  4. npm ERR! code ETARGET
4 Beiträge 2 Kommentatoren 877 Aufrufe 2 Beobachtet
    majawe
    schrieb am zuletzt editiert von majawe
    [erledigt]
    Moin zusammen,
    kann keine stable updates mehr der Adpater machen mit der Fehlermeldung:
    Jemand eine Idee?
    Raspi 4B 8 GB
    Node.js v18.17.0
    NPM 9.6.7
    • M majawe
      [erledigt]
      Moin zusammen,
      Jemand eine Idee?
      Raspi 4B 8 GB
      Node.js v18.17.0
      NPM 9.6.7
      Thomas BraunT Offline
      @majawe
      iob update
      ion repo list
      sagt?
      Oder gleich die Ausgaben von
      iob diag
        majawe
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Architecture    : armv7l
        Docker          : false
        Virtualization  : none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         13:31:07 up 18:35,  1 user,  load average: 1.20, 1.71, 1.32
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=45.2'C
        volt=0.8500V
        *** Time and Time Zones ***
                       Local time: Mon 2023-07-31 13:31:07 CEST
                   Universal time: Mon 2023-07-31 11:31:07 UTC
                         RTC time: Mon 2023-07-31 11:31:08
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           7.9G        1.6G        4.9G         16M        1.4G        6.0G
        Swap:           99M          0B         99M
        Total:         8.0G        1.6G        5.0G
                 7897 M total memory
                 1624 M used memory
                  766 M active memory
                 2076 M inactive memory
                 4892 M free memory
                  200 M buffer memory
                 1179 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FILESYSTEM ***
        /dev/root      ext4       26G   18G  7.2G  72% /
        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
        tmpfs          tmpfs     3.9G   16K  3.9G   1% /dev/shm
        tmpfs          tmpfs     3.9G   17M  3.9G   1% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/sda1      vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
        [Sun Jul 30 18:55:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:0B:6F:61 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=52e4cf4c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Sun Jul 30 18:55:45 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [Sun Jul 30 18:55:45 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sun Jul 30 18:55:46 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
        Show mounted filesystems (real ones only):
        TARGET        SOURCE    FSTYPE OPTIONS
        /             /dev/sda2 ext4   rw,noatime
        |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        7.5G    /var/
        7.1G    /var/log
        208M    /var/cache
        202M    /var/cache/apt
        143M    /var/cache/apt/archives
        Archived and active journals take up 16.0M in the file system.
        /opt/iobroker/backups:
        61M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        667M    /opt/iobroker/iobroker-data/
        332M    /opt/iobroker/iobroker-data/files
        181M    /opt/iobroker/iobroker-data/backup-objects
        72M     /opt/iobroker/iobroker-data/files/telegram.admin
        53M     /opt/iobroker/iobroker-data/files/javascript.admin
        47M     /opt/iobroker/iobroker-data/objects.jsonl
        36M     /opt/iobroker/iobroker-data/states.jsonl
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        18M     /opt/iobroker/iobroker-data/objects.json.migrated
        18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.0
        /usr/bin/node           v18.17.0
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Installed: 18.17.0-deb-1nodesource1
          Candidate: 18.17.0-deb-1nodesource1
          Version table:
         *** 18.17.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     7.0.3
        npm ERR! code ELSPROBLEMS
        npm ERR! invalid: iobroker.doorbird@0.1.5 /opt/iobroker/node_modules/iobroker.doorbird
        npm ERR! invalid: iobroker.energiefluss@3.6.0 /opt/iobroker/node_modules/iobroker.energiefluss
        npm ERR! invalid: iobroker.fusionsolar@1.0.0 /opt/iobroker/node_modules/iobroker.fusionsolar
        npm ERR! invalid: iobroker.husq-automower@1.1.0 /opt/iobroker/node_modules/iobroker.husq-automower
        npm ERR! invalid: iobroker.life360@0.2.20 /opt/iobroker/node_modules/iobroker.life360
        npm ERR! invalid: iobroker.nuki-extended@2.6.5 /opt/iobroker/node_modules/iobroker.nuki-extended
        npm ERR! invalid: iobroker.switchbot-ble@0.2.2 /opt/iobroker/node_modules/iobroker.switchbot-ble
        npm ERR! invalid: iobroker.tibber@0.3.1-beta /opt/iobroker/node_modules/iobroker.tibber
        npm ERR! invalid: iobroker.tibberconnect@0.0.9 /opt/iobroker/node_modules/iobroker.tibberconnect
        npm ERR! invalid: iobroker.vis-materialdesign@0.5.94 /opt/iobroker/node_modules/iobroker.vis-materialdesign
        npm ERR! invalid: iobroker.vuplus@0.1.1 /opt/iobroker/node_modules/iobroker.vuplus
        npm ERR! invalid: iobroker.wled@0.6.8 /opt/iobroker/node_modules/iobroker.wled
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-07-31T11_31_31_949Z-debug-0.log
        Adapters from github:   12
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioBroker-RasPi4                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : ioBroker-RasPi4                          -  enabled
          system.adapter.awattar.0                : awattar               : ioBroker-RasPi4                          - disabled
          system.adapter.backitup.0               : backitup              : ioBroker-RasPi4                          - disabled
        + system.adapter.cloud.0                  : cloud                 : ioBroker-RasPi4                          -  enabled
          system.adapter.daswetter.0              : daswetter             : ioBroker-RasPi4                          -  enabled
        + system.adapter.discovery.0              : discovery             : ioBroker-RasPi4                          -  enabled
        + system.adapter.doorbird.0               : doorbird              : ioBroker-RasPi4                          -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : ioBroker-RasPi4                          -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker-RasPi4                          -  enabled
          system.adapter.fusionsolar.0            : fusionsolar           : ioBroker-RasPi4                          - disabled
        + system.adapter.hm-rega.0                : hm-rega               : ioBroker-RasPi4                          -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : ioBroker-RasPi4                          -  enabled
        + system.adapter.info.0                   : info                  : ioBroker-RasPi4                          -  enabled
        + system.adapter.iot.0                    : iot                   : ioBroker-RasPi4                          -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker-RasPi4                          -  enabled
        + system.adapter.linux-control.0          : linux-control         : ioBroker-RasPi4                          -  enabled
          system.adapter.midea.0                  : midea                 : ioBroker-RasPi4                          - disabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker-RasPi4                          -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.net-tools.0              : net-tools             : ioBroker-RasPi4                          -  enabled
        + system.adapter.node-red.0               : node-red              : ioBroker-RasPi4                          -  enabled, port: 1880, bind: 0.0.0.0
          system.adapter.nuki-extended.0          : nuki-extended         : ioBroker-RasPi4                          - disabled
          system.adapter.oilfox.0                 : oilfox                : ioBroker-RasPi4                          - disabled
          system.adapter.onvif.0                  : onvif                 : ioBroker-RasPi4                          - disabled
        + system.adapter.parser.0                 : parser                : ioBroker-RasPi4                          -  enabled
        + system.adapter.ph803w.0                 : ph803w                : ioBroker-RasPi4                          -  enabled
        + system.adapter.philips-tv.0             : philips-tv            : ioBroker-RasPi4                          -  enabled
        + system.adapter.pushover.0               : pushover              : ioBroker-RasPi4                          -  enabled
        + system.adapter.shelly.0                 : shelly                : ioBroker-RasPi4                          -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : ioBroker-RasPi4                          -  enabled, port: 8087, bind: 192.168.0.2, run as: admin
        + system.adapter.smartgarden.0            : smartgarden           : ioBroker-RasPi4                          -  enabled
        + system.adapter.sonoff.0                 : sonoff                : ioBroker-RasPi4                          -  enabled, port: 1885, bind: 0.0.0.0
          system.adapter.sonos.0                  : sonos                 : ioBroker-RasPi4                          - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker-RasPi4                          -  enabled
        + system.adapter.telegram.0               : telegram              : ioBroker-RasPi4                          -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : ioBroker-RasPi4                          -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.tesla-motors.0           : tesla-motors          : ioBroker-RasPi4                          - disabled
        + system.adapter.text2command.0           : text2command          : ioBroker-RasPi4                          -  enabled
          system.adapter.tibberconnect.0          : tibberconnect         : ioBroker-RasPi4                          - disabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker-RasPi4                          -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-RasPi4                          - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-RasPi4                          - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-RasPi4                          -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-RasPi4                          -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-RasPi4                          - disabled
          system.adapter.vis.0                    : vis                   : ioBroker-RasPi4                          -  enabled
        + system.adapter.web.0                    : web                   : ioBroker-RasPi4                          -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
        + system.adapter.web.1                    : web                   : ioBroker-RasPi4                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : ioBroker-RasPi4                          -  enabled
        + system.adapter.zigbee.0                 : zigbee                : ioBroker-RasPi4                          -  enabled, port: tcp://192.168.0.55:20108
        + instance is alive
        ioBroker-Repositories
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "awattar"      : 1.0.6    , installed 1.0.6
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
        Adapter    "bmw"          : 2.5.7    , installed 2.5.7
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "doorbird"     : 1.0.5    , installed 0.1.5  [Updatable]
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
        Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "linux-control": 1.1.3    , installed 1.1.3
        Adapter    "micronova"    : 0.0.2    , installed 0.0.2
        Adapter    "midea"        : 0.0.7    , installed 0.0.7
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
        Adapter    "oilfox"       : 4.1.2    , installed 4.1.2
        Adapter    "onvif"        : 1.0.5    , installed 1.0.5
        Adapter    "parser"       : 1.3.2    , installed 1.3.2
        Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
        Adapter    "socketio"     : 4.2.0    , installed 4.2.0
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "sonos"        : 2.3.1    , installed 2.2.3  [Updatable]
        Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
        Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
        Adapter    "text2command" : 3.0.2    , installed 2.2.2  [Updatable]
        Adapter    "trashschedule": 2.2.0    , installed 2.0.3  [Updatable]
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "web"          : 4.3.0    , installed 4.3.0
        Adapter    "wled"         : 0.6.7    , installed 0.6.8
        Adapter    "ws"           : 1.3.0    , installed 1.3.0
        Adapter    "zigbee"       : 1.8.16   , installed 1.8.10 [Updatable]
        Objects and States
        Objects:        23170
        States:         20165
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15251      317/deCONZ
        tcp        0      0 192.168.0.2:42001       0.0.0.0:*               LISTEN      1001       4178608    3065/io.hm-rpc.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18904      669/sshd
        tcp        0      0 192.168.0.2:8087        0.0.0.0:*               LISTEN      1001       4184247    4628/io.simple-api.
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       4179452    3272/node-red
        tcp        0      0 192.168.0.2:42010       0.0.0.0:*               LISTEN      1001       4177614    3191/io.hm-rpc.1
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17441      317/deCONZ
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       4183132    3751/io.sonoff.0
        tcp        0      0 192.168.0.2:8701        0.0.0.0:*               LISTEN      1001       4177646    3251/io.hm-rpc.2
        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          18445      372/python
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       4181082    3467/io.mqtt.0
        tcp        0      0 192.168.0.2:8100        0.0.0.0:*               LISTEN      1001       4188738    6086/io.doorbird.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4176161    2091/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4174677    2091/iobroker.js-co
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16235      674/redis-server 12
        tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          18039      652/node
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4175397    2270/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4190366    5582/io.web.1
        tcp6       0      0 :::8083                 :::*                    LISTEN      1001       4186420    5203/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          18906      669/sshd
        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16236      674/redis-server 12
        tcp6       0      0 :::3500                 :::*                    LISTEN      0          18043      652/node
        udp        0      0 0.0.0.0:56228           0.0.0.0:*                           1001       4204239    3560/io.shelly.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       4179757    3560/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18451      651/dhcpcd
        udp        0      0 0.0.0.0:1250            0.0.0.0:*                           0          19862      653/openvpn
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4185440    5327/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17054      319/avahi-daemon: r
        udp        0      0 0.0.0.0:57661           0.0.0.0:*                           108        17056      319/avahi-daemon: r
        udp        0      0 0.0.0.0:43863           0.0.0.0:*                           1001       4183337    3796/io.ph803w.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17444      317/deCONZ
        udp6       0      0 :::39863                :::*                                108        17057      319/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          16320      651/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        17055      319/avahi-daemon: r
        2023-07-31 13:31:37.806  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
        2023-07-31 13:31:39.531  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
        2023-07-31 13:31:42.577  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
        2023-07-31 13:31:44.210  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
        2023-07-31 13:31:47.403  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.PV1_Voltage" has to be stringified but received type "number"
        2023-07-31 13:31:47.908  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.PV1_Current" has to be stringified but received type "number"
        2023-07-31 13:31:49.367  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.PV2_Voltage" has to be stringified but received type "number"
        2023-07-31 13:31:49.982  - info: linux-control.0 (5420) successful received data from MMM (192.168.0.247:22)
        2023-07-31 13:31:50.388  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.PV2_Current" has to be stringified but received type "number"
        2023-07-31 13:31:53.451  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
        2023-07-31 13:31:55.632  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
        2023-07-31 13:31:57.956  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
        2023-07-31 13:31:59.856  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
        2023-07-31 13:32:02.886  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
        2023-07-31 13:32:04.068  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
        2023-07-31 13:32:07.493  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
        2023-07-31 13:32:08.941  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
        2023-07-31 13:32:12.509  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
        2023-07-31 13:32:14.792  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
        2023-07-31 13:32:17.903  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.PV1_Voltage" has to be stringified but received type "number"
        2023-07-31 13:32:18.482  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.PV1_Current" has to be stringified but received type "number"
        2023-07-31 13:32:18.951  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.PV2_Voltage" has to be stringified but received type "number"
        2023-07-31 13:32:19.890  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.PV2_Current" has to be stringified but received type "number"
        2023-07-31 13:32:26.119  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
        2023-07-31 13:32:27.788  - info: node-red.0 (3272) State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
        • M majawe
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        10
          Codename:       buster
          VERSION_ID="10"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=45.2'C
          volt=0.8500V
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M          0B         99M
                   7897 M total memory
                   1624 M used memory
                    766 M active memory
                   4892 M free memory
                    200 M buffer memory
                   1179 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          7.5G    /var/
          7.1G    /var/log
          208M    /var/cache
          202M    /var/cache/apt
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        23170
          States:         20165
          Pending Updates: 0
          @majawe sagte in npm ERR! code ETARGET:
          buster
          Aktualisieren!
          iob upgrade doorbird@0.1.5 --debug
          iob upgrade all --debug
