  4. update auf VIS 2 nicht möglich
    3.2k
    3.1k
4 Beiträge 2 Kommentatoren 283 Aufrufe 2 Beobachtet
  • K Offline
    Kellerkind-86
    schrieb am zuletzt editiert von Kellerkind-86
    Hi,ich versuche mich gerade an die VIS 2, leider habe ich die js-controller version "4.0.24".
    denke es liegt daran.
    habe dann NODE.JS auf v16.17.1 geupdatet. aber das ist es ja anscheinend nicht. bitte um Hilfe.
    ERROR: Process exited with code 32 weniger mehr $ iobroker add vis-2 --host raspberrypi NPM version: 8.15.0Installing iobroker.vis-2@2.2.5... (System call) 285 packages are looking for funding run `npm fund` for details host.raspberrypi install adapter vis-2 upload [12] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [11] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [10] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [9] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [8] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [6] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [4] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [1] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/jsonConfig.json jsonConfig.json application/json upload [0] vis-2.admin /opt/iobroker/node_modules/iobroker.vis-2/admin/vis-2.png vis-2.png image/png upload [675] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/asset-manifest.json asset-manifest.json application/json upload [650] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/img/bulbOff.png img/bulbOff.png image/png upload [600] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-hard_100_eeeeee_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-hard_100_eeeeee_1x100.png image/png upload [550] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.min.css text/css upload [500] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_gloss-wave_30_3d3644_500x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_gloss-wave_30_3d3644_500x100.png image/png upload [450] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_dots-medium_80_ffff38_4x4.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_dots-medium_80_ffff38_4x4.png image/png upload [400] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_flat_55_fbec88_40x100.png lib/css/themes/jquery-ui/redmond/images/ui-bg_flat_55_fbec88_40x100.png image/png upload [350] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/start/jquery-ui.min.css lib/css/themes/jquery-ui/start/jquery-ui.min.css text/css upload [300] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-icons_ffd27a_256x240.png lib/css/themes/jquery-ui/ui-lightness/images/ui-icons_ffd27a_256x240.png image/png upload [250] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/material-icons/baseline.json material-icons/baseline.json application/json upload [200] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/static/js/main.c6771b2d.js.map static/js/main.c6771b2d.js.map application/json upload [150] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml upload [100] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml upload [90] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml upload [80] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain upload [60] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/basic/img/Prev_StatefulIFrame8.png widgets/basic/img/Prev_StatefulIFrame8.png image/png upload [50] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/basic/img/Prev_ValueFloatBar.png widgets/basic/img/Prev_ValueFloatBar.png image/png upload [40] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/basic/img/Prev_ValueTimestamp.png widgets/basic/img/Prev_ValueTimestamp.png image/png upload [30] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/basic/img/pin_red5.svg widgets/basic/img/pin_red5.svg image/svg+xml upload [20] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/jqui/img/Prev_ButtonLinkBlank.png widgets/jqui/img/Prev_ButtonLinkBlank.png image/png upload [17] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/jqui/img/Prev_ContainerDialogExternal.png widgets/jqui/img/Prev_ContainerDialogExternal.png image/png upload [15] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/jqui/img/Prev_IconHttpGet.png widgets/jqui/img/Prev_IconHttpGet.png image/png upload [14] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/jqui/img/Prev_IconLink.png widgets/jqui/img/Prev_IconLink.png image/png upload [7] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/swipe/doc.html widgets/swipe/doc.html text/html upload [6] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png upload [2] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/swipe.html widgets/swipe.html text/html upload [0] vis-2 /opt/iobroker/node_modules/iobroker.vis-2/www/widgets/tabs.html widgets/tabs.html text/html host.raspberrypi Invalid version of "js-controller". Installed "4.0.24", required ">=5.0.0" ERROR: Process exited with code 32
    danke
    Gruß Marcell
    • K Kellerkind-86
      danke
      @kellerkind-86 sagte in update auf VIS 2 nicht möglich:
      Vis2 benötigt einen js-controller >=5.0.0.
      Steht auch so in der Meldung.
      Und warum nicht auf die derzeitige Empfehlung v18?
      K 1 Antwort Letzte Antwort
        Kellerkind-86
        @thomas-braun mhmm hab ich anscheinend überlesen.
        Wird jetzt aber geändert aber wie Update ich den js Controller ?😕
        Gruß Marcell
        • K Kellerkind-86
          Wie immer. :-)
          Ich würde das Beta-Repo freischalten. Hast du vermutlich ja eh...
          iob update
          iob stop
          iob upgrade self
          iob start
          Zuvor würde ich aber nodejs@18 installieren. 16 ist im upstream abgekündigt.
