  4. Node-Red
  5. Tasmota Status per HTTP get
    6.4k
2 Beiträge 1 Kommentatoren 3.4k Aufrufe 1 Beobachtet
  • C Offline
    csh-de
    wenn ich im Browser zb: http://192.168.178.142/cm?cmnd=status 10 eingebe kommt:
    {"StatusSNS":{"Time":"2023-09-16T15:15:57","ENERGY":{"TotalStartTime":"2023-08-05T18:04:21","Total":25.429,"Yesterday":0.000,"Today":0.037,"Power":89,"ApparentPower":89,"ReactivePower":0,"Factor":1.00,"Voltage":249,"Current":0.358}}}
    ich schaffe es aber nicht in Red Node abzurufen.
            "id": "9a43fef011b0ad4f",
            "type": "tab",
            "label": "Flow 1",
            "disabled": false,
            "info": "",
            "env": []
            "id": "fc04f069131f9d7c",
            "type": "inject",
            "z": "9a43fef011b0ad4f",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "{\"cmnd\":\"status%2010\"}",
            "payloadType": "json",
            "x": 220,
            "y": 240,
            "wires": [
                    "2d7ed60db535f6cc"
            "id": "2d7ed60db535f6cc",
            "type": "http request",
            "name": "TasmotaSteckdose",
            "method": "GET",
            "ret": "txt",
            "paytoqs": "query",
            "url": "http://192.168.178.142/cm?",
            "tls": "",
            "persist": false,
            "proxy": "",
            "insecureHTTPParser": false,
            "authType": "",
            "senderr": false,
            "headers": [],
            "x": 470,
            "y": 240,
            "wires": [
                    "369334a92691a70f"
            "id": "369334a92691a70f",
            "type": "debug",
            "name": "debug 87",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "statusType": "auto",
            "x": 680,
            "y": 240,
            "wires": []
    Wenn ich es so mache kommt die Antwort für http://192.168.178.142/cm?cmnd=status als würde er das %2010 nicht mit anhängen, wo könnte der Fehler sein?
    C 1 Antwort Letzte Antwort
    • C csh-de
              "type": "tab",
              "label": "Flow 1",
              "disabled": false,
              "info": "",
              "env": []
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "x": 220,
              "y": 240,
              "wires": [
                      "2d7ed60db535f6cc"
              "method": "GET",
              "ret": "txt",
              "paytoqs": "query",
              "tls": "",
              "persist": false,
              "proxy": "",
              "authType": "",
              "senderr": false,
              "headers": [],
              "x": 470,
              "y": 240,
              "wires": [
                      "369334a92691a70f"
              "type": "debug",
              "name": "debug 87",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 680,
              "y": 240,
              "wires": []
      csh-de
      @csh-de
      Fehler erkannt... {"cmnd":"status 10"} muss es sein... also so:
              "type": "tab",
              "label": "Flow 1",
              "disabled": false,
              "info": "",
              "env": []
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "{\"cmnd\":\"status 10\"}",
              "x": 210,
              "y": 240,
              "wires": [
                      "2d7ed60db535f6cc"
              "method": "GET",
              "ret": "txt",
              "paytoqs": "query",
              "tls": "",
              "persist": false,
              "proxy": "",
              "authType": "",
              "senderr": false,
              "headers": [],
              "x": 470,
              "y": 240,
              "wires": [
                      "369334a92691a70f"
              "type": "debug",
              "name": "debug 87",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 680,
              "y": 240,
              "wires": []
