  4. IoBroker reagiert nicht mehr
    6.1k
6 Beiträge 2 Kommentatoren 644 Aufrufe 2 Beobachtet
  • C Offline
    Chris-D 0
    schrieb am zuletzt editiert von Chris-D 0
    Mein IOBROKER ist nicht mehr erreichbar.
    Morgens aufgewacht und IOBROKER ist nicht mehr erreichbar.
    IOBROKER FIx hat auch nicht geholfen.
    pi@raspberrypi:~ $ iobroker update
    node:internal/modules/cjs/loader:1031
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15)
        at Function.Module._load (node:internal/modules/cjs/loader:873:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:22:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    IOB Diag Ausgabe wie folgt:
                            v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Installation:           native
    Kernel:                 armv7l
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     30
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob        roker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:1        5)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_ma        in:81:12)
      requireStack: []
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                            /usr/bin/node           v16.20.2
                            /usr/bin/npm            8.19.4
                            /usr/local/bin/npx              7.20.3
                            /usr/bin/corepack       0.17.0
    Recommended versions are nodejs  and npm
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    for more information on how to fix these errors.
    MEMORY:
    Mem:           3.8G         87M        3.3G        8.0M        438M        3.6G
    Swap:           99M          0B         99M
    Total:         3.9G         87M        3.4G
      throw err;
      requireStack: []
    Active iob-Instances:   0
      throw err;
      requireStack: []
      throw err;
      requireStack: []
    ioBroker Core:          js-controller
      throw err;
      requireStack: []
                            admin
      throw err;
      requireStack: []
    ioBroker Status:
      throw err;
      requireStack: []
    Objects:                0
    States:                 0
    Size of iob-Database:
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    7.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    7.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    0       /opt/iobroker/iobroker-data/objects.json.broken
    8.1M    /opt/iobroker/iobroker-data/states.jsonl
    1020K   /opt/iobroker/iobroker-data/states.json.migrated
    1020K   /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    Was kann ich machen?
    • C Chris-D 0
        throw err;
        requireStack: []
                              v.2023-10-10
               Icon name: computer
            Architecture: arm
      Kernel:                 armv7l
      Userland:               armhf
      User-ID:                1000
      X-Server:               false
        throw err;
        requireStack: []
                              /usr/bin/npm            8.19.4
      Please check
      MEMORY:
      Swap:           99M          0B         99M
        throw err;
        requireStack: []
        throw err;
        requireStack: []
        throw err;
        requireStack: []
        throw err;
        requireStack: []
                              admin
        throw err;
        requireStack: []
      ioBroker Status:
        throw err;
        requireStack: []
      Objects:                0
      States:                 0
      @chris-d-0
      (buster)
      Tot, installier da ein lebendiges Release.
      In der 64Bit-Lite-Version.
      Update-Stau, nodejs&Co. falsch installiert...
      C 1 Antwort Letzte Antwort
        @chris-d-0
        (buster)
        Chris-D 0
        @thomas-braun Danke für den Hinweis. Wie genau mache ich das?
        • C Chris-D 0
          @chris-d-0
          Neuinstallation?
          Mit dem Raspberry OS Imager.
          Danach halt Backup des ioBroker einspielen.
            @chris-d-0
            Neuinstallation?
            Chris-D 0
            @thomas-braun Kompletter PI? Habe noch mehr darauf laufen...
            Gibt es keine Alternative?
            • C Chris-D 0
              @chris-d-0
              Buster ist TOT.
              'nuff said. .
              Fur das was da sonst noch läuft hast du ja auch eine Backup-Strategie.
