  4. Solved: BackITUp: MySQL DB Sicherung schlägt fehl
    5.4k
53 Beiträge 5 Kommentatoren 7.3k Aufrufe 3 Beobachtet
    @azrael42 sagte in BackITUp: MySQL DB Sicherung schlägt fehl:
    iobroker@RKO-Central:~$ mount | grep iobroker
    Moin,
    einfach nur den befehl, ohne etwas zu filtern/grepen
    mount
    VG
    Bernd
    Azrael42A Offline
    Azrael42A Offline
    Azrael42
    #41
    @dp20eic
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
    udev on /dev type devtmpfs (rw,nosuid,relatime,size=1945708k,nr_inodes=486427,mode=755)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=392408k,mode=755)
    /dev/sda1 on / type ext4 (rw,relatime,errors=remount-ro)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
    pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
    none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13452)
    mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
    hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
    debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
    tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
    configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=392404k,nr_inodes=98101,mode=700,uid=1000,gid=1000)
    KNX - Modbus - EBus - Smartmeter
    PV Überschuss Steuerung für Wallbox und WP mit Node-Red, SQL Programmierung, eigens entwickelte KNX Komponenten
    • Azrael42A Azrael42
      @dp20eic said in BackITUp: MySQL DB Sicherung schlägt fehl:
      dann musst Du das auf die mariadb-dump machen
      iobroker@RKO-Central:~$ ls -la /usr/bin/mariadb-dump
      -rwxr-xr-x 1 root root 4000928 Apr 15 21:50 /usr/bin/mariadb-dump
      Wenn ich das richtig verstehe, darf der User "iobroker" ausführen.
      aber das hast Du gemountet oder machst Du erst ein Lokales-Backup und dann verschiebst Du es nach OneDrive
      Ja, es wird erst ein lokales Backup erstellt, welches dann von BackITUp nach OneDrive KOPIERT wird.
      "mount" gibt weder für das Ziel noch für den Dateipfad von Mariadb-dump etwas an.
      iobroker@RKO-Central:~$ mount | grep usr
      #42
      Moin,
      ja, das sieht normal aus.
      Kannst Du trotz allem noch mal den Einstellungsdialog zeigen
      Ich hab das nur mal so installiert, ich nutze den BackItUp Adaper nicht.
      Vielleicht auch mal den Pfad leer lassen.
      Mir fällt ansonsten heute nichts mehr dazu ein.
      VG
      Bernd
      P.S.: Auf Thai ist die Zahl 5 = ha somit 5555
      Azrael42A 1 Antwort Letzte Antwort
        Moin,
        VG
        Bernd
        Azrael42A Offline
        Azrael42A Offline
        Azrael42
        schrieb am zuletzt editiert von Azrael42
        #43
        @dp20eic
        Jo, ich gebe für heute auch auf. Danke noch an alle, die bis hier mitgedacht haben!
        Ansonsten weiß ich schon, wo mein Handtuch ist;)
        Thomas BraunT ? 2 Antworten Letzte Antwort
          @dp20eic
          #44
          @azrael42
          Gib mal bei full path das Linkziel ein:
            @azrael42
            Azrael42A Offline
            Azrael42A Offline
            Azrael42
            #45
            @thomas-braun said in BackITUp: MySQL DB Sicherung schlägt fehl:
            Bleibt leider exakt gleich. Geht nicht. :(
              @dp20eic
              #46
              Moin,
              und die Sonnenbrille nicht vergessen :)
              Wenn Du als iobroker das ausführst
              iobroker@RKO-Central:~$ mariadb-dump -u iobroker -p  iobroker > /opt/iobroker/backups/mysql_test.sql
              Wenn Du das Passwort gleich mitgeben willst, dann -ppasswort ohne Leerzeichen.
              Dann kannst Du auch noch mal versuchen, ob Du als iobroker etwas im Verzeichnis anlegen kannst.
              touch /opt/iobroker/backups/test.txt
              VG
              Bernd
              HomoranH Azrael42A 2 Antworten Letzte Antwort
                Moin,
                VG
                Bernd
                #47
                @dp20eic ich bin als Linux-Laie ein wenig verwirrt.
                @dp20eic sagte in BackITUp: MySQL DB Sicherung schlägt fehl:
                iobroker@RKO-Central:.....
                passt doch nicht zu
                @thomas-braun sagte in BackITUp: MySQL DB Sicherung schlägt fehl:
                Der iobroker bekommt keine login shell.
                da müsste doch
                sudo -H -u iobroker COMMAND
                verwendet werden.
                oder/und der iobroker bei @Azrael42 ist ein selbst angelegter user und nicht der Systemuser
                ? 1 Antwort Letzte Antwort
                  passt doch nicht zu
                  da müsste doch
                  verwendet werden.
                  #48
                  @homoran sagte in BackITUp: MySQL DB Sicherung schlägt fehl:
                  passt doch nicht zu
                  Moin,
                  ja, da hast Du recht, aber ich hatte ja in einem Post auch gezeigt, wie man trotzdem zum User wird.
                  Ich finde die Art und Weise, wie ioBroker das aktuell löst sehr gut und ärger mich, dass ich diesen Ansatz hier geschrieben habe.
                  Du hast natürlich recht, nach ioBroker Paradigma muss, das noch davor, wenn TE als Richard angemeldet ist
                  sudo -H -u iobroker mariadb-dump ...
                  Wenn der TE aber wie von mir beschrieben als iobroker angemeldet ist, dann sollte es auch ohne sudo usw. gehen, oder auch nicht, wenn es immer noch klemmt, warum auch immer.
                  Ich werde, wenn mir Frauchen heute etwas Zeit gibt, mal alles nötige bei mir installieren und auch testen.
                  Denn ich verstehe es nicht, es sollte klappen, es seiden der TE hat bei seinen arbeiten am 25.5. irgendetwas verstellt, das er uns noch nicht gesagt hat.
                  VG
                  Bernd
                    passt doch nicht zu
                    Moin,
                    VG
                    Bernd
                    #49
                    um Fehler dabei auszuschließen sollte IMHO zuerst immer der "offizielle" Weg beschritten werden.
                    Leider gibt es sehr viele user, die bei der Installation des OS "ihren" User ebenfalls iobroker nennen.
                      #50
                      Moin,
                      ja, stimmt, das ist verwirrend.
                      Was noch fehlt, vom TE, sind die Informationen zum User und den Rechten, die dieser in der Datenbank hat.
                      Mich verwirrt auch, dass obwohl alles auf dem gleichen Rechner läuft, der Rechnername RKO-Central eingetragen ist, sollte da nicht ein localhost oder 127.0.0.1 ausreichen?
                      Wenn ich das für mich umsetzen würde, dann würde ich das in etwa so machen, dass ich einen speziellen User nur für die Backups in der Datenbank anlegen würde und nicht den gleichen nutze wie der, der die Daten schreibt.
                      mysql/mariadb Backup Benutzer erstellen
                      Mein Gedankengang
                      Um Backups der mysql/mariadb Datenbanken zu erstellen braucht es einen Benutzer, der auf alle Datenbanken zugreifen kann.
                      Die Backups mit dem root User zu machen ist einfach, aber keine Gute Idee, da dieser User auch alles kaputt machen kann, zu viele Rechte ;)
                      Voraussetzung
                      Welche Berechtigungen braucht es mindestens, um dieser Aufgabe gerecht zu werden?
                      Ein mysql/mariadb Backup User muss lesenden Zugriff auf alle Datenbanken haben, er darf auf keinen Fall Schreibzugriff auf die Daten haben, denn sonst könnte jemand, der den Account des Backupbenutzers übernommen hat, nicht nur die Backups, sondern auch die Daten auf der Datenbank löschen!
                      Das will man natürlich nicht :)
                      Umsetzung
                      Ein minimales Set von Berechtigungen, die problemlos mit mysqldump/mariadb-dump funktioniert, ist:
                      GRANT SELECT, RELOAD, LOCK TABLES, EVENT ON *.* TO 'backup'@'%' IDENTIFIED BY PASSWORD 'p455w0rd'
                      Dies erstellt den Benutzer backup mit dem Passwort: p455w0rd.
                      Der Benutzer kann sich von überall aus mit der Datenbank verbinden (%) und alle Daten lesen, jedoch keine Daten schreiben/löschen.
                      Wenn man die Backups nur vom Backup Server aus macht, könnte man anstelle von „%“ auch „localhost“, oder „127.0.0.1“ nehmen, um den Benutzer weiter einzuschränken.
                      VG
                      Bernd
                      Edit
                      1. Ich habe mir in meiner iobroker LXC-Testinstanz, mariadb, mariadb-client installiert, da ich kein KleinWeich Account habe, habe ich anstatt OneDrive halt mal Google-Drive genutzt.
                      2. Dann habe User angelegt
                        • sql_iobroker
                          MariaDB [(none)]> CREATE USER 'sql_iobroker'@'localhost' IDENTIFIED BY 'sql-iobroker';
                          MariaDB [(none)]> GRANT ALL PRIVILEGES ON iobroker.* TO 'sql_iobroker'@'localhost';
                        • backup
                          MariaDB [(none)]> CREATE USER 'backup'@'localhost' IDENTIFIED BY 'dasgehtdichnichtsan';
                          MariaDB [(none)]> GRANT SELECT, RELOAD, LOCK TABLES, EVENT ON *.* TO 'backup'@'localhost';
                      3. Die ioBroker - Adapter installiert
                        • SQL und Backitup
                      4. Die Adapert konfiguriert
                        • SQL - Adapter
                        • Backitup - Adapter
                      5. Check alle Adapter sind grün
                      6. Trommelwirbel, Backup angestoßen
                        Started iobroker ...
                        [DEBUG] [iobroker] - host.arch-iob 6676 states saved
                        [DEBUG] [iobroker] - host.arch-iob 7596 objects saved
                        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_06_11-13_56_22_backupiobroker.tar.gz
                        [DEBUG] [iobroker] - done
                        [DEBUG] [mysql] - MySql-Backup started ...
                        [DEBUG] [mysql] - MySql File deleted!
                        [DEBUG] [mysql] - MySql-Backup for is finish
                        [DEBUG] [mysql] - done
                        [DEBUG] [googledrive] - Google Drive: Copy iobroker_2023_06_11-13_56_22_backupiobroker.tar.gz...
                        [DEBUG] [googledrive] - Google Drive: Copy mysql_2023_06_11-13_56_27_backupiobroker.tar.gz...
                        [DEBUG] [googledrive] - done
                        [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
                        [DEBUG] [clean] - done
                        [DEBUG] [historyHTML] - new history html values created
                        [DEBUG] [historyHTML] - done
                        [DEBUG] [historyJSON] - new history json values created
                        [DEBUG] [historyJSON] - done
                        [EXIT] 0
                      So, bei mir gibt es keine Probleme, der einzige Unterschied, ist, dass meine Testinstallation nicht auf Debian, sondern unter Arch Linux läuft und ich aktuell die z-shell (zsh) anstelle von bash nutze.
                      Ich habe auch mal einige Fehler gemacht, um zu schauen was so im journal auftaucht
                       14:01:53  dp20eic@arch-iob  ~  ⬡ v18.15.0  20s 
                      $ journalctl -u mariadb
                      Jun 11 12:57:15 arch-iob systemd[1]: Starting MariaDB 10.11.3 database server...
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] Starting MariaDB 10.11.3-MariaDB source revision 0bb31039f54bd6a0dc8f0fc7d40e6b58a51998b0 as process 21738
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: The first data file './ibdata1' did not exist. A new tablespace will be created!
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Compressed tables use zlib 1.2.13
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Number of transaction pools: 1
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Using generic crc32 instructions
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Using liburing
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000MiB, chunk size = 2.000MiB
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Completed initialization of buffer pool
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Setting file './ibdata1' size to 12.000MiB. Physically writing the file full; Please wait ...
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: File './ibdata1' size is now 12.000MiB.
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Buffered log writes (block size=512 bytes)
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Doublewrite buffer not found: creating new
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: 128 rollback segments are active.
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: Setting file './ibtmp1' size to 12.000MiB. Physically writing the file full; Please wait ...
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: File './ibtmp1' size is now 12.000MiB.
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] InnoDB: log sequence number 0; transaction id 3
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [ERROR] Could not open mysql.plugin table: "Table 'mysql.plugin' doesn't exist". Some plugins may be not loaded
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [ERROR] Can't open and lock privilege tables: Table 'mysql.servers' doesn't exist
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] Server socket created on IP: '0.0.0.0'.
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [Note] Server socket created on IP: '::'.
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.db' doesn't exist
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: 2023-06-11 12:57:15 0 [ERROR] Aborting
                      Jun 11 12:57:15 arch-iob mariadbd[21738]: Warning: Memory not freed: 280
                      Jun 11 12:57:15 arch-iob systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
                      Jun 11 12:57:15 arch-iob systemd[1]: mariadb.service: Failed with result 'exit-code'.
                      Jun 11 12:57:15 arch-iob systemd[1]: Failed to start MariaDB 10.11.3 database server.
                      Jun 11 13:00:02 arch-iob systemd[1]: Starting MariaDB 10.11.3 database server...
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] Starting MariaDB 10.11.3-MariaDB source revision 0bb31039f54bd6a0dc8f0fc7d40e6b58a51998b0 as process 21927
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Compressed tables use zlib 1.2.13
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Number of transaction pools: 1
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Using generic crc32 instructions
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Using liburing
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000MiB, chunk size = 2.000MiB
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Completed initialization of buffer pool
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Buffered log writes (block size=512 bytes)
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: 128 rollback segments are active.
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Setting file './ibtmp1' size to 12.000MiB. Physically writing the file full; Please wait ...
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: File './ibtmp1' size is now 12.000MiB.
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: log sequence number 45468; transaction id 15
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] InnoDB: Buffer pool(s) load completed at 230611 13:00:02
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] Server socket created on IP: '0.0.0.0'.
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] Server socket created on IP: '::'.
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: 2023-06-11 13:00:02 0 [Note] /usr/bin/mariadbd: ready for connections.
                      Jun 11 13:00:02 arch-iob mariadbd[21927]: Version: '10.11.3-MariaDB'  socket: '/run/mysqld/mysqld.sock'  port: 3306  Arch Linux
                      Jun 11 13:00:02 arch-iob systemd[1]: Started MariaDB 10.11.3 database server.
                      Jun 11 13:00:25 arch-iob mariadbd[21927]: 2023-06-11 13:00:25 3 [Warning] Access denied for user 'root'@'localhost'
                      Jun 11 13:07:36 arch-iob mariadbd[21927]: 2023-06-11 13:07:36 5 [Warning] Access denied for user 'root'@'localhost'
                      Jun 11 13:07:55 arch-iob mariadbd[21927]: 2023-06-11 13:07:55 6 [Warning] Access denied for user 'root'@'localhost'
                      Jun 11 13:07:59 arch-iob mariadbd[21927]: 2023-06-11 13:07:59 7 [Warning] Access denied for user 'root'@'localhost'
                      Jun 11 13:08:00 arch-iob mariadbd[21927]: 2023-06-11 13:08:00 8 [Warning] Access denied for user 'root'@'localhost'
                      Jun 11 13:12:21 arch-iob mariadbd[21927]: 2023-06-11 13:12:21 15 [Warning] Access denied for user 'root'@'localhost'
                      Jun 11 13:19:13 arch-iob mariadbd[21927]: 2023-06-11 13:19:13 17 [Warning] Access denied for user 'sql_iobroker'@'localhost' (using password: YES)
                      Hier auch noch mal die Rechte in der Datenbank
                      VG und schönen Sonntag
                      Bernd
                        Moin,
                        VG
                        Bernd
                        Azrael42A Offline
                        Azrael42A Offline
                        Azrael42
                        #51
                        Schon wieder aktiv? Danke!
                        Verlangt nach dem SQL User Passwort und spring dann sofort wieder in die Shell. Habe es auch mit der "Offiziellen" Version ausgeführt, also "sudo -H -u ..."
                        Jip, geht.
                        -rw-rw-r--+ 1 iobroker iobroker        0 Jun 11 13:20 mysql_test_2.sql
                        -rw-rw-r--+ 1 iobroker iobroker        0 Jun 11 13:17 mysql_test.sql
                        -rw-rw-r--+ 1 iobroker iobroker        0 Jun 11 13:17 test.txt
                        Das tut es leider nicht. Nur leere Dateien.
                        Mit dem sudo ohne dedizierten User davor, funktioniert es.
                        sudo mariadb-dump -u iobroker -p iobroker > /opt/iobroker/backups/mysql_test_3.sql
                        -rw-rw-r--+ 1 richard  richard  267923908 Jun 11 13:30 mysql_test_3.sql
                        Deshalb wäre ich jetzt mal so kühn zu behaupten, das die Userrechte in der MariaDB passen.
                        Habe aber dennoch mal einen Backupuser angelegt, der das gleiche Verhalten zeigt.
                          Moin,
                          Mein Gedankengang
                          Voraussetzung
                          Umsetzung
                          VG
                          Bernd
                          Edit
                            • sql_iobroker
                            • backup
                            • SQL und Backitup
                            • SQL - Adapter
                            [EXIT] 0
                          Bernd
                          Azrael42A Offline
                          Azrael42A Offline
                          Azrael42
                          #52
                          Danke für die Mühe und den Test.
                          So war es ja ebenfalls, bis ich da was kaputt gemacht habe.
                          Ich kapituliere jetzt aber und nehme ein händisches Backup zu einem Restore heran. Auf einem neu installierten System wird es wieder funktionieren.
                            Moin,
                            Mein Gedankengang
                            Voraussetzung
                            Umsetzung
                            VG
                            Bernd
                            Edit
                              • sql_iobroker
                              • backup
                              • SQL und Backitup
                              • SQL - Adapter
                              [EXIT] 0
                            Bernd
                            Azrael42A Offline
                            Azrael42A Offline
                            Azrael42
                            #53
                            @dp20eic
                            Hat mir natürlich keine Ruhe gelassen...
                            Ich bin also nochmal zurück zum Anfang. Habe die "mysqldump" Befehle zerlegt und alle Kombinationen getestet.
                            Dann wollte ich über die Konsole auf den DB Server, um ein paar weitere Tests zu machen.
                            Dabei bekam ich dann den ersten aussagekräftigen Fehler:
                            richard@RKO-Central:/var/log$ mysql -u iobroker -p iobroker
                            mysql: unknown variable 'log_error=/var/log/mysqld.log'
                            An die Variable erinnerte ich mich, die hatte ich nach dem Verbindungsabbruch zum SQL Server gesetzt. Das Log war damals wie heute fast leer. Gleicher Befehl mit "sudo" vorweg meldet sich an die DB an.
                            Also das ganze wieder zurück gesetzt (Variable entfernt) und den Server neu gestartet.
                            Es funktioniert wieder!
                            Was soll ich sagen? Auf jeden fall weiß ich jetzt, was ich am 25.05. verändert habe. Asche auf mein Haupt!
                            Danke nochmal!
