  4. Iobroker - Update / Adapter installieren (Fertig Images)
    5.7k
2 Beiträge 2 Kommentatoren 1.4k Aufrufe
  • N Offline
    N Offline
    noxx
    Hallo
    ich nutze gerade das fertig Image von iOBroker (14.05)
    Wollte gerade einen Adapter installieren, bekomme aber einen Fehler.
    Images und ioBroker habe ich über die Konsole inzwischen upgedatet, Fehler bleibt.
    $ ./iobroker add rflink
    host.ioBroker-RasPi install adapter rflink
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.rflink"
    node-pre-gyp
     ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.3 (node-v48 ABI) (falling back to source compile with node-gyp)
    gyp
    WARN
    EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.3"
    gyp
    WARN
    EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/.node-gyp"
    make: *** No rule to make target '../.node-gyp/6.10.3/include/node/common.gypi', needed by 'Makefile'.  Schluss.
    gyp
    ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
    gyp
     ERR!
     System Linux 4.9.24-v7+gyp ERR!
    command
     "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport
    gyp ERR! node -v v6.10.3
    gyp ERR! node-gyp -v v3.6.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp
    ERR!
     stack Error: Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release' (1)
    node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp
    ERR!
    stack     at emitTwo (events.js:106:13)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    node-pre-gyp
    ERR! stack     at maybeClose (internal/child_process.js:886:16)node-pre-gyp
     ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
    node-pre-gyp ERR! System Linux 4.9.24-v7+node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport
    node-pre-gyp ERR! node -v v6.10.3
    node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    node-pre-gyp ERR! not ok</anonymous>
    • kmxakK Offline
      kmxakK Offline
      kmxak
      schau mal hier:
      http://forum.iobroker.net/viewtopic.php?t=6572
      Gruß Alex
