Loading iSCSI transport class v2.0-870.
    [    1.239043] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [    1.335185] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [    1.336396] usbcore: registered new interface driver r8152
    [    1.336467] usbcore: registered new interface driver lan78xx
    [    1.336540] usbcore: registered new interface driver smsc95xx
    [    1.338199] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
    [    1.338371] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.338407] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [    1.341966] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
    [    1.343318] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    1.343338] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.343356] usb usb1: Product: xHCI Host Controller
    [    1.343372] usb usb1: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
    [    1.343389] usb usb1: SerialNumber: 0000:01:00.0
    [    1.344135] hub 1-0:1.0: USB hub found
    [    1.344236] hub 1-0:1.0: 1 port detected
    [    1.344914] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.344941] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [    1.344967] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    1.345555] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [    1.345574] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.345592] usb usb2: Product: xHCI Host Controller
    [    1.345608] usb usb2: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
    [    1.345624] usb usb2: SerialNumber: 0000:01:00.0
    [    1.346357] hub 2-0:1.0: USB hub found
    [    1.346441] hub 2-0:1.0: 4 ports detected
    [    1.348208] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    1.348536] dwc_otg: FIQ enabled
    [    1.348551] dwc_otg: NAK holdoff enabled
    [    1.348566] dwc_otg: FIQ split-transaction FSM enabled
    [    1.348585] Module dwc_common_port init
    [    1.349037] usbcore: registered new interface driver uas
    [    1.349160] usbcore: registered new interface driver usb-storage
    [    1.349365] mousedev: PS/2 mouse device common for all mice
    [    1.351077] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    1.354488] sdhci: Secure Digital Host Controller Interface driver
    [    1.354506] sdhci: Copyright(c) Pierre Ossman
    [    1.355287] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    1.355903] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.360123] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.360467] hid: raw HID events driver (C) Jiri Kosina
    [    1.360677] usbcore: registered new interface driver usbhid
    [    1.360692] usbhid: USB HID core driver
    [    1.366896] Initializing XFRM netlink socket
    [    1.366942] NET: Registered protocol family 17
    [    1.367090] Key type dns_resolver registered
    [    1.367560] Registering SWP/SWPB emulation handler
    [    1.367754] registered taskstats version 1
    [    1.367797] Loading compiled-in X.509 certificates
    [    1.368683] Key type ._fscrypt registered
    [    1.368701] Key type .fscrypt registered
    [    1.368716] Key type fscrypt-provisioning registered
    [    1.380296] uart-pl011 fe201000.serial: there is not valid maps for state default
    [    1.380601] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [    1.380678] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
    [    1.387625] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [    1.388680] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    1.388697] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    1.419056] of_cfs_init
    [    1.419330] of_cfs_init: OK
    [    1.426610] mmc1: Controller never released inhibit bit(s).
    [    1.450400] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    1.452089] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.453776] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.457224] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    1.458928] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.466586] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
    [    1.467266] Waiting for root device PARTUUID=a4b718ee-02...
    [    1.528030] mmc1: new high speed SDIO card at address 0001
    [    1.625041] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    1.807666] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [    1.807686] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    1.807704] usb 1-1: Product: USB2.0 Hub
    [    1.809599] hub 1-1:1.0: USB hub found
    [    1.809916] hub 1-1:1.0: 4 ports detected
    [    1.955389] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    [    1.987034] usb 2-2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 2.09
    [    1.987053] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    1.987071] usb 2-2: Product: USB to ATA/ATAPI Bridge
    [    1.987088] usb 2-2: Manufacturer: JMicron
    [    1.987105] usb 2-2: SerialNumber: 0123456789ABCDEF
    [    2.011482] scsi host0: uas
    [    2.012968] scsi 0:0:0:0: Direct-Access     JMicron  Generic          0209 PQ: 0 ANSI: 6
    [    2.015803] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
    [    2.015823] sd 0:0:0:0: [sda] 4096-byte physical blocks
    [    2.016172] sd 0:0:0:0: [sda] Write Protect is off
    [    2.016192] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
    [    2.016661] sd 0:0:0:0: [sda] Disabling FUA
    [    2.016682] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [    2.017489] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
    [    2.021048]  sda: sda1 sda2
    [    2.024847] sd 0:0:0:0: [sda] Attached SCSI disk
    [    2.049722] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [    2.049740] EXT4-fs (sda2): write access will be enabled during recovery
    [    2.083670] EXT4-fs (sda2): recovery complete
    [    2.085750] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.085838] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [    2.087042] devtmpfs: mounted
    [    2.097311] Freeing unused kernel memory: 2048K
    [    2.097638] Run /sbin/init as init process
    [    2.097652]   with arguments:
    [    2.097667]     /sbin/init
    [    2.097681]     splash
    [    2.097695]   with environment:
    [    2.097710]     HOME=/
    [    2.097725]     TERM=linux
    [    2.135073] usb 1-1.3: new low-speed USB device number 3 using xhci_hcd
    [    2.277499] usb 1-1.3: New USB device found, idVendor=03f0, idProduct=0024, bcdDevice= 3.00
    [    2.277521] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [    2.277538] usb 1-1.3: Product: HP Basic USB Keyboard
    [    2.277554] usb 1-1.3: Manufacturer: CHICONY
    [    2.292399] input: CHICONY HP Basic USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:03F0:0024.0001/input/input0
    [    2.356631] hid-generic 0003:03F0:0024.0001: input,hidraw0: USB HID v1.10 Keyboard [CHICONY HP Basic USB Keyboard] on usb-0000:01:00.0-1.3/input0
    [    2.416791] systemd[1]: System time before build time, advancing clock.
    [    2.455136] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
    [    2.495084] NET: Registered protocol family 10
    [    2.496521] Segment Routing with IPv6
    [    2.546293] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    2.547195] systemd[1]: Detected architecture arm.
    [    2.586911] systemd[1]: Set hostname to <raspberrypi>.
    [    2.623793] usb 1-1.4: New USB device found, idVendor=413c, idProduct=3200, bcdDevice=29.10
    [    2.623816] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [    2.623834] usb 1-1.4: Product: Dell USB Mouse
    [    2.623852] usb 1-1.4: Manufacturer: Dell
    [    2.636895] input: Dell Dell USB Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:413C:3200.0002/input/input1
    [    2.637711] hid-generic 0003:413C:3200.0002: input,hidraw1: USB HID v1.10 Mouse [Dell Dell USB Mouse] on usb-0000:01:00.0-1.4/input0
    [    3.329598] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.340353] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.340449] systemd[1]: Reached target Swap.
    [    3.340930] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.341873] systemd[1]: Listening on Journal Socket.
    [    3.350136] systemd[1]: Starting Set the console keyboard layout...
    [    3.358673] systemd[1]: Starting Restore / save the current clock...
    [    3.360908] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [    3.361696] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.369565] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.569907] i2c /dev entries driver
    [    3.579423] Driver for 1-wire Dallas network protocol.
    [    4.227001] EXT4-fs (sda2): re-mounted. Opts: (null)
    [    4.321208] systemd-journald[127]: Received request to flush runtime journal from PID 1
    [    4.923491] gpio-4 (onewire@4): enforced open drain please flag it properly in DT/ACPI DSDT/board file
    [    4.966200] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [    4.966858] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [    4.967412] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [    4.968000] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [    5.136549] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    5.142644] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [    5.146364] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    5.146391] [vc_sm_connected_init]: start
    [    5.164500] mc: Linux media interface: v0.10
    [    5.186017] [vc_sm_connected_init]: installed successfully
    [    5.206640] bcm2835_audio bcm2835_audio: card created with 4 channels
    [    5.291975] videodev: Linux video capture interface: v2.00
    [    5.327247] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    5.330090] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    5.333247] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    5.339587] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [    5.343611] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [    5.365948] checking generic (3e5c3000 500000) vs hw (0 ffffffffffffffff)
    [    5.365969] fb0: switching to vc4drmfb from simple
    [    5.375241] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [    5.375548] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [    5.376599] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [    5.377082] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [    5.377483] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [    5.377510] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [    5.377533] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [    5.377553] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [    5.377575] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [    5.377798] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [    5.378832] Console: switching to colour dummy device 80x30
    [    5.406478] bcm2835_audio bcm2835_audio: card created with 4 channels
    [    5.502866] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [    5.515404] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
    [    5.519339] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    5.570920] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    5.577502] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    5.577544] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    5.581240] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
    [    5.593341] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    5.593380] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    5.608280] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    5.608338] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    5.619708] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
    [    5.619749] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
    [    5.645197] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [    5.664475] brcmfmac: F1 signature read @0x18000000=0x15264345
    [    5.717428] Console: switching to colour frame buffer device 160x64
    [    5.734106] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    5.744289] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
    [    5.744694] usbcore: registered new interface driver brcmfmac
    [    5.855585] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
    [    6.015821] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    6.021254] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
    [    7.632319] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
    [    7.832995] random: crng init done
    [    7.833009] random: 7 urandom warning(s) missed due to ratelimiting
    [    8.343034] uart-pl011 fe201000.serial: no DMA platform data
    [   31.835061] vcc-sd: disabling
    [   38.895051] sd 0:0:0:0: [sda] tag#28 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD IN
    [   38.895073] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 00 1e 68 90 00 00 20 00
    [   38.895400] sd 0:0:0:0: [sda] tag#27 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
    [   38.895417] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 00 09 47 78 00 00 08 00
    [   38.895631] sd 0:0:0:0: [sda] tag#26 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD IN
    [   38.895646] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 00 0c 2f b0 00 00 08 00
    [   38.896041] sd 0:0:0:0: [sda] tag#25 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
    [   38.896056] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 01 50 d6 00 00 00 20 00
    [   38.896490] sd 0:0:0:0: [sda] tag#24 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD IN
    [   38.896505] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 01 04 23 50 00 01 00 00
    [   38.897423] sd 0:0:0:0: [sda] tag#23 uas_eh_abort_handler 0 uas-tag 11 inflight: CMD IN
    [   38.897438] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 00 09 72 08 00 00 08 00
    [   38.897689] sd 0:0:0:0: [sda] tag#22 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD IN
    [   38.897705] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 00 16 ac 10 00 01 00 00
    [   38.898726] sd 0:0:0:0: [sda] tag#21 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
    [   38.898741] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 03 ed 2d a8 00 01 00 00
    [   38.899660] sd 0:0:0:0: [sda] tag#20 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
    [   38.899674] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 00 16 a8 d8 00 01 00 00
    [   38.900668] sd 0:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD IN
    [   38.900683] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 00 0c 40 b8 00 00 08 00
    [   38.900965] sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD IN
    [   38.900980] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 08 49 27 08 00 00 08 00
    [   40.175053] sd 0:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 12 inflight: CMD OUT
    [   40.175074] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x2a 2a 00 00 38 20 00 00 00 08 00
    [   58.320100] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c
    [   58.334094] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
    [   63.855061] sd 0:0:0:0: [sda] tag#3 uas_eh_abort_handler 0 uas-tag 13 inflight: CMD IN
    [   63.855082] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 07 32 64 00 00 01 00 00
    [   67.455042] sd 0:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 14 inflight: CMD OUT
    [   67.455061] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x2a 2a 00 00 0c 27 98 00 00 08 00
    [   67.515116] scsi host0: uas_eh_device_reset_handler start
    [   67.666342] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    [   67.701754] scsi host0: uas_eh_device_reset_handler success
    [   68.085587] 8021q: 802.1Q VLAN Support v1.8
    [   68.325379] Adding 1048572k swap on /var/swap.  Priority:-2 extents:1 across:1048572k FS
    [   68.631465] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    [   69.156288] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    [   69.157665] bcmgenet fd580000.ethernet eth0: Link is Down
    [   71.275247] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
    [   71.275285] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   99.695036] sd 0:0:0:0: [sda] tag#9 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD IN
    [   99.695053] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 00 89 31 80 00 00 08 00
    [   99.695194] sd 0:0:0:0: [sda] tag#8 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
    [   99.695208] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 00 09 28 90 00 00 08 00
    [   99.695500] sd 0:0:0:0: [sda] tag#6 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
    [   99.695514] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 00 09 73 b0 00 00 08 00
    [   99.695856] sd 0:0:0:0: [sda] tag#5 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
    [   99.695869] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 07 21 d4 90 00 01 00 00
    [   99.696787] sd 0:0:0:0: [sda] tag#4 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD IN
    [   99.696800] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 00 44 80 e0 00 00 20 00
    [  101.375034] sd 0:0:0:0: [sda] tag#10 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD IN
    [  101.375051] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 00 09 c3 78 00 00 08 00
    [  104.095033] sd 0:0:0:0: [sda] tag#12 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD OUT
    [  104.095050] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x2a 2a 00 00 38 21 60 00 02 30 00
    [  104.095539] sd 0:0:0:0: [sda] tag#11 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD IN
    [  104.095552] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 01 d4 c1 10 00 00 18 00
    [  104.355029] sd 0:0:0:0: [sda] tag#13 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD IN
    [  104.355045] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 00 43 6f e8 00 00 20 00
    [  121.919615] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46
    [  121.927043] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
    [  129.775046] sd 0:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD
    [  129.775065] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
    [  129.815125] scsi host0: uas_eh_device_reset_handler start
    [  129.966172] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    [  130.001031] scsi host0: uas_eh_device_reset_handler success
    [  132.158181] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    [  161.775034] sd 0:0:0:0: [sda] tag#19 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
    [  161.775054] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 07 22 2b b0 00 01 00 00
    [  161.775855] sd 0:0:0:0: [sda] tag#16 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
    [  161.775869] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 00 09 24 60 00 00 08 00
    [  161.776191] sd 0:0:0:0: [sda] tag#10 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
    [  161.776204] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 00 23 a5 50 00 00 20 00
    [  161.776636] sd 0:0:0:0: [sda] tag#9 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
    [  161.776649] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 00 14 e6 60 00 00 58 00
    [  162.575034] sd 0:0:0:0: [sda] tag#17 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD IN
    [  162.575051] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 06 08 20 08 00 00 08 00
    [  165.455042] sd 0:0:0:0: [sda] tag#28 uas_eh_abort_handler 0 uas-tag 21 inflight: CMD OUT
    [  165.455062] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x2a 2a 00 00 08 2b 88 00 00 08 00
    [  165.455377] sd 0:0:0:0: [sda] tag#27 uas_eh_abort_handler 0 uas-tag 19 inflight: CMD OUT
    [  165.455392] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x2a 2a 00 00 08 2b 30 00 00 08 00
    [  165.455719] sd 0:0:0:0: [sda] tag#26 uas_eh_abort_handler 0 uas-tag 18 inflight: CMD OUT
    [  165.455734] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x2a 2a 00 00 08 2a 60 00 00 08 00
    [  165.456065] sd 0:0:0:0: [sda] tag#25 uas_eh_abort_handler 0 uas-tag 17 inflight: CMD OUT
    [  165.456080] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x2a 2a 00 00 08 2a 18 00 00 08 00
    [  165.456406] sd 0:0:0:0: [sda] tag#24 uas_eh_abort_handler 0 uas-tag 20 inflight: CMD OUT
    [  165.456421] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x2a 2a 00 00 08 2b 78 00 00 08 00
    [  165.456752] sd 0:0:0:0: [sda] tag#23 uas_eh_abort_handler 0 uas-tag 16 inflight: CMD OUT
    [  165.456767] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x2a 2a 00 00 08 29 e8 00 00 08 00
    [  165.457097] sd 0:0:0:0: [sda] tag#22 uas_eh_abort_handler 0 uas-tag 15 inflight: CMD OUT
    [  165.457111] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x2a 2a 00 00 08 29 18 00 00 08 00
    [  165.457445] sd 0:0:0:0: [sda] tag#21 uas_eh_abort_handler 0 uas-tag 14 inflight: CMD OUT
    [  165.457460] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x2a 2a 00 00 08 28 d0 00 00 08 00
    [  165.457788] sd 0:0:0:0: [sda] tag#20 uas_eh_abort_handler 0 uas-tag 13 inflight: CMD OUT
    [  165.457803] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x2a 2a 00 00 08 27 18 00 00 10 00
    [  165.458132] sd 0:0:0:0: [sda] tag#18 uas_eh_abort_handler 0 uas-tag 12 inflight: CMD OUT
    [  165.458147] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x2a 2a 00 00 08 26 f0 00 00 08 00
    [  165.458487] sd 0:0:0:0: [sda] tag#15 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD OUT
    [  165.458501] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x2a 2a 00 05 a4 20 50 00 00 10 00
    [  165.458854] sd 0:0:0:0: [sda] tag#14 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD OUT
    [  165.458868] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x2a 2a 00 05 a4 33 18 00 00 10 00
    [  165.459202] sd 0:0:0:0: [sda] tag#13 uas_eh_abort_handler 0 uas-tag 11 inflight: CMD OUT
    [  165.459216] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x2a 2a 00 00 08 20 10 00 00 08 00
    [  165.459535] sd 0:0:0:0: [sda] tag#12 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD OUT
    [  165.459549] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x2a 2a 00 00 af 0f f8 00 00 08 00
    [  165.459885] sd 0:0:0:0: [sda] tag#11 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD OUT
    [  165.459899] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x2a 2a 00 05 a5 4c 40 00 00 10 00
    [  165.460230] sd 0:0:0:0: [sda] tag#8 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD OUT
    [  165.460245] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x2a 2a 00 05 ad 04 40 00 00 18 00
    [  165.460588] sd 0:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 27 inflight: CMD OUT
    [  165.460602] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x2a 2a 00 00 08 ac 78 00 00 08 00
    [  165.460920] sd 0:0:0:0: [sda] tag#6 uas_eh_abort_handler 0 uas-tag 26 inflight: CMD OUT
    [  165.460934] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x2a 2a 00 00 08 ab d8 00 00 08 00
    [  165.461269] sd 0:0:0:0: [sda] tag#5 uas_eh_abort_handler 0 uas-tag 29 inflight: CMD OUT
    [  165.461283] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x2a 2a 00 00 08 b8 90 00 00 10 00
    [  165.461615] sd 0:0:0:0: [sda] tag#4 uas_eh_abort_handler 0 uas-tag 28 inflight: CMD OUT
    [  165.461629] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x2a 2a 00 00 08 b5 68 00 00 08 00
    [  165.461970] sd 0:0:0:0: [sda] tag#3 uas_eh_abort_handler 0 uas-tag 25 inflight: CMD OUT
    [  165.461984] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x2a 2a 00 00 08 2d 98 00 00 08 00
    [  165.462317] sd 0:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 24 inflight: CMD OUT
    [  165.462331] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x2a 2a 00 00 08 2c 68 00 00 08 00
    [  165.462658] sd 0:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 23 inflight: CMD OUT
    [  165.462672] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x2a 2a 00 00 08 2c 58 00 00 08 00
    [  165.463004] sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 22 inflight: CMD OUT
    [  165.463018] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 08 2c 20 00 00 08 00
    [  165.495584] scsi host0: uas_eh_device_reset_handler start
    [  165.655777] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    [  165.689520] scsi host0: uas_eh_device_reset_handler success
    [  172.679937] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c00000000000 crc ca
    [  172.687426] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered.
    [  196.335056] sd 0:0:0:0: [sda] tag#24 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
    [  196.335076] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 08 4c 23 38 00 00 08 00
    [  196.335476] sd 0:0:0:0: [sda] tag#23 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
    [  196.335491] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 01 65 58 20 00 00 e0 00
    [  196.336263] sd 0:0:0:0: [sda] tag#22 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD IN
    [  196.336276] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 07 22 2e 90 00 00 a8 00
    [  196.336846] sd 0:0:0:0: [sda] tag#21 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
    [  196.336859] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 00 20 e5 58 00 00 08 00
    [  196.337098] sd 0:0:0:0: [sda] tag#6 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD OUT
    [  196.337111] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x2a 2a 00 01 4d 40 38 00 00 08 00
    [  196.337622] sd 0:0:0:0: [sda] tag#5 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
    [  196.337635] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 00 14 0d c8 00 01 00 00
    [  196.338618] sd 0:0:0:0: [sda] tag#3 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD IN
    [  196.338631] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 00 42 82 f8 00 00 08 00
    [  202.095137] sd 0:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD OUT
    [  202.095159] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x2a 2a 00 00 38 27 18 00 00 78 00
    [  211.695252] sd 0:0:0:0: [sda] tag#28 uas_eh_abort_handler 0 uas-tag 29 inflight: CMD OUT
    [  211.695267] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x2a 2a 00 01 4d 30 28 00 00 08 00
    [  211.695621] sd 0:0:0:0: [sda] tag#27 uas_eh_abort_handler 0 uas-tag 11 inflight: CMD OUT
    [  211.695632] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x2a 2a 00 05 a4 33 20 00 00 18 00
    [  211.695946] sd 0:0:0:0: [sda] tag#26 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD OUT
    [  211.695956] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x2a 2a 00 06 08 20 18 00 00 08 00
    [  211.696298] sd 0:0:0:0: [sda] tag#25 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD OUT
    [  211.696308] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x2a 2a 00 05 ad 04 50 00 00 18 00
    Mein Adapter: JUNG/GIRA eNet-Adapter
    • S stoffel67
      [    2.097681]     splash
      [    2.097710]     HOME=/
      @stoffel67 sagte in Raspi 4 bootet extrem langsam:
      Da hat es Einschläge auf dem Dateisystem gegeben.
      Weiter unten sind noch mehr Meldungen das Gerät sda betreffend.
      Ich würde sagen, der Datenträger ist Matsch.
        stoffel67
        kan ich da irgendwas „reparieren“. ist eine 256 Gb M.2 SSD?
        neu formatieren oder echt „wegschmeißen“?
        • S stoffel67
          Vermutlich eher nicht.
            stoffel67
            schrieb am zuletzt editiert von stoffel67
            OK, dann werd ich mal neu aufsetzen… neue SSD besorgen…
            welches Image sollte ich für den RP4 nehmen?
            32 bit 64bit, PiOS oder legacy ???? was ist da richtig für ioBroker
            • S stoffel67
              @stoffel67
              64bit - Lite - Bookworm
              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
