  4. Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    5.1k
6 Beiträge 2 Kommentatoren 2.0k Aufrufe 2 Beobachtet
    paul01
    Hallo liebe comunity!
    seit dem letzten Neustart des PIs startet der iobroker nicht mehr. Folgenden Status liefert er:
    pi@iobroker:~ $ iobroker status
    Uncaught Rejection: Error: Cannot find module 'source-map'
    Require stack:
    - /opt/iobroker/node_modules/source-map-support/source-map-support.js
    - /opt/iobroker/node_modules/@iobroker/plugin-sentry/index.js
    - /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginHandler.js
    - /opt/iobroker/node_modules/@iobroker/plugin-base/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
        at Function.Module._load (node:internal/modules/cjs/loader:841:27)
        at Module.require (node:internal/modules/cjs/loader:1067:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/source-map-support/source-map-support.js:1:25)
        at Module._compile (node:internal/modules/cjs/loader:1165:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        at Module.load (node:internal/modules/cjs/loader:1043:32)
        at Function.Module._load (node:internal/modules/cjs/loader:878:12)
    kann mir hier jemand weiterhelfen?
    Danke!
    Paul
    • P paul01
      Require stack:
      Danke!
      Paul
      @paul01
      iob diag
      sagt? In der Langfassung.
      P 1 Antwort Letzte Antwort
        @paul01
        iob diag
        paul01
        ======== Start marking the full check here =========
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         14:09:39 up 44 min,  1 user,  load average: 0.76, 0.93, 1.03
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2023-10-27 14:09:39 CEST
                   Universal time: Fri 2023-10-27 12:09:39 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CEST, +0200)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G        260M        2.8G         16M        791M        3.5G
        Swap:           99M          0B         99M
        Total:         3.9G        260M        2.9G
                 3838 M total memory
                  260 M used memory
                  395 M active memory
                  490 M inactive memory
                 2786 M free memory
                  171 M buffer memory
                  620 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FAILED SERVICES ***
          UNIT            LOAD   ACTIVE SUB    DESCRIPTION
        * dhcpcd.service  loaded failed failed dhcpcd on all interfaces
        * lightdm.service loaded failed failed Light Display Manager
        2 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       59G   18G   39G  32% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        [Fri Oct 27 13:24:41 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:A6:9D:71 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Fri Oct 27 13:24:42 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Fri Oct 27 13:24:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Oct 27 13:24:44 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems \(real ones only\):
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.1G    /var/
        463M    /var/lib
        304M    /var/cache
        298M    /var/cache/apt
        239M    /var/cache/apt/archives
        Archived and active journals take up 16.0M in the file system.
        /opt/iobroker/backups:
        11G     /opt/iobroker/backups/
        4.0K    /opt/iobroker/backups/influxDB_2022_08_21-02_00_17_backupiobroker
        4.0K    /opt/iobroker/backups/influxDB_2022_08_20-02_00_17_backupiobroker
        4.0K    /opt/iobroker/backups/influxDB_2022_08_19-02_00_17_backupiobroker
        4.0K    /opt/iobroker/backups/influxDB_2022_08_18-02_00_17_backupiobroker
        /opt/iobroker/iobroker-data:
        1.3G    /opt/iobroker/iobroker-data/
        918M    /opt/iobroker/iobroker-data/history
        255M    /opt/iobroker/iobroker-data/files
        105M    /opt/iobroker/iobroker-data/backup-objects
        72M     /opt/iobroker/iobroker-data/files/telegram.admin
        27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
        12M     /opt/iobroker/iobroker-data/objects.jsonl
        7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
        6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
        /dev/serial/by-id/usb-Espressif_USB_JTAG_serial_debug_unit_DC:54:75:BA:43:98-if00
        /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D47D89-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v16.19.0
        /usr/bin/node           v16.19.0
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        /usr/bin/corepack       0.15.1
        nodejs:
          Installed: 16.19.0-deb-1nodesource1
          Candidate: 16.20.2-deb-1nodesource1
          Version table:
             16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         *** 16.19.0-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @buttercup/fetch@0.1.2 /opt/iobroker/node_modules/@buttercup/fetch
        npm ERR! extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
        npm ERR! extraneous: @microsoft/microsoft-graph-types@2.38.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
        npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
        npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
        npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
        npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
        npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
        npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
        npm ERR! extraneous: data-uri-to-buffer@4.0.1 /opt/iobroker/node_modules/data-uri-to-buffer
        npm ERR! extraneous: dropbox-v2-api@2.5.10 /opt/iobroker/node_modules/dropbox-v2-api
        npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
        npm ERR! extraneous: fast-xml-parser@3.21.1 /opt/iobroker/node_modules/fast-xml-parser
        npm ERR! extraneous: fetch-blob@3.2.0 /opt/iobroker/node_modules/fetch-blob
        npm ERR! extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
        npm ERR! extraneous: formdata-polyfill@4.0.10 /opt/iobroker/node_modules/formdata-polyfill
        npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
        npm ERR! extraneous: gaxios@5.1.0 /opt/iobroker/node_modules/gaxios
        npm ERR! extraneous: gcp-metadata@5.2.0 /opt/iobroker/node_modules/gcp-metadata
        npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
        npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
        npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
        npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
        npm ERR! missing: iobroker.backitup@2.6.19, required by iobroker.inst@2.0.3
        npm ERR! invalid: iobroker.flot@1.12.0 /opt/iobroker/node_modules/iobroker.flot
        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
        npm ERR! extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
        npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
        npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
        npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
        npm ERR! extraneous: node-domexception@1.0.0 /opt/iobroker/node_modules/node-domexception
        npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
        npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
        npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/readable-stream
        npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
        npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
        npm ERR! extraneous: web-streams-polyfill@3.2.1 /opt/iobroker/node_modules/web-streams-polyfill
        npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
        npm ERR! extraneous: node-fetch@3.3.2 /opt/iobroker/node_modules/@buttercup/fetch/node_modules/node-fetch
        npm ERR! missing: googleapis-common@^6.0.3, required by @googleapis/drive@5.1.0
        npm ERR! invalid: @iobroker/adapter-core@2.6.0 /opt/iobroker/node_modules/@iobroker/adapter-core
        npm ERR! invalid: axios@0.27.2 /opt/iobroker/node_modules/axios
        npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/iobroker.info/node_modules/form-data
        npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
        npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/readable-stream/node_modules/isarray
        npm ERR! missing: source-map@^0.6.0, required by source-map-support@0.5.21
        npm ERR!     /home/pi/.npm/_logs/2023-10-27T12_09_48_576Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Require stack:
        Core adapters versions
        js-controller:  4.0.23
        admin:          6.12.0
        javascript:     6.1.4
        npm ERR!     /home/pi/.npm/_logs/2023-10-27T12_10_36_692Z-debug-0.log
        Adapters from github:   0
        Adapter State
         States database error: connect ECONNREFUSED 127.0.0.1:9000
         redis get system.host.iobroker.alive, error - Connection is closed.
         redis get system.host.iobroker.plugins.sentry.enabled, error - Connection is closed.
        Require stack:
         Cannot load "redlock_acquire": Connection is closed.
         Cannot load "redlock_extend": Connection is closed.
         Cannot load "redlock_release": Connection is closed.
         Cannot load "script": Connection is closed.
         Cannot initialize database scripts: Cannot load "script" into objects database: Connection is closed.
        Require stack:
        ioBroker-Repositories
        Require stack:
        Installed ioBroker-Instances
        Require stack:
        Objects and States
        Objects:        7
        States:         6
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Get:2 https://repos.influxdata.com/debian buster InRelease [7047 B]
        Hit:3 http://archive.raspberrypi.org/debian buster InRelease
        Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
        Hit:5 https://repo.ebusd.eu/apt/default/buster buster InRelease
        Get:6 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
        Err:2 https://repos.influxdata.com/debian buster InRelease
        Err:6 https://packages.grafana.com/oss/deb stable InRelease
        Fetched 7047 B in 2s (3863 B/s)
        Reading package lists...
        Pending Updates: 140
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17601      624/sshd
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        17656      596/influxd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       93822      10860/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       91866      10860/iobroker.js-c
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16291      626/redis-server 12
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        21054      596/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17603      624/sshd
        tcp6       0      0 :::3000                 :::*                    LISTEN      115        20987      747/grafana-server
        tcp6       0      0 :::3306                 :::*                    LISTEN      114        19459      679/mysqld
        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16292      626/redis-server 12
        udp        0      0 0.0.0.0:49154           0.0.0.0:*                           108        14026      412/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14024      412/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        14025      412/avahi-daemon: r
        udp6       0      0 :::42381                :::*                                108        14027      412/avahi-daemon: r
        Require stack:
        - /opt/iobroker/node_modules/iobroker.js-controller/main.js
        - /opt/iobroker/node_modules/iobroker.js-controller/controller.js
        2023-10-27 14:14:50.816  - error: host.iobroker Error: Cannot find module 'source-map'
        Require stack:
        • P paul01
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : armhf
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M          0B         99M
                   3838 M total memory
                    260 M used memory
                    395 M active memory
                   2786 M free memory
                    171 M buffer memory
                    620 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          1.1G    /var/
          463M    /var/lib
          304M    /var/cache
          298M    /var/cache/apt
          USB-Devices by-id:
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Require stack:
          admin:          6.12.0
          javascript:     6.1.4
          Adapter State
          Require stack:
          Require stack:
          Require stack:
          Require stack:
          Objects and States
          Objects:        7
          States:         6
          Require stack:
          Require stack:
          @paul01
          Buster ist tot, installier da Debian 12 'Bookworm' (64Bit Lite) neu und spiel dann dein Update ein.
          Und das neue System dann besser pflegen. 140 hängende Updates und veraltete Repos zeigen ein versumpftes Ding an.
            @paul01
            paul01
            ich denke das ding ist nun komplett zerschossen, upgrade auf bookworm hat ihm den rest gegeben. danke für deinen support! werde nicht um einen kompletten neustart herumkommen. wie du schreibst, pflege hat in letzter zeit leider sehr gelitten.
            • P paul01
              @paul01
              Ich hatte doch geschrieben, du sollst das NEUinstallieren. Als 64Bit-Version.
